Managed network and dnsmasq syslog entries
Dear community members of this awesome piece of software that is LXD/LXC,
I am using network managed bridge interfaces, projects from LXD to manage LXC containers some of which are set with static IP, on Debian.
I noticed a lot of dnsmasq-dhcp log entries (using rsyslog). For instance:
May 23 21:38:06 razuberi dnsmasq-dhcp[2842]: Ignoring domain tools for DHCP host name zigbee2mqtt
May 23 21:43:37 razuberi dnsmasq-dhcp[2842]: Ignoring domain tools for DHCP host name nodered
May 23 21:59:50 razuberi dnsmasq-dhcp[2842]: Ignoring domain tools for DHCP host name homeassistant
May 23 21:59:58 razuberi dnsmasq-dhcp[2842]: Ignoring domain tools for DHCP host name adguardhome
In the above, tools is the name of a project while zigbee2mqtt, nodered and so on are names of active LXC instances.
Question 1: are these log entries expected?
Question 2: shouldn’t they be silenced given the option --quiet-dhcp is set on the dnsmasq call from user lxd for LXD to manage DHCP?
Question 3: I though of force-silence at the rsyslog level, but beforehand I wanted to expose this and ask the above questions.
All the best.
According to https://docs.pi-hole.net/ftldns/dnsmasq_warn/ this means:
A DHCP client is not allowed to claim name HOSTNAME in the current DHCP configuration.
And looking at https://discourse.pi-hole.net/t/ignoring-domain-config-domain-for-dhcp-host-name-hostname/52027/8
It seems that the DHCP client those instances are using is trying to claim a domain outside of the managed network’s domain.
Thank you for your input.
A stock Debian bullseye instance uses systemd-resolved as DHCP client.
How should it be tuned for the instance not to “claim” its hostname on the DNS zone of the host?
Conversely, is there a way to tune it so as to resolve the instance hostname from the host (for example with instance.project_name from the host similarly as instance.lxd between instances)?
