This was the output of
zfs list -t all
zpooldata3/lxd 117G 573G 96K none
zpooldata3/lxd/containers 116G 573G 96K none
zpooldata3/lxd/containers/bionic-selenium 456M 573G 765M /var/lib/lxd/storage-pools/default/containers/bionic-selenium
zpooldata3/lxd/containers/xenial-b 2.14G 573G 2.14G /var/lib/lxd/storage-pools/default/containers/xenial-b
zpooldata3/lxd/containers/trusty-android 9.86G 573G 9.86G /var/lib/lxd/storage-pools/default/containers/trusty-android
How can I point my lxd to use the dataset zpooldata3/lxd for all the storage? It happend as I had to rsync to rollback my root and I missed to backup my /var/lib/lxd…
Any tips…
lxc --version
2.21
This is the output of df
udev 7.8G 0 7.8G 0% /dev
tmpfs 1.6G 9.5M 1.6G 1% /run
/dev/sdc7 54G 20G 32G 38% /
tmpfs 7.9G 8.5M 7.9G 1% /dev/shm
tmpfs 5.0M 8.0K 5.0M 1% /run/lock
tmpfs 7.9G 0 7.9G 0% /sys/fs/cgroup
/dev/sdc8 62G 52M 59G 1% /tmp
/dev/sdc5 708G 401G 272G 60% /localbackup
zpooldata3/data3 1.2T 607G 574G 52% /data3
zpooldata3/home 834G 260G 574G 32% /home
zpooldata3 574G 128K 574G 1% /zpooldata3
cgmfs 100K 0 100K 0% /run/cgmanager/fs
tmpfs 1.6G 28K 1.6G 1% /run/user/1000
tmpfs 100K 0 100K 0% /var/lib/lxd/shmounts
tmpfs 100K 0 100K 0% /var/lib/lxd/devlxd
stgraber
(Stéphane Graber)
November 5, 2018, 5:57pm
4
Ok, make sure your system has a working LXD by running lxc info.
If that works, then try:
zfs mount zpooldata3/lxd/containers/bionic-selenium
zfs mount zpooldata3/lxd/containers/xenial-b
zfs mount zpooldata3/lxd/containers/trusty-android
lxd import bionic-selenium
lxd import xenial-b
lxd import trusty-android
I meant lxc info works
certificate_fingerprint: 323859f65465656566c67be46a6332c10d867c
driver: lxc
driver_version: 2.0.8
kernel: Linux
kernel_architecture: x86_64
kernel_version: 4.13.0-43-generic
server: lxd
server_pid: 5762
server_version: "2.21"
storage: ""
Thanks for the quick reply
ZFS mount command was success
df shows proper mount
zpooldata3/lxd/containers/bionic-selenium 602012672 783232 601229440 1% /var/lib/lxd/storage-pools/default/containers/bionic-selenium
error: No root device could be found.
UPDATE: some how USED BY is 0
lxc storage list
| default | | zfs | zpooldata3/lxd | 0 |
Any other ideas. Thanks!
stgraber
(Stéphane Graber)
November 5, 2018, 6:15pm
6
Ah, yeah, it’s a bug we fixed recently.
Try doing:
lxc profile device add default root disk path=/ pool=default
Then run the lxd import bionic-selenium again.
stgraber
(Stéphane Graber)
7
If that works, the others should import without trouble.
Note that you’ll still need to manually recreate any network you had on the system as those aren’t part of the emergency backup.
If using the default setup, this should do the trick:
lxc network create lxdbr0
lxc profile device add default eth0 nic nictype=bridged parent=lxdbr0 name=eth0
OK I wrote too quickly. It did not recover the issue.
lxc list
| bionic-selenium | STOPPED | | | PERSISTENT | 0 |
lxc profile edit default
config: {}
nictype: bridged
parent: lxdbr0
pool: default
- /1.0/containers/bionic-selenium
- /1.0/containers/trusty-android
Remote: unix://
Created: 2018/11/06 09:35 UTC
Status: Stopped
Type: persistent
Profiles: default
lxc start bionic-selenium
Log:
lxc 20181106093601.543 ERROR lxc_conf - conf.c:mount_rootfs:798 - Permission denied - Failed to get real path for "/var/lib/lxd/containers/bionic-selenium/rootfs".
lxc 20181106093601.543 ERROR lxc_conf - conf.c:setup_rootfs:1220 - Failed to mount rootfs "/var/lib/lxd/containers/bionic-selenium/rootfs" onto "/usr/lib/x86_64-linux-gnu/lxc" with options "(null)".
lxc 20181106093601.543 ERROR lxc_conf - conf.c:do_rootfs_setup:3899 - failed to setup rootfs for 'bionic-selenium'
lxc 20181106093601.543 ERROR lxc_conf - conf.c:lxc_setup:3981 - Error setting up rootfs mount after spawn
lxc 20181106093601.543 ERROR lxc_start - start.c:do_start:811 - Failed to setup container "bionic-selenium".
lxc 20181106093601.543 ERROR lxc_sync - sync.c:__sync_wait:57 - An error occurred in another process (expected sequence number 3)
lxc 20181106093601.586 ERROR lxc_start - start.c:__lxc_start:1358 - Failed to spawn container "bionic-selenium".
lxc 20181106093602.185 ERROR lxc_conf - conf.c:run_buffer:416 - Script exited with status 1.
lxc 20181106093602.185 ERROR lxc_start - start.c:lxc_fini:546 - Failed to run lxc.hook.post-stop for container "bionic-selenium".
lxc 20181106093602.185 WARN lxc_commands - commands.c:lxc_cmd_rsp_recv:177 - Command get_cgroup failed to receive response: Connection reset by peer.
Even a new container launch shows same issue.
Any other suggestions.
stgraber
(Stéphane Graber)
November 7, 2018, 4:40am
9
That suggests you have bad permissions preventing unprivileged containers from working on your system, please show:
sudo stat -c "%n %a" / /var /var/lib /var/lib/lxd /var/lib/lxd/containers /var/lib/lxd/storage-pools /var/lib/lxd/storage-pools/default /var/lib/lxd/storage-pools/default/containers
Normal output should be something like:
/ 755
/var 755
/var/lib 755
/var/lib/lxd 711
/var/lib/lxd/containers 711
/var/lib/lxd/storage-pools 711
/var/lib/lxd/storage-pools/default 711
/var/lib/lxd/storage-pools/default/containers 711
thanks for the reply.
I was a bit in a hurry though lxd did not start, copy worked OK. So managed to lxd remote copy these to remote server and move them back later.
lxd import xenial-b
after this add remote.
copy to remote
purge my local LXD
install from backports 3.0.1
Copy back everything from remote
Finally did this so that next time I save my time
I’m thinking of moving the current /var/lib/lxd to a zfs dataset liblxd so that I can restore the full lxd server elsewhere. If everything, containers and /var/lib/lxd is on zfs, then it seems true that I should be able to send and receive the snapshots and have everything working at destination as an exact copy of the src. Do people agree that this should work? (I will install lxd at destination so that init script, log dir etc is created).
how would you go about doing the initial migrati…
Thanks a lot…
