some insights provided by the /1.0/metrics
API endpoint are also in the /1.0/instances?recursion=2
result. Namely, the path state.cpu.usage
or state.distk.root.usage
in the later call for a given instance. Both are also available in the metrics endpoint as lxd_cpu_seconds_total
or lxd_filesystem_size_bytes
Are the values in both endpoints coming from the same source, or are they retrieved differently?
The metrics documentation mentions it is resource heavy. Is the instance call cheaper?
Thank you,
David
