Good day all,
I’m not sure it’s ok to post about MicroCloud problems, but here goes.
Attempting to get going with MicroCloud, microcloud init consistently fails with the same error every single time for the past three days and numerous reinstalls. Below is a run with latest/edge packages where possible.
Hardware:
RPi 4 / 8GB RAM (6 units)
1TB SSD (intended for Ceph)
64GB Flash (intended for local storage)
eth0 for cluster traffic
Wifi for everything else
Ubuntu 22.04
ladmin@beta:~$ snap list
core20 20230801 2019 latest/stable canonical✓ base
core22 20230801 867 latest/stable canonical✓ base
lxd git-35860e8 26005 latest/edge canonical✓ -
microceph 0+git.66190c4 716 latest/edge canonical✓ -
microcloud git-813e9d8 662 latest/edge canonical✓ -
microovn 22.03.3+snapa304000172 278 22.03/stable canonical✓ -
snapd 2.60.4 20298 latest/stable canonical✓ snapd
ladmin@beta:~$ sudo microcloud init
Waiting for LXD to start...
Select an address for MicroCloud's internal traffic:
Using address "172.28.15.12" for MicroCloud
Limit search for other MicroCloud servers to 172.28.15.12/24? (yes/no) [default=yes]:
Scanning for eligible servers ...
Selected "delta" at "172.28.15.14"
Selected "gamma" at "172.28.15.13"
Selected "kappa" at "172.28.15.15"
Selected "theta" at "172.28.15.16"
Selected "beta" at "172.28.15.12"
Selected "iota" at "172.28.15.17"
Error: Failed to get system resources of peer "iota": Get "https://172.28.15.17:9443/1.0/services/lxd/1.0/resources": Unable to connect to: 172.28.15.17:9443 ([dial tcp 172.28.15.17:9443: i/o timeout])
The relevant MicroCloud logs:
Oct 14 10:40:23 beta systemd[1843]: Started snap.microcloud.microcloud-a7bacd97-8ee8-4655-a95e-ebabcbe8feb4.scope.
Oct 14 10:40:38 beta systemd[1]: Started snap.microcloud.microcloud-ac0b2642-eba3-402f-bf68-196c56f5db30.scope.
Oct 14 10:41:08 beta kernel: [13307.889258] audit: type=1400 audit(1697294468.091:73): apparmor="DENIED" operation="open" profile="snap.microcloud.microcloud" name="/var/lib/snapd/hostfs/etc/ssl/certs/ca-certificates.crt" pid=3221 comm="microcloud" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
Oct 14 10:41:28 beta systemd[1]: snap.microcloud.microcloud-ac0b2642-eba3-402f-bf68-196c56f5db30.scope: Deactivated successfully.
Oct 14 10:41:28 beta systemd[1]: snap.microcloud.microcloud-ac0b2642-eba3-402f-bf68-196c56f5db30.scope: Consumed 1.431s CPU time.
And last:
ladmin@iota:~$ ls -la /var/lib/snapd/hostfs
total 8
drwxr-xr-x 2 root root 4096 May 29 08:08 .
drwxr-xr-x 23 root root 4096 Oct 14 07:13 ..
ladmin@beta:~$ ls -la /var/lib/snapd/hostfs
total 8
drwxr-xr-x 23 root root 4096 Oct 14 07:12 ..
It looks like init is unable to start the necessary HTTPS session because it appears that all the nodes are missing stuff under /var/lib/snapd/hostfs. What is missing? How do I recover?
Thanks for any clues.
