Microvm option for running vms?
Hi everyone, has anyone tried running microVMs under Incus?
I’ve attempted to set it up but haven’t had any success so far. Below is the relevant part of my profile configuration:
  raw.qemu: |-
    -M microvm
    -nographic
    -enable-kvm
    -bios /usr/share/qemu/bios-microvm.bin
  raw.qemu.conf: |-
    [global][0]
    [global][1]
    [smp-opts]
    [object "mem0"]
    [numa]
    [boot-opts]
    [device "qemu_pcie0"]
    [device "qemu_balloon"]
    [device "dev-qemu_rng"]
    [device "qemu_keyboard"]
    [device "qemu_tablet"]
    [device "qemu_vsock"]
    [device "dev-qemu_serial"]
    [device "qemu_spice"]
    [device "qemu_serial_legacy"]
    [device "qemu_serial"]
    [device "qemu_spicedir"]
    [device "qemu_usb"]
    [device "qemu_spice-usb1"]
    [device "qemu_spice-usb2"]
    [device "qemu_spice-usb3"]
    [device "qemu_pcie1"]
    [device "qemu_scsi"]
    [device "qemu_pcie2"]
    [device "dev-qemu_config-drive-9p"]
    [device "dev-qemu_agent-drive-9p"]
    [device "qemu_pcie3"]
    [device "qemu_gpu"]
    [device "qemu_pcie4"]
    [device "qemu_pcie5"]
    [device "qemu_pcie6"]
    [device "qemu_pcie7"]
    [device "qemu_pcie8"]
  security.secureboot: "false"
I’m trying to run a stripped-down variant of a VM via Incus alongside my regular containers. Generic VMs work without any issues, but microVMs are giving me trouble.
The raw.qemu part is my attempt to remove PCIe devices that are unsupported in microVMs. Might be wrong, now I am ending with the error:
Error: Failed to add CPUs: Failed to query hotpluggable CPUs: Failed to query hotpluggable CPUs: machine does not support hot-plugging CPUs
Has anyone managed to get this working, or is there something I’m missing in the configuration?
Or is it possible to run microvm somehow in general under incus?
Side note: Microvm works for me without any problem on the same machine directly via qemu commands.
Where do you get such microvm images from? That is, if someone was to try them and replicate the error, what files are required to give it a go?
I am trying regular alpine 3.20 (vm) image, or I have image(s) which works for firecracker and qemu (same image works for both of them). So I think nothing extra special needed inside the image itself (I might be wrong).
