Hello
Without using lxd-to-incus migration tool, how can one manually migrate from LXD to Incus?
Current env
LXD - Client & Server version: 5.18, lxcfs version: 5.0.4 based on copr/ganto/lxc4 distribution (non-snap)
Hello
Current env
Why canât you use lxd-to-incus?
If itâs because it somehow canât handle the source or target due to them being Fedora packages, Iâd prefer we fix the tool to handle that case, that should be pretty easy to do.
The socket path was of different path
# lxd-to-incus
=> Looking for source server
==> Detected: manual installation
=> Looking for target server
=> Connecting to source server
Error: Failed to connect to the source: Get âhttp://unix.socket/1.0â: dial unix /var/lib/lxd/unix.socket: connect: no such file or directory
The socket file is instead located in /run/lxd.socket.
Ah, thatâs easy enough to fix, Iâll try to reproduce things in a VM here to avoid having to go multiple rounds to get that one fixed ![]()
tgraber@dakara:~/data/code/lxc/incus (stgraber/migrate)$ incus launch images:fedora/39 f39 --vm
Creating f39
Starting f39
stgraber@dakara:~/data/code/lxc/incus (stgraber/migrate)$ incus exec f39 bash
[root@f39 ~]# dnf install dnf-plugins-core
determining the fastest mirror (141 hosts).. done. [=== ] --- B/s | 0 B --:-- ETA
Fedora 39 - x86_64 19 MB/s | 89 MB 00:04
Fedora 39 openh264 (From Cisco) - x86_64 4.0 kB/s | 2.5 kB 00:00
Fedora 39 - x86_64 - Updates 21 MB/s | 17 MB 00:00
Dependencies resolved.
Package Architecture Version Repository Size
Installing:
dnf-plugins-core noarch 4.4.3-1.fc39 updates 38 k
Installing dependencies:
dbus-libs x86_64 1:1.14.10-1.fc39 fedora 156 k
fonts-filesystem noarch 1:2.0.5-12.fc39 fedora 8.2 k
js-jquery noarch 3.6.4-2.fc39 fedora 172 k
python3-dateutil noarch 1:2.8.2-10.fc39 fedora 355 k
python3-dbus x86_64 1.3.2-4.fc39 fedora 157 k
python3-distro noarch 1.8.0-6.fc39 fedora 49 k
python3-dnf-plugins-core noarch 4.4.3-1.fc39 updates 317 k
python3-six noarch 1.16.0-12.fc39 fedora 41 k
python3-systemd x86_64 235-5.fc39 fedora 107 k
web-assets-filesystem noarch 5-20.fc39 fedora 7.9 k
Installing weak dependencies:
python-systemd-doc x86_64 235-5.fc39 fedora 75 k
Transaction Summary
Install 12 Packages
Total download size: 1.4 M
Installed size: 4.6 M
Is this ok [y/N]: y
Downloading Packages:
done.a 39 - x86_64 0% [ ] 2.4 MB/s | 24 kB 00:07 ETA
(1/12): fonts-filesystem-2.0.5-12.fc39.noarch.rpm 140 kB/s | 8.2 kB 00:00
(2/12): dbus-libs-1.14.10-1.fc39.x86_64.rpm 1.7 MB/s | 156 kB 00:00
(3/12): js-jquery-3.6.4-2.fc39.noarch.rpm 1.7 MB/s | 172 kB 00:00
(4/12): python-systemd-doc-235-5.fc39.x86_64.rpm 1.6 MB/s | 75 kB 00:00
(5/12): python3-dateutil-2.8.2-10.fc39.noarch.rpm 6.4 MB/s | 355 kB 00:00
(6/12): python3-dbus-1.3.2-4.fc39.x86_64.rpm 3.2 MB/s | 157 kB 00:00
(7/12): python3-distro-1.8.0-6.fc39.noarch.rpm 915 kB/s | 49 kB 00:00
(8/12): python3-six-1.16.0-12.fc39.noarch.rpm 1.3 MB/s | 41 kB 00:00
(9/12): web-assets-filesystem-5-20.fc39.noarch.rpm 276 kB/s | 7.9 kB 00:00
(10/12): python3-systemd-235-5.fc39.x86_64.rpm 1.9 MB/s | 107 kB 00:00
(11/12): dnf-plugins-core-4.4.3-1.fc39.noarch.rpm 921 kB/s | 38 kB 00:00
(12/12): python3-dnf-plugins-core-4.4.3-1.fc39.noarch.rpm 7.5 MB/s | 317 kB 00:00
Total 2.6 MB/s | 1.4 MB 00:00
Running transaction check
Transaction check succeeded.
Running transaction test
Transaction test succeeded.
Running transaction
Preparing : 1/1
Installing : python3-six-1.16.0-12.fc39.noarch 1/12
Installing : python3-dateutil-1:2.8.2-10.fc39.noarch 2/12
Installing : python3-distro-1.8.0-6.fc39.noarch 3/12
Installing : fonts-filesystem-1:2.0.5-12.fc39.noarch 4/12
Installing : web-assets-filesystem-5-20.fc39.noarch 5/12
Installing : js-jquery-3.6.4-2.fc39.noarch 6/12
Installing : python-systemd-doc-235-5.fc39.x86_64 7/12
Installing : python3-systemd-235-5.fc39.x86_64 8/12
Installing : dbus-libs-1:1.14.10-1.fc39.x86_64 9/12
Installing : python3-dbus-1.3.2-4.fc39.x86_64 10/12
Installing : python3-dnf-plugins-core-4.4.3-1.fc39.noarch 11/12
Installing : dnf-plugins-core-4.4.3-1.fc39.noarch 12/12
Running scriptlet: dnf-plugins-core-4.4.3-1.fc39.noarch 12/12
Verifying : dbus-libs-1:1.14.10-1.fc39.x86_64 1/12
Verifying : fonts-filesystem-1:2.0.5-12.fc39.noarch 2/12
Verifying : js-jquery-3.6.4-2.fc39.noarch 3/12
Verifying : python-systemd-doc-235-5.fc39.x86_64 4/12
Verifying : python3-dateutil-1:2.8.2-10.fc39.noarch 5/12
Verifying : python3-dbus-1.3.2-4.fc39.x86_64 6/12
Verifying : python3-distro-1.8.0-6.fc39.noarch 7/12
Verifying : python3-six-1.16.0-12.fc39.noarch 8/12
Verifying : python3-systemd-235-5.fc39.x86_64 9/12
Verifying : web-assets-filesystem-5-20.fc39.noarch 10/12
Verifying : dnf-plugins-core-4.4.3-1.fc39.noarch 11/12
Verifying : python3-dnf-plugins-core-4.4.3-1.fc39.noarch 12/12
Installed:
dbus-libs-1:1.14.10-1.fc39.x86_64 dnf-plugins-core-4.4.3-1.fc39.noarch fonts-filesystem-1:2.0.5-12.fc39.noarch
js-jquery-3.6.4-2.fc39.noarch python-systemd-doc-235-5.fc39.x86_64 python3-dateutil-1:2.8.2-10.fc39.noarch
python3-dbus-1.3.2-4.fc39.x86_64 python3-distro-1.8.0-6.fc39.noarch python3-dnf-plugins-core-4.4.3-1.fc39.noarch
python3-six-1.16.0-12.fc39.noarch python3-systemd-235-5.fc39.x86_64 web-assets-filesystem-5-20.fc39.noarch
Complete!
[root@f39 ~]# dnf copr enable ganto/lxc4
Enabling a Copr repository. Please note that this repository is not part
of the main distribution, and quality may vary.
The Fedora Project does not exercise any power over the contents of
this repository beyond the rules outlined in the Copr FAQ at
<https://docs.pagure.org/copr.copr/user_documentation.html#what-i-can-build-in-copr>,
and packages are not held to any quality or security level.
Please do not file bug reports about these packages in Fedora
Bugzilla. In case of problems, contact the owner of this repository.
Do you really want to enable copr.fedorainfracloud.org/ganto/lxc4? [y/N]: y
Repository successfully enabled.
[root@f39 ~]# dnf install lxd incus
Copr repo for lxc4 owned by ganto 598 kB/s | 127 kB 00:00
Installing:
incus x86_64 0.2-0.2.fc39 copr:copr.fedorainfracloud.org:ganto:lxc4 17 M
lxd x86_64 5.18-0.2.fc39 copr:copr.fedorainfracloud.org:ganto:lxc4 13 M
abattis-cantarell-vf-fonts noarch 0.301-10.fc39 fedora 121 k
acl x86_64 2.3.1-8.fc39 fedora 71 k
alsa-lib x86_64 1.2.10-3.fc39 fedora 522 k
attr x86_64 2.5.1-8.fc39 fedora 63 k
cairo x86_64 1.18.0-1.fc39 fedora 710 k
capstone x86_64 4.0.2-15.fc39 fedora 861 k
cdparanoia-libs x86_64 10.2-42.fc39 fedora 54 k
container-selinux noarch 2:2.224.0-1.fc39 updates 55 k
cowsql x86_64 1.15.3-0.1.fc39 copr:copr.fedorainfracloud.org:ganto:lxc4 86 k
daxctl-libs x86_64 78-1.fc39 fedora 41 k
default-fonts-core-sans noarch 4.0-9.fc39 fedora 32 k
dnsmasq x86_64 2.89-6.fc39 fedora 357 k
dqlite x86_64 1.16.0-0.1.fc39 copr:copr.fedorainfracloud.org:ganto:lxc4 93 k
e2fsprogs-libs x86_64 1.47.0-2.fc39 fedora 226 k
ebtables-legacy x86_64 2.0.11-14.fc39 fedora 97 k
fontconfig x86_64 2.14.2-5.fc39 fedora 297 k
freetype x86_64 2.13.1-2.fc39 fedora 414 k
fribidi x86_64 1.0.13-2.fc39 fedora 91 k
fuse3-libs x86_64 3.16.1-1.fc39 fedora 94 k
google-noto-fonts-common noarch 20230801-4.fc39 updates 17 k
google-noto-sans-vf-fonts noarch 20230801-4.fc39 updates 583 k
gpgme x86_64 1.20.0-5.fc39 fedora 210 k
graphene x86_64 1.10.6-6.fc39 fedora 61 k
graphite2 x86_64 1.3.14-12.fc39 fedora 95 k
gstreamer1 x86_64 1.22.7-1.fc39 updates 1.4 M
gstreamer1-plugins-base x86_64 1.22.7-1.fc39 updates 2.2 M
harfbuzz x86_64 8.2.1-2.fc39 fedora 975 k
hwdata noarch 0.376-1.fc39 updates 1.6 M
incus-client x86_64 0.2-0.2.fc39 copr:copr.fedorainfracloud.org:ganto:lxc4 4.9 M
iptables-legacy x86_64 1.8.9-5.fc39 fedora 52 k
iptables-legacy-libs x86_64 1.8.9-5.fc39 fedora 38 k
ipxe-roms-qemu noarch 20220210-4.git64113751.fc39 fedora 1.5 M
iso-codes noarch 4.15.0-2.fc39 fedora 3.5 M
libX11 x86_64 1.8.7-1.fc39 fedora 650 k
libX11-common noarch 1.8.7-1.fc39 fedora 176 k
libX11-xcb x86_64 1.8.7-1.fc39 fedora 12 k
libXau x86_64 1.0.11-3.fc39 fedora 31 k
libXext x86_64 1.3.5-3.fc39 fedora 39 k
libXfixes x86_64 6.0.0-6.fc39 fedora 19 k
libXft x86_64 2.3.8-3.fc39 fedora 72 k
libXi x86_64 1.8.1-2.fc39 fedora 40 k
libXrender x86_64 0.9.11-3.fc39 fedora 27 k
libXv x86_64 1.0.11-19.fc39 fedora 18 k
libXxf86vm x86_64 1.1.5-3.fc39 fedora 18 k
libaio x86_64 0.3.111-16.fc39 fedora 24 k
libdatrie x86_64 0.2.13-7.fc39 fedora 32 k
libdrm x86_64 2.4.117-1.fc39 updates 156 k
libepoxy x86_64 1.5.10-4.fc39 fedora 234 k
libfdt x86_64 1.7.0-4.fc39 fedora 34 k
libglvnd x86_64 1:1.7.0-1.fc39 fedora 133 k
libglvnd-egl x86_64 1:1.7.0-1.fc39 fedora 36 k
libglvnd-glx x86_64 1:1.7.0-1.fc39 fedora 142 k
libgudev x86_64 238-2.fc39 fedora 35 k
libjpeg-turbo x86_64 2.1.4-3.fc39 fedora 183 k
libmetalink x86_64 0.1.3-32.fc39 fedora 32 k
libogg x86_64 2:1.3.5-6.fc39 fedora 33 k
libpciaccess x86_64 0.16-9.fc39 fedora 26 k
libpmem x86_64 1.13.1-1.fc39 fedora 112 k
libpng x86_64 2:1.6.37-15.fc39 fedora 119 k
librdmacm x86_64 46.0-4.fc39 fedora 72 k
libslirp x86_64 4.7.0-4.fc39 fedora 75 k
libthai x86_64 0.1.29-6.fc39 fedora 213 k
libtheora x86_64 1:1.1.1-34.fc39 fedora 166 k
libunwind x86_64 1.7.0-0.2.rc2.fc39 fedora 70 k
liburing x86_64 2.5-1.fc39 updates 39 k
libusal x86_64 1.1.11-52.fc39 fedora 137 k
libusb1 x86_64 1.0.26-3.fc39 fedora 74 k
libuv x86_64 1:1.46.0-2.fc39 fedora 159 k
libvisual x86_64 1:0.4.1-2.fc39 fedora 151 k
libvorbis x86_64 1:1.3.7-8.fc39 fedora 195 k
libwayland-client x86_64 1.22.0-2.fc39 fedora 34 k
libwayland-cursor x86_64 1.22.0-2.fc39 fedora 19 k
libwayland-egl x86_64 1.22.0-2.fc39 fedora 13 k
libwayland-server x86_64 1.22.0-2.fc39 fedora 42 k
libxcb x86_64 1.13.1-12.fc39 fedora 233 k
libxshmfence x86_64 1.3-13.fc39 fedora 12 k
llvm16-libs x86_64 16.0.6-5.fc39 fedora 27 M
lm_sensors-libs x86_64 3.6.0-14.fc39 fedora 41 k
lxc-libs x86_64 5.0.3-0.2.fc39 copr:copr.fedorainfracloud.org:ganto:lxc4 1.2 M
lxc-templates x86_64 5.0.3-0.2.fc39 copr:copr.fedorainfracloud.org:ganto:lxc4 20 k
lxcfs x86_64 5.0.4-1.fc39 fedora 92 k
lxd-client x86_64 5.18-0.2.fc39 copr:copr.fedorainfracloud.org:ganto:lxc4 5.5 M
lzo x86_64 2.10-9.fc39 fedora 66 k
mesa-dri-drivers x86_64 23.2.1-2.fc39 fedora 25 M
mesa-filesystem x86_64 23.2.1-2.fc39 fedora 18 k
mesa-libEGL x86_64 23.2.1-2.fc39 fedora 132 k
mesa-libGL x86_64 23.2.1-2.fc39 fedora 174 k
mesa-libgbm x86_64 23.2.1-2.fc39 fedora 45 k
mesa-libglapi x86_64 23.2.1-2.fc39 fedora 52 k
ndctl-libs x86_64 78-1.fc39 fedora 88 k
numactl-libs x86_64 2.0.16-3.fc39 fedora 30 k
opus x86_64 1.3.1-13.fc39 fedora 205 k
orc x86_64 0.4.33-3.fc39 fedora 202 k
pango x86_64 1.51.0-1.fc39 fedora 343 k
pixman x86_64 0.42.2-2.fc39 fedora 288 k
qemu-common x86_64 2:8.1.1-1.fc39 updates 587 k
qemu-ui-opengl x86_64 2:8.1.1-1.fc39 updates 24 k
qemu-ui-spice-core x86_64 2:8.1.1-1.fc39 updates 35 k
raft x86_64 0.17.1-2.fc39 fedora 97 k
rpm-plugin-selinux x86_64 4.19.0-1.fc39 fedora 20 k
rsync x86_64 3.2.7-5.fc39 fedora 422 k
seabios-bin noarch 1.16.2-2.fc39 fedora 182 k
seavgabios-bin noarch 1.16.2-2.fc39 fedora 38 k
selinux-policy noarch 39.2-1.fc39 updates 56 k
selinux-policy-targeted noarch 39.2-1.fc39 updates 6.7 M
snappy x86_64 1.1.10-2.fc39 fedora 37 k
spice-server x86_64 0.15.1-3.fc39 fedora 392 k
squashfs-tools x86_64 4.6.1-2.fc39 fedora 249 k
usbredir x86_64 0.13.0-3.fc39 fedora 50 k
wget x86_64 1.21.3-7.fc39 fedora 792 k
xdelta x86_64 3.1.0-17.fc39 fedora 90 k
xen-libs x86_64 4.17.2-4.fc39 updates 639 k
xen-licenses x86_64 4.17.2-4.fc39 updates 55 k
xml-common noarch 0.6.3-61.fc39 fedora 31 k
xxhash-libs x86_64 0.8.2-1.fc39 fedora 37 k
yajl x86_64 2.1.0-22.fc39 fedora 38 k
edk2-ovmf noarch 20230825-25.fc39 updates 10 M
genisoimage x86_64 1.1.11-52.fc39 fedora 333 k
logrotate x86_64 3.21.0-4.fc39 fedora 75 k
lxd-agent x86_64 5.18-0.2.fc39 copr:copr.fedorainfracloud.org:ganto:lxc4 4.6 M
lxd-ui noarch 0.3-0.3.fc39 copr:copr.fedorainfracloud.org:ganto:lxc4 3.0 M
mesa-va-drivers x86_64 23.2.1-2.fc39 fedora 3.9 M
qemu-char-spice x86_64 2:8.1.1-1.fc39 updates 19 k
qemu-device-display-virtio-gpu x86_64 2:8.1.1-1.fc39 updates 35 k
qemu-device-display-virtio-vga x86_64 2:8.1.1-1.fc39 updates 18 k
qemu-device-usb-redirect x86_64 2:8.1.1-1.fc39 updates 36 k
qemu-img x86_64 2:8.1.1-1.fc39 updates 1.9 M
qemu-system-x86-core x86_64 2:8.1.1-1.fc39 updates 7.9 M
Transaction Summary
Install 130 Packages
Total download size: 158 M
Installed size: 617 M
Is this ok [y/N]: y
(1/130): cowsql-1.15.3-0.1.fc39.x86_64.rpm 1.3 MB/s | 86 kB 00:00
(2/130): dqlite-1.16.0-0.1.fc39.x86_64.rpm 855 kB/s | 93 kB 00:00
(3/130): lxc-libs-5.0.3-0.2.fc39.x86_64.rpm 5.0 MB/s | 1.2 MB 00:00
(4/130): incus-client-0.2-0.2.fc39.x86_64.rpm 15 MB/s | 4.9 MB 00:00
(5/130): lxc-templates-5.0.3-0.2.fc39.x86_64.rpm 583 kB/s | 20 kB 00:00
(6/130): incus-0.2-0.2.fc39.x86_64.rpm 17 MB/s | 17 MB 00:00
(7/130): lxd-agent-5.18-0.2.fc39.x86_64.rpm 7.5 MB/s | 4.6 MB 00:00
(8/130): lxd-5.18-0.2.fc39.x86_64.rpm 18 MB/s | 13 MB 00:00
(9/130): abattis-cantarell-vf-fonts-0.301-10.fc39.noarch.rpm 608 kB/s | 121 kB 00:00
(10/130): lxd-ui-0.3-0.3.fc39.noarch.rpm 9.1 MB/s | 3.0 MB 00:00
(11/130): lxd-client-5.18-0.2.fc39.x86_64.rpm 15 MB/s | 5.5 MB 00:00
(12/130): alsa-lib-1.2.10-3.fc39.x86_64.rpm 7.7 MB/s | 522 kB 00:00
(13/130): acl-2.3.1-8.fc39.x86_64.rpm 764 kB/s | 71 kB 00:00
(14/130): attr-2.5.1-8.fc39.x86_64.rpm 992 kB/s | 63 kB 00:00
(15/130): cdparanoia-libs-10.2-42.fc39.x86_64.rpm 1.5 MB/s | 54 kB 00:00
(16/130): capstone-4.0.2-15.fc39.x86_64.rpm 14 MB/s | 861 kB 00:00
(17/130): cairo-1.18.0-1.fc39.x86_64.rpm 7.4 MB/s | 710 kB 00:00
(18/130): daxctl-libs-78-1.fc39.x86_64.rpm 786 kB/s | 41 kB 00:00
(19/130): default-fonts-core-sans-4.0-9.fc39.noarch.rpm 880 kB/s | 32 kB 00:00
(20/130): e2fsprogs-libs-1.47.0-2.fc39.x86_64.rpm 4.9 MB/s | 226 kB 00:00
(21/130): dnsmasq-2.89-6.fc39.x86_64.rpm 6.8 MB/s | 357 kB 00:00
(22/130): fontconfig-2.14.2-5.fc39.x86_64.rpm 7.1 MB/s | 297 kB 00:00
(23/130): freetype-2.13.1-2.fc39.x86_64.rpm 9.0 MB/s | 414 kB 00:00
(24/130): ebtables-legacy-2.0.11-14.fc39.x86_64.rpm 882 kB/s | 97 kB 00:00
(25/130): fribidi-1.0.13-2.fc39.x86_64.rpm 2.3 MB/s | 91 kB 00:00
(26/130): fuse3-libs-3.16.1-1.fc39.x86_64.rpm 2.6 MB/s | 94 kB 00:00
(27/130): genisoimage-1.1.11-52.fc39.x86_64.rpm 7.3 MB/s | 333 kB 00:00
(28/130): gpgme-1.20.0-5.fc39.x86_64.rpm 4.0 MB/s | 210 kB 00:00
(29/130): graphene-1.10.6-6.fc39.x86_64.rpm 1.2 MB/s | 61 kB 00:00
(30/130): graphite2-1.3.14-12.fc39.x86_64.rpm 2.9 MB/s | 95 kB 00:00
(31/130): harfbuzz-8.2.1-2.fc39.x86_64.rpm 15 MB/s | 975 kB 00:00
(32/130): iptables-legacy-1.8.9-5.fc39.x86_64.rpm 763 kB/s | 52 kB 00:00
(33/130): iptables-legacy-libs-1.8.9-5.fc39.x86_64.rpm 631 kB/s | 38 kB 00:00
(34/130): ipxe-roms-qemu-20220210-4.git64113751.fc39.noarch.rpm 13 MB/s | 1.5 MB 00:00
(35/130): libX11-1.8.7-1.fc39.x86_64.rpm 6.6 MB/s | 650 kB 00:00
(36/130): iso-codes-4.15.0-2.fc39.noarch.rpm 18 MB/s | 3.5 MB 00:00
(37/130): libX11-common-1.8.7-1.fc39.noarch.rpm 1.9 MB/s | 176 kB 00:00
(38/130): libX11-xcb-1.8.7-1.fc39.x86_64.rpm 146 kB/s | 12 kB 00:00
(39/130): libXfixes-6.0.0-6.fc39.x86_64.rpm 643 kB/s | 19 kB 00:00
(40/130): libXau-1.0.11-3.fc39.x86_64.rpm 887 kB/s | 31 kB 00:00
(41/130): libXext-1.3.5-3.fc39.x86_64.rpm 952 kB/s | 39 kB 00:00
(42/130): libXft-2.3.8-3.fc39.x86_64.rpm 2.0 MB/s | 72 kB 00:00
(43/130): libXv-1.0.11-19.fc39.x86_64.rpm 557 kB/s | 18 kB 00:00
(44/130): libXi-1.8.1-2.fc39.x86_64.rpm 571 kB/s | 40 kB 00:00
(45/130): libXrender-0.9.11-3.fc39.x86_64.rpm 358 kB/s | 27 kB 00:00
(46/130): libXxf86vm-1.1.5-3.fc39.x86_64.rpm 583 kB/s | 18 kB 00:00
(47/130): libaio-0.3.111-16.fc39.x86_64.rpm 726 kB/s | 24 kB 00:00
(48/130): libdatrie-0.2.13-7.fc39.x86_64.rpm 977 kB/s | 32 kB 00:00
(49/130): libepoxy-1.5.10-4.fc39.x86_64.rpm 6.0 MB/s | 234 kB 00:00
(50/130): libfdt-1.7.0-4.fc39.x86_64.rpm 1.0 MB/s | 34 kB 00:00
(51/130): libglvnd-1.7.0-1.fc39.x86_64.rpm 3.0 MB/s | 133 kB 00:00
(52/130): libglvnd-egl-1.7.0-1.fc39.x86_64.rpm 1.1 MB/s | 36 kB 00:00
(53/130): libglvnd-glx-1.7.0-1.fc39.x86_64.rpm 4.1 MB/s | 142 kB 00:00
(54/130): libgudev-238-2.fc39.x86_64.rpm 1.1 MB/s | 35 kB 00:00
(55/130): libjpeg-turbo-2.1.4-3.fc39.x86_64.rpm 5.3 MB/s | 183 kB 00:00
(56/130): libmetalink-0.1.3-32.fc39.x86_64.rpm 1.1 MB/s | 32 kB 00:00
(57/130): libogg-1.3.5-6.fc39.x86_64.rpm 1.0 MB/s | 33 kB 00:00
(58/130): libpciaccess-0.16-9.fc39.x86_64.rpm 867 kB/s | 26 kB 00:00
(59/130): libpmem-1.13.1-1.fc39.x86_64.rpm 3.4 MB/s | 112 kB 00:00
(60/130): libpng-1.6.37-15.fc39.x86_64.rpm 3.5 MB/s | 119 kB 00:00
(61/130): librdmacm-46.0-4.fc39.x86_64.rpm 1.7 MB/s | 72 kB 00:00
(62/130): libslirp-4.7.0-4.fc39.x86_64.rpm 1.9 MB/s | 75 kB 00:00
(63/130): libthai-0.1.29-6.fc39.x86_64.rpm 5.9 MB/s | 213 kB 00:00
(64/130): libtheora-1.1.1-34.fc39.x86_64.rpm 4.9 MB/s | 166 kB 00:00
(65/130): libunwind-1.7.0-0.2.rc2.fc39.x86_64.rpm 2.0 MB/s | 70 kB 00:00
(66/130): libusb1-1.0.26-3.fc39.x86_64.rpm 2.2 MB/s | 74 kB 00:00
(67/130): libuv-1.46.0-2.fc39.x86_64.rpm 4.6 MB/s | 159 kB 00:00
(68/130): libusal-1.1.11-52.fc39.x86_64.rpm 2.2 MB/s | 137 kB 00:00
(69/130): libvisual-0.4.1-2.fc39.x86_64.rpm 4.5 MB/s | 151 kB 00:00
(70/130): libwayland-client-1.22.0-2.fc39.x86_64.rpm 1.1 MB/s | 34 kB 00:00
(71/130): libwayland-cursor-1.22.0-2.fc39.x86_64.rpm 657 kB/s | 19 kB 00:00
(72/130): libvorbis-1.3.7-8.fc39.x86_64.rpm 3.0 MB/s | 195 kB 00:00
(73/130): libwayland-egl-1.22.0-2.fc39.x86_64.rpm 431 kB/s | 13 kB 00:00
(74/130): libwayland-server-1.22.0-2.fc39.x86_64.rpm 1.2 MB/s | 42 kB 00:00
(75/130): libxcb-1.13.1-12.fc39.x86_64.rpm 6.4 MB/s | 233 kB 00:00
(76/130): libxshmfence-1.3-13.fc39.x86_64.rpm 345 kB/s | 12 kB 00:00
(77/130): logrotate-3.21.0-4.fc39.x86_64.rpm 2.4 MB/s | 75 kB 00:00
(78/130): lm_sensors-libs-3.6.0-14.fc39.x86_64.rpm 940 kB/s | 41 kB 00:00
(79/130): lzo-2.10-9.fc39.x86_64.rpm 1.6 MB/s | 66 kB 00:00
(80/130): lxcfs-5.0.4-1.fc39.x86_64.rpm 1.0 MB/s | 92 kB 00:00
(81/130): mesa-filesystem-23.2.1-2.fc39.x86_64.rpm 201 kB/s | 18 kB 00:00
(82/130): mesa-libEGL-23.2.1-2.fc39.x86_64.rpm 484 kB/s | 132 kB 00:00
(83/130): mesa-libGL-23.2.1-2.fc39.x86_64.rpm 625 kB/s | 174 kB 00:00
(84/130): mesa-libgbm-23.2.1-2.fc39.x86_64.rpm 192 kB/s | 45 kB 00:00
(85/130): llvm16-libs-16.0.6-5.fc39.x86_64.rpm 21 MB/s | 27 MB 00:01
(86/130): mesa-libglapi-23.2.1-2.fc39.x86_64.rpm 203 kB/s | 52 kB 00:00
(87/130): mesa-dri-drivers-23.2.1-2.fc39.x86_64.rpm 20 MB/s | 25 MB 00:01
(88/130): ndctl-libs-78-1.fc39.x86_64.rpm 1.5 MB/s | 88 kB 00:00
(89/130): numactl-libs-2.0.16-3.fc39.x86_64.rpm 916 kB/s | 30 kB 00:00
(90/130): opus-1.3.1-13.fc39.x86_64.rpm 3.1 MB/s | 205 kB 00:00
(91/130): orc-0.4.33-3.fc39.x86_64.rpm 2.9 MB/s | 202 kB 00:00
(92/130): mesa-va-drivers-23.2.1-2.fc39.x86_64.rpm 19 MB/s | 3.9 MB 00:00
(93/130): pango-1.51.0-1.fc39.x86_64.rpm 3.8 MB/s | 343 kB 00:00
(94/130): pixman-0.42.2-2.fc39.x86_64.rpm 4.5 MB/s | 288 kB 00:00
(95/130): rpm-plugin-selinux-4.19.0-1.fc39.x86_64.rpm 687 kB/s | 20 kB 00:00
(96/130): raft-0.17.1-2.fc39.x86_64.rpm 1.7 MB/s | 97 kB 00:00
(97/130): rsync-3.2.7-5.fc39.x86_64.rpm 8.3 MB/s | 422 kB 00:00
(98/130): seabios-bin-1.16.2-2.fc39.noarch.rpm 4.5 MB/s | 182 kB 00:00
(99/130): seavgabios-bin-1.16.2-2.fc39.noarch.rpm 1.2 MB/s | 38 kB 00:00
(100/130): snappy-1.1.10-2.fc39.x86_64.rpm 1.2 MB/s | 37 kB 00:00
(101/130): spice-server-0.15.1-3.fc39.x86_64.rpm 10 MB/s | 392 kB 00:00
(102/130): squashfs-tools-4.6.1-2.fc39.x86_64.rpm 6.4 MB/s | 249 kB 00:00
(103/130): usbredir-0.13.0-3.fc39.x86_64.rpm 920 kB/s | 50 kB 00:00
(104/130): xml-common-0.6.3-61.fc39.noarch.rpm 955 kB/s | 31 kB 00:00
(105/130): xdelta-3.1.0-17.fc39.x86_64.rpm 1.0 MB/s | 90 kB 00:00
(106/130): xxhash-libs-0.8.2-1.fc39.x86_64.rpm 1.0 MB/s | 37 kB 00:00
(107/130): wget-1.21.3-7.fc39.x86_64.rpm 6.5 MB/s | 792 kB 00:00
(108/130): yajl-2.1.0-22.fc39.x86_64.rpm 902 kB/s | 38 kB 00:00
(109/130): container-selinux-2.224.0-1.fc39.noarch.rpm 1.3 MB/s | 55 kB 00:00
(110/130): google-noto-sans-vf-fonts-20230801-4.fc39.noarch.rpm 8.6 MB/s | 583 kB 00:00
(111/130): google-noto-fonts-common-20230801-4.fc39.noarch.rpm 239 kB/s | 17 kB 00:00
(112/130): gstreamer1-plugins-base-1.22.7-1.fc39.x86_64.rpm 13 MB/s | 2.2 MB 00:00
(113/130): gstreamer1-1.22.7-1.fc39.x86_64.rpm 4.8 MB/s | 1.4 MB 00:00
(114/130): edk2-ovmf-20230825-25.fc39.noarch.rpm 25 MB/s | 10 MB 00:00
(115/130): hwdata-0.376-1.fc39.noarch.rpm 8.6 MB/s | 1.6 MB 00:00
(116/130): liburing-2.5-1.fc39.x86_64.rpm 881 kB/s | 39 kB 00:00
(117/130): libdrm-2.4.117-1.fc39.x86_64.rpm 2.1 MB/s | 156 kB 00:00
(118/130): qemu-char-spice-8.1.1-1.fc39.x86_64.rpm 329 kB/s | 19 kB 00:00
(119/130): qemu-common-8.1.1-1.fc39.x86_64.rpm 8.8 MB/s | 587 kB 00:00
(120/130): qemu-device-display-virtio-gpu-8.1.1-1.fc39.x86_64.rpm 476 kB/s | 35 kB 00:00
(121/130): qemu-device-display-virtio-vga-8.1.1-1.fc39.x86_64.rpm 532 kB/s | 18 kB 00:00
(122/130): qemu-device-usb-redirect-8.1.1-1.fc39.x86_64.rpm 443 kB/s | 36 kB 00:00
(123/130): qemu-img-8.1.1-1.fc39.x86_64.rpm 17 MB/s | 1.9 MB 00:00
(124/130): qemu-system-x86-core-8.1.1-1.fc39.x86_64.rpm 36 MB/s | 7.9 MB 00:00
(125/130): qemu-ui-opengl-8.1.1-1.fc39.x86_64.rpm 133 kB/s | 24 kB 00:00
(126/130): qemu-ui-spice-core-8.1.1-1.fc39.x86_64.rpm 238 kB/s | 35 kB 00:00
(127/130): selinux-policy-39.2-1.fc39.noarch.rpm 1.7 MB/s | 56 kB 00:00
(128/130): xen-libs-4.17.2-4.fc39.x86_64.rpm 10 MB/s | 639 kB 00:00
(129/130): xen-licenses-4.17.2-4.fc39.x86_64.rpm 1.0 MB/s | 55 kB 00:00
(130/130): selinux-policy-targeted-39.2-1.fc39.noarch.rpm 36 MB/s | 6.7 MB 00:00
Total 29 MB/s | 158 MB 00:05
Copr repo for lxc4 owned by ganto 28 kB/s | 985 B 00:00
Importing GPG key 0x0B5C3D64:
Userid : "ganto_lxc4 (None) <ganto#lxc4@copr.fedorahosted.org>"
Fingerprint: 29FD D5F7 2A40 29C3 1E28 4645 1CCB 9CBF 0B5C 3D64
From : https://download.copr.fedorainfracloud.org/results/ganto/lxc4/pubkey.gpg
Is this ok [y/N]: y
Key imported successfully
Running transaction
Running scriptlet: selinux-policy-targeted-39.2-1.fc39.noarch 1/1
Preparing : 1/1
Installing : pixman-0.42.2-2.fc39.x86_64 1/130
Installing : libpng-2:1.6.37-15.fc39.x86_64 2/130
Installing : libX11-xcb-1.8.7-1.fc39.x86_64 3/130
Installing : edk2-ovmf-20230825-25.fc39.noarch 4/130
Installing : libxshmfence-1.3-13.fc39.x86_64 5/130
Installing : libwayland-client-1.22.0-2.fc39.x86_64 6/130
Installing : libuv-1:1.46.0-2.fc39.x86_64 7/130
Installing : libogg-2:1.3.5-6.fc39.x86_64 8/130
Installing : libjpeg-turbo-2.1.4-3.fc39.x86_64 9/130
Running scriptlet: dnsmasq-2.89-6.fc39.x86_64 10/130
Installing : dnsmasq-2.89-6.fc39.x86_64 10/130
Installing : daxctl-libs-78-1.fc39.x86_64 11/130
Installing : raft-0.17.1-2.fc39.x86_64 12/130
Installing : selinux-policy-39.2-1.fc39.noarch 13/130
Running scriptlet: selinux-policy-39.2-1.fc39.noarch 13/130
Running scriptlet: selinux-policy-targeted-39.2-1.fc39.noarch 14/130
Installing : selinux-policy-targeted-39.2-1.fc39.noarch 14/130
Running scriptlet: container-selinux-2:2.224.0-1.fc39.noarch 15/130
Installing : container-selinux-2:2.224.0-1.fc39.noarch 15/130
Installing : liburing-2.5-1.fc39.x86_64 16/130
Running scriptlet: xml-common-0.6.3-61.fc39.noarch 17/130
Installing : xml-common-0.6.3-61.fc39.noarch 17/130
Installing : xdelta-3.1.0-17.fc39.x86_64 18/130
Installing : orc-0.4.33-3.fc39.x86_64 19/130
Installing : opus-1.3.1-13.fc39.x86_64 20/130
Installing : numactl-libs-2.0.16-3.fc39.x86_64 21/130
Installing : mesa-filesystem-23.2.1-2.fc39.x86_64 22/130
Installing : lzo-2.10-9.fc39.x86_64 23/130
Installing : squashfs-tools-4.6.1-2.fc39.x86_64 24/130
Running scriptlet: logrotate-3.21.0-4.fc39.x86_64 25/130
Installing : logrotate-3.21.0-4.fc39.x86_64 25/130
Created symlink /etc/systemd/system/timers.target.wants/logrotate.timer â /usr/lib/systemd/system/logrotate.timer.
Installing : llvm16-libs-16.0.6-5.fc39.x86_64 26/130
Installing : libwayland-server-1.22.0-2.fc39.x86_64 27/130
Installing : libglvnd-1:1.7.0-1.fc39.x86_64 28/130
Installing : libaio-0.3.111-16.fc39.x86_64 29/130
Installing : fuse3-libs-3.16.1-1.fc39.x86_64 30/130
Installing : qemu-img-2:8.1.1-1.fc39.x86_64 31/130
Installing : ebtables-legacy-2.0.11-14.fc39.x86_64 32/130
Running scriptlet: ebtables-legacy-2.0.11-14.fc39.x86_64 32/130
Installing : attr-2.5.1-8.fc39.x86_64 33/130
Installing : acl-2.3.1-8.fc39.x86_64 34/130
Installing : iso-codes-4.15.0-2.fc39.noarch 35/130
Installing : cowsql-1.15.3-0.1.fc39.x86_64 36/130
Installing : dqlite-1.16.0-0.1.fc39.x86_64 37/130
Installing : ndctl-libs-78-1.fc39.x86_64 38/130
Installing : libpmem-1.13.1-1.fc39.x86_64 39/130
Installing : libtheora-1:1.1.1-34.fc39.x86_64 40/130
Installing : libvorbis-1:1.3.7-8.fc39.x86_64 41/130
Installing : libwayland-cursor-1.22.0-2.fc39.x86_64 42/130
Installing : xen-licenses-4.17.2-4.fc39.x86_64 43/130
Installing : hwdata-0.376-1.fc39.noarch 44/130
Installing : libpciaccess-0.16-9.fc39.x86_64 45/130
Installing : libdrm-2.4.117-1.fc39.x86_64 46/130
Installing : google-noto-fonts-common-20230801-4.fc39.noarch 47/130
Installing : google-noto-sans-vf-fonts-20230801-4.fc39.noarch 48/130
Installing : yajl-2.1.0-22.fc39.x86_64 49/130
Installing : xxhash-libs-0.8.2-1.fc39.x86_64 50/130
Installing : rsync-3.2.7-5.fc39.x86_64 51/130
Installing : snappy-1.1.10-2.fc39.x86_64 52/130
Installing : seavgabios-bin-1.16.2-2.fc39.noarch 53/130
Installing : seabios-bin-1.16.2-2.fc39.noarch 54/130
Installing : lm_sensors-libs-3.6.0-14.fc39.x86_64 55/130
Installing : libwayland-egl-1.22.0-2.fc39.x86_64 56/130
Installing : libvisual-1:0.4.1-2.fc39.x86_64 57/130
Installing : libusb1-1.0.26-3.fc39.x86_64 58/130
Installing : usbredir-0.13.0-3.fc39.x86_64 59/130
Installing : libusal-1.1.11-52.fc39.x86_64 60/130
Installing : genisoimage-1.1.11-52.fc39.x86_64 61/130
Running scriptlet: genisoimage-1.1.11-52.fc39.x86_64 61/130
Installing : libunwind-1.7.0-0.2.rc2.fc39.x86_64 62/130
Installing : gstreamer1-1.22.7-1.fc39.x86_64 63/130
Running scriptlet: gstreamer1-1.22.7-1.fc39.x86_64 63/130
Installing : libslirp-4.7.0-4.fc39.x86_64 64/130
Installing : librdmacm-46.0-4.fc39.x86_64 65/130
Installing : libmetalink-0.1.3-32.fc39.x86_64 66/130
Installing : libgudev-238-2.fc39.x86_64 67/130
Installing : libfdt-1.7.0-4.fc39.x86_64 68/130
Installing : libepoxy-1.5.10-4.fc39.x86_64 69/130
Installing : libdatrie-0.2.13-7.fc39.x86_64 70/130
Installing : libthai-0.1.29-6.fc39.x86_64 71/130
Installing : libXau-1.0.11-3.fc39.x86_64 72/130
Installing : libxcb-1.13.1-12.fc39.x86_64 73/130
Installing : mesa-va-drivers-23.2.1-2.fc39.x86_64 74/130
Installing : mesa-libglapi-23.2.1-2.fc39.x86_64 75/130
Installing : mesa-dri-drivers-23.2.1-2.fc39.x86_64 76/130
Installing : mesa-libgbm-23.2.1-2.fc39.x86_64 77/130
Installing : libglvnd-egl-1:1.7.0-1.fc39.x86_64 78/130
Installing : mesa-libEGL-23.2.1-2.fc39.x86_64 79/130
Installing : libX11-common-1.8.7-1.fc39.noarch 80/130
Installing : libX11-1.8.7-1.fc39.x86_64 81/130
Installing : libXext-1.3.5-3.fc39.x86_64 82/130
Installing : libXrender-0.9.11-3.fc39.x86_64 83/130
Installing : libXi-1.8.1-2.fc39.x86_64 84/130
Installing : libXv-1.0.11-19.fc39.x86_64 85/130
Installing : libXxf86vm-1.1.5-3.fc39.x86_64 86/130
Installing : libXfixes-6.0.0-6.fc39.x86_64 87/130
Installing : libglvnd-glx-1:1.7.0-1.fc39.x86_64 88/130
Installing : mesa-libGL-23.2.1-2.fc39.x86_64 89/130
Installing : ipxe-roms-qemu-20220210-4.git64113751.fc39.noarch 90/130
Installing : qemu-common-2:8.1.1-1.fc39.x86_64 91/130
Running scriptlet: qemu-common-2:8.1.1-1.fc39.x86_64 91/130
Installing : qemu-device-display-virtio-gpu-2:8.1.1-1.fc39.x86_64 92/130
Installing : qemu-device-display-virtio-vga-2:8.1.1-1.fc39.x86_64 93/130
Installing : qemu-device-usb-redirect-2:8.1.1-1.fc39.x86_64 94/130
Installing : qemu-ui-opengl-2:8.1.1-1.fc39.x86_64 95/130
Installing : iptables-legacy-libs-1.8.9-5.fc39.x86_64 96/130
Installing : iptables-legacy-1.8.9-5.fc39.x86_64 97/130
Running scriptlet: iptables-legacy-1.8.9-5.fc39.x86_64 97/130
Installing : lxc-libs-5.0.3-0.2.fc39.x86_64 98/130
Running scriptlet: lxc-libs-5.0.3-0.2.fc39.x86_64 98/130
Installing : graphite2-1.3.14-12.fc39.x86_64 99/130
Installing : graphene-1.10.6-6.fc39.x86_64 100/130
Installing : gpgme-1.20.0-5.fc39.x86_64 101/130
Installing : wget-1.21.3-7.fc39.x86_64 102/130
Installing : lxc-templates-5.0.3-0.2.fc39.x86_64 103/130
Installing : lxcfs-5.0.4-1.fc39.x86_64 104/130
Running scriptlet: lxcfs-5.0.4-1.fc39.x86_64 104/130
Installing : fribidi-1.0.13-2.fc39.x86_64 105/130
Installing : e2fsprogs-libs-1.47.0-2.fc39.x86_64 106/130
Installing : xen-libs-4.17.2-4.fc39.x86_64 107/130
Installing : cdparanoia-libs-10.2-42.fc39.x86_64 108/130
Installing : capstone-4.0.2-15.fc39.x86_64 109/130
Installing : qemu-system-x86-core-2:8.1.1-1.fc39.x86_64 110/130
Installing : alsa-lib-1.2.10-3.fc39.x86_64 111/130
Installing : abattis-cantarell-vf-fonts-0.301-10.fc39.noarch 112/130
Installing : default-fonts-core-sans-4.0-9.fc39.noarch 113/130
Installing : cairo-1.18.0-1.fc39.x86_64 114/130
Installing : harfbuzz-8.2.1-2.fc39.x86_64 115/130
Installing : freetype-2.13.1-2.fc39.x86_64 116/130
Installing : fontconfig-2.14.2-5.fc39.x86_64 117/130
Running scriptlet: fontconfig-2.14.2-5.fc39.x86_64 117/130
Installing : libXft-2.3.8-3.fc39.x86_64 118/130
Installing : pango-1.51.0-1.fc39.x86_64 119/130
Installing : gstreamer1-plugins-base-1.22.7-1.fc39.x86_64 120/130
Installing : spice-server-0.15.1-3.fc39.x86_64 121/130
Installing : qemu-ui-spice-core-2:8.1.1-1.fc39.x86_64 122/130
Installing : qemu-char-spice-2:8.1.1-1.fc39.x86_64 123/130
Installing : lxd-client-5.18-0.2.fc39.x86_64 124/130
Installing : lxd-agent-5.18-0.2.fc39.x86_64 125/130
Running scriptlet: lxd-agent-5.18-0.2.fc39.x86_64 125/130
Installing : lxd-ui-0.3-0.3.fc39.noarch 126/130
Running scriptlet: lxd-5.18-0.2.fc39.x86_64 127/130
Installing : lxd-5.18-0.2.fc39.x86_64 127/130
Installing : incus-client-0.2-0.2.fc39.x86_64 128/130
Running scriptlet: incus-0.2-0.2.fc39.x86_64 129/130
Installing : incus-0.2-0.2.fc39.x86_64 129/130
Installing : rpm-plugin-selinux-4.19.0-1.fc39.x86_64 130/130
Running scriptlet: selinux-policy-targeted-39.2-1.fc39.noarch 130/130
Running scriptlet: container-selinux-2:2.224.0-1.fc39.noarch 130/130
Running scriptlet: fontconfig-2.14.2-5.fc39.x86_64 130/130
Running scriptlet: rpm-plugin-selinux-4.19.0-1.fc39.x86_64 130/130
Verifying : cowsql-1.15.3-0.1.fc39.x86_64 1/130
Verifying : dqlite-1.16.0-0.1.fc39.x86_64 2/130
Verifying : incus-0.2-0.2.fc39.x86_64 3/130
Verifying : incus-client-0.2-0.2.fc39.x86_64 4/130
Verifying : lxc-libs-5.0.3-0.2.fc39.x86_64 5/130
Verifying : lxc-templates-5.0.3-0.2.fc39.x86_64 6/130
Verifying : lxd-5.18-0.2.fc39.x86_64 7/130
Verifying : lxd-agent-5.18-0.2.fc39.x86_64 8/130
Verifying : lxd-client-5.18-0.2.fc39.x86_64 9/130
Verifying : lxd-ui-0.3-0.3.fc39.noarch 10/130
Verifying : abattis-cantarell-vf-fonts-0.301-10.fc39.noarch 11/130
Verifying : acl-2.3.1-8.fc39.x86_64 12/130
Verifying : alsa-lib-1.2.10-3.fc39.x86_64 13/130
Verifying : attr-2.5.1-8.fc39.x86_64 14/130
Verifying : cairo-1.18.0-1.fc39.x86_64 15/130
Verifying : capstone-4.0.2-15.fc39.x86_64 16/130
Verifying : cdparanoia-libs-10.2-42.fc39.x86_64 17/130
Verifying : daxctl-libs-78-1.fc39.x86_64 18/130
Verifying : default-fonts-core-sans-4.0-9.fc39.noarch 19/130
Verifying : dnsmasq-2.89-6.fc39.x86_64 20/130
Verifying : e2fsprogs-libs-1.47.0-2.fc39.x86_64 21/130
Verifying : ebtables-legacy-2.0.11-14.fc39.x86_64 22/130
Verifying : fontconfig-2.14.2-5.fc39.x86_64 23/130
Verifying : freetype-2.13.1-2.fc39.x86_64 24/130
Verifying : fribidi-1.0.13-2.fc39.x86_64 25/130
Verifying : fuse3-libs-3.16.1-1.fc39.x86_64 26/130
Verifying : genisoimage-1.1.11-52.fc39.x86_64 27/130
Verifying : gpgme-1.20.0-5.fc39.x86_64 28/130
Verifying : graphene-1.10.6-6.fc39.x86_64 29/130
Verifying : graphite2-1.3.14-12.fc39.x86_64 30/130
Verifying : harfbuzz-8.2.1-2.fc39.x86_64 31/130
Verifying : iptables-legacy-1.8.9-5.fc39.x86_64 32/130
Verifying : iptables-legacy-libs-1.8.9-5.fc39.x86_64 33/130
Verifying : ipxe-roms-qemu-20220210-4.git64113751.fc39.noarch 34/130
Verifying : iso-codes-4.15.0-2.fc39.noarch 35/130
Verifying : libX11-1.8.7-1.fc39.x86_64 36/130
Verifying : libX11-common-1.8.7-1.fc39.noarch 37/130
Verifying : libX11-xcb-1.8.7-1.fc39.x86_64 38/130
Verifying : libXau-1.0.11-3.fc39.x86_64 39/130
Verifying : libXext-1.3.5-3.fc39.x86_64 40/130
Verifying : libXfixes-6.0.0-6.fc39.x86_64 41/130
Verifying : libXft-2.3.8-3.fc39.x86_64 42/130
Verifying : libXi-1.8.1-2.fc39.x86_64 43/130
Verifying : libXrender-0.9.11-3.fc39.x86_64 44/130
Verifying : libXv-1.0.11-19.fc39.x86_64 45/130
Verifying : libXxf86vm-1.1.5-3.fc39.x86_64 46/130
Verifying : libaio-0.3.111-16.fc39.x86_64 47/130
Verifying : libdatrie-0.2.13-7.fc39.x86_64 48/130
Verifying : libepoxy-1.5.10-4.fc39.x86_64 49/130
Verifying : libfdt-1.7.0-4.fc39.x86_64 50/130
Verifying : libglvnd-1:1.7.0-1.fc39.x86_64 51/130
Verifying : libglvnd-egl-1:1.7.0-1.fc39.x86_64 52/130
Verifying : libglvnd-glx-1:1.7.0-1.fc39.x86_64 53/130
Verifying : libgudev-238-2.fc39.x86_64 54/130
Verifying : libjpeg-turbo-2.1.4-3.fc39.x86_64 55/130
Verifying : libmetalink-0.1.3-32.fc39.x86_64 56/130
Verifying : libogg-2:1.3.5-6.fc39.x86_64 57/130
Verifying : libpciaccess-0.16-9.fc39.x86_64 58/130
Verifying : libpmem-1.13.1-1.fc39.x86_64 59/130
Verifying : libpng-2:1.6.37-15.fc39.x86_64 60/130
Verifying : librdmacm-46.0-4.fc39.x86_64 61/130
Verifying : libslirp-4.7.0-4.fc39.x86_64 62/130
Verifying : libthai-0.1.29-6.fc39.x86_64 63/130
Verifying : libtheora-1:1.1.1-34.fc39.x86_64 64/130
Verifying : libunwind-1.7.0-0.2.rc2.fc39.x86_64 65/130
Verifying : libusal-1.1.11-52.fc39.x86_64 66/130
Verifying : libusb1-1.0.26-3.fc39.x86_64 67/130
Verifying : libuv-1:1.46.0-2.fc39.x86_64 68/130
Verifying : libvisual-1:0.4.1-2.fc39.x86_64 69/130
Verifying : libvorbis-1:1.3.7-8.fc39.x86_64 70/130
Verifying : libwayland-client-1.22.0-2.fc39.x86_64 71/130
Verifying : libwayland-cursor-1.22.0-2.fc39.x86_64 72/130
Verifying : libwayland-egl-1.22.0-2.fc39.x86_64 73/130
Verifying : libwayland-server-1.22.0-2.fc39.x86_64 74/130
Verifying : libxcb-1.13.1-12.fc39.x86_64 75/130
Verifying : libxshmfence-1.3-13.fc39.x86_64 76/130
Verifying : llvm16-libs-16.0.6-5.fc39.x86_64 77/130
Verifying : lm_sensors-libs-3.6.0-14.fc39.x86_64 78/130
Verifying : logrotate-3.21.0-4.fc39.x86_64 79/130
Verifying : lxcfs-5.0.4-1.fc39.x86_64 80/130
Verifying : lzo-2.10-9.fc39.x86_64 81/130
Verifying : mesa-dri-drivers-23.2.1-2.fc39.x86_64 82/130
Verifying : mesa-filesystem-23.2.1-2.fc39.x86_64 83/130
Verifying : mesa-libEGL-23.2.1-2.fc39.x86_64 84/130
Verifying : mesa-libGL-23.2.1-2.fc39.x86_64 85/130
Verifying : mesa-libgbm-23.2.1-2.fc39.x86_64 86/130
Verifying : mesa-libglapi-23.2.1-2.fc39.x86_64 87/130
Verifying : mesa-va-drivers-23.2.1-2.fc39.x86_64 88/130
Verifying : ndctl-libs-78-1.fc39.x86_64 89/130
Verifying : numactl-libs-2.0.16-3.fc39.x86_64 90/130
Verifying : opus-1.3.1-13.fc39.x86_64 91/130
Verifying : orc-0.4.33-3.fc39.x86_64 92/130
Verifying : pango-1.51.0-1.fc39.x86_64 93/130
Verifying : pixman-0.42.2-2.fc39.x86_64 94/130
Verifying : raft-0.17.1-2.fc39.x86_64 95/130
Verifying : rpm-plugin-selinux-4.19.0-1.fc39.x86_64 96/130
Verifying : rsync-3.2.7-5.fc39.x86_64 97/130
Verifying : seabios-bin-1.16.2-2.fc39.noarch 98/130
Verifying : seavgabios-bin-1.16.2-2.fc39.noarch 99/130
Verifying : snappy-1.1.10-2.fc39.x86_64 100/130
Verifying : spice-server-0.15.1-3.fc39.x86_64 101/130
Verifying : squashfs-tools-4.6.1-2.fc39.x86_64 102/130
Verifying : usbredir-0.13.0-3.fc39.x86_64 103/130
Verifying : wget-1.21.3-7.fc39.x86_64 104/130
Verifying : xdelta-3.1.0-17.fc39.x86_64 105/130
Verifying : xml-common-0.6.3-61.fc39.noarch 106/130
Verifying : xxhash-libs-0.8.2-1.fc39.x86_64 107/130
Verifying : yajl-2.1.0-22.fc39.x86_64 108/130
Verifying : container-selinux-2:2.224.0-1.fc39.noarch 109/130
Verifying : edk2-ovmf-20230825-25.fc39.noarch 110/130
Verifying : google-noto-fonts-common-20230801-4.fc39.noarch 111/130
Verifying : google-noto-sans-vf-fonts-20230801-4.fc39.noarch 112/130
Verifying : gstreamer1-1.22.7-1.fc39.x86_64 113/130
Verifying : gstreamer1-plugins-base-1.22.7-1.fc39.x86_64 114/130
Verifying : hwdata-0.376-1.fc39.noarch 115/130
Verifying : libdrm-2.4.117-1.fc39.x86_64 116/130
Verifying : liburing-2.5-1.fc39.x86_64 117/130
Verifying : qemu-char-spice-2:8.1.1-1.fc39.x86_64 118/130
Verifying : qemu-common-2:8.1.1-1.fc39.x86_64 119/130
Verifying : qemu-device-display-virtio-gpu-2:8.1.1-1.fc39.x86_64 120/130
Verifying : qemu-device-display-virtio-vga-2:8.1.1-1.fc39.x86_64 121/130
Verifying : qemu-device-usb-redirect-2:8.1.1-1.fc39.x86_64 122/130
Verifying : qemu-img-2:8.1.1-1.fc39.x86_64 123/130
Verifying : qemu-system-x86-core-2:8.1.1-1.fc39.x86_64 124/130
Verifying : qemu-ui-opengl-2:8.1.1-1.fc39.x86_64 125/130
Verifying : qemu-ui-spice-core-2:8.1.1-1.fc39.x86_64 126/130
Verifying : selinux-policy-39.2-1.fc39.noarch 127/130
Verifying : selinux-policy-targeted-39.2-1.fc39.noarch 128/130
Verifying : xen-libs-4.17.2-4.fc39.x86_64 129/130
Verifying : xen-licenses-4.17.2-4.fc39.x86_64 130/130
Installed:
abattis-cantarell-vf-fonts-0.301-10.fc39.noarch acl-2.3.1-8.fc39.x86_64 alsa-lib-1.2.10-3.fc39.x86_64
attr-2.5.1-8.fc39.x86_64 cairo-1.18.0-1.fc39.x86_64 capstone-4.0.2-15.fc39.x86_64
cdparanoia-libs-10.2-42.fc39.x86_64 container-selinux-2:2.224.0-1.fc39.noarch cowsql-1.15.3-0.1.fc39.x86_64
daxctl-libs-78-1.fc39.x86_64 default-fonts-core-sans-4.0-9.fc39.noarch dnsmasq-2.89-6.fc39.x86_64
dqlite-1.16.0-0.1.fc39.x86_64 e2fsprogs-libs-1.47.0-2.fc39.x86_64 ebtables-legacy-2.0.11-14.fc39.x86_64
edk2-ovmf-20230825-25.fc39.noarch fontconfig-2.14.2-5.fc39.x86_64 freetype-2.13.1-2.fc39.x86_64
fribidi-1.0.13-2.fc39.x86_64 fuse3-libs-3.16.1-1.fc39.x86_64 genisoimage-1.1.11-52.fc39.x86_64
google-noto-fonts-common-20230801-4.fc39.noarch google-noto-sans-vf-fonts-20230801-4.fc39.noarch gpgme-1.20.0-5.fc39.x86_64
graphene-1.10.6-6.fc39.x86_64 graphite2-1.3.14-12.fc39.x86_64 gstreamer1-1.22.7-1.fc39.x86_64
gstreamer1-plugins-base-1.22.7-1.fc39.x86_64 harfbuzz-8.2.1-2.fc39.x86_64 hwdata-0.376-1.fc39.noarch
incus-0.2-0.2.fc39.x86_64 incus-client-0.2-0.2.fc39.x86_64 iptables-legacy-1.8.9-5.fc39.x86_64
iptables-legacy-libs-1.8.9-5.fc39.x86_64 ipxe-roms-qemu-20220210-4.git64113751.fc39.noarch iso-codes-4.15.0-2.fc39.noarch
libX11-1.8.7-1.fc39.x86_64 libX11-common-1.8.7-1.fc39.noarch libX11-xcb-1.8.7-1.fc39.x86_64
libXau-1.0.11-3.fc39.x86_64 libXext-1.3.5-3.fc39.x86_64 libXfixes-6.0.0-6.fc39.x86_64
libXft-2.3.8-3.fc39.x86_64 libXi-1.8.1-2.fc39.x86_64 libXrender-0.9.11-3.fc39.x86_64
libXv-1.0.11-19.fc39.x86_64 libXxf86vm-1.1.5-3.fc39.x86_64 libaio-0.3.111-16.fc39.x86_64
libdatrie-0.2.13-7.fc39.x86_64 libdrm-2.4.117-1.fc39.x86_64 libepoxy-1.5.10-4.fc39.x86_64
libfdt-1.7.0-4.fc39.x86_64 libglvnd-1:1.7.0-1.fc39.x86_64 libglvnd-egl-1:1.7.0-1.fc39.x86_64
libglvnd-glx-1:1.7.0-1.fc39.x86_64 libgudev-238-2.fc39.x86_64 libjpeg-turbo-2.1.4-3.fc39.x86_64
libmetalink-0.1.3-32.fc39.x86_64 libogg-2:1.3.5-6.fc39.x86_64 libpciaccess-0.16-9.fc39.x86_64
libpmem-1.13.1-1.fc39.x86_64 libpng-2:1.6.37-15.fc39.x86_64 librdmacm-46.0-4.fc39.x86_64
libslirp-4.7.0-4.fc39.x86_64 libthai-0.1.29-6.fc39.x86_64 libtheora-1:1.1.1-34.fc39.x86_64
libunwind-1.7.0-0.2.rc2.fc39.x86_64 liburing-2.5-1.fc39.x86_64 libusal-1.1.11-52.fc39.x86_64
libusb1-1.0.26-3.fc39.x86_64 libuv-1:1.46.0-2.fc39.x86_64 libvisual-1:0.4.1-2.fc39.x86_64
libvorbis-1:1.3.7-8.fc39.x86_64 libwayland-client-1.22.0-2.fc39.x86_64 libwayland-cursor-1.22.0-2.fc39.x86_64
libwayland-egl-1.22.0-2.fc39.x86_64 libwayland-server-1.22.0-2.fc39.x86_64 libxcb-1.13.1-12.fc39.x86_64
libxshmfence-1.3-13.fc39.x86_64 llvm16-libs-16.0.6-5.fc39.x86_64 lm_sensors-libs-3.6.0-14.fc39.x86_64
logrotate-3.21.0-4.fc39.x86_64 lxc-libs-5.0.3-0.2.fc39.x86_64 lxc-templates-5.0.3-0.2.fc39.x86_64
lxcfs-5.0.4-1.fc39.x86_64 lxd-5.18-0.2.fc39.x86_64 lxd-agent-5.18-0.2.fc39.x86_64
lxd-client-5.18-0.2.fc39.x86_64 lxd-ui-0.3-0.3.fc39.noarch lzo-2.10-9.fc39.x86_64
mesa-dri-drivers-23.2.1-2.fc39.x86_64 mesa-filesystem-23.2.1-2.fc39.x86_64 mesa-libEGL-23.2.1-2.fc39.x86_64
mesa-libGL-23.2.1-2.fc39.x86_64 mesa-libgbm-23.2.1-2.fc39.x86_64 mesa-libglapi-23.2.1-2.fc39.x86_64
mesa-va-drivers-23.2.1-2.fc39.x86_64 ndctl-libs-78-1.fc39.x86_64 numactl-libs-2.0.16-3.fc39.x86_64
opus-1.3.1-13.fc39.x86_64 orc-0.4.33-3.fc39.x86_64 pango-1.51.0-1.fc39.x86_64
pixman-0.42.2-2.fc39.x86_64 qemu-char-spice-2:8.1.1-1.fc39.x86_64 qemu-common-2:8.1.1-1.fc39.x86_64
qemu-device-display-virtio-gpu-2:8.1.1-1.fc39.x86_64 qemu-device-display-virtio-vga-2:8.1.1-1.fc39.x86_64 qemu-device-usb-redirect-2:8.1.1-1.fc39.x86_64
qemu-img-2:8.1.1-1.fc39.x86_64 qemu-system-x86-core-2:8.1.1-1.fc39.x86_64 qemu-ui-opengl-2:8.1.1-1.fc39.x86_64
qemu-ui-spice-core-2:8.1.1-1.fc39.x86_64 raft-0.17.1-2.fc39.x86_64 rpm-plugin-selinux-4.19.0-1.fc39.x86_64
rsync-3.2.7-5.fc39.x86_64 seabios-bin-1.16.2-2.fc39.noarch seavgabios-bin-1.16.2-2.fc39.noarch
selinux-policy-39.2-1.fc39.noarch selinux-policy-targeted-39.2-1.fc39.noarch snappy-1.1.10-2.fc39.x86_64
spice-server-0.15.1-3.fc39.x86_64 squashfs-tools-4.6.1-2.fc39.x86_64 usbredir-0.13.0-3.fc39.x86_64
wget-1.21.3-7.fc39.x86_64 xdelta-3.1.0-17.fc39.x86_64 xen-libs-4.17.2-4.fc39.x86_64
xen-licenses-4.17.2-4.fc39.x86_64 xml-common-0.6.3-61.fc39.noarch xxhash-libs-0.8.2-1.fc39.x86_64
Complete!
[root@f39 ~]# systemctl enable --now lxd incus
Created symlink /etc/systemd/system/multi-user.target.wants/lxd-containers.service â /usr/lib/systemd/system/lxd-containers.service.
Created symlink /etc/systemd/system/sockets.target.wants/lxd.socket â /usr/lib/systemd/system/lxd.socket.
Failed to enable auxiliary unit incus-instances.service, ignoring.
Created symlink /etc/systemd/system/sockets.target.wants/incus.socket â /usr/lib/systemd/system/incus.socket.
[root@f39 ~]# lxd init --auto
Error: Failed to connect to local LXD: Get "http://unix.socket/1.0": dial unix /var/lib/lxd/unix.socket: connect: no such file or directory
[root@f39 ~]#
exit
[root@f39 ~]# lxc launch images:alpine/edge a1
Creating a1
Starting a1
[root@f39 ~]# lxc list
| a1 | RUNNING | 10.135.73.181 (eth0) | fd42:b278:1160:e9fd:216:3eff:fe28:f94 (eth0) | CONTAINER | 0 |
[root@f39 ~]# incus list
If this is your first time running Incus on this machine, you should also run: incus admin init
To start your first container, try: incus launch images:ubuntu/22.04
Or for a virtual machine: incus launch images:ubuntu/22.04 --vm
[root@f39 ~]# /root/lxd-to-incus
==> Detected: COPR package
==> Detected: systemd
=> Connecting to the target server
=> Checking server versions
==> Source version: 5.18
==> Target version: 0.2
=> Validating version compatibility
=> Checking that the source server isn't empty
=> Checking that the target server is empty
=> Validating source server configuration
The migration is now ready to proceed.
At this point, the source server and all its instances will be stopped.
Instances will come back online once the migration is complete.
Proceed with the migration? [default=no]: yes
=> Stopping the source server
=> Stopping the target server
=> Wiping the target server
=> Migrating the data
=> Migrating database
=> Writing database patch
=> Cleaning up target paths
=> Starting the target server
=> Checking the target server
Uninstall the LXD package? [default=no]: yes
=> Uninstalling the source server
| a1 | RUNNING | 10.135.73.181 (eth0) | | CONTAINER | 0 |
curl https://dl.stgraber.org/incus/lxd-to-incus.18366 -o /root/lxd-to-incus && chmod +x /root/lxd-to-incus
To get the binary I used above until the new logic gets merged upstream.
Seems to work.
Any idea if anyone is working on selinux policies for incus? I can toggle selinux to permissive, but will be toggled back to âenforcedâ after a short interval.
I know thereâs been some interest for it recently as I was talking with Neal Gompa about getting an official package into Fedora, but we need someone who actually understands SELinux to do the work.
Iâve been approach by someone who said he could do that work should someone want to pay for it. So I guess weâll see if we have some folks with the needed knowledge who want to tackle this on their own or if we have enough folks who want to sponsor that work to pay for someone to do it.
The basic work to support SELinux labeling exists in liblxc through lxc.selinux.context but all that really does is set the initial context at the time the container starts, it doesnât take care of any of the filesystem labeling or providing labeling rules for the other files used by Incus.
Sadly while Iâm pretty familiar with both AppArmor and Seccomp, I have no real world experience of SELinux so donât feel like Iâm knowledgeable enough to take on this work myself.
Manually fixed the selinux and this package incus-selinux.noarch by ganto on fedora lxc4 copr solves it.
