Hey All,
I am new to the container, lxc, lxd stuff and I am at the end of my knowledge.
I have a fresh setup with a Raspberry PI 4 installed with Ubuntu 22.04 arm64.
So far everything works fine for containers but I can’t get any vm to launch.
~ lxc launch images:ubuntu/focal ubuntu --vm 1 ✘ root@sirius 15:40:47
Creating ubuntu
Error: Failed instance creation: Failed creating instance record: Instance type “virtual-machine” is not supported on this server: vhost_vsock kernel module not loaded
Seems like I am missing a kernel module, but I was not able to find or load it.
Already googled for it but was not able to find any matching problem with solution.
Do you have any idea or tip?
Here are some more information about the installed software versions:
~ uname -r
root@sirius 15:44:17
5.15.0-1005-raspi
~ lxd.check-kernel root@sirius 15:44:20
/snap/lxd/22927/bin/lxc-checkconfig: 69: lxc-start: not found
LXC version
Kernel configuration not found at /proc/config.gz; searching…
Kernel configuration found at /boot/config-5.15.0-1005-raspi
— Namespaces —
Namespaces: enabled
Utsname namespace: enabled
Ipc namespace: enabled
Pid namespace: enabled
User namespace: enabled
newuidmap is not installed
newgidmap is not installed
Network namespace: enabled— Control groups —
Cgroups: enabled
Cgroup namespace: enabledCgroup v1 mount points:
Cgroup v2 mount points:
/sys/fs/cgroupCgroup v1 systemd controller: missing
Cgroup v1 freezer controller: missing
Cgroup ns_cgroup: required
Cgroup device: enabled
Cgroup sched: enabled
Cgroup cpu account: enabled
Cgroup cpuset: enabled— Misc —
Macvlan: enabled, not loaded
Vlan: enabled, not loaded
Bridges: enabled, loaded
Advanced netfilter: enabled, loaded
CONFIG_NETFILTER_XT_TARGET_CHECKSUM: enabled, not loaded
FUSE (for use with lxcfs): enabled, not loaded— Checkpoint/Restore —
checkpoint restore: enabled
CONFIG_FHANDLE: enabled
CONFIG_EVENTFD: enabled
CONFIG_EPOLL: enabled
CONFIG_UNIX_DIAG: enabled
CONFIG_INET_DIAG: enabled
CONFIG_PACKET_DIAG: enabled
CONFIG_NETLINK_DIAG: enabled
File capabilities:Note : Before booting a new kernel, you can check its configuration
usage : CONFIG=/path/to/config /snap/lxd/22927/bin/lxc-checkconfig ~ lsmod | grep vsock
root@sirius 15:44:26
~ lsmod | grep vhost 0|1 ✘ root@sirius 15:44:42
~ lsmod | grep kvm 0|1 ✘ root@sirius 15:44:47
~ ls -la /dev/kvm 0|1 ✘ root@sirius 15:44:59
crw-rw---- 1 root kvm 10, 232 Apr 21 14:14 /dev/kvm
~ snap list lxd root@sirius 15:45:09
lxd 5.0.0-b0287c1 22927 5.0/stable/… canonical✓ -
~ dpkg -l | grep linux-image root@sirius 15:45:25
ii linux-image-5.15.0-1005-raspi 5.15.0-1005.5 arm64 Linux kernel image for version 5.15.0 on ARMv8 SMP
~ dpkg -l | grep lxc root@sirius 15:45:48
ii liblxc-common 1:5.0.0~git2209-g5a7b9ce67-0ubuntu1 arm64 Linux Containers userspace tools (common tools)
ii liblxc-dev 1:5.0.0~git2209-g5a7b9ce67-0ubuntu1 arm64 Linux Containers userspace tools (development)
ii liblxc1 1:5.0.0~git2209-g5a7b9ce67-0ubuntu1 arm64 Linux Containers userspace tools (library)
ii lxcfs 5.0.0-0ubuntu2 arm64 FUSE based filesystem for LXC
Thanks in advance!
