Mix srio-v and bridge
Quick question , but can we mix sr-iov and bridge on the same interface? Or should I better use my dual-nic card to use one interface for haw networking and bridge and the other for SR-IOV ?
On most cards you can use the PF for normal host networking/bridging and then use VFs for guest instances. The main thing to check is whether it can do hardware hairpin as if it can’t, then you may not be able to communicate between host and guest.
