I’m trying to mount my local /home/myuser/development
directory inside an lxd container, at /home/myuser/development
. It actually kind of works, but not completely.
I’m using a custom profile like this
# this is the output of lxc profile show myprofile
raw.idmap: both 1000 1000
user.vendor-data: |
#cloud-config
locale: pt_PT.UTF-8
users:
- name: myuser
lock_passwd: false
shell: /bin/bash
sudo: ['ALL=(ALL) NOPASSWD:ALL']
ssh_import_id: 'gh:mygithubuser
description:
dev_directory:
path: /home/myuser/development
source: /home/myuser/development
Now if I launch a new container with
lxc launch ubuntu:18.04 test -p default -p myprofile
The container starts up and my /home/myuser/development
directory is indeed properly mounted. The problem is that /home/myuser
is owned by root.
# lxc exec test -- /bin/bash
ls -lah /home
drwxr-xr-x 3 root root 4.0K Jan 9 11:26 .
drwxr-xr-x 22 root root 4.0K Dec 6 16:02 ..
drwxr-xr-x 3 root root 4.0K Jan 9 11:26 myuser
This also means that the ssh_import_id
entry of my profile’s cloud-init section fails (since it cannot write to the user’s own home directory).
I do however have ownership of the stuff under the mounted dir:
ls -lah /home/myuser
total 12K
drwxr-xr-x 3 root root 4.0K Jan 9 11:26 ..
drwxrwxr-x 73 myuser myuser 4.0K Jan 9 10:43 development
In order to overcome this I need to manually do a recursive chown in myuser
home dir and then import my github ssh key.
Is it not possible to mount sub-dirs of of a user’s home with lxd?
