Hi all,
I am a user of a container, when I run the following command I receive error:
$ mount –o loop,offset=32256 /dist/m5/sytem/myfile.img /mnt
mount: /mnt: mount failed: Unknown error -1
Any help is appreciated.
Thanks,
Mohammad
Hi all,
Thanks,
Mohammad
Is it a privileged or unprivileged container, is that LXC or LXD?
You’re not providing a lot of context here
This error usually indicates that you don’t have any /dev/loop* devices in your container. But if your container is unprivileged, solving that part of the problem won’t do you any good anyway.
To use loop devices in a container you need:
All of those are very privileged operations which could be used to attack the host and are therefore not allowed by default, so you need quite a bit of tweaking for that. How to do that depends on whether you’re using LXC or LXD.
