I’m currently using LXD containers for running Wine and games inside, thanks to great tutorials from Simos Xenitellis.
However there’s one issue I’m stuck with. I cannot mount a DVD inside the container (ubuntu 18.04 based). The host is also ubuntu 18.04 desktop.
It works if I set the container in privileged mode, but I would like to get access from unprivileged one.
IMO, it should work. But it does not, tried it myself with host 18.04/container 18.04 and host 16.04 / host 18.04 or 16.04 all with snap 3.11 (The OP did not say what is used but from the id used it’s probably snap too)
@XuRuHang, is there a requirement for the container to mount the physical Unix block device? Such as due to some copy-protection restriction in the game? Or, you want to just access some game assets?
@simos
yes exactly I would like to access optical drives in a more convenient way, both for copy protection (despite Wine is not dealing with all types, some are well managed) and also to access assets on the disk required by some games, or even during game installation.
I will dig in the documentation links sent, and will let you know
I’m giving an update on this topic
Well I first tried to use “propagation” option for lxc config device but seems not working in my ubuntu 18.04 (LXD 3.0.3):
Invalid device configuration key for disk: propagation
I got more or less some success by following these steps:
