I need some help. I get the error below regardless if the container is privileged or not. Any advise would be appreciated.
[root@build-arch ~]# distrobuilder build-lxd distrobuilder/doc/examples/centos
mount: /tmp/distrobuilder/iso: mount failed: Operation not permitted.
Error: Error while downloading source: exit status 1
[denis@T450s ~]$ lxc config show build-arch
image.architecture: amd64
image.description: Archlinux current amd64 (20190317_04:18)
image.os: Archlinux
image.release: current
image.serial: “20190317_04:18”
security.privileged: “true”
volatile.base_image: d779d565736c7d365135d36816a8b98e90b3804fd434b9326f55e11d162b741e
volatile.eth0.hwaddr: 00:16:3e:5f:b7:06
volatile.idmap.base: “0”
volatile.idmap.next: ‘’
volatile.last_state.idmap: ‘’
devices: {}
description: “”
