I am trying to mount an image inside a container, but cant because i get a “Operation not permitted.” error.
I already found some topics with similar issues but they always involved loop devices, which I am not sure if I need them.
for example I followed this post but still get the error.
https://github.com/lxc/lxd/issues/2980#issuecomment-283472030
As far as I understand it, the container needs to me privileged and I need to allow mount in app armor. I did both but I still cant mount the images inside a container.
My guess is that I miss/don’t know some basics but I cant figure it out.
Thank you for your help.
lxc config show
image.architecture: amd64
image.description: ubuntu 20.04 LTS amd64 (release) (20210223)
image.label: release
image.os: ubuntu
image.release: focal
image.serial: "20210223"
image.type: squashfs
image.version: "20.04"
raw.apparmor: mount,
security.privileged: "true"
volatile.base_image: b9e93652ee67612114951d910acc4fd6fce0473f8dc0bf562c602e997fcb4857
volatile.eth0.host_name: veth09f823e3
volatile.eth0.hwaddr: 00:16:3e:c1:94:dc
volatile.idmap.base: "0"
volatile.idmap.current: '[]'
volatile.idmap.next: '[]'
volatile.uuid: 4f29e250-8b82-4b30-bda8-2ad61b2f1c55
loop0:
path: /dev/loop0
type: unix-block
loop1:
path: /dev/loop1
type: unix-block
loop2:
path: /dev/loop2
type: unix-block
loop3:
path: /dev/loop3
type: unix-block
loop4:
path: /dev/loop4
type: unix-block
loop5:
path: /dev/loop5
type: unix-block
loop6:
path: /dev/loop6
type: unix-block
loop7:
path: /dev/loop7
type: unix-block
lxc info
core.https_address: '[::]'
core.trust_password: true
api_extensions:
- container_stop_priority
- container_syscall_filtering
- auth_pki
- container_last_used_at
- etag
- patch
- usb_devices
- https_allowed_credentials
- image_compression_algorithm
- directory_manipulation
- container_cpu_time
- storage_zfs_use_refquota
- storage_lvm_mount_options
- network
- profile_usedby
- container_push
- container_exec_recording
- certificate_update
- gpu_devices
- container_image_properties
- migration_progress
- id_map
- network_firewall_filtering
- network_routes
- storage
- file_delete
- file_append
- network_dhcp_expiry
- storage_lvm_vg_rename
- storage_lvm_thinpool_rename
- network_vlan
- image_create_aliases
- container_stateless_copy
- container_only_migration
- storage_zfs_clone_copy
- unix_device_rename
- storage_lvm_use_thinpool
- storage_rsync_bwlimit
- network_vxlan_interface
- storage_btrfs_mount_options
- entity_description
- image_force_refresh
- storage_lvm_lv_resizing
- id_map_base
- file_symlinks
- container_push_target
- network_vlan_physical
- storage_images_delete
- container_edit_metadata
- storage_driver_ceph
- storage_ceph_user_name
- resource_limits
- resources
- kernel_limits
- storage_api_volume_rename
- macaroon_authentication
- network_sriov
- console
- restrict_devlxd
- migration_pre_copy
- infiniband
- maas_network
- devlxd_events
- proxy
- network_dhcp_gateway
- file_get_symlink
- network_leases
- unix_device_hotplug
- operation_description
- clustering
- event_lifecycle
- nvidia_runtime
- container_mount_propagation
- container_backup
- devlxd_images
- proxy_unix
- proxy_udp
- clustering_join
- network_state
- proxy_unix_dac_properties
- container_protection_delete
- unix_priv_drop
- pprof_http
- proxy_haproxy_protocol
- network_hwaddr
- proxy_nat
- network_nat_order
- container_full
- candid_authentication
- backup_compression
- candid_config
- nvidia_runtime_config
- storage_unmapped
- projects
- candid_config_key
- network_vxlan_ttl
- container_incremental_copy
- usb_optional_vendorid
- snapshot_scheduling
- container_copy_project
- clustering_server_address
- container_protection_shift
- snapshot_expiry
- snapshot_expiry_creation
- network_leases_location
- resources_cpu_socket
- resources_gpu
- resources_numa
- kernel_features
- id_map_current
- event_location
- network_nat_address
- container_nic_routes
- rbac
- cluster_internal_copy
- seccomp_notify
- lxc_features
- container_nic_ipvlan
- network_vlan_sriov
- storage_cephfs
- container_nic_ipfilter
- resources_v2
- container_syscall_intercept
- container_disk_shift
- storage_shifted
- resources_infiniband
- daemon_storage
- instances
- image_types
- resources_disk_sata
- clustering_roles
- images_expiry
- resources_network_firmware
- ceph_data_pool_name
- compression_squashfs
- container_raw_mount
- container_nic_routed
- container_disk_ceph
- virtual-machines
- image_profiles
- clustering_architecture
- resources_disk_id
- storage_lvm_stripes
- vm_boot_priority
- unix_hotplug_devices
- api_filtering
- instance_nic_network
- clustering_sizing
- firewall_driver
- projects_limits
- limits_hugepages
- projects_restrictions
- volume_snapshot_scheduling
- trust_ca_certificates
- snapshot_disk_usage
- clustering_edit_roles
- resources_usb_pci
- resources_cpu_threads_numa
- resources_cpu_core_die
- api_os
- container_nic_ipvlan_mode
- resources_system
- images_push_relay
- network_dns_search
- container_nic_routed_limits
- instance_nic_bridged_vlan
- network_state_bond_bridge
- usedby_consistency
- custom_block_volumes
- clustering_failure_domains
- resources_gpu_mdev
- console_vga_type
- projects_limits_disk
- network_type_macvlan
- network_type_sriov
- network_type_ovn
- projects_networks
- custom_volume_backup
- backup_override_name
- storage_rsync_compression
- network_type_physical
- network_ovn_nat
- tpm_device_type
- gpu_mdev
- resources_pci_iommu
- resources_network_usb
- resources_disk_address
- network_ovn_dhcp
- projects_limits_instances
- network_state_vlan
- instance_bulk_state_change
- network_gvrp
- instance_pool_move
- gpu_sriov
- pci_device_type
- storage_volume_state
- network_acl
- migration_stateful
- disk_state_quota
- storage_ceph_features
- projects_compression
- certificate_project
- network_ovn_acl
- projects_images_auto_update
api_status: stable
api_version: "1.0"
auth: trusted
public: false
auth_methods:
- tls
environment:
addresses:
- 192.168.178.10:8443
- '[2001:16b8:c1:5900:b441:a7b4:b279:3e5c]:8443'
- '[2001:16b8:c1:5900:1cb2:7f6c:4ce5:9779]:8443'
- '[2001:16b8:c1:5900:53df:8467:93a9:4331]:8443'
- 192.168.178.30:8443
- '[2001:16b8:c1:5900:b92d:9526:5f3d:9473]:8443'
- '[2001:16b8:c1:5900:3990:1381:5d8b:596d]:8443'
- '[2001:16b8:c1:5900:ac32:4c:619e:2f3a]:8443'
- 10.0.0.1:8443
- 192.168.122.1:8443
- 10.162.52.1:8443
- '[fd42:109c:21bd:8459::1]:8443'
architectures:
- x86_64
- i686
certificate: |
-----BEGIN CERTIFICATE-----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-----END CERTIFICATE-----
certificate_fingerprint: 6d581c3db0ebf50de2eb1740487ad6db55a11e7b8128ca4f56fd253f0d7b274b
driver: lxc | qemu
driver_version: 4.0.6 | 5.2.0
firewall: nftables
kernel: Linux
kernel_architecture: x86_64
kernel_features:
netnsid_getifaddrs: "true"
seccomp_listener: "true"
shiftfs: "false"
uevent_injection: "true"
unpriv_fscaps: "true"
kernel_version: 5.8.0-44-generic
lxc_features:
cgroup2: "true"
devpts_fd: "true"
mount_injection_file: "true"
network_ipvlan: "true"
network_l2proxy: "true"
network_veth_router: "true"
pidfd: "true"
seccomp_notify: "true"
os_name: Ubuntu
os_version: "20.10"
project: default
server: lxd
server_clustered: false
server_name: flaep-U2010
server_pid: 2913
server_version: "4.12"
storage: btrfs
storage_version: 4.15.1
lxc exec priv1 /bin/bash
root@priv1:~# rm out.img
root@priv1:~# truncate -s 10G out.img
root@priv1:~# mkfs.ext4 -F out.img
mke2fs 1.45.5 (07-Jan-2020)
Discarding device blocks: done
Creating filesystem with 2621440 4k blocks and 655360 inodes
Filesystem UUID: 5f28a5e3-9fd7-42cf-8f62-f1edea4860ef
Superblock backups stored on blocks:
32768, 98304, 163840, 229376, 294912, 819200, 884736, 1605632
Allocating group tables: done
Writing inode tables: done
Creating journal (16384 blocks): done
Writing superblocks and filesystem accounting information: done
root@priv1:~# mount out.img /mnt
mount: /mnt: mount failed: Operation not permitted.
root@priv1:~# mount -o loop,ro,noexec,noload out.img /mnt
