and all mounted on the host.
When I try to mount the mounted /tank/Multimedia in a container at (let’s say) /Multimedia, the it only show the contents of Multimedia and not the sub datasets Music, Video and Fotos.
Is there a way to mount such a dataset recursively or do I really have to add them all in the container seperately with lxc config device add…?
Hmmmm maybe I should think about RTFM first for a change. Thanks Stephane! That was exactly what I was looking for.
Triple bookmarked: https://github.com/lxc/lxd/blob/master/doc
