Hi all,
I’ve been using a custom storage volume located on a zfs-backed storage pool as a shared mount on several containers for a while with no issues.
From the docs, it also appears that one should be able to share a custom storage volume with virtual machines. However, I’m getting an odd virtiofsd error when trying to do so.
Steps:
incus create images:debian/trixie debiantest --vm
incus storage volume attach nvme custom/vmvol debiantest /mnt/vmvol
incus start debiantest
This throws:
Error: Failed to start device "custom/vmvol": Failed to setup virtiofsd for device "custom/vmvol": open /var/lib/incus/devices/debiantest/virtio-fs.custom: no such file or directory
Try `incus info --show-log debiantest` for more info
Executing that last command yields:
Description:
Status: STOPPED
Type: virtual-machine
Created: 2025/05/03 15:58 PDT
Last Used: 2025/05/03 16:02 PDT
Error: open /var/log/incus/debiantest/qemu.log: no such file or directory
Both qemu and virtiofsd are installed. The host is running NixOS unstable and runs both containers and VMs fine.
Any ideas what might be going on here? Is mounting custom storage volumes into VMs (rather than containers) supported? Or do only path-based mounts work with VMs / virtiofs / 9p?
Thanks!
