Running pct start
with --debug
option gave me this:
ERROR utils - ../src/lxc/utils.c:safe_mount:1220 - Invalid argument - Failed to mount "/run/user/0" onto "/usr/lib/x86_64-linux-gnu/lxc/rootfs/srv/sockets"
ERROR conf - ../src/lxc/conf.c:mount_entry:2439 - Invalid argument - Failed to mount "/run/user/0" on "/usr/lib/x86_64-linux-gnu/lxc/rootfs/srv/sockets"
Nothing new here.
Looking into safe_mount:1220
errors I found a bunch of people having similar issues on proxmox:
https://forum.proxmox.com/threads/safe_mount-1200-invalid-argument.102687/
Changing lxc.mount.entry: /run/user/[UID] srv/sockets none bind,create=dir
to mp0: /run/user/[UID],mp=/srv/sockets
apparently made it work for me. I have no idea why it wouldn’t work using lxc.mount.entry, but somebody suggested only one mount point per directory can be mounted this way, although I also tried to mount in different directories without success. Another user mentioned overlayfs, which I have no idea what it is but can apparently cause issues.
Still, even though I found a solution to my issue, the cause of the problem is still unknown, so for curiosities sake if it is still helpful you can see my /proc/self/mountifo
below:
23 29 0:21 / /sys rw,nosuid,nodev,noexec,relatime shared:7 - sysfs sysfs rw
24 29 0:22 / /proc rw,relatime shared:13 - proc proc rw
25 29 0:5 / /dev rw,nosuid,relatime shared:2 - devtmpfs udev rw,size=131938332k,nr_inodes=32984583,mode=755,inode64
26 25 0:23 / /dev/pts rw,nosuid,noexec,relatime shared:3 - devpts devpts rw,gid=5,mode=620,ptmxmode=000
27 29 0:24 / /run rw,nosuid,nodev,noexec,relatime shared:5 - tmpfs tmpfs rw,size=26398560k,mode=755,inode64
29 1 253:1 / / rw,relatime shared:1 - ext4 /dev/mapper/pve-root rw,errors=remount-ro
30 23 0:6 / /sys/kernel/security rw,nosuid,nodev,noexec,relatime shared:8 - securityfs securityfs rw
31 25 0:26 / /dev/shm rw,nosuid,nodev shared:4 - tmpfs tmpfs rw,inode64
32 27 0:27 / /run/lock rw,nosuid,nodev,noexec,relatime shared:6 - tmpfs tmpfs rw,size=5120k,inode64
33 23 0:28 / /sys/fs/cgroup rw,nosuid,nodev,noexec,relatime shared:9 - cgroup2 cgroup2 rw
34 23 0:29 / /sys/fs/pstore rw,nosuid,nodev,noexec,relatime shared:10 - pstore pstore rw
35 23 0:30 / /sys/firmware/efi/efivars rw,nosuid,nodev,noexec,relatime shared:11 - efivarfs efivarfs rw
36 23 0:31 / /sys/fs/bpf rw,nosuid,nodev,noexec,relatime shared:12 - bpf bpf rw,mode=700
37 24 0:32 / /proc/sys/fs/binfmt_misc rw,relatime shared:14 - autofs systemd-1 rw,fd=29,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=64812
38 23 0:12 / /sys/kernel/tracing rw,nosuid,nodev,noexec,relatime shared:15 - tracefs tracefs rw
39 23 0:7 / /sys/kernel/debug rw,nosuid,nodev,noexec,relatime shared:16 - debugfs debugfs rw
40 25 0:19 / /dev/mqueue rw,nosuid,nodev,noexec,relatime shared:17 - mqueue mqueue rw
41 25 0:33 / /dev/hugepages rw,relatime shared:18 - hugetlbfs hugetlbfs rw,pagesize=2M
42 23 0:34 / /sys/fs/fuse/connections rw,nosuid,nodev,noexec,relatime shared:19 - fusectl fusectl rw
43 23 0:20 / /sys/kernel/config rw,nosuid,nodev,noexec,relatime shared:20 - configfs configfs rw
66 27 0:35 / /run/credentials/systemd-sysusers.service ro,nosuid,nodev,noexec,relatime shared:21 - ramfs ramfs rw,mode=700
44 24 0:36 / /proc/fs/nfsd rw,relatime shared:22 - nfsd nfsd rw
70 27 0:37 / /run/credentials/systemd-tmpfiles-setup-dev.service ro,nosuid,nodev,noexec,relatime shared:23 - ramfs ramfs rw,mode=700
121 27 0:38 / /run/credentials/systemd-sysctl.service ro,nosuid,nodev,noexec,relatime shared:33 - ramfs ramfs rw,mode=700
96 29 8:34 / /home rw,relatime shared:50 - fuseblk /dev/sdc2 rw,user_id=0,group_id=0,default_permissions,allow_other,blksize=4096
129 27 0:39 / /run/credentials/systemd-tmpfiles-setup.service ro,nosuid,nodev,noexec,relatime shared:52 - ramfs ramfs rw,mode=700
99 37 0:40 / /proc/sys/fs/binfmt_misc rw,nosuid,nodev,noexec,relatime shared:54 - binfmt_misc binfmt_misc rw
148 27 0:41 / /run/rpc_pipefs rw,relatime shared:66 - rpc_pipefs sunrpc rw
381 29 0:46 / /var/lib/lxcfs rw,nosuid,nodev,relatime shared:179 - fuse.lxcfs lxcfs rw,user_id=0,group_id=0,allow_other
799 29 0:54 / /etc/pve rw,nosuid,nodev,relatime shared:393 - fuse /dev/fuse rw,user_id=0,group_id=0,default_permissions,allow_other
548 27 0:52 / /run/user/0 rw,nosuid,nodev,relatime shared:294 - tmpfs tmpfs rw,size=26398556k,nr_inodes=6599639,mode=700,inode64
565 29 0:53 / /root/GDrive rw,nosuid,nodev,relatime shared:303 - fuse.rclone GoogleDrive: rw,user_id=0,group_id=0
531 548 0:50 / /run/user/0/doc rw,nosuid,nodev,relatime shared:262 - fuse.portal portal rw,user_id=0,group_id=0
I don’t mind trying to figure out the cause of this issue if it is useful to the community, even though I already have a solution.
