Hi, I have the following problem:
- I have a (relatively) small SSD where’s my system (Linux Mint 20.2, if it matters) and a (much larger) HD array completely handled by ZFS and mounted on my
/home. - I installed LXD from snap as advised and I created a few containers.
- I actually need just one of them, but as I use it to launch a rather large yocto build it needs a huge amount of disk.
- Compilation died due to lack of space.
- Now I have NO free space on main disk:
mcon@cinderella:/tmp$ df
Filesystem 1K-blocks Used Available Use% Mounted on
udev 16369964 0 16369964 0% /dev
tmpfs 3283676 2516 3281160 1% /run
/dev/sda5 146595780 139084284 0 100% /
tmpfs 16418360 250420 16167940 2% /dev/shm
tmpfs 5120 4 5116 1% /run/lock
tmpfs 16418360 0 16418360 0% /sys/fs/cgroup
/dev/sda1 129039 5034 124005 4% /boot/efi
homez/mcon 5077915776 1713844864 3364070912 34% /home/mcon
homez/mauro 3364088960 18048 3364070912 1% /home/mauro
homez 3780690560 416619648 3364070912 12% /homez
homez/etherpad 3364324608 253696 3364070912 1% /homez/etherpad
/dev/loop1 63360 63360 0 100% /snap/core20/1242
/dev/loop2 74880 74880 0 100% /snap/lxd/22114
/dev/loop0 63488 63488 0 100% /snap/core20/1270
/dev/loop3 43264 43264 0 100% /snap/snapd/14066
/dev/loop4 74752 74752 0 100% /snap/lxd/22147
/dev/loop5 44416 44416 0 100% /snap/snapd/14295
tmpfs 3283672 68 3283604 1% /run/user/1000
tmpfs 1024 0 1024 0% /var/snap/lxd/common/ns
- I killed the container (
lxc stop bionic && lxc delete bionic) and now I got my disk space back (although it seems there has been some “leakage”, but I’m not positive on that).
Question is: how can I setup things so that container data is stored in my zfs array?
I have a relatively large space there (4x3T in RAIDZ2 configuration giving me ~6T usable space; about one half is actually in use) but I’m unsure about how to proceed ans if btrfs can actually live alongside with zfz (I would like to avoid reformatting/repartitioning, if at all possible).
Note: my current setup is:
mcon@cinderella:/tmp$ lxc storage list
| NAME | DRIVER | SOURCE | DESCRIPTION | USED BY |
| default | dir | /var/snap/lxd/common/lxd/storage-pools/default | | 1 |
I see there DRIVER -> dir so I guess all btrf vs zfs debate shouldn’t really matter, right?
What are my options?
Please consider I’m a relative newbie to LXD.
Any advice would be very welcome.
