in a newly setup ubuntu 18.04 without zfs, I started lxd init with all the defaults, now I added a mirror zfs, is there a way to move lxd to zfs? Thanks,
S.
S.
You can setup a new zfs backed storage pool using a dataset from your mirror zfs as the source, you can then use lxc move
with the --storage
option to move containers between storage pools.
I did a lxd init again, but in the end:
Error: Failed to update profile ‘default’: At least one container relies on this profile’s root disk device
