Moving to Incus for users of pylxd
For LXD users who were also using the python module pylxd, I guess there will not be a “pyincus” python module to switch to.
So in order to move to Incus I guess we need to change our python code to either:
I’ve been planning on moving away from pylxd for a while now due to a bug that has been fixed but not made it into a release yet. So moving to Incus will be a good reason to do this.
I would expect pylxd to actually work fine against the Incus API.
You may need to tweak the connection logic a bit to force it to talk to the correct unix socket path when not using the network (TLS) API, but other than that, most of the functions will work just the same.
Incus is going to get features that LXD doesn’t have (and possibly vice-versa), but pylxd has been lagging behind a LOT over recent years, so that’s unlikely to really be visible.
Upstream Incus folks don’t have a lot of python knowledge so we’re not likely to create a pyincus of our own. However if someone wants to start such a project and maintain it, we’d happily host it.
Note that any such project would probably want to start from scratch as the pylxd design seems quite odd and hard to keep up to date with server-side changes. A lot of the design dates back from its integration with OpenStack which isn’t a thing anymore and so should allow for a more modern and easier to use module be developed.
This is good to know, I’ll try it in the short term.
But eventually I think I’ll replace it with a thin wrapper around the Incus REST API using python requests. If I come up with anything useful I’ll share it.
As there is a rest-api.yml, which is supposed to follow openapi specifications, it can be used to auto-generate clients. In that case, everyone can just generate it for their intended language.
Currently, it seem like the specification isn’t working too well, it’s not passing the openapi validators. Maybe that could be a starting point.
We generate the swagger metadata as a way to get API documentation.
It’s very unlikely to work to generate a functional client due to our API doing a fair few things that swagger cannot represent (mix of REST & websocket, TLS based authentication, …).
I tried it today, I use a default pylxd.client.Client() in my python code and initially got a unix socket exception:
pylxd.exceptions.ClientConnectionFailed: ('Connection aborted.', FileNotFoundError(2, 'No such file or directory'))
Had a quick peek at the code and worked out by default it uses /var/lib/lxd/unix.socket unless the LXD_DIR environment variable is set, in which case it will use $LXD_DIR/unix.socket. So I set the environment variable in the shell as follows:
export LXD_DIR=/var/lib/incus
Then ran the python again and hit the following exception at the point where it is creating a new instance using an image:
conftest.py:305: in new_container
    container = client.containers.create(config, wait=True)
../../../../.local/share/virtualenvs/test.1-hxo-P72l/lib/python3.10/site-packages/pylxd/models/instance.py:323: in create
    response = client.api[cls._endpoint].post(json=config, target=target)
../../../../.local/share/virtualenvs/test.1-hxo-P72l/lib/python3.10/site-packages/pylxd/client.py:216: in post
    self._assert_response(response, allowed_status_codes=(200, 201, 202))
_ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _
self = <pylxd.client._APINode object at 0x7f9a039801c0>, response = <Response [404]>, allowed_status_codes = (200, 201, 202)
stream = False, is_api = True
    def _assert_response(
        self, response, allowed_status_codes=(200,), stream=False, is_api=True
        """Assert properties of the response.
        LXD's API clearly defines specific responses. If the API
        response is something unexpected (i.e. an error), then
        we need to raise an exception and have the call points
        handle the errors or just let the issue be raised to the
        user.
        if response.status_code not in allowed_status_codes:
            if response.status_code == 404:
>               raise exceptions.NotFound(response)
E               pylxd.exceptions.NotFound: not found
../../../../.local/share/virtualenvs/test.1-hxo-P72l/lib/python3.10/site-packages/pylxd/client.py:144: NotFound
Ran again with the debugger I see what was in the request attached to this 404 response:
(Pdb) print(response.request)
<PreparedRequest [POST]>
(Pdb) print(response.request.url)
http+unix://%2Fvar%2Flib%2Fincus%2Funix.socket/1.0/containers
(Pdb) print(response.request.path_url)
/1.0/containers
Pdb) print(response.request.headers)
{'User-Agent': 'python-requests/2.31.0', 'Accept-Encoding': 'gzip, deflate, br', 'Accept': '*/*', 'Connection': 'keep-alive', 'Content-Length': '87', 'Content-Type': 'application/json'}
(Pdb) print(response.request.body)
b'{"name": "psp-dbmaster", "source": {"type": "image", "alias": "centos/7/psp/dbmaster"}}'
(Pdb)
Looking at the Incus API spec there is no method named containers. The LXD API spec also does not contain a containers method. I’m assuming that in LXD this method was renamed from containers to instances (see Incus API POST instances) and in LXD there is a redirect, but in Incus there is not?
On a machine with both incus and lxd installed I can run the following curl commands:
curl --unix-socket /var/lib/lxd/unix.socket http://localhost/1.0/containers
200
curl --unix-socket /var/lib/lxd/unix.socket http://localhost/1.0/instances
200
curl --unix-socket /var/lib/incus/unix.socket http://localhost/1.0/containers
404
curl --unix-socket /var/lib/incus/unix.socket http://localhost/1.0/instances
200
So I will need to patch pylxd client.py to replace the containers method name with instances. To be continued…
Oh, so that’s bad because even in LXD those URLs are deprecated :slight_smile:
A patch to make pylxd use /instances/ instead shouldn’t be controversial at all as it’s the right thing to do even for LXD.
I have it working now. In my code (which I wrote about 5 years ago) I was using pylxd.models.Container instead of pylxd.models.Instance. After correcting my code to use the latter everywhere, it’s now all working.
For example I changed things like this:
-    if(client.containers.exists(name)):
-        container = client.containers.get(name)
+    if(client.instances.exists(name)):
+        container = client.instances.get(name)
The advice to use instances changed in the pylxd docs progressively between 2.2.11, 2.3.0 and 2.3.1.
In summary, as long as you are using instances instead of containers in your python code and also setting the LXD_DIR environment variable to /var/lib/incus, it all works fine :slight_smile:
pylxd does indeed work with pylxd 2.3.4 with lxd and incus. My main issue is I can’t get Incus to work with Amazon Linux 2023.
LXD still works via a private version of snapd
I still use pylxd for all my project work because it saves time when I’m dealing with lxd.
I see no sign of anyone producing an alternative version… If you know of one please give me a link.
I guess the RESTAPI isn’t to that much more work… But I would end up reinventing the wheel so to speak so I’ll stick with pylxd for the moment…
Ok, so I’ve written 2 sets of tooling for this:
The example client is a full OOP client wrapper around pyincusd. I have not included it in pyincusd or shipped it as its own package as the maintenance requirements are higher. pyincusd is significantly easier to maintain, because it is just CI/CD. It calls an OpenAPI client generator nightly when it detects a new version of incusd that publishes the new client to pypi. For OpenAPI generator “misbehaviors,” there is a patches/ directory for opt-in patches to be applied on top of the generated client that you can opt in or out of at runtime at your pleasure.
The runtime-toggleable monkey patches make maintenance extremely low effort, because that reduces the maintenance surface to just one-off PRs against the patches/ directory and the main PRs against .github/workflows.
Moving them into an org account
Hey,
Nice work! You might be interested into a script of mine to setup a nested incus for automated tests of incusd-client: scripts/setup-nested-incus.sh · main · René Jochum / incus-compose · GitLab
Please let me know if so :slight_smile:
Kind regards,
René
