Multipe macvlan Ips for nested docker containers
i’m not sure how i should fix this. I used to have multiple macvlan (tagged) networks. On each network i had multiple containers running, having different ips.
from my old docker-compose:
version: "3"
services:
  a:
    networks:
      vpnvlan:
        ipv4_address: 192.168.20.150
  b:
    networks:
      vpnvlan:
        ipv4_address: 192.168.20.160
networks:
  vpnvlan:
    driver: macvlan
    driver_opts:
      parent: eth0.1020
    ipam:
        - subnet: 192.168.20.0/24
          gateway: 192.168.20.1
Since i wanted to try lxd, i got stuck.
  1. It seems that i can create macvlan IF and attach it to an lxc container… it even gets the ip.
    • but then how do i pass the proper parent to docker, such that it can take or create the proper
      network and then assign correctly the ips?
      using it as above does not work
  2. i had an idea to create multiple macvlan ifs as profile and attach it to an lxc container and the assign it 1 by 1 to docker containers, but somehow this feels a bit klunky in comparison
should i then use this profile (which works for dhcp) and create multiple devices?
config: {}
    nictype: macvlan
    parent: eno1
    vlan: "1020"
- /1.0/instances/ubuntu-container
  1. How do i set a static IP of a macvlan IF for the lxc container, using ip command inside the container did not work unfortunately, although dhcp works perfectly
I think i solved the Static ip problem of a lxc container:
“/etc/netplan/50-cloud-init.yaml”
ethernets:
dhcp4: no
dhcp6: no
addresses:
- 192.168.20.111/24
gateway4: 192.168.20.1
nameservers:
addresses:
- 192.168.20.1
- 8.8.8.8
and then:
netplan --debug apply
works like a charm (found here Lxd + Netplan + Static IP's in same subnet HOW-TO - #7 by sdurnov)
I think a fresh day solved my multiday problem.
i had a wrong docker network parent in lxd world.
I had before:
  vpnvlan:
    driver: macvlan
    driver_opts:
      parent: **eth0.1020**
which worked in plain non nested docker
now i changed it to eth0 without the vlan tag:
  vpnvlan:
    driver: macvlan
    driver_opts:
      parent: **eth0**
and it works like a charm :slight_smile: IPs are also allocated correctly
so to reitarate.
my macvlan profile
config: {}
    nictype: macvlan
    parent: eno1
    vlan: "1020"
and docker-compose:
version: "3"
services:
  a:
    networks:
      vpnvlan:
  b:
    networks:
      vpnvlan:
networks:
  vpnvlan:
    driver: macvlan
    driver_opts:
      parent: eth0
    ipam:
