I have two LXD containers:
- the first, called “front”, has two network interfaces: one internal (host’s bridge lxdbr0) and a public ip (host’s bridge br0)
- the second, called “mysql”, with only an internal IP (host’s bridge lxdbr0)
I want to forward port 3306 from the public facing interface of “front” to the internal facing interface of “mysql” container. It doesn’t work as expected. I can connect from “front” to “mysql” on port 3306, but not from outside/public network.
Front’s config:
root@front:~# cat /etc/defaukt/ufw
DEFAULT_FORWARD_POLICY="ACCEPT"
root@front:~# ufw status verbose
Status: active
Logging: on (low)
Default: deny (incoming), allow (outgoing), allow (routed)
New profiles: skip
To Action From
443/tcp ALLOW IN Anywhere
80/tcp ALLOW IN Anywhere
3306/tcp ALLOW IN Anywhere
443/tcp (v6) ALLOW IN Anywhere (v6)
80/tcp (v6) ALLOW IN Anywhere (v6)
3306/tcp (v6) ALLOW IN Anywhere (v6)
root@front:~# sysctl net/ipv4/ip_forward
net.ipv4.ip_forward = 1
root@front:~# sysctl net/ipv6/conf/default/forwarding
net.ipv6.conf.default.forwarding = 1
root@front:~# sysctl net/ipv6/conf/all/forwarding
net.ipv6.conf.all.forwarding = 1
root@front:~# cat /etc/ufw/before.rules
*nat
:PREROUTING ACCEPT [0:0]
-F
-A PREROUTING -i eth0 -p tcp --dport 3306 -j DNAT --to-destination 10.2.249.204:3306
root@front:~# iptables -t nat -L -n -v
Chain PREROUTING (policy ACCEPT 536 packets, 53325 bytes)
pkts bytes target prot opt in out source destination
4 240 DNAT tcp -- eth0 * 0.0.0.0/0 0.0.0.0/0 tcp dpt:3306 to:10.2.249.204:3306
Chain INPUT (policy ACCEPT 77 packets, 4278 bytes)
Chain OUTPUT (policy ACCEPT 4615 packets, 277K bytes)
Chain POSTROUTING (policy ACCEPT 4619 packets, 278K bytes)
root@front:~# ip a
inet6 ::1/128 scope host
31: eth0@if32: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
link/ether 00:16:3e:6a:74:9c brd ff:ff:ff:ff:ff:ff link-netnsid 0
inet [redacted]/24 brd 202.22.232.255 scope global eth0
inet6 [redacted]/64 scope global
inet6 fe80::216:3eff:fe6a:749c/64 scope link
33: eth1@if34: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
link/ether 00:16:3e:4e:d0:c2 brd ff:ff:ff:ff:ff:ff link-netnsid 0
inet 10.2.249.2/24 brd 10.2.249.255 scope global dynamic eth1
valid_lft 3445sec preferred_lft 3445sec
inet6 fe80::216:3eff:fe4e:d0c2/64 scope link
