I created a vm with ISO downloaded from github as boot media ,tpm device already added .
but got error below :
unable to begin install without seed configuration
thanks !
thanks !
thanks , I will try . but what is the purpose of iso from github ,seems it cannot be used to install directly .
The releases on Github are all outdated and will be deleted soon.
We use Github Actions to build the artifacts which then get pulled, validated, signed and are published through our image servers.
Hi, getting the same error here. Used the online customizer and downloaded the image (3,2GB). It boots but with the same error. Redid the process four times, all with same result. Hp Elitedesk mini. 10th gen i5, 32GB ram. Not sure where I am going wrong. I’m so excited to play with this
You’re responding to a pretty old topic about an issue that happened from directly downloading the .iso without going through the customizer.
Could you open another topic describing your exact issue with the exact error (screenshot/photo ideally) of what you’re getting?
