lxc instance in host gets GPU and acceleration in headless xrdp works.
But the nested lxc doesn’t accept GPU from its parent lxc instance:
Error: Failed preparing container for start: Failed to start device “gpu0”: The “major” property may not be set when adding a device to a nested container
I set lxc config set docker security.nesting=true on host’s instance ‘inst1’ and on ‘docker’ inside lxc instance.
In Lxc instance ‘inst1’:
root@inst1:~# ls -all /dev/dri
total 0
drwxr-xr-x 2 root root 80 Mar 29 13:30 .
drwxr-xr-x 10 root root 540 Mar 29 13:32 …
crw-rw---- 1 root root 226, 0 Mar 29 13:30 card0
crw-rw---- 1 root root 226, 128 Mar 29 13:30 renderD128
root@inst1:~# lxc info --resources
GPU:
NUMA node: 0
Vendor: VMware (15ad)
Product: SVGA II Adapter (0405)
PCI address: 0000:00:0f.0
Driver: vmwgfx (2.15.0.0)
DRM:
Card: card0 (226:0)
Control: controlD64 (226:0)
Render: renderD128 (226:128)
root@inst1:~# lxc list
| docker | RUNNING | 172.17.0.1 (docker0) | | CONTAINER | 0 |
| | | 10.25.151.160 (eth0) | | | |
root@inst1:~# lxc stop docker
root@inst1:~# lxc config device add docker gpu0 gpu
Device gpu0 added to docker
root@inst1:~# lxc start docker
Try lxc info --show-log docker for more info
root@inst1:~#
/dev/dri in nested docker:
root@inst1:~# docker run --device=/dev/dri -it dockernested /bin/bash
root@324e45f33efc:/# ls -all /dev/dri
total 0
drwxr-xr-x 2 root root 80 Mar 29 21:05 .
drwxr-xr-x 6 root root 380 Mar 29 21:05 …
