Netplan apply hangs in Ubuntu 26.04 LXC (Incus/macvlan), works in 24.04
I am running Ubuntu cloud images in LXC containers in my private lab environment. The setup uses macvlan networking provided by Incus. The same configuration works correctly on Ubuntu 24.04, but on Ubuntu 26.04 the networking setup breaks due to netplan apply hanging during execution.
incus network list
|  NAME   |   TYPE   | MANAGED | IPV4 | IPV6 | DESCRIPTION | USED BY |  STATE  |
| eno1    | physical | NO      |      |      |             | 2       |         |
| eno2    | physical | NO      |      |      |             | 8       |         |
| vlsrv   | macvlan  | YES     |      |      |             | 1       | CREATED |
cloud-init.network-config.yaml
version: 2
ethernets:
    dhcp4: no
    dhcp6: no
    addresses:
      - 10.0.65.21/24
    routes:
      - to: default
        via: 10.0.65.1
    nameservers:
      addresses:
        - 10.0.65.1
Ubuntu 24.04 cloud image → :white_check_mark: working
incus init images:ubuntu/24.04/cloud cfg01 -n vlsrv
Creating cfg01
incus config set cfg01 cloud-init.user-data - < cloud-init.user-data.yaml
incus config set cfg01 cloud-init.network-config - < cloud-init.network-config.yaml
incus start cfg01
incus exec  cfg01 -- bash
root@cfg01:~# ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 ...
8: eth0@if2: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
    link/ether 10:66:6a:9e:85:b2 brd ff:ff:ff:ff:ff:ff link-netnsid 0
    inet 10.0.65.21/24 brd 10.0.65.255 scope global eth0
    inet6 fe80::1266:6aff:fe9e:85b2/64 scope link
Ubuntu 26.04 cloud image → :cross_mark: broken
incus init images:ubuntu/26.04/cloud cfg01 -n vlsrv
Creating cfg01
incus start cfg01
ip a
6: eth0@if2: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
    link/ether 10:66:6a:57:f4:c9 brd ff:ff:ff:ff:ff:ff link-netnsid 0
    inet6 fe80::1266:6aff:fe57:f4c9/64 scope link proto kernel_ll
Now the problems begin. I tried to apply netplan manually, but it gets stuck:
netplan --debug apply
DEBUG:command configure: running ['/usr/libexec/netplan/configure']
** (configure:249): DEBUG: 10:32:13.666: starting new processing pass
** (configure:249): DEBUG: 10:32:13.666: eth0: adding new route
** (configure:249): DEBUG: 10:32:13.666: We have some netdefs, pass them through a final round of validation
** (configure:249): DEBUG: 10:32:13.666: eth0: setting default backend to 1
** (configure:249): DEBUG: 10:32:13.666: Configuration is valid
** (configure:249): DEBUG: 10:32:13.667: using ovs-vsctl at /usr/bin/ovs-vsctl
** (configure:249): DEBUG: 10:32:13.667: Generating output files..
** (configure:249): DEBUG: 10:32:13.667: Open vSwitch: definition eth0 is not for us (backend 1)
** (configure:249): DEBUG: 10:32:13.667: NetworkManager: definition eth0 is not for us (backend 1)
DEBUG:executing Netplan systemd-generator via daemon-reload
DEBUG:netplan generated networkd configuration changed, reloading networkd
DEBUG:Cannot call Open vSwitch: Cannot apply Open vSwitch cleanup: ovs-vsctl is 'not-found'
After this, netplan apply never completes.
If I set the IP manually, everything works:
ip addr add 10.0.65.21/24 dev eth0
ip route add default via 10.0.65.1
    inet 127.0.0.1/8
6: eth0@if2: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 ...
    inet 10.0.65.21/24
Connectivity works:
ping 10.0.65.1
64 bytes from 10.0.65.1: icmp_seq=1 ttl=255 time=0.406 ms
64 bytes from 10.0.65.1: icmp_seq=2 ttl=255 time=0.199 ms
Observations
  1. No Open vSwitch is installed or configured in the container
  2. No OVS references exist in netplan configuration
Is there anything broken in Ubuntu 26.04 regarding netplan in LXC containers, or am I missing something in the setup?
Same issue and resolution as I found here I expect.
Yes, that resolved the problem.
I’ll move to Incus OS later on. The current server doesn’t support Secure Boot, but the new one will, so there’ll be no more hassle with Ubuntu.
Thanks for the solution and for pointing me in the right direction!
What does sysctl kernel.apparmor_restrict_unprivileged_unconfined show?
Recent Zabbly-packaged versions of incus include a fix for this.
I installed the default package from Ubuntu 26.04, so it was Incus 6.0.5. I had to adjust some physical disks on my lab server, so I reinstalled Incus from the Zabbly repo with Incus 7 LTS and yes, you are correct, there the setting is configured automatically:
kernel.apparmor_restrict_unprivileged_unconfined = 0
