Network and agent constantly crashing in debian VM
Hi!
I have a problem that the network in my vm constantly crash when its receving data.
Need some help to find the issue. Everything is updated to the latest version.
This started today. The Vm has worked fine since startup a few weeks ago.
Host is ubuntu 24.04
Status on the vm becomes “error”. I get kicked out if I exec because the agent gives “Error: Failed to connect to the agent”. After a while it works again but the this happens with just a few minutes apart.
Agent error “Error: read vsock vm(4294967295):572670636->vm(2883693065):8443: connection reset by peer”
When trying to exec
config: image.architecture: amd64 image.description: Debian bookworm amd64 (20241007_05:24) image.os: Debian image.release: bookworm image.serial: “20241007_05:24” image.type: disk-kvm.img
image.variant: default
limits.cpu: “8”
limits.memory: 16GiB
security.idmap.isolated: “1”
volatile.base_image: 37145c4210794728f3a16c36e2d4c6cd1a943ed9d1983eafb7a8457b80578e52
volatile.cloud-init.instance-id: 9a46d7b4-3818-48b8-82df-43d16bab4390
volatile.eth0.hwaddr: 00:16:3e:28:44:85
volatile.last_state.ready: “false”
volatile.uuid: 1be9d8d5-27e1-458e-afd1-bf31abbfcb8c
volatile.uuid.generation: 1be9d8d5-27e1-458e-afd1-bf31abbfcb8c
volatile.vsock_id: “2883693065”
Info:
Operating System: OS: Debian GNU/Linux OS Version: 12 (bookworm) Kernel Version: 6.1.0-28-amd64 Hostname: vm FQDN: localhost
Update: ive also noticed that a container loses its connection when this happens. Same vlan.
