Hello, beginner to LXD here, so I am sorry in advance if this question is stupid.
I am trying to find out, how is the network bandwidth limitation implemented in relationship with cgroups.
For example, when I limit memory via
lxc profile set default limits.memory 512MB
I can find the corresponding value in
/sys/fs/cgroup/memory/lxc/container_name/memory.limit_in_bytes
But when I limit the network bandwidth via
lxc profile device set default eth0 limits.ingress/egress 100Mbit
I can’t find the correct cgroup file anywhere. So does the implementation use something else than cgroups? (Cannot find it anywhere in net_cls nor net_prio)
Thank you in advance.
