On Gentoo ~amd64 with lxd-3.7, I’m seeing an error with network interface initialization when launching or init/starting containers. I’m not clear whether the eth0
referred to in the log output is container eth0
or host eth0
With a freshly lxd init’d instance, preseed output as follows:
config: {}
networks:
- config:
ipv4.address: auto
ipv6.address: auto
managed: false
type: ""
storage_pools:
- config:
source: /dev/sda2
driver: zfs
- config: {}
nictype: bridged
parent: lxdbr0
pool: lxd
cluster: null
Instances fail as follows:
$ lxc launch bionic b001
Creating b001
Starting b001
Error: Failed to run: /usr/sbin/lxd forkstart b001 /var/lib/lxd/containers /var/log/lxd/b001/lxc.conf:
Try `lxc info --show-log local:b001` for more info
$ lxc info --show-log local:b001
Remote: unix://
Created: 2018/12/10 07:19 UTC
Status: Stopped
Type: persistent
Profiles: default
Log:
lxc b001 20181210071924.622 ERROR conf - conf.c:run_buffer:335 - Script exited with status 32
lxc b001 20181210071924.622 ERROR conf - conf.c:lxc_setup:3589 - Failed to run mount hooks
lxc b001 20181210071924.622 ERROR start - start.c:do_start:1263 - Failed to setup container "b001"
lxc b001 20181210071924.623 ERROR sync - sync.c:__sync_wait:62 - An error occurred in another process (expected sequence number 5)
lxc b001 20181210071924.624 WARN network - network.c:lxc_delete_network_priv:2589 - Operation not permitted - Failed to remove interface "eth0" with index 14
lxc b001 20181210071924.624 ERROR lxccontainer - lxccontainer.c:wait_on_daemonized_start:842 - Received container state "ABORTING" instead of "RUNNING"
lxc b001 20181210071924.628 ERROR start - start.c:__lxc_start:1939 - Failed to spawn container "b001"
lxc b001 20181210071924.694 ERROR utils - utils.c:recursive_destroy:1727 - No such file or directory - Failed to open dir "/sys/fs/cgroup/openrc//lxc/b001"
lxc b001 20181210071924.694 WARN cgfsng - cgroups/cgfsng.c:cgroup_rmdir:1058 - Failed to destroy "/sys/fs/cgroup/openrc//lxc/b001"
lxc 20181210071924.715 WARN commands - commands.c:lxc_cmd_rsp_recv:132 - Connection reset by peer - Failed to receive response for command "get_state"
Behavior is the same with all distro images I’ve tried bionic, xenial, alpine, fedora etc.
The Gentoo shows a normal bridge instance:
$ sudo brctl show
bridge name bridge id STP enabled interfaces
lxdbr0 8000.000000000000 no
On the host Gentoo host, eth0 is present but down. Wireless and wired connection as managed by connman (using iwd for wireless)
$ ip link show
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN mode DEFAULT group default qlen 1000
2: wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP mode DORMANT group default qlen 1000
3: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN mode DEFAULT group default qlen 1000
11: lxdbr0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN mode DEFAULT group default qlen 1000
My sudo-enabled user is in group lxd. No change if I run the above as sudo.
Thanks for any suggestions on troubleshooting steps.
