Facing this issue from some time on lxd containers are running for long period.
| lxc-e0f8a96e-0258-4c90-927c-30784bbee6e1 | RUNNING | 172.17.0.1 (docker0) | | CONTAINER | 0 |
I had docker container running inside this lxd container and lxc list output above only shows docker IP right now. But earlier it had a lxd bridge as well.
If I check lxd profile it still shows the eth0 device in it
nictype: bridged
parent: qbnet9ba82616fa
I have in past created a new network and then replaced it with the previous one in profile but it doesn’t work always. Sometimes I need to reboot. I need a reliable experience here. Not sure what’s wrong with this configuration…
