Network Forward Ports maximum 500 per network - Possible Bug?
Hello All
It appears that there is a max limit on the amount of Network Forward ports you can add per parent network.
So far i can only get a max of 500 network forward ports added in total, regardless of if theyre in different network forwards, seems to be a max of 500 for the whole network.
The error i get is:
                ip saddr 10.204.37.148 ip daddr 10.204.37.148 tcp dport 11499 masquerade
: fork/exec /snap/lxd/23537/bin/nft: argument list too long
I did a bit of looking an some places suggest setting a higher ulimit -n to allow argument lists to be larger, but as lxd is snap packaged, i dont think i can set this and have it apply inside snap.
Below is an example of what i was trying to do with the above output.
hostip=$1
instanceip=$2
network="example"
   echo "Recreating network forward"
   lxc network forward delete $network $hostip
   lxc network forward create $network $hostip
   echo "Adding port entry for ssh"
   lxc network forward port add $network $hostip tcp 10022 $instanceip 22
   echo "Adding port entry for server ports"
   lxc network forward port add $network $hostip tcp 11000-11499 $instanceip
   lxc network forward port add $network $hostip tcp 11500-11999 $instanceip
   lxc network forward port add $network $hostip tcp 12000-12499 $instanceip
   lxc network forward port add $network $hostip tcp 12500-12999 $instanceip
Perhaps i am expecting too much of network forwards, or is there something known that might help?
Thanks for your efforts!
Matt
We should be able to use the -f - to nft command and pass the config in via stdin.
Please can you open an issue here Issues · lxc/lxd · GitHub to track it.
Hello @matt_neteo, did you open the tracking issue? Thanks
This should fix it
https://github.com/lxc/lxd/pull/10902
