I just upgraded from Bionic to Cosmic. LXD and content migrated correctly. Trouble started when I tried to clean up and start again as a clean state.
Seems like LXD network is not working correctly.
No IP assigned to containers.
IPv4 CIDR assigned during
LXD initwithout any error. Dnsmasq for lxdbr0 not running. -
No content in lxdbr0 folder.
Any thoughts what I may be missing? I have added and removed LXD (3.0.2, 3.6) and re-created init/configuration quite a few times. Sure thing, I am missing something very small.
a@cloud:~$ sudo ls -al /var/snap/lxd/common/lxd/networks/lxdbr0
total 16
drwx--x--x 3 root root 4096 Oct 23 21:39 .
drwx--x--x 3 root root 4096 Oct 23 21:13 ..
drwxr-xr-x 2 root root 4096 Oct 23 21:13 dnsmasq.hosts
-rw-r--r-- 1 root root 0 Oct 24 00:57 dnsmasq.leases
-rw-r--r-- 1 root root 1 Oct 24 01:00 dnsmasq.raw
a@cloud:~$ sudo ls -al /var/snap/lxd/common/lxd/networks/lxdbr0/dnsmasq.hosts
total 8
drwxr-xr-x 2 root root 4096 Oct 23 21:13 .
drwx--x--x 3 root root 4096 Oct 23 21:39 ..
a@cloud:~$ sudo cat /var/snap/lxd/common/lxd/networks/lxdbr0/dnsmasq.leases`
a@cloud:~$ sudo cat /var/snap/lxd/common/lxd/networks/lxdbr0/dnsmasq.raw`
a@cloud:~$ ps ax | grep lxdbr0
3864 pts/0 S+ 0:00 grep --color=auto lxdbr0
a@cloud:~$ ps ax | grep dnsmasq
2995 ? S 0:00 dnsmasq -u lxc-dnsmasq --strict-order --bind-interfaces --pid-file=/run/lxc/dnsmasq.pid --listen-address 10.0.3.1 --dhcp-range 10.0.3.2,10.0.3.254 --dhcp-lease-max=253 --dhcp-no-override --except-interface=lo --interface=lxcbr0 --dhcp-leasefile=/var/lib/misc/dnsmasq.lxcbr0.leases --dhcp-authoritative
3772 ? S 0:00 /usr/sbin/dnsmasq --conf-file=/var/lib/libvirt/dnsmasq/default.conf --leasefile-ro --dhcp-script=/usr/lib/libvirt/libvirt_leaseshelper
3773 ? S 0:00 /usr/sbin/dnsmasq --conf-file=/var/lib/libvirt/dnsmasq/default.conf --leasefile-ro --dhcp-script=/usr/lib/libvirt/libvirt_leaseshelper
3871 pts/0 S+ 0:00 grep --color=auto dnsmasq
a@cloud:~$ lxc network show lxdbr0
ipv4.address: 10.100.100.1/24
ipv4.nat: "true"
ipv6.address: none
type: bridge
- /1.0/containers/test
managed: true
status: Created
locations:
- none
