Network not working on LXD container
Hi i create lxd container, but child os do not have network.
my actions :
#install LXD
sudo snap install lxd
# init lxd
lxd init (all settings set by default)
#init child OS
lxc launch ubuntu:20.04 nextCloud
lxc exec  nextCloud bash
#check network on child os
ping 8.8.8.8
ping: connect: Network is unreachable
My child os network status :
root@nextCloud:~# ip a
    inet6 ::1/128 scope host
5: eth0@if6: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
    link/ether 00:16:3e:0f:26:60 brd ff:ff:ff:ff:ff:ff link-netnsid 0
    inet6 fe80::216:3eff:fe0f:2660/64 scope link
root@nextCloud:~# ip r
root@nextCloud:~#
My parent os network status:
enp6s0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 192.168.100.2  netmask 255.255.255.0  broadcast 192.168.100.255
        inet6 fe80::1a67:b0ff:fe3e:8104  prefixlen 64  scopeid 0x20<link>
        ether 18:67:b0:3e:81:04  txqueuelen 1000  (Ethernet)
        RX packets 12897  bytes 2826549 (2.8 MB)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 7335  bytes 669325 (669.3 KB)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
        inet 127.0.0.1  netmask 255.0.0.0
        inet6 ::1  prefixlen 128  scopeid 0x10<host>
        loop  txqueuelen 1000  (Local Loopback)
        RX packets 264  bytes 20838 (20.8 KB)
        TX packets 264  bytes 20838 (20.8 KB)
lxdbr0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 10.99.15.1  netmask 255.255.255.0  broadcast 0.0.0.0
        inet6 fe80::60a5:40ff:fe8a:42ef  prefixlen 64  scopeid 0x20<link>
        inet6 fd42:dbee:4b9f:45bf::1  prefixlen 64  scopeid 0x0<global>
        ether ee:16:f1:7c:31:8c  txqueuelen 1000  (Ethernet)
        RX packets 242  bytes 69113 (69.1 KB)
        TX packets 105  bytes 18812 (18.8 KB)
veth6a859f40: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        RX packets 242  bytes 72501 (72.5 KB)
        TX packets 97  bytes 17912 (17.9 KB)
andrei@q:~$ lxc network list
|  NAME  |   TYPE   | MANAGED | DESCRIPTION | USED BY |
| enp6s0 | physical | NO      |             | 0       |
| lxdbr0 | bridge   | YES     |             | 1       |
| wlp3s0 | physical | NO      |             | 0       |
andrei@q:~$ lxc network show lxdbr0
  ipv4.address: 10.99.15.1/24
  ipv4.nat: "true"
  ipv6.address: fd42:dbee:4b9f:45bf::1/64
  ipv6.nat: "true"
type: bridge
- /1.0/instances/nextCloud
managed: true
status: Created
locations:
- none
andrei@q:~$
andrei@q:~$ lxc list
|   NAME    |  STATE  | IPV4 | IPV6 |   TYPE    | SNAPSHOTS |
| nextCloud | RUNNING |      |      | CONTAINER | 0         |
That’s either firewall related or dnsmasq failed to start.
Show ps fauxww to figure out if dnsmasq is running.
And iptables -L -n -v to see if there’s something odd in your firewall.
You don’t say what distro you’re on, if you are on Fedora 32, then it’s likely firewalld, there is a section in our doc on how to workaround that.
If you’re not and you have Docker installed, it’s most likely Docker that broke networking on your system…
lsb_release -a
No LSB modules are available.
Distributor ID:	Ubuntu
Description:	Ubuntu 18.04.4 LTS
Release:	18.04
Codename:	bionic
iptables -L -n -v
sudo iptables -L -n -v
Chain INPUT (policy ACCEPT 3692 packets, 466K bytes)
 pkts bytes target     prot opt in     out     source               destination
    0     0 ACCEPT     tcp  --  lxdbr0 *       0.0.0.0/0            0.0.0.0/0            tcp dpt:53 /* generated for LXD network lxdbr0 */
    0     0 ACCEPT     udp  --  lxdbr0 *       0.0.0.0/0            0.0.0.0/0            udp dpt:53 /* generated for LXD network lxdbr0 */
  133 42693 ACCEPT     udp  --  lxdbr0 *       0.0.0.0/0            0.0.0.0/0            udp dpt:67 /* generated for LXD network lxdbr0 */
Chain FORWARD (policy ACCEPT 0 packets, 0 bytes)
    0     0 ACCEPT     all  --  *      lxdbr0  0.0.0.0/0            0.0.0.0/0            /* generated for LXD network lxdbr0 */
    0     0 ACCEPT     all  --  lxdbr0 *       0.0.0.0/0            0.0.0.0/0            /* generated for LXD network lxdbr0 */
Chain OUTPUT (policy ACCEPT 3327 packets, 527K bytes)
    0     0 ACCEPT     tcp  --  *      lxdbr0  0.0.0.0/0            0.0.0.0/0            tcp spt:53 /* generated for LXD network lxdbr0 */
    0     0 ACCEPT     udp  --  *      lxdbr0  0.0.0.0/0            0.0.0.0/0            udp spt:53 /* generated for LXD network lxdbr0 */
    0     0 ACCEPT     udp  --  *      lxdbr0  0.0.0.0/0            0.0.0.0/0            udp spt:67 /* generated for LXD network lxdbr0 */
ps fauxww
USER       PID %CPU %MEM    VSZ   RSS TTY      STAT START   TIME COMMAND
root         2  0.0  0.0      0     0 ?        S    Jun04   0:06 [kthreadd]
root         4  0.0  0.0      0     0 ?        I<   Jun04   0:00  \_ [kworker/0:0H]
root         6  0.0  0.0      0     0 ?        I<   Jun04   0:00  \_ [mm_percpu_wq]
root         7  0.0  0.0      0     0 ?        S    Jun04   0:00  \_ [ksoftirqd/0]
root         8  0.0  0.0      0     0 ?        I    Jun04   0:07  \_ [rcu_sched]
root         9  0.0  0.0      0     0 ?        I    Jun04   0:00  \_ [rcu_bh]
root        10  0.0  0.0      0     0 ?        S    Jun04   0:00  \_ [migration/0]
root        11  0.0  0.0      0     0 ?        S    Jun04   0:00  \_ [watchdog/0]
root        12  0.0  0.0      0     0 ?        S    Jun04   0:00  \_ [cpuhp/0]
root        13  0.0  0.0      0     0 ?        S    Jun04   0:00  \_ [cpuhp/1]
root        14  0.0  0.0      0     0 ?        S    Jun04   0:00  \_ [watchdog/1]
root        15  0.0  0.0      0     0 ?        S    Jun04   0:00  \_ [migration/1]
root        16  0.0  0.0      0     0 ?        S    Jun04   0:00  \_ [ksoftirqd/1]
root        18  0.0  0.0      0     0 ?        I<   Jun04   0:00  \_ [kworker/1:0H]
root        19  0.0  0.0      0     0 ?        S    Jun04   0:00  \_ [kdevtmpfs]
root        20  0.0  0.0      0     0 ?        I<   Jun04   0:00  \_ [netns]
root        21  0.0  0.0      0     0 ?        S    Jun04   0:00  \_ [rcu_tasks_kthre]
root        22  0.0  0.0      0     0 ?        S    Jun04   0:00  \_ [kauditd]
root        25  0.0  0.0      0     0 ?        S    Jun04   0:00  \_ [khungtaskd]
root        26  0.0  0.0      0     0 ?        S    Jun04   0:00  \_ [oom_reaper]
root        27  0.0  0.0      0     0 ?        I<   Jun04   0:00  \_ [writeback]
root        28  0.0  0.0      0     0 ?        S    Jun04   0:00  \_ [kcompactd0]
root        29  0.0  0.0      0     0 ?        SN   Jun04   0:00  \_ [ksmd]
root        30  0.0  0.0      0     0 ?        SN   Jun04   0:00  \_ [khugepaged]
root        31  0.0  0.0      0     0 ?        I<   Jun04   0:00  \_ [crypto]
root        32  0.0  0.0      0     0 ?        I<   Jun04   0:00  \_ [kintegrityd]
root        33  0.0  0.0      0     0 ?        I<   Jun04   0:00  \_ [kblockd]
root        34  0.0  0.0      0     0 ?        I<   Jun04   0:00  \_ [ata_sff]
root        35  0.0  0.0      0     0 ?        I<   Jun04   0:00  \_ [md]
root        36  0.0  0.0      0     0 ?        I<   Jun04   0:00  \_ [edac-poller]
root        37  0.0  0.0      0     0 ?        I<   Jun04   0:00  \_ [devfreq_wq]
root        38  0.0  0.0      0     0 ?        I<   Jun04   0:00  \_ [watchdogd]
root        40  0.0  0.0      0     0 ?        S    Jun04   0:00  \_ [kswapd0]
root        41  0.0  0.0      0     0 ?        I<   Jun04   0:00  \_ [kworker/u5:0]
root        42  0.0  0.0      0     0 ?        S    Jun04   0:00  \_ [ecryptfs-kthrea]
root        84  0.0  0.0      0     0 ?        I<   Jun04   0:00  \_ [kthrotld]
root        85  0.0  0.0      0     0 ?        I<   Jun04   0:00  \_ [acpi_thermal_pm]
root        92  0.0  0.0      0     0 ?        I<   Jun04   0:00  \_ [ipv6_addrconf]
root       101  0.0  0.0      0     0 ?        I<   Jun04   0:00  \_ [kstrp]
root       118  0.0  0.0      0     0 ?        I<   Jun04   0:00  \_ [charger_manager]
root       159  0.0  0.0      0     0 ?        S    Jun04   0:00  \_ [scsi_eh_0]
root       160  0.0  0.0      0     0 ?        I<   Jun04   0:00  \_ [scsi_tmf_0]
root       161  0.0  0.0      0     0 ?        S    Jun04   0:00  \_ [scsi_eh_1]
root       167  0.0  0.0      0     0 ?        I<   Jun04   0:00  \_ [scsi_tmf_1]
root       169  0.0  0.0      0     0 ?        S    Jun04   0:00  \_ [scsi_eh_2]
root       172  0.0  0.0      0     0 ?        I<   Jun04   0:00  \_ [scsi_tmf_2]
root       175  0.0  0.0      0     0 ?        S    Jun04   0:00  \_ [scsi_eh_3]
root       176  0.0  0.0      0     0 ?        I<   Jun04   0:00  \_ [scsi_tmf_3]
root       184  0.0  0.0      0     0 ?        S    Jun04   0:00  \_ [irq/16-mmc0]
root       186  0.0  0.0      0     0 ?        I<   Jun04   0:00  \_ [ttm_swap]
root       188  0.0  0.0      0     0 ?        I<   Jun04   0:00  \_ [kworker/1:1H]
root       190  0.0  0.0      0     0 ?        I<   Jun04   0:03  \_ [kworker/0:1H]
root       258  0.0  0.0      0     0 ?        I<   Jun04   0:00  \_ [raid5wq]
root       306  0.0  0.0      0     0 ?        S    Jun04   0:04  \_ [jbd2/sda2-8]
root       307  0.0  0.0      0     0 ?        I<   Jun04   0:00  \_ [ext4-rsv-conver]
root       395  0.0  0.0      0     0 ?        I<   Jun04   0:00  \_ [iscsi_eh]
root       397  0.0  0.0      0     0 ?        I<   Jun04   0:00  \_ [ib-comp-wq]
root       398  0.0  0.0      0     0 ?        I<   Jun04   0:00  \_ [ib-comp-unb-wq]
root       399  0.0  0.0      0     0 ?        I<   Jun04   0:00  \_ [ib_mcast]
root       400  0.0  0.0      0     0 ?        I<   Jun04   0:00  \_ [ib_nl_sa_wq]
root       401  0.0  0.0      0     0 ?        I<   Jun04   0:00  \_ [rdma_cm]
root       411  0.0  0.0      0     0 ?        S<   Jun04   0:00  \_ [loop0]
root       412  0.0  0.0      0     0 ?        S<   Jun04   0:00  \_ [loop1]
root       415  0.0  0.0      0     0 ?        S<   Jun04   0:00  \_ [loop2]
root       419  0.0  0.0      0     0 ?        S<   Jun04   0:00  \_ [loop3]
root       423  0.0  0.0      0     0 ?        S<   Jun04   0:00  \_ [loop4]
root       424  0.0  0.0      0     0 ?        S<   Jun04   0:00  \_ [loop5]
root       427  0.0  0.0      0     0 ?        S<   Jun04   0:00  \_ [loop6]
root       428  0.0  0.0      0     0 ?        S<   Jun04   0:00  \_ [loop7]
root       430  0.0  0.0      0     0 ?        S<   Jun04   0:00  \_ [loop8]
root       431  0.0  0.0      0     0 ?        S<   Jun04   0:00  \_ [loop9]
root       435  0.0  0.0      0     0 ?        S<   Jun04   0:00  \_ [loop10]
root       438  0.0  0.0      0     0 ?        S<   Jun04   0:00  \_ [loop11]
root       439  0.0  0.0      0     0 ?        S<   Jun04   0:00  \_ [loop12]
root       440  0.0  0.0      0     0 ?        S<   Jun04   0:00  \_ [loop13]
root       441  0.0  0.0      0     0 ?        S<   Jun04   0:00  \_ [loop14]
root       442  0.0  0.0      0     0 ?        S<   Jun04   0:00  \_ [loop15]
root       443  0.0  0.0      0     0 ?        S<   Jun04   0:00  \_ [loop16]
root       444  0.0  0.0      0     0 ?        S<   Jun04   0:00  \_ [loop17]
root       480  0.0  0.0      0     0 ?        I<   Jun04   0:00  \_ [cfg80211]
root       491  0.0  0.0      0     0 ?        I<   Jun04   0:00  \_ [kworker/u5:1]
root      1524  0.0  0.0      0     0 ?        I<   Jun04   0:00  \_ [dio/sda2]
root      1583  0.0  0.0      0     0 ?        S<   Jun04   0:00  \_ [spl_system_task]
root      1585  0.0  0.0      0     0 ?        S<   Jun04   0:00  \_ [spl_delay_taskq]
root      1586  0.0  0.0      0     0 ?        S<   Jun04   0:03  \_ [spl_dynamic_tas]
root      1587  0.0  0.0      0     0 ?        S<   Jun04   0:00  \_ [spl_kmem_cache]
root      1595  0.0  0.0      0     0 ?        S<   Jun04   0:00  \_ [zvol]
root      1603  0.0  0.0      0     0 ?        S    Jun04   0:00  \_ [arc_prune]
root      1606  0.0  0.0      0     0 ?        S    Jun04   0:02  \_ [arc_reclaim]
root      1607  0.0  0.0      0     0 ?        S    Jun04   0:00  \_ [dbu_evict]
root      1608  0.0  0.0      0     0 ?        SN   Jun04   0:01  \_ [dbuf_evict]
root      1610  0.0  0.0      0     0 ?        SN   Jun04   0:09  \_ [z_vdev_file]
root      1611  0.0  0.0      0     0 ?        S    Jun04   0:02  \_ [l2arc_feed]
root      1682  0.0  0.0      0     0 ?        S<   Jun04   0:03  \_ [z_null_iss]
root      1683  0.0  0.0      0     0 ?        S<   Jun04   0:02  \_ [z_null_int]
root      1684  0.0  0.0      0     0 ?        S<   Jun04   0:00  \_ [z_rd_iss]
root      1685  0.0  0.0      0     0 ?        S<   Jun04   0:00  \_ [z_rd_int_0]
root      1686  0.0  0.0      0     0 ?        S<   Jun04   0:00  \_ [z_rd_int_1]
root      1687  0.0  0.0      0     0 ?        S<   Jun04   0:00  \_ [z_rd_int_2]
root      1688  0.0  0.0      0     0 ?        S<   Jun04   0:00  \_ [z_rd_int_3]
root      1689  0.0  0.0      0     0 ?        S<   Jun04   0:00  \_ [z_rd_int_4]
root      1690  0.0  0.0      0     0 ?        S<   Jun04   0:00  \_ [z_rd_int_5]
root      1691  0.0  0.0      0     0 ?        S<   Jun04   0:00  \_ [z_rd_int_6]
root      1692  0.0  0.0      0     0 ?        S<   Jun04   0:00  \_ [z_rd_int_7]
root      1693  0.0  0.0      0     0 ?        S<   Jun04   0:30  \_ [z_wr_iss]
root      1694  0.0  0.0      0     0 ?        S<   Jun04   0:00  \_ [z_wr_iss_h]
root      1695  0.0  0.0      0     0 ?        S<   Jun04   0:02  \_ [z_wr_int_0]
root      1696  0.0  0.0      0     0 ?        S<   Jun04   0:02  \_ [z_wr_int_1]
root      1697  0.0  0.0      0     0 ?        S<   Jun04   0:02  \_ [z_wr_int_2]
root      1698  0.0  0.0      0     0 ?        S<   Jun04   0:02  \_ [z_wr_int_3]
root      1699  0.0  0.0      0     0 ?        S<   Jun04   0:02  \_ [z_wr_int_4]
root      1700  0.0  0.0      0     0 ?        S<   Jun04   0:02  \_ [z_wr_int_5]
root      1701  0.0  0.0      0     0 ?        S<   Jun04   0:02  \_ [z_wr_int_6]
root      1702  0.0  0.0      0     0 ?        S<   Jun04   0:02  \_ [z_wr_int_7]
root      1703  0.0  0.0      0     0 ?        S<   Jun04   0:00  \_ [z_wr_int_h]
root      1704  0.0  0.0      0     0 ?        S<   Jun04   0:00  \_ [z_fr_iss_0]
root      1705  0.0  0.0      0     0 ?        S<   Jun04   0:00  \_ [z_fr_iss_1]
root      1706  0.0  0.0      0     0 ?        S<   Jun04   0:00  \_ [z_fr_iss_2]
root      1707  0.0  0.0      0     0 ?        S<   Jun04   0:00  \_ [z_fr_iss_3]
root      1708  0.0  0.0      0     0 ?        S<   Jun04   0:00  \_ [z_fr_iss_4]
root      1709  0.0  0.0      0     0 ?        S<   Jun04   0:00  \_ [z_fr_iss_5]
root      1710  0.0  0.0      0     0 ?        S<   Jun04   0:00  \_ [z_fr_iss_6]
root      1711  0.0  0.0      0     0 ?        S<   Jun04   0:00  \_ [z_fr_iss_7]
root      1712  0.0  0.0      0     0 ?        S<   Jun04   0:00  \_ [z_fr_int]
root      1713  0.0  0.0      0     0 ?        S<   Jun04   0:00  \_ [z_cl_iss]
root      1714  0.0  0.0      0     0 ?        S<   Jun04   0:00  \_ [z_cl_int]
root      1715  0.0  0.0      0     0 ?        S<   Jun04   0:00  \_ [z_ioctl_iss]
root      1716  0.0  0.0      0     0 ?        S<   Jun04   0:00  \_ [z_ioctl_int]
root      1717  0.0  0.0      0     0 ?        S    Jun04   0:00  \_ [z_zvol]
root      1718  0.0  0.0      0     0 ?        S    Jun04   0:00  \_ [z_prefetch]
root      1719  0.0  0.0      0     0 ?        S    Jun04   0:00  \_ [z_upgrade]
root      1720  0.0  0.0      0     0 ?        S<   Jun04   0:00  \_ [metaslab_group_]
root      1740  0.0  0.0      0     0 ?        SN   Jun04   0:02  \_ [dp_sync_taskq]
root      1741  0.0  0.0      0     0 ?        SN   Jun04   0:00  \_ [dp_zil_clean_ta]
root      1742  0.0  0.0      0     0 ?        SN   Jun04   0:00  \_ [dp_zil_clean_ta]
root      1743  0.0  0.0      0     0 ?        S    Jun04   0:00  \_ [z_iput]
root      1872  0.0  0.0      0     0 ?        S    Jun04   0:01  \_ [txg_quiesce]
root      1873  0.0  0.0      0     0 ?        S    Jun04   0:12  \_ [txg_sync]
root      1874  0.0  0.0      0     0 ?        S    Jun04   0:02  \_ [mmp]
root      6245  0.0  0.0      0     0 ?        I    Jun04   0:14  \_ [kworker/1:2]
root      8452  0.0  0.0      0     0 ?        I    00:00   0:04  \_ [kworker/1:1]
root     24749  0.0  0.0      0     0 ?        I    01:58   0:03  \_ [kworker/0:0]
root      8978  0.0  0.0      0     0 ?        S<   03:58   0:00  \_ [loop18]
root     23926  0.0  0.0      0     0 ?        I    05:42   0:00  \_ [kworker/u4:2]
root     25359  0.0  0.0      0     0 ?        I    05:54   0:00  \_ [kworker/u4:1]
root     25830  0.0  0.0      0     0 ?        I    05:59   0:00  \_ [kworker/0:2]
root     26782  0.0  0.0      0     0 ?        I    06:06   0:00  \_ [kworker/u4:0]
root     28771  0.0  0.0      0     0 ?        I    06:20   0:00  \_ [kworker/0:1]
root     29159  0.0  0.0      0     0 ?        S<   06:22   0:00  \_ [z_wr_int_0]
root     29162  0.0  0.0      0     0 ?        S<   06:22   0:00  \_ [z_wr_int_5]
root     29163  0.0  0.0      0     0 ?        S<   06:22   0:00  \_ [z_wr_int_6]
root     29164  0.0  0.0      0     0 ?        S<   06:22   0:00  \_ [z_wr_int_1]
root     29165  0.0  0.0      0     0 ?        S<   06:22   0:00  \_ [z_wr_int_0]
root     29166  0.0  0.0      0     0 ?        S<   06:22   0:00  \_ [z_wr_int_0]
root     29169  0.0  0.0      0     0 ?        S<   06:22   0:00  \_ [z_wr_int_2]
root     29171  0.0  0.0      0     0 ?        S<   06:22   0:00  \_ [z_wr_int_2]
root     29172  0.0  0.0      0     0 ?        S<   06:22   0:00  \_ [z_wr_int_2]
root     29176  0.0  0.0      0     0 ?        S<   06:22   0:00  \_ [z_wr_int_1]
root         1  0.0  0.2  78288  9368 ?        Ss   Jun04   0:07 /sbin/init
root       381  0.0  1.2 132912 46484 ?        S<s  Jun04   0:02 /lib/systemd/systemd-journald
root       405  0.0  0.0  97708  1900 ?        Ss   Jun04   0:00 /sbin/lvmetad -f
root       406  0.0  0.1  47128  5764 ?        Ss   Jun04   0:09 /lib/systemd/systemd-udevd
systemd+   671  0.0  0.0 141936  3156 ?        Ssl  Jun04   0:00 /lib/systemd/systemd-timesyncd
systemd+   806  0.0  0.1  80180  6028 ?        Ss   Jun04   0:00 /lib/systemd/systemd-networkd
systemd+   833  0.0  0.1  70640  5040 ?        Ss   Jun04   0:00 /lib/systemd/systemd-resolved
daemon     916  0.0  0.0  28332  2508 ?        Ss   Jun04   0:00 /usr/sbin/atd -f
root       919  0.0  0.0 110484  3576 ?        Ssl  Jun04   0:05 /usr/sbin/irqbalance --foreground
message+   920  0.0  0.1  50104  4728 ?        Rs   Jun04   0:00 /usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation --syslog-only
root       937  0.0  0.4 169104 17296 ?        Ssl  Jun04   0:00 /usr/bin/python3 /usr/bin/networkd-dispatcher --run-startup-triggers
root       938  0.0  0.0  30028  3308 ?        Ss   Jun04   0:00 /usr/sbin/cron -f
root       952  0.0  0.3  56392 13508 ?        Ss   Jun04   0:14 /usr/bin/python -m SimpleHTTPServer 3031 &
root       954  0.0  0.0  95540  1624 ?        Ssl  Jun04   0:00 /usr/bin/lxcfs /var/lib/lxcfs/
root       957  0.0  0.1  70668  6252 ?        Ss   Jun04   0:01 /lib/systemd/systemd-logind
root       959  0.0  0.3  56392 13524 ?        Ss   Jun04   0:14 /usr/bin/python -m SimpleHTTPServer 3030 &
root       960  0.0  0.3 264064 12432 ?        Ss   Jun04   0:02 /usr/sbin/nmbd --foreground --no-process-group
syslog     962  0.0  0.1 267272  5224 ?        Ssl  Jun04   0:00 /usr/sbin/rsyslogd -n
root       963  0.0  0.7 1012960 28056 ?       Ssl  Jun04   0:33 /usr/lib/snapd/snapd
bind       964  0.0  0.5 290524 21596 ?        Ssl  Jun04   0:00 /usr/sbin/named -f -4 -u bind
root       965  0.0  0.2 452596  9716 ?        Ssl  Jun04   0:01 /snap/canonical-livepatch/95/canonical-livepatchd
root       966  0.0  0.1 286248  6940 ?        Ssl  Jun04   0:01 /usr/lib/accountsservice/accounts-daemon
root       996  0.0  0.5 185944 20136 ?        Ssl  Jun04   0:00 /usr/bin/python3 /usr/share/unattended-upgrades/unattended-upgrade-shutdown --wait-for-signal
root      1002  0.0  0.1  72300  6368 ?        Ss   Jun04   0:00 /usr/sbin/sshd -D
root     28769  0.0  0.2 107984  7276 ?        Ss   06:20   0:00  \_ sshd: andrei [priv]
andrei   28891  0.0  0.0 107984  3572 ?        S    06:20   0:00      \_ sshd: andrei@pts/0
andrei   28892  0.1  0.1  23468  5916 pts/0    Ss   06:20   0:00          \_ -bash
andrei   29178  0.0  0.1  40420  3956 pts/0    R+   06:22   0:00              \_ ps fauxww
root      1009  0.0  0.0  14888  1980 tty1     Ss+  Jun04   0:00 /sbin/agetty -o -p -- \u --noclear tty1 linux
root      1052  0.0  0.1 288884  6592 ?        Ssl  Jun04   0:00 /usr/lib/policykit-1/polkitd --no-debug
root      1222  0.0  0.5 355712 20600 ?        Ss   Jun04   0:00 /usr/sbin/smbd --foreground --no-process-group
root      1250  0.0  0.1 343660  6188 ?        S    Jun04   0:00  \_ /usr/sbin/smbd --foreground --no-process-group
root      1251  0.0  0.1 343652  4752 ?        S    Jun04   0:00  \_ /usr/sbin/smbd --foreground --no-process-group
root      1266  0.0  0.1 355712  6908 ?        S    Jun04   0:00  \_ /usr/sbin/smbd --foreground --no-process-group
root      1492  0.0  0.0 237212  1676 ?        Sl   Jun04   0:00 lxcfs /var/snap/lxd/common/var/lib/lxcfs -p /var/snap/lxd/common/lxcfs.pid
root     12876  0.0  0.4 1313672 17184 ?       Ss   Jun04   0:00 [lxc monitor] /var/snap/lxd/common/lxd/containers nextCloud
1000000  12889  0.0  0.2 169588  8080 ?        Ss   Jun04   0:01  \_ /sbin/init
1000000  13033  0.0  0.2  35244  9108 ?        Ss   Jun04   0:01      \_ /lib/systemd/systemd-journald
1000000  13088  0.0  0.0  21592  3076 ?        Ss   Jun04   0:00      \_ /lib/systemd/systemd-udevd
1000000  13131  0.0  0.0   3612  1508 ?        Ss   Jun04   0:00      \_ snapfuse /var/lib/snapd/snaps/core18_1754.snap /snap/core18/1754 -o ro,nodev,allow_other,suid
1000000  13132  0.0  0.0   3660  1340 ?        Ss   Jun04   0:00      \_ snapfuse /var/lib/snapd/snaps/lxd_15223.snap /snap/lxd/15223 -o ro,nodev,allow_other,suid
1000000  13134  0.0  0.0   3488  1260 ?        Ss   Jun04   0:00      \_ snapfuse /var/lib/snapd/snaps/snapd_7264.snap /snap/snapd/7264 -o ro,nodev,allow_other,suid
1000100  13299  0.0  0.1  18548  5528 ?        Ss   Jun04   0:01      \_ /lib/systemd/systemd-networkd
1000101  13323  0.0  0.2  24116  9384 ?        Ss   Jun04   0:03      \_ /lib/systemd/systemd-resolved
1000000  13794  0.0  0.1 241020  5888 ?        Ssl  Jun04   0:01      \_ /usr/lib/accountsservice/accounts-daemon
1000000  13801  0.0  0.0   8540  1916 ?        Ss   Jun04   0:00      \_ /usr/sbin/cron -f
1000103  13802  0.0  0.0   7400  3020 ?        Ss   Jun04   0:00      \_ /usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation --syslog-only
1000000  13807  0.0  0.4  29216 14704 ?        Ss   Jun04   0:00      \_ /usr/bin/python3 /usr/bin/networkd-dispatcher --run-startup-triggers
1000104  13808  0.0  0.0 154816  3144 ?        Ssl  Jun04   0:00      \_ /usr/sbin/rsyslogd -n -iNONE
1000000  13810  0.3  0.6 940492 25136 ?        Ssl  Jun04   1:57      \_ /usr/lib/snapd/snapd
1000000  13812  0.0  0.1  16636  5484 ?        Ss   Jun04   0:01      \_ /lib/systemd/systemd-logind
1000001  13818  0.0  0.0   3796  1636 ?        Ss   Jun04   0:00      \_ /usr/sbin/atd -f
1000000  13837  0.0  0.0   7356  1424 pts/0    Ss+  Jun04   0:00      \_ /sbin/agetty -o -p -- \u --noclear --keep-baud console 115200,38400,9600 linux
1000000  13843  0.0  0.1  12164  4408 ?        Ss   Jun04   0:00      \_ sshd: /usr/sbin/sshd -D [listener] 0 of 10-100 startups
1000000  13865  0.0  0.1 236412  6044 ?        Ssl  Jun04   0:00      \_ /usr/lib/policykit-1/polkitd --no-debug
1000000  14119  0.0  0.4 108040 16304 ?        Ssl  Jun04   0:00      \_ /usr/bin/python3 /usr/share/unattended-upgrades/unattended-upgrade-shutdown --wait-for-signal
root      9673  0.0  0.0   4640  1848 ?        Ss   03:59   0:00 /bin/sh /snap/lxd/15359/commands/daemon.start
root      9797  0.1  2.3 1721512 85444 ?       Sl   03:59   0:10  \_ lxd --logfile /var/snap/lxd/common/lxd/logs/lxd.log --group lxd
andrei   28772  0.0  0.2  76948  8116 ?        Ss   06:20   0:00 /lib/systemd/systemd --user
andrei   28773  0.0  0.0 112268  2948 ?        S    06:20   0:00  \_ (sd-pam)
Yep dnsmasq doesn’t appear to be running.
Please show output of sudo netstat -ulpn on the LXD host, to see if there is another process preventing it from starting.
Similar to LXD containers doesn't have IPV4 address and cant access to network (bridge)
Proto Recv-Q Send-Q Local Address           Foreign Address         State       PID/Program name
udp        0      0 10.99.15.1:53           0.0.0.0:*                           964/named
udp        0      0 192.168.100.2:53        0.0.0.0:*                           964/named
udp        0      0 127.0.0.1:53            0.0.0.0:*                           964/named
udp        0      0 127.0.0.53:53           0.0.0.0:*                           833/systemd-resolve
udp        0      0 192.168.100.2:68        0.0.0.0:*                           806/systemd-network
udp        0      0 10.99.15.255:137        0.0.0.0:*                           960/nmbd
udp        0      0 10.99.15.1:137          0.0.0.0:*                           960/nmbd
udp        0      0 192.168.100.255:137     0.0.0.0:*                           960/nmbd
udp        0      0 192.168.100.2:137       0.0.0.0:*                           960/nmbd
udp        0      0 0.0.0.0:137             0.0.0.0:*                           960/nmbd
udp        0      0 10.99.15.255:138        0.0.0.0:*                           960/nmbd
udp        0      0 10.99.15.1:138          0.0.0.0:*                           960/nmbd
udp        0      0 192.168.100.255:138     0.0.0.0:*                           960/nmbd
udp        0      0 192.168.100.2:138       0.0.0.0:*                           960/nmbd
udp        0      0 0.0.0.0:138             0.0.0.0:*                           960/nmbd
udp6       0      0 fe80::1a67:b0ff:fe3:546 :::*                                806/systemd-network
You have named listening on the LXD bridge’s lxdbr0 interface’s IP (10.99.15.1) this will prevent LXD’s dnsmasq from starting on that interface and break DNS and DHCP for containers.
ok i am stop a bind9 on my server, how to me restart a dnsmasq service?
If you restart LXD service it will start dnsmasq.
thanks all is work )
pleass sir lxd gui pylxd api php making and all auto sh all lxd container gui
