It was working but now no packets past lxdbr0. The iptables MASQUERADE rule is gone.
I run wireshark on both eth0 and lxdbr0 then started a ping in a container to another machine on host network.MP packets on lxdbr0 but not eth0.
I have attached
lxc info
lxc network list
lxc network info lxdbr0
lxc network show lxdbr0
Is there a command I could run to re-setup iptables?
$ lxc info
core.https_address: ‘[::]’
core.trust_password: true
api_extensions:
- container_stop_priority
- container_syscall_filtering
- auth_pki
- container_last_used_at
- etag
- patch
- usb_devices
- https_allowed_credentials
- image_compression_algorithm
- directory_manipulation
- container_cpu_time
- storage_zfs_use_refquota
- storage_lvm_mount_options
- network
- profile_usedby
- container_push
- container_exec_recording
- certificate_update
- gpu_devices
- container_image_properties
- migration_progress
- id_map
- network_firewall_filtering
- network_routes
- storage
- file_delete
- file_append
- network_dhcp_expiry
- storage_lvm_vg_rename
- storage_lvm_thinpool_rename
- network_vlan
- image_create_aliases
- container_stateless_copy
- container_only_migration
- storage_zfs_clone_copy
- unix_device_rename
- storage_lvm_use_thinpool
- storage_rsync_bwlimit
- network_vxlan_interface
- storage_btrfs_mount_options
- entity_description
- image_force_refresh
- storage_lvm_lv_resizing
- id_map_base
- file_symlinks
- container_push_target
- network_vlan_physical
- storage_images_delete
- container_edit_metadata
- storage_driver_ceph
- storage_ceph_user_name
- resource_limits
- resources
- kernel_limits
- storage_api_volume_rename
- macaroon_authentication
- network_sriov
- console
- restrict_devlxd
- migration_pre_copy
- infiniband
- maas_network
- devlxd_events
- proxy
- network_dhcp_gateway
- file_get_symlink
- network_leases
- unix_device_hotplug
- operation_description
- clustering
- event_lifecycle
- nvidia_runtime
- container_mount_propagation
- container_backup
- devlxd_images
- proxy_unix
- proxy_udp
- clustering_join
- network_state
- proxy_unix_dac_properties
- container_protection_delete
- unix_priv_drop
- pprof_http
- proxy_haproxy_protocol
- network_hwaddr
- proxy_nat
- network_nat_order
- container_full
- candid_authentication
- backup_compression
- candid_config
- nvidia_runtime_config
- storage_unmapped
- projects
- candid_config_key
- network_vxlan_ttl
- container_incremental_copy
- usb_optional_vendorid
- snapshot_scheduling
- snapshot_schedule_aliases
- container_copy_project
- clustering_server_address
- container_protection_shift
- snapshot_expiry
- snapshot_expiry_creation
- network_leases_location
- resources_cpu_socket
- resources_gpu
- resources_numa
- kernel_features
- id_map_current
- event_location
- network_nat_address
- container_nic_routes
- rbac
- cluster_internal_copy
- seccomp_notify
- lxc_features
- container_nic_ipvlan
- network_vlan_sriov
- storage_cephfs
- container_nic_ipfilter
- resources_v2
- container_syscall_intercept
- container_disk_shift
- storage_shifted
- resources_infiniband
- daemon_storage
- instances
- image_types
- resources_disk_sata
- clustering_roles
- images_expiry
- resources_network_firmware
- ceph_data_pool_name
- compression_squashfs
- container_raw_mount
- container_nic_routed
- container_disk_ceph
- virtual-machines
- image_profiles
- clustering_architecture
- resources_disk_id
- storage_lvm_stripes
- vm_boot_priority
- unix_hotplug_devices
- api_filtering
- instance_nic_network
- clustering_sizing
- firewall_driver
- projects_limits
- limits_hugepages
- projects_restrictions
- volume_snapshot_scheduling
- trust_ca_certificates
- snapshot_disk_usage
- clustering_edit_roles
- resources_usb_pci
- resources_cpu_threads_numa
- resources_cpu_core_die
- api_os
- container_nic_ipvlan_mode
- resources_system
- images_push_relay
- network_dns_search
- container_nic_routed_limits
- instance_nic_bridged_vlan
- network_state_bond_bridge
- usedby_consistency
- custom_block_volumes
- clustering_failure_domains
- resources_gpu_mdev
- console_vga_type
- projects_limits_disk
- network_type_macvlan
- network_type_sriov
- network_type_ovn
- projects_networks
- custom_volume_backup
- backup_override_name
- storage_rsync_compression
- network_type_physical
- network_ovn_nat
- tpm_device_type
- gpu_mdev
- resources_pci_iommu
- resources_network_usb
- resources_disk_address
- network_ovn_dhcp
- projects_limits_instances
- network_state_vlan
- instance_bulk_state_change
- network_gvrp
- instance_pool_move
- gpu_sriov
- pci_device_type
- storage_volume_state
- network_acl
- migration_stateful
- disk_state_quota
- storage_ceph_features
- projects_compression
- certificate_project
- network_ovn_acl
- projects_images_auto_update
- images_default_architecture
- network_ovn_acl_defaults
- gpu_mig
- project_usage
- network_bridge_acl
- warnings
- clustering_join_token
- clustering_description
- server_trusted_proxy
- clustering_update_cert
- storage_api_project
- resources_gpu_usb
- clustering_evacuation
api_status: stable
api_version: “1.0”
auth: trusted
public: false
auth_methods: - tls
environment:
addresses:- 192.168.42.5:8443
- 172.17.0.1:8443
- 10.66.42.1:8443
- ‘[fd42:e66:1a5b:98b5::1]:8443’
architectures: - x86_64
- i686
certificate: |
-----BEGIN CERTIFICATE-----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-----END CERTIFICATE-----
certificate_fingerprint: 525c1de4e49a36c5d528a7d96b226a6f3c0a5e855979ee9fffc98ff184e87d80
driver: lxc
driver_version: 4.0.10
firewall: nftables
kernel: Linux
kernel_architecture: x86_64
kernel_features:
netnsid_getifaddrs: “true”
seccomp_listener: “true”
seccomp_listener_continue: “true”
shiftfs: “false”
uevent_injection: “true”
unpriv_fscaps: “true”
kernel_version: 5.11.0-31-generic
lxc_features:
cgroup2: “true”
devpts_fd: “true”
idmapped_mounts_v2: “true”
mount_injection_file: “true”
network_gateway_device_route: “true”
network_ipvlan: “true”
network_l2proxy: “true”
network_phys_macvlan_mtu: “true”
network_veth_router: “true”
pidfd: “true”
seccomp_allow_deny_syntax: “true”
seccomp_notify: “true”
seccomp_proxy_send_notify_fd: “true”
os_name: Ubuntu
os_version: “21.04”
project: default
server: lxd
server_clustered: false
server_name: a9
server_pid: 7041
server_version: “4.17”
storage: btrfs
storage_version: 5.4.1
storage_supported_drivers: - name: dir
version: “1”
remote: false - name: lvm
version: 2.03.07(2) (2019-11-30) / 1.02.167 (2019-11-30) / 4.43.0
remote: false - name: zfs
version: 2.0.2-1ubuntu5
remote: false - name: ceph
version: 15.2.13
remote: true - name: btrfs
version: 5.4.1
remote: false - name: cephfs
version: 15.2.13
remote: true
$ lxc network list
| NAME | TYPE | MANAGED | IPV4 | IPV6 | DESCRIPTION | USED BY |
| docker0 | bridge | NO | | | | 0 |
| enp7s0 | physical | NO | | | | 0 |
| lxdbr0 | bridge | YES | 10.66.42.1/24 | fd42:e66:1a5b:98b5::1/64 | | 3 |
$ lxc network info lxdbr0
MAC address: 00:16:3e:3a:91:ef
MTU: 1500
State: up
Ips:
inet 10.66.42.1
inet6 fd42:e66:1a5b:98b5::1
inet6 fe80::216:3eff:fe3a:91ef
Network usage:
Bytes received: 104.97kB
Bytes sent: 26.88kB
Packets received: 1231
Packets sent: 237
$ lxc network show lxdbr0
ipv4.address: 10.66.42.1/24
ipv4.firewall: “False”
ipv4.nat: “true”
ipv6.address: fd42:e66:1a5b:98b5::1/64
ipv6.nat: “true”
description: “”
type: bridge
- /1.0/instances/lxdgui
- /1.0/instances/wine
- /1.0/profiles/default
managed: true
status: Created
locations: - none
