I have a requirement to setup LXC containers in a OpenWRT Machine.
My System Details:
Laptop OS: Debian GNU/Linux bullseye/sid, 9.12 – Network is available. Everything works fine
VM OS: OpenWRT 19.07.2 – Network is available. Everything works fine
Container OS: OpenWRT 19.07 – Network is Unavailable. This is the issue
The VMs Configurations are as follows:
lxc-checkconfig
--- Namespaces ---
Namespaces: enabled
Utsname namespace: enabled
Ipc namespace: enabled
Pid namespace: enabled
User namespace: enabled
Network namespace: enabled
--- Control groups ---
Cgroups: enabled
Cgroup v1 mount points:
/sys/fs/cgroup
Cgroup v2 mount points:
Cgroup v1 systemd controller: /usr/bin/lxc-checkconfig: line 167: printf \033[1;31m: not found
Cgroup v1 freezer controller: /usr/bin/lxc-checkconfig: line 174: printf \033[1;31m: not found
Cgroup v1 clone_children flag: enabled
Cgroup device: enabled
Cgroup sched: enabled
Cgroup cpu account: enabled
Cgroup cpuset: enabled
--- Misc ---
Macvlan: enabled, loaded
Vlan: enabled, not loaded
Bridges: enabled, not loaded
Advanced netfilter: enabled, not loaded
CONFIG_NF_NAT_IPV4: enabled, loaded
CONFIG_NF_NAT_IPV6: missing
CONFIG_IP_NF_TARGET_MASQUERADE: enabled, loaded
CONFIG_IP6_NF_TARGET_MASQUERADE: missing
CONFIG_NETFILTER_XT_TARGET_CHECKSUM: missing
CONFIG_NETFILTER_XT_MATCH_COMMENT: enabled, loaded
FUSE (for use with lxcfs): missing
--- Checkpoint/Restore ---
checkpoint restore: missing
CONFIG_FHANDLE: missing
CONFIG_EVENTFD: enabled
CONFIG_EPOLL: enabled
CONFIG_UNIX_DIAG: missing
CONFIG_INET_DIAG: missing
CONFIG_PACKET_DIAG: missing
CONFIG_NETLINK_DIAG: missing
File capabilities: enabled
brctl show
bridge name bridge id STP enabled interfaces
br-mng 7fff.0800272bc85f no eth0
vethXH0YJS
cat /proc/net/arp
IP address HW type Flags HW address Mask Device
10.0.XX.XX 0x1 0x2 52:54:00:12:35:02 * eth1
192.168.XX.XX 0x1 0x2 0a:00:27:00:00:03 * br-mng
The /etc/lxc/default.conf file in Virtual Machine has the following entries
lxc.net.0.type = veth
lxc.network.link = br-mng
lxc.network.flags = up
lxc.network.hwaddr = 08:00:27:2b:c8:5f
The ifconfig -a output of the VM is:
br-mng Link encap:Ethernet HWaddr 08:00:27:2B:C8:5F
--- Some lines ---
eth0 Link encap:Ethernet HWaddr 08:00:27:2B:C8:5F
--- Some lines ---
eth1 Link encap:Ethernet HWaddr 08:00:27:79:CB:CF
--- Some lines ---
eth2 Link encap:Ethernet HWaddr 08:00:27:4F:C7:A5
--- Some lines ---
lo Link encap:Local Loopback
--- Some lines ---
vethXH0YJS Link encap:Ethernet HWaddr FE:61:34:FE:61:12
--- Some lines ---
I have created a container inside the VM. The container starts fine and i am able to perform lxc-attach and other basic operations.
In VM, the entries of /srv/lxc/MyContainer/config are:
lxc.net.0.link = br-mng
lxc.net.0.flags = up
lxc.net.0.hwaddr = 08:00:27:2B:C8:5F
However the container doesn’t have network access.
When i try to run opkg update command inside MyContainer, it throws error message Failed to establish connection. ping gogle.com also doesn’t work
The brctl show and /proc/net/arp commands give blank response inside container
Additional Info:
- I have set Promiscuous mode in Virtual Box as Allow All. Irrespective of the option that i choose in this dropdown, network is not available inside the conatiner
- When i execute the command lxc-ls -f, i see the IPv4 address as 192.168.1.1 for a brief moment and then it disappears and it is shown as -
Could you please help me to resolve the network issues in my container.
Am i missing anything?
