ps aux | grep dnsmasq
libvirt+ 2282 0.0 0.0 9228 2104 ? S 22:28 0:00 /usr/sbin/dnsmasq --conf-file=/var/lib/libvirt/dnsmasq/default.conf --leasefile-ro --dhcp-script=/usr/lib/libvirt/libvirt_leaseshelper
root 2283 0.0 0.0 9200 332 ? S 22:28 0:00 /usr/sbin/dnsmasq --conf-file=/var/lib/libvirt/dnsmasq/default.conf --leasefile-ro --dhcp-script=/usr/lib/libvirt/libvirt_leaseshelper
lxc-dns+ 3682 0.0 0.0 24536 352 ? S 22:29 0:00 dnsmasq -u lxc-dnsmasq --strict-order --bind-interfaces --pid-file=/run/lxc/dnsmasq.pid --listen-address 10.0.3.1 --dhcp-range 10.0.3.2,10.0.3.254 --dhcp-lease-max=253 --dhcp-no-override --except-interface=lo --interface=lxcbr0 --dhcp-leasefile=/var/lib/misc/dnsmasq.lxcbr0.leases --dhcp-authoritative
toochev+ 6210 0.0 0.0 18800 2696 pts/3 S+ 22:32 0:00 grep --color=auto dnsmasq
sudo nft list ruleset
table bridge filter {
chain INPUT {
type filter hook input priority filter; policy accept;
chain FORWARD {
type filter hook forward priority filter; policy accept;
chain OUTPUT {
type filter hook output priority filter; policy accept;
iptables -L -n -v
Chain INPUT (policy ACCEPT 33336 packets, 386M bytes)
pkts bytes target prot opt in out source destination
0 0 ACCEPT tcp -- lxdbr0 * 0.0.0.0/0 0.0.0.0/0 tcp dpt:53 /* generated for LXD network lxdbr0 */
0 0 ACCEPT udp -- lxdbr0 * 0.0.0.0/0 0.0.0.0/0 udp dpt:53 /* generated for LXD network lxdbr0 */
23 7256 ACCEPT udp -- lxdbr0 * 0.0.0.0/0 0.0.0.0/0 udp dpt:67 /* generated for LXD network lxdbr0 */
0 0 ACCEPT tcp -- lxcbr0 * 0.0.0.0/0 0.0.0.0/0 tcp dpt:53
0 0 ACCEPT udp -- lxcbr0 * 0.0.0.0/0 0.0.0.0/0 udp dpt:53
0 0 ACCEPT tcp -- lxcbr0 * 0.0.0.0/0 0.0.0.0/0 tcp dpt:67
0 0 ACCEPT udp -- lxcbr0 * 0.0.0.0/0 0.0.0.0/0 udp dpt:67
33824 386M LIBVIRT_INP all -- * * 0.0.0.0/0 0.0.0.0/0
Chain FORWARD (policy ACCEPT 0 packets, 0 bytes)
0 0 ACCEPT all -- * lxdbr0 0.0.0.0/0 0.0.0.0/0 /* generated for LXD network lxdbr0 */
0 0 ACCEPT all -- lxdbr0 * 0.0.0.0/0 0.0.0.0/0 /* generated for LXD network lxdbr0 */
0 0 ACCEPT all -- * lxcbr0 0.0.0.0/0 0.0.0.0/0
0 0 ACCEPT all -- lxcbr0 * 0.0.0.0/0 0.0.0.0/0
0 0 LIBVIRT_FWX all -- * * 0.0.0.0/0 0.0.0.0/0
0 0 LIBVIRT_FWI all -- * * 0.0.0.0/0 0.0.0.0/0
0 0 LIBVIRT_FWO all -- * * 0.0.0.0/0 0.0.0.0/0
Chain OUTPUT (policy ACCEPT 30167 packets, 4859K bytes)
0 0 ACCEPT tcp -- * lxdbr0 0.0.0.0/0 0.0.0.0/0 tcp spt:53 /* generated for LXD network lxdbr0 */
0 0 ACCEPT udp -- * lxdbr0 0.0.0.0/0 0.0.0.0/0 udp spt:53 /* generated for LXD network lxdbr0 */
0 0 ACCEPT udp -- * lxdbr0 0.0.0.0/0 0.0.0.0/0 udp spt:67 /* generated for LXD network lxdbr0 */
30700 5016K LIBVIRT_OUT all -- * * 0.0.0.0/0 0.0.0.0/0
Chain LIBVIRT_FWI (1 references)
0 0 ACCEPT all -- * virbr0 0.0.0.0/0 192.168.122.0/24 ctstate RELATED,ESTABLISHED
0 0 REJECT all -- * virbr0 0.0.0.0/0 0.0.0.0/0 reject-with icmp-port-unreachable
Chain LIBVIRT_FWO (1 references)
0 0 ACCEPT all -- virbr0 * 192.168.122.0/24 0.0.0.0/0
0 0 REJECT all -- virbr0 * 0.0.0.0/0 0.0.0.0/0 reject-with icmp-port-unreachable
Chain LIBVIRT_FWX (1 references)
0 0 ACCEPT all -- virbr0 virbr0 0.0.0.0/0 0.0.0.0/0
Chain LIBVIRT_INP (1 references)
0 0 ACCEPT udp -- virbr0 * 0.0.0.0/0 0.0.0.0/0 udp dpt:53
0 0 ACCEPT tcp -- virbr0 * 0.0.0.0/0 0.0.0.0/0 tcp dpt:53
0 0 ACCEPT udp -- virbr0 * 0.0.0.0/0 0.0.0.0/0 udp dpt:67
0 0 ACCEPT tcp -- virbr0 * 0.0.0.0/0 0.0.0.0/0 tcp dpt:67
Chain LIBVIRT_OUT (1 references)
0 0 ACCEPT udp -- * virbr0 0.0.0.0/0 0.0.0.0/0 udp dpt:53
0 0 ACCEPT tcp -- * virbr0 0.0.0.0/0 0.0.0.0/0 tcp dpt:53
0 0 ACCEPT udp -- * virbr0 0.0.0.0/0 0.0.0.0/0 udp dpt:68
0 0 ACCEPT tcp -- * virbr0 0.0.0.0/0 0.0.0.0/0 tcp dpt:68
grep -i apparmor /var/log/kern.log
Aug 3 22:17:05 cobalt kernel: [ 70.785841] audit: type=1400 audit(1596507425.582:85): apparmor="DENIED" operation="open" profile="/snap/core/9665/usr/lib/snapd/snap-confine" name="/etc/pop-os/os-release" pid=3676 comm="snap-confine" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
Aug 3 22:17:05 cobalt kernel: [ 70.788114] audit: type=1400 audit(1596507425.586:86): apparmor="DENIED" operation="open" profile="snap.lxd.lxd" name="/etc/pop-os/os-release" pid=3676 comm="snap-exec" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
Aug 3 22:17:06 cobalt kernel: [ 71.446320] audit: type=1400 audit(1596507426.242:87): apparmor="DENIED" operation="open" profile="/snap/core/9665/usr/lib/snapd/snap-confine" name="/etc/pop-os/os-release" pid=3717 comm="snap-confine" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
Aug 3 22:17:06 cobalt kernel: [ 71.447928] audit: type=1400 audit(1596507426.242:88): apparmor="DENIED" operation="open" profile="snap.lxd.daemon" name="/etc/pop-os/os-release" pid=3717 comm="snap-exec" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
Aug 3 22:17:06 cobalt kernel: [ 71.726007] audit: type=1400 audit(1596507426.522:89): apparmor="STATUS" operation="profile_replace" info="same as current profile, skipping" profile="unconfined" name="/usr/bin/lxc-start" pid=3860 comm="apparmor_parser"
Aug 3 22:17:06 cobalt kernel: [ 71.742270] audit: type=1400 audit(1596507426.538:90): apparmor="STATUS" operation="profile_replace" info="same as current profile, skipping" profile="unconfined" name="lxc-container-default" pid=3870 comm="apparmor_parser"
Aug 3 22:17:06 cobalt kernel: [ 71.742273] audit: type=1400 audit(1596507426.538:91): apparmor="STATUS" operation="profile_replace" info="same as current profile, skipping" profile="unconfined" name="lxc-container-default-cgns" pid=3870 comm="apparmor_parser"
Aug 3 22:17:06 cobalt kernel: [ 71.742275] audit: type=1400 audit(1596507426.538:92): apparmor="STATUS" operation="profile_replace" info="same as current profile, skipping" profile="unconfined" name="lxc-container-default-with-mounting" pid=3870 comm="apparmor_parser"
Aug 3 22:17:06 cobalt kernel: [ 71.742277] audit: type=1400 audit(1596507426.538:93): apparmor="STATUS" operation="profile_replace" info="same as current profile, skipping" profile="unconfined" name="lxc-container-default-with-nesting" pid=3870 comm="apparmor_parser"
Aug 3 22:18:17 cobalt kernel: [ 142.849036] audit: type=1400 audit(1596507497.604:94): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lxd_dnsmasq-lxdbr1_</var/snap/lxd/common/lxd>" pid=4195 comm="apparmor_parser"
Aug 3 22:18:17 cobalt kernel: [ 142.851939] audit: type=1400 audit(1596507497.608:95): apparmor="DENIED" operation="open" profile="lxd_dnsmasq-lxdbr1_</var/snap/lxd/common/lxd>" name="/home/lxd/common/lxd/networks/lxdbr1/dnsmasq.raw" pid=4202 comm="dnsmasq" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
Aug 3 22:18:28 cobalt kernel: [ 153.518786] audit: type=1400 audit(1596507508.274:96): apparmor="DENIED" operation="open" profile="/snap/core/9665/usr/lib/snapd/snap-confine" name="/etc/pop-os/os-release" pid=4278 comm="snap-confine" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
Aug 3 22:18:28 cobalt kernel: [ 153.521081] audit: type=1400 audit(1596507508.278:97): apparmor="DENIED" operation="open" profile="snap.lxd.lxc" name="/var/lib/snapd/hostfs/etc/pop-os/os-release" pid=4278 comm="snap-exec" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
Aug 3 22:18:31 cobalt kernel: [ 156.674896] audit: type=1400 audit(1596507511.430:98): apparmor="DENIED" operation="open" profile="/snap/core/9665/usr/lib/snapd/snap-confine" name="/etc/pop-os/os-release" pid=4321 comm="snap-confine" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
Aug 3 22:18:31 cobalt kernel: [ 156.676969] audit: type=1400 audit(1596507511.434:99): apparmor="DENIED" operation="open" profile="snap.lxd.lxc" name="/var/lib/snapd/hostfs/etc/pop-os/os-release" pid=4321 comm="snap-exec" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
Aug 3 22:18:31 cobalt kernel: [ 156.725705] audit: type=1400 audit(1596507511.482:100): apparmor="DENIED" operation="open" profile="/snap/core/9665/usr/lib/snapd/snap-confine" name="/etc/pop-os/os-release" pid=4357 comm="snap-confine" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
Aug 3 22:18:31 cobalt kernel: [ 156.727379] audit: type=1400 audit(1596507511.482:101): apparmor="DENIED" operation="open" profile="snap.lxd.lxc" name="/var/lib/snapd/hostfs/etc/pop-os/os-release" pid=4357 comm="snap-exec" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
Aug 3 22:18:31 cobalt kernel: [ 156.766407] audit: type=1400 audit(1596507511.522:102): apparmor="DENIED" operation="open" profile="/snap/core/9665/usr/lib/snapd/snap-confine" name="/etc/pop-os/os-release" pid=4391 comm="snap-confine" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
Aug 3 22:18:31 cobalt kernel: [ 156.768139] audit: type=1400 audit(1596507511.526:103): apparmor="DENIED" operation="open" profile="snap.lxd.lxc" name="/var/lib/snapd/hostfs/etc/pop-os/os-release" pid=4391 comm="snap-exec" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
Aug 3 22:18:31 cobalt kernel: [ 156.801234] audit: type=1400 audit(1596507511.558:104): apparmor="DENIED" operation="open" profile="/snap/core/9665/usr/lib/snapd/snap-confine" name="/etc/pop-os/os-release" pid=4426 comm="snap-confine" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
Aug 3 22:18:31 cobalt kernel: [ 156.802791] audit: type=1400 audit(1596507511.558:105): apparmor="DENIED" operation="open" profile="snap.lxd.lxc" name="/var/lib/snapd/hostfs/etc/pop-os/os-release" pid=4426 comm="snap-exec" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
Aug 3 22:18:44 cobalt kernel: [ 169.838538] audit: type=1400 audit(1596507524.600:108): apparmor="DENIED" operation="open" profile="/snap/core/9665/usr/lib/snapd/snap-confine" name="/etc/pop-os/os-release" pid=4496 comm="snap-confine" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
Aug 3 22:18:44 cobalt kernel: [ 169.840611] audit: type=1400 audit(1596507524.600:109): apparmor="DENIED" operation="open" profile="snap.lxd.lxc" name="/var/lib/snapd/hostfs/etc/pop-os/os-release" pid=4496 comm="snap-exec" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
Aug 3 22:22:22 cobalt kernel: [ 387.889345] audit: type=1400 audit(1596507742.629:110): apparmor="DENIED" operation="open" profile="/snap/core/9665/usr/lib/snapd/snap-confine" name="/etc/pop-os/os-release" pid=6129 comm="snap-confine" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
Aug 3 22:22:22 cobalt kernel: [ 387.889512] audit: type=1400 audit(1596507742.629:111): apparmor="DENIED" operation="open" profile="/snap/core/9665/usr/lib/snapd/snap-confine" name="/etc/pop-os/os-release" pid=6129 comm="snap-confine" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
Aug 3 22:22:22 cobalt kernel: [ 387.904717] audit: type=1400 audit(1596507742.645:112): apparmor="DENIED" operation="open" profile="snap-update-ns.chromium" name="/etc/pop-os/os-release" pid=6179 comm="5" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
Aug 3 22:22:22 cobalt kernel: [ 387.938439] audit: type=1400 audit(1596507742.677:113): apparmor="DENIED" operation="open" profile="snap-update-ns.chromium" name="/etc/pop-os/os-release" pid=6186 comm="5" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
Aug 3 22:22:22 cobalt kernel: [ 387.946584] audit: type=1400 audit(1596507742.685:114): apparmor="DENIED" operation="open" profile="snap.chromium.chromium" name="/etc/pop-os/os-release" pid=6129 comm="snap-exec" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
Aug 3 22:22:22 cobalt kernel: [ 388.059077] audit: type=1400 audit(1596507742.797:115): apparmor="DENIED" operation="open" profile="snap.chromium.chromium" name="/home/toochevere/.Public/" pid=6243 comm="head" requested_mask="r" denied_mask="r" fsuid=1000 ouid=1000
Aug 3 22:22:22 cobalt kernel: [ 388.204491] audit: type=1400 audit(1596507742.945:116): apparmor="DENIED" operation="open" profile="snap.chromium.chromium" name="/etc/pop-os/os-release" pid=6277 comm="snapctl" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
Aug 3 22:22:36 cobalt kernel: [ 401.645270] audit: type=1400 audit(1596507756.388:189): apparmor="DENIED" operation="open" profile="snap.chromium.chromium" name="/etc/pop-os/os-release" pid=6129 comm="ThreadPoolForeg" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
Aug 3 22:22:36 cobalt kernel: [ 401.667108] audit: type=1400 audit(1596507756.408:190): apparmor="DENIED" operation="open" profile="snap.chromium.chromium" name="/run/udev/data/+thunderbolt:domain0" pid=6129 comm="ThreadPoolForeg" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
Aug 3 22:22:36 cobalt kernel: [ 401.667201] audit: type=1400 audit(1596507756.408:191): apparmor="DENIED" operation="open" profile="snap.chromium.chromium" name="/run/udev/data/+thunderbolt:0-0" pid=6129 comm="ThreadPoolForeg" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
Aug 3 22:23:30 cobalt kernel: [ 455.550711] audit: type=1400 audit(1596507810.286:192): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lxd-test_</var/snap/lxd/common/lxd>" pid=7982 comm="apparmor_parser"
Aug 3 22:23:31 cobalt kernel: [ 456.377397] audit: type=1400 audit(1596507811.114:193): apparmor="STATUS" operation="profile_load" label="lxd-test_</var/snap/lxd/common/lxd>//&:lxd-test_<var-snap-lxd-common-lxd>:unconfined" name="lsb_release" pid=8135 comm="apparmor_parser"
Aug 3 22:23:31 cobalt kernel: [ 456.390961] audit: type=1400 audit(1596507811.126:194): apparmor="STATUS" operation="profile_load" label="lxd-test_</var/snap/lxd/common/lxd>//&:lxd-test_<var-snap-lxd-common-lxd>:unconfined" name="nvidia_modprobe" pid=8136 comm="apparmor_parser"
Aug 3 22:23:31 cobalt kernel: [ 456.391654] audit: type=1400 audit(1596507811.126:195): apparmor="STATUS" operation="profile_load" label="lxd-test_</var/snap/lxd/common/lxd>//&:lxd-test_<var-snap-lxd-common-lxd>:unconfined" name="nvidia_modprobe//kmod" pid=8136 comm="apparmor_parser"
Aug 3 22:23:31 cobalt kernel: [ 456.457787] audit: type=1400 audit(1596507811.194:196): apparmor="STATUS" operation="profile_load" label="lxd-test_</var/snap/lxd/common/lxd>//&:lxd-test_<var-snap-lxd-common-lxd>:unconfined" name="/usr/bin/man" pid=8138 comm="apparmor_parser"
Aug 3 22:23:31 cobalt kernel: [ 456.458199] audit: type=1400 audit(1596507811.194:197): apparmor="STATUS" operation="profile_load" label="lxd-test_</var/snap/lxd/common/lxd>//&:lxd-test_<var-snap-lxd-common-lxd>:unconfined" name="man_filter" pid=8138 comm="apparmor_parser"
Aug 3 22:23:31 cobalt kernel: [ 456.458614] audit: type=1400 audit(1596507811.194:198): apparmor="STATUS" operation="profile_load" label="lxd-test_</var/snap/lxd/common/lxd>//&:lxd-test_<var-snap-lxd-common-lxd>:unconfined" name="man_groff" pid=8138 comm="apparmor_parser"
Aug 3 22:23:31 cobalt kernel: [ 456.512605] audit: type=1400 audit(1596507811.250:199): apparmor="STATUS" operation="profile_load" label="lxd-test_</var/snap/lxd/common/lxd>//&:lxd-test_<var-snap-lxd-common-lxd>:unconfined" name="/usr/sbin/tcpdump" pid=8141 comm="apparmor_parser"
Aug 3 22:23:31 cobalt kernel: [ 456.649714] audit: type=1400 audit(1596507811.386:200): apparmor="STATUS" operation="profile_load" label="lxd-test_</var/snap/lxd/common/lxd>//&:lxd-test_<var-snap-lxd-common-lxd>:unconfined" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=8137 comm="apparmor_parser"
Aug 3 22:23:31 cobalt kernel: [ 456.650115] audit: type=1400 audit(1596507811.386:201): apparmor="STATUS" operation="profile_load" label="lxd-test_</var/snap/lxd/common/lxd>//&:lxd-test_<var-snap-lxd-common-lxd>:unconfined" name="/usr/lib/NetworkManager/nm-dhcp-helper" pid=8137 comm="apparmor_parser"
Aug 3 22:23:50 cobalt kernel: [ 475.854268] audit: type=1400 audit(1596507830.593:206): apparmor="DENIED" operation="open" profile="/snap/core/9665/usr/lib/snapd/snap-confine" name="/etc/pop-os/os-release" pid=8311 comm="snap-confine" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
Aug 3 22:23:50 cobalt kernel: [ 475.856929] audit: type=1400 audit(1596507830.597:207): apparmor="DENIED" operation="open" profile="snap.lxd.lxc" name="/var/lib/snapd/hostfs/etc/pop-os/os-release" pid=8311 comm="snap-exec" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
Aug 3 22:23:52 cobalt kernel: [ 477.484705] audit: type=1400 audit(1596507832.221:208): apparmor="DENIED" operation="open" profile="/snap/core/9665/usr/lib/snapd/snap-confine" name="/etc/pop-os/os-release" pid=8870 comm="snap-confine" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
Aug 3 22:23:52 cobalt kernel: [ 477.487385] audit: type=1400 audit(1596507832.225:209): apparmor="DENIED" operation="open" profile="snap.lxd.lxc" name="/var/lib/snapd/hostfs/etc/pop-os/os-release" pid=8870 comm="snap-exec" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
Aug 3 22:23:52 cobalt kernel: [ 477.564597] audit: type=1400 audit(1596507832.301:210): apparmor="DENIED" operation="open" profile="/snap/core/9665/usr/lib/snapd/snap-confine" name="/etc/pop-os/os-release" pid=8903 comm="snap-confine" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
Aug 3 22:23:52 cobalt kernel: [ 477.566852] audit: type=1400 audit(1596507832.305:211): apparmor="DENIED" operation="open" profile="snap.lxd.lxc" name="/var/lib/snapd/hostfs/etc/pop-os/os-release" pid=8903 comm="snap-exec" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
Aug 3 22:23:52 cobalt kernel: [ 477.768894] audit: type=1400 audit(1596507832.509:212): apparmor="STATUS" operation="profile_replace" info="same as current profile, skipping" profile="unconfined" name="lxd-test_</var/snap/lxd/common/lxd>" pid=8994 comm="apparmor_parser"
Aug 3 22:23:53 cobalt kernel: [ 478.437843] audit: type=1400 audit(1596507833.177:213): apparmor="STATUS" operation="profile_load" label="lxd-test_</var/snap/lxd/common/lxd>//&:lxd-test_<var-snap-lxd-common-lxd>:unconfined" name="lsb_release" pid=9132 comm="apparmor_parser"
Aug 3 22:23:53 cobalt kernel: [ 478.438171] audit: type=1400 audit(1596507833.177:214): apparmor="STATUS" operation="profile_load" label="lxd-test_</var/snap/lxd/common/lxd>//&:lxd-test_<var-snap-lxd-common-lxd>:unconfined" name="nvidia_modprobe" pid=9133 comm="apparmor_parser"
Aug 3 22:23:53 cobalt kernel: [ 478.438175] audit: type=1400 audit(1596507833.177:215): apparmor="STATUS" operation="profile_load" label="lxd-test_</var/snap/lxd/common/lxd>//&:lxd-test_<var-snap-lxd-common-lxd>:unconfined" name="nvidia_modprobe//kmod" pid=9133 comm="apparmor_parser"
Aug 3 22:24:02 cobalt kernel: [ 488.087383] audit: type=1400 audit(1596507842.824:226): apparmor="DENIED" operation="open" profile="/snap/core/9665/usr/lib/snapd/snap-confine" name="/etc/pop-os/os-release" pid=9209 comm="snap-confine" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
Aug 3 22:24:02 cobalt kernel: [ 488.090094] audit: type=1400 audit(1596507842.828:227): apparmor="DENIED" operation="open" profile="snap.lxd.lxc" name="/var/lib/snapd/hostfs/etc/pop-os/os-release" pid=9209 comm="snap-exec" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
Aug 3 22:24:02 cobalt kernel: [ 488.144717] audit: type=1400 audit(1596507842.880:228): apparmor="DENIED" operation="open" profile="/snap/core/9665/usr/lib/snapd/snap-confine" name="/etc/pop-os/os-release" pid=9251 comm="snap-confine" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
Aug 3 22:24:02 cobalt kernel: [ 488.146511] audit: type=1400 audit(1596507842.884:229): apparmor="DENIED" operation="open" profile="snap.lxd.lxc" name="/var/lib/snapd/hostfs/etc/pop-os/os-release" pid=9251 comm="snap-exec" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
Aug 3 22:24:03 cobalt kernel: [ 488.898406] audit: type=1400 audit(1596507843.636:230): apparmor="DENIED" operation="open" profile="/snap/core/9665/usr/lib/snapd/snap-confine" name="/etc/pop-os/os-release" pid=9410 comm="snap-confine" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
Aug 3 22:24:03 cobalt kernel: [ 488.900311] audit: type=1400 audit(1596507843.636:231): apparmor="DENIED" operation="open" profile="snap.lxd.lxc" name="/var/lib/snapd/hostfs/etc/pop-os/os-release" pid=9410 comm="snap-exec" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
Aug 3 22:24:13 cobalt kernel: [ 499.028460] audit: type=1400 audit(1596507853.764:232): apparmor="DENIED" operation="open" profile="/snap/core/9665/usr/lib/snapd/snap-confine" name="/etc/pop-os/os-release" pid=9508 comm="snap-confine" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
Aug 3 22:24:13 cobalt kernel: [ 499.030683] audit: type=1400 audit(1596507853.768:233): apparmor="DENIED" operation="open" profile="snap.lxd.lxc" name="/var/lib/snapd/hostfs/etc/pop-os/os-release" pid=9508 comm="snap-exec" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
Aug 3 22:24:15 cobalt kernel: [ 500.304171] audit: type=1400 audit(1596507855.040:234): apparmor="DENIED" operation="open" profile="/snap/core/9665/usr/lib/snapd/snap-confine" name="/etc/pop-os/os-release" pid=10052 comm="snap-confine" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
Aug 3 22:24:15 cobalt kernel: [ 500.309743] audit: type=1400 audit(1596507855.048:235): apparmor="DENIED" operation="open" profile="snap.lxd.lxc" name="/var/lib/snapd/hostfs/etc/pop-os/os-release" pid=10052 comm="snap-exec" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
Aug 3 22:24:15 cobalt kernel: [ 500.371541] audit: type=1400 audit(1596507855.108:236): apparmor="DENIED" operation="open" profile="/snap/core/9665/usr/lib/snapd/snap-confine" name="/etc/pop-os/os-release" pid=10086 comm="snap-confine" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
Aug 3 22:24:15 cobalt kernel: [ 500.373559] audit: type=1400 audit(1596507855.112:237): apparmor="DENIED" operation="open" profile="snap.lxd.lxc" name="/var/lib/snapd/hostfs/etc/pop-os/os-release" pid=10086 comm="snap-exec" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
Aug 3 22:24:15 cobalt kernel: [ 500.572765] audit: type=1400 audit(1596507855.308:238): apparmor="STATUS" operation="profile_replace" info="same as current profile, skipping" profile="unconfined" name="lxd-test_</var/snap/lxd/common/lxd>" pid=10174 comm="apparmor_parser"
Aug 3 22:24:15 cobalt kernel: [ 501.027327] audit: type=1400 audit(1596507855.764:239): apparmor="STATUS" operation="profile_load" label="lxd-test_</var/snap/lxd/common/lxd>//&:lxd-test_<var-snap-lxd-common-lxd>:unconfined" name="lsb_release" pid=10297 comm="apparmor_parser"
Aug 3 22:24:15 cobalt kernel: [ 501.029221] audit: type=1400 audit(1596507855.764:240): apparmor="STATUS" operation="profile_load" label="lxd-test_</var/snap/lxd/common/lxd>//&:lxd-test_<var-snap-lxd-common-lxd>:unconfined" name="/usr/sbin/tcpdump" pid=10303 comm="apparmor_parser"
Aug 3 22:24:15 cobalt kernel: [ 501.030221] audit: type=1400 audit(1596507855.768:241): apparmor="STATUS" operation="profile_load" label="lxd-test_</var/snap/lxd/common/lxd>//&:lxd-test_<var-snap-lxd-common-lxd>:unconfined" name="nvidia_modprobe" pid=10298 comm="apparmor_parser"
Aug 3 22:24:22 cobalt kernel: [ 508.156674] audit: type=1400 audit(1596507862.892:252): apparmor="DENIED" operation="open" profile="/snap/core/9665/usr/lib/snapd/snap-confine" name="/etc/pop-os/os-release" pid=10394 comm="snap-confine" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
Aug 3 22:24:22 cobalt kernel: [ 508.158444] audit: type=1400 audit(1596507862.896:253): apparmor="DENIED" operation="open" profile="snap.lxd.lxc" name="/var/lib/snapd/hostfs/etc/pop-os/os-release" pid=10394 comm="snap-exec" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
Aug 3 22:24:41 cobalt kernel: [ 526.461095] audit: type=1400 audit(1596507881.196:254): apparmor="DENIED" operation="open" profile="/snap/core/9665/usr/lib/snapd/snap-confine" name="/etc/pop-os/os-release" pid=10674 comm="snap-confine" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
Aug 3 22:24:41 cobalt kernel: [ 526.463269] audit: type=1400 audit(1596507881.200:255): apparmor="DENIED" operation="open" profile="snap.lxd.daemon" name="/var/lib/snapd/hostfs/etc/pop-os/os-release" pid=10674 comm="snap-exec" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
Aug 3 22:24:43 cobalt kernel: [ 529.094930] audit: type=1400 audit(1596507883.832:256): apparmor="DENIED" operation="open" profile="/snap/core/9665/usr/lib/snapd/snap-confine" name="/etc/pop-os/os-release" pid=10820 comm="snap-confine" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
Aug 3 22:24:43 cobalt kernel: [ 529.097012] audit: type=1400 audit(1596507883.832:257): apparmor="DENIED" operation="open" profile="snap.lxd.hook.remove" name="/var/lib/snapd/hostfs/etc/pop-os/os-release" pid=10820 comm="snap-exec" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
Aug 3 22:24:44 cobalt kernel: [ 529.812661] audit: type=1400 audit(1596507884.548:258): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="snap.lxd.check-kernel" pid=10929 comm="apparmor_parser"
Aug 3 22:24:44 cobalt kernel: [ 529.816587] audit: type=1400 audit(1596507884.552:259): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="snap.lxd.benchmark" pid=10927 comm="apparmor_parser"
Aug 3 22:24:44 cobalt kernel: [ 529.817249] audit: type=1400 audit(1596507884.552:260): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="snap.lxd.buginfo" pid=10928 comm="apparmor_parser"
Aug 3 22:24:44 cobalt kernel: [ 529.818305] audit: type=1400 audit(1596507884.556:261): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="snap.lxd.hook.install" pid=10932 comm="apparmor_parser"
Aug 3 22:24:44 cobalt kernel: [ 529.818686] audit: type=1400 audit(1596507884.556:262): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="snap.lxd.hook.remove" pid=10933 comm="apparmor_parser"
Aug 3 22:24:44 cobalt kernel: [ 529.820440] audit: type=1400 audit(1596507884.556:263): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="snap.lxd.activate" pid=10926 comm="apparmor_parser"
Aug 3 22:24:46 cobalt kernel: [ 531.625612] audit: type=1400 audit(1596507886.364:309): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="snap.lxd.check-kernel" pid=11100 comm="apparmor_parser"
Aug 3 22:24:46 cobalt kernel: [ 531.627364] audit: type=1400 audit(1596507886.364:310): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="snap.lxd.activate" pid=11097 comm="apparmor_parser"
Aug 3 22:24:46 cobalt kernel: [ 531.635189] audit: type=1400 audit(1596507886.372:311): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="snap.lxd.hook.remove" pid=11102 comm="apparmor_parser"
Aug 3 22:24:46 cobalt kernel: [ 531.636834] audit: type=1400 audit(1596507886.372:312): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="snap.lxd.daemon" pid=11101 comm="apparmor_parser"
Aug 3 22:24:46 cobalt kernel: [ 531.641081] audit: type=1400 audit(1596507886.376:313): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="snap.lxd.lxc" pid=11103 comm="apparmor_parser"
Aug 3 22:24:46 cobalt kernel: [ 531.642634] audit: type=1400 audit(1596507886.380:314): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="snap.lxd.lxc-to-lxd" pid=11104 comm="apparmor_parser"
Aug 3 22:24:46 cobalt kernel: [ 531.644962] audit: type=1400 audit(1596507886.380:315): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="snap.lxd.benchmark" pid=11098 comm="apparmor_parser"
Aug 3 22:24:46 cobalt kernel: [ 531.657229] audit: type=1400 audit(1596507886.392:316): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="snap.lxd.buginfo" pid=11099 comm="apparmor_parser"
Aug 3 22:24:46 cobalt kernel: [ 531.703039] audit: type=1400 audit(1596507886.440:317): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="snap.lxd.lxd" pid=11105 comm="apparmor_parser"
Aug 3 22:24:46 cobalt kernel: [ 531.703720] audit: type=1400 audit(1596507886.440:318): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="snap.lxd.migrate" pid=11106 comm="apparmor_parser"
Aug 3 22:26:47 cobalt kernel: [ 653.084407] audit: type=1400 audit(1596508007.824:326): apparmor="STATUS" operation="profile_replace" info="same as current profile, skipping" profile="unconfined" name="snap-update-ns.lxd" pid=12147 comm="apparmor_parser"
Aug 3 22:26:47 cobalt kernel: [ 653.210676] audit: type=1400 audit(1596508007.952:327): apparmor="STATUS" operation="profile_replace" info="same as current profile, skipping" profile="unconfined" name="snap.lxd.activate" pid=12148 comm="apparmor_parser"
Aug 3 22:26:47 cobalt kernel: [ 653.211557] audit: type=1400 audit(1596508007.952:328): apparmor="STATUS" operation="profile_replace" info="same as current profile, skipping" profile="unconfined" name="snap.lxd.check-kernel" pid=12151 comm="apparmor_parser"
Aug 3 22:26:47 cobalt kernel: [ 653.211657] audit: type=1400 audit(1596508007.952:329): apparmor="STATUS" operation="profile_replace" info="same as current profile, skipping" profile="unconfined" name="snap.lxd.hook.configure" pid=12153 comm="apparmor_parser"
Aug 3 22:26:47 cobalt kernel: [ 653.222218] audit: type=1400 audit(1596508007.964:330): apparmor="STATUS" operation="profile_replace" info="same as current profile, skipping" profile="unconfined" name="snap.lxd.buginfo" pid=12150 comm="apparmor_parser"
Aug 3 22:26:47 cobalt kernel: [ 653.223102] audit: type=1400 audit(1596508007.964:331): apparmor="STATUS" operation="profile_replace" info="same as current profile, skipping" profile="unconfined" name="snap.lxd.benchmark" pid=12149 comm="apparmor_parser"
Aug 3 22:26:47 cobalt kernel: [ 653.225129] audit: type=1400 audit(1596508007.964:332): apparmor="STATUS" operation="profile_replace" info="same as current profile, skipping" profile="unconfined" name="snap.lxd.hook.install" pid=12154 comm="apparmor_parser"
Aug 3 22:26:47 cobalt kernel: [ 653.228249] audit: type=1400 audit(1596508007.968:333): apparmor="STATUS" operation="profile_replace" info="same as current profile, skipping" profile="unconfined" name="snap.lxd.daemon" pid=12152 comm="apparmor_parser"
Aug 3 22:26:47 cobalt kernel: [ 653.246074] audit: type=1400 audit(1596508007.988:334): apparmor="STATUS" operation="profile_replace" info="same as current profile, skipping" profile="unconfined" name="snap.lxd.hook.remove" pid=12155 comm="apparmor_parser"
Aug 3 22:26:48 cobalt kernel: [ 653.285157] audit: type=1400 audit(1596508008.024:335): apparmor="STATUS" operation="profile_replace" info="same as current profile, skipping" profile="unconfined" name="snap.lxd.migrate" pid=12161 comm="apparmor_parser"
Aug 3 22:27:47 cobalt kernel: [ 712.834583] audit: type=1400 audit(1596508067.577:377): apparmor="DENIED" operation="open" profile="/snap/core/9665/usr/lib/snapd/snap-confine" name="/etc/pop-os/os-release" pid=12839 comm="snap-confine" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
Aug 3 22:27:47 cobalt kernel: [ 712.836613] audit: type=1400 audit(1596508067.577:378): apparmor="DENIED" operation="open" profile="snap.lxd.lxd" name="/etc/pop-os/os-release" pid=12839 comm="snap-exec" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
Aug 3 22:28:51 cobalt kernel: [ 0.321412] AppArmor: AppArmor initialized
Aug 3 22:28:51 cobalt kernel: [ 0.683224] AppArmor: AppArmor Filesystem Enabled
Aug 3 22:28:51 cobalt kernel: [ 1.687563] AppArmor: AppArmor sha1 policy hashing enabled
Aug 3 22:28:51 cobalt kernel: [ 1.689147] evm: security.apparmor
Aug 3 22:28:51 cobalt kernel: [ 40.850600] audit: type=1400 audit(1596508130.653:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libvirtd" pid=1637 comm="apparmor_parser"
Aug 3 22:28:51 cobalt kernel: [ 40.850603] audit: type=1400 audit(1596508130.653:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libvirtd//qemu_bridge_helper" pid=1637 comm="apparmor_parser"
Aug 3 22:28:51 cobalt kernel: [ 40.851078] audit: type=1400 audit(1596508130.657:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/haveged" pid=1638 comm="apparmor_parser"
Aug 3 22:28:51 cobalt kernel: [ 40.852003] audit: type=1400 audit(1596508130.657:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="ippusbxd" pid=1639 comm="apparmor_parser"
Aug 3 22:28:51 cobalt kernel: [ 40.852445] audit: type=1400 audit(1596508130.657:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="virt-aa-helper" pid=1635 comm="apparmor_parser"
Aug 3 22:28:51 cobalt kernel: [ 40.854102] audit: type=1400 audit(1596508130.657:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/lxc-start" pid=1641 comm="apparmor_parser"
Aug 3 22:28:51 cobalt kernel: [ 40.855837] audit: type=1400 audit(1596508130.661:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/cups-browsed" pid=1633 comm="apparmor_parser"
Aug 3 22:28:51 cobalt kernel: [ 40.860716] audit: type=1400 audit(1596508130.665:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=1645 comm="apparmor_parser"
Aug 3 22:28:51 cobalt kernel: [ 40.860719] audit: type=1400 audit(1596508130.665:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/NetworkManager/nm-dhcp-helper" pid=1645 comm="apparmor_parser"
Aug 3 22:28:51 cobalt kernel: [ 40.860722] audit: type=1400 audit(1596508130.665:11): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/connman/scripts/dhclient-script" pid=1645 comm="apparmor_parser"
Aug 3 22:29:21 cobalt kernel: [ 71.666246] audit: type=1400 audit(1596508161.469:85): apparmor="STATUS" operation="profile_replace" info="same as current profile, skipping" profile="unconfined" name="/usr/bin/lxc-start" pid=3692 comm="apparmor_parser"
Aug 3 22:29:21 cobalt kernel: [ 71.685771] audit: type=1400 audit(1596508161.489:86): apparmor="STATUS" operation="profile_replace" info="same as current profile, skipping" profile="unconfined" name="lxc-container-default" pid=3701 comm="apparmor_parser"
Aug 3 22:29:21 cobalt kernel: [ 71.685775] audit: type=1400 audit(1596508161.489:87): apparmor="STATUS" operation="profile_replace" info="same as current profile, skipping" profile="unconfined" name="lxc-container-default-cgns" pid=3701 comm="apparmor_parser"
Aug 3 22:29:21 cobalt kernel: [ 71.685777] audit: type=1400 audit(1596508161.489:88): apparmor="STATUS" operation="profile_replace" info="same as current profile, skipping" profile="unconfined" name="lxc-container-default-with-mounting" pid=3701 comm="apparmor_parser"
Aug 3 22:29:21 cobalt kernel: [ 71.685779] audit: type=1400 audit(1596508161.489:89): apparmor="STATUS" operation="profile_replace" info="same as current profile, skipping" profile="unconfined" name="lxc-container-default-with-nesting" pid=3701 comm="apparmor_parser"
Aug 3 22:29:22 cobalt kernel: [ 72.990470] audit: type=1400 audit(1596508162.776:90): apparmor="DENIED" operation="open" profile="/snap/core/9665/usr/lib/snapd/snap-confine" name="/etc/pop-os/os-release" pid=3743 comm="snap-confine" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
Aug 3 22:29:22 cobalt kernel: [ 72.992333] audit: type=1400 audit(1596508162.776:91): apparmor="DENIED" operation="open" profile="snap.lxd.lxd" name="/etc/pop-os/os-release" pid=3743 comm="snap-exec" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
Aug 3 22:29:23 cobalt kernel: [ 73.641860] audit: type=1400 audit(1596508163.411:92): apparmor="DENIED" operation="open" profile="/snap/core/9665/usr/lib/snapd/snap-confine" name="/etc/pop-os/os-release" pid=3784 comm="snap-confine" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
Aug 3 22:29:23 cobalt kernel: [ 73.643936] audit: type=1400 audit(1596508163.411:93): apparmor="DENIED" operation="open" profile="snap.lxd.daemon" name="/etc/pop-os/os-release" pid=3784 comm="snap-exec" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
Aug 3 22:30:13 cobalt kernel: [ 123.754891] audit: type=1400 audit(1596508213.357:94): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lxd_dnsmasq-lxdbr0_</var/snap/lxd/common/lxd>" pid=4165 comm="apparmor_parser"
Aug 3 22:30:13 cobalt kernel: [ 123.758085] audit: type=1400 audit(1596508213.357:95): apparmor="DENIED" operation="open" profile="lxd_dnsmasq-lxdbr0_</var/snap/lxd/common/lxd>" name="/home/lxd/common/lxd/networks/lxdbr0/dnsmasq.raw" pid=4169 comm="dnsmasq" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
Aug 3 22:30:32 cobalt kernel: [ 143.184459] audit: type=1400 audit(1596508232.790:96): apparmor="DENIED" operation="open" profile="/snap/core/9665/usr/lib/snapd/snap-confine" name="/etc/pop-os/os-release" pid=4248 comm="snap-confine" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
Aug 3 22:30:32 cobalt kernel: [ 143.186696] audit: type=1400 audit(1596508232.794:97): apparmor="DENIED" operation="open" profile="snap.lxd.lxc" name="/var/lib/snapd/hostfs/etc/pop-os/os-release" pid=4248 comm="snap-exec" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
Aug 3 22:30:35 cobalt kernel: [ 146.368440] audit: type=1400 audit(1596508235.975:98): apparmor="DENIED" operation="open" profile="/snap/core/9665/usr/lib/snapd/snap-confine" name="/etc/pop-os/os-release" pid=4291 comm="snap-confine" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
Aug 3 22:30:35 cobalt kernel: [ 146.370502] audit: type=1400 audit(1596508235.979:99): apparmor="DENIED" operation="open" profile="snap.lxd.lxc" name="/var/lib/snapd/hostfs/etc/pop-os/os-release" pid=4291 comm="snap-exec" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
Aug 3 22:30:36 cobalt kernel: [ 146.418109] audit: type=1400 audit(1596508236.027:100): apparmor="DENIED" operation="open" profile="/snap/core/9665/usr/lib/snapd/snap-confine" name="/etc/pop-os/os-release" pid=4326 comm="snap-confine" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
Aug 3 22:30:36 cobalt kernel: [ 146.419758] audit: type=1400 audit(1596508236.027:101): apparmor="DENIED" operation="open" profile="snap.lxd.lxc" name="/var/lib/snapd/hostfs/etc/pop-os/os-release" pid=4326 comm="snap-exec" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
Aug 3 22:30:36 cobalt kernel: [ 146.460410] audit: type=1400 audit(1596508236.067:102): apparmor="DENIED" operation="open" profile="/snap/core/9665/usr/lib/snapd/snap-confine" name="/etc/pop-os/os-release" pid=4361 comm="snap-confine" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
Aug 3 22:30:36 cobalt kernel: [ 146.461945] audit: type=1400 audit(1596508236.071:103): apparmor="DENIED" operation="open" profile="snap.lxd.lxc" name="/var/lib/snapd/hostfs/etc/pop-os/os-release" pid=4361 comm="snap-exec" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
Aug 3 22:30:36 cobalt kernel: [ 146.494546] audit: type=1400 audit(1596508236.103:104): apparmor="DENIED" operation="open" profile="/snap/core/9665/usr/lib/snapd/snap-confine" name="/etc/pop-os/os-release" pid=4395 comm="snap-confine" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
Aug 3 22:30:36 cobalt kernel: [ 146.496195] audit: type=1400 audit(1596508236.103:105): apparmor="DENIED" operation="open" profile="snap.lxd.lxc" name="/var/lib/snapd/hostfs/etc/pop-os/os-release" pid=4395 comm="snap-exec" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
Aug 3 22:30:42 cobalt kernel: [ 152.628635] audit: type=1400 audit(1596508242.240:108): apparmor="DENIED" operation="open" profile="/snap/core/9665/usr/lib/snapd/snap-confine" name="/etc/pop-os/os-release" pid=4462 comm="snap-confine" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
Aug 3 22:30:42 cobalt kernel: [ 152.630971] audit: type=1400 audit(1596508242.240:109): apparmor="DENIED" operation="open" profile="snap.lxd.lxc" name="/var/lib/snapd/hostfs/etc/pop-os/os-release" pid=4462 comm="snap-exec" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
Aug 3 22:30:53 cobalt kernel: [ 163.923771] audit: type=1400 audit(1596508253.534:110): apparmor="DENIED" operation="open" profile="/snap/core/9665/usr/lib/snapd/snap-confine" name="/etc/pop-os/os-release" pid=4497 comm="snap-confine" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
Aug 3 22:30:53 cobalt kernel: [ 163.925891] audit: type=1400 audit(1596508253.534:111): apparmor="DENIED" operation="open" profile="snap.lxd.lxc" name="/var/lib/snapd/hostfs/etc/pop-os/os-release" pid=4497 comm="snap-exec" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
Aug 3 22:30:59 cobalt kernel: [ 170.033005] audit: type=1400 audit(1596508259.642:112): apparmor="DENIED" operation="open" profile="/snap/core/9665/usr/lib/snapd/snap-confine" name="/etc/pop-os/os-release" pid=4554 comm="snap-confine" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
Aug 3 22:30:59 cobalt kernel: [ 170.033256] audit: type=1400 audit(1596508259.642:113): apparmor="DENIED" operation="open" profile="/snap/core/9665/usr/lib/snapd/snap-confine" name="/etc/pop-os/os-release" pid=4554 comm="snap-confine" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
Aug 3 22:30:59 cobalt kernel: [ 170.044430] audit: type=1400 audit(1596508259.654:114): apparmor="DENIED" operation="open" profile="snap-update-ns.chromium" name="/etc/pop-os/os-release" pid=4605 comm="5" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
Aug 3 22:30:59 cobalt kernel: [ 170.074068] audit: type=1400 audit(1596508259.682:115): apparmor="DENIED" operation="open" profile="snap-update-ns.chromium" name="/etc/pop-os/os-release" pid=4612 comm="5" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
Aug 3 22:30:59 cobalt kernel: [ 170.082083] audit: type=1400 audit(1596508259.690:116): apparmor="DENIED" operation="open" profile="snap.chromium.chromium" name="/etc/pop-os/os-release" pid=4554 comm="snap-exec" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
Aug 3 22:30:59 cobalt kernel: [ 170.189630] audit: type=1400 audit(1596508259.798:117): apparmor="DENIED" operation="open" profile="snap.chromium.chromium" name="/home/toochevere/.Public/" pid=4668 comm="head" requested_mask="r" denied_mask="r" fsuid=1000 ouid=1000
Aug 3 22:30:59 cobalt kernel: [ 170.334781] audit: type=1400 audit(1596508259.945:118): apparmor="DENIED" operation="open" profile="snap.chromium.chromium" name="/etc/pop-os/os-release" pid=4702 comm="snapctl" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
Aug 3 22:31:14 cobalt kernel: [ 185.058321] audit: type=1400 audit(1596508274.659:191): apparmor="DENIED" operation="open" profile="snap.chromium.chromium" name="/etc/pop-os/os-release" pid=4554 comm="ThreadPoolForeg" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
Aug 3 22:31:14 cobalt kernel: [ 185.081734] audit: type=1400 audit(1596508274.683:192): apparmor="DENIED" operation="open" profile="snap.chromium.chromium" name="/run/udev/data/+thunderbolt:domain0" pid=4554 comm="ThreadPoolForeg" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
Aug 3 22:31:14 cobalt kernel: [ 185.081833] audit: type=1400 audit(1596508274.683:193): apparmor="DENIED" operation="open" profile="snap.chromium.chromium" name="/run/udev/data/+thunderbolt:0-0" pid=4554 comm="ThreadPoolForeg" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
Aug 3 22:32:20 cobalt kernel: [ 251.155077] audit: type=1400 audit(1596508340.740:194): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lxd-test_</var/snap/lxd/common/lxd>" pid=6417 comm="apparmor_parser"
Aug 3 22:32:21 cobalt kernel: [ 251.976032] audit: type=1400 audit(1596508341.560:195): apparmor="STATUS" operation="profile_load" label="lxd-test_</var/snap/lxd/common/lxd>//&:lxd-test_<var-snap-lxd-common-lxd>:unconfined" name="lsb_release" pid=6574 comm="apparmor_parser"
Aug 3 22:32:21 cobalt kernel: [ 251.996414] audit: type=1400 audit(1596508341.584:196): apparmor="STATUS" operation="profile_load" label="lxd-test_</var/snap/lxd/common/lxd>//&:lxd-test_<var-snap-lxd-common-lxd>:unconfined" name="nvidia_modprobe" pid=6575 comm="apparmor_parser"
Aug 3 22:32:21 cobalt kernel: [ 251.996902] audit: type=1400 audit(1596508341.584:197): apparmor="STATUS" operation="profile_load" label="lxd-test_</var/snap/lxd/common/lxd>//&:lxd-test_<var-snap-lxd-common-lxd>:unconfined" name="nvidia_modprobe//kmod" pid=6575 comm="apparmor_parser"
Aug 3 22:32:21 cobalt kernel: [ 252.030150] audit: type=1400 audit(1596508341.616:198): apparmor="STATUS" operation="profile_load" label="lxd-test_</var/snap/lxd/common/lxd>//&:lxd-test_<var-snap-lxd-common-lxd>:unconfined" name="/usr/bin/man" pid=6577 comm="apparmor_parser"
Aug 3 22:32:21 cobalt kernel: [ 252.030641] audit: type=1400 audit(1596508341.616:199): apparmor="STATUS" operation="profile_load" label="lxd-test_</var/snap/lxd/common/lxd>//&:lxd-test_<var-snap-lxd-common-lxd>:unconfined" name="man_filter" pid=6577 comm="apparmor_parser"
Aug 3 22:32:21 cobalt kernel: [ 252.031014] audit: type=1400 audit(1596508341.616:200): apparmor="STATUS" operation="profile_load" label="lxd-test_</var/snap/lxd/common/lxd>//&:lxd-test_<var-snap-lxd-common-lxd>:unconfined" name="man_groff" pid=6577 comm="apparmor_parser"
Aug 3 22:32:21 cobalt kernel: [ 252.089958] audit: type=1400 audit(1596508341.676:201): apparmor="STATUS" operation="profile_load" label="lxd-test_</var/snap/lxd/common/lxd>//&:lxd-test_<var-snap-lxd-common-lxd>:unconfined" name="/usr/sbin/tcpdump" pid=6580 comm="apparmor_parser"
Aug 3 22:32:21 cobalt kernel: [ 252.188066] audit: type=1400 audit(1596508341.772:202): apparmor="STATUS" operation="profile_load" label="lxd-test_</var/snap/lxd/common/lxd>//&:lxd-test_<var-snap-lxd-common-lxd>:unconfined" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=6576 comm="apparmor_parser"
Aug 3 22:32:21 cobalt kernel: [ 252.188543] audit: type=1400 audit(1596508341.776:203): apparmor="STATUS" operation="profile_load" label="lxd-test_</var/snap/lxd/common/lxd>//&:lxd-test_<var-snap-lxd-common-lxd>:unconfined" name="/usr/lib/NetworkManager/nm-dhcp-helper" pid=6576 comm="apparmor_parser"
Aug 3 22:32:40 cobalt kernel: [ 271.400155] audit: type=1400 audit(1596508360.983:208): apparmor="DENIED" operation="open" profile="/snap/core/9665/usr/lib/snapd/snap-confine" name="/etc/pop-os/os-release" pid=6709 comm="snap-confine" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
Aug 3 22:32:40 cobalt kernel: [ 271.401876] audit: type=1400 audit(1596508360.987:209): apparmor="DENIED" operation="open" profile="snap.lxd.lxc" name="/var/lib/snapd/hostfs/etc/pop-os/os-release" pid=6709 comm="snap-exec" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
Aug 3 22:32:42 cobalt kernel: [ 272.981759] audit: type=1400 audit(1596508362.567:210): apparmor="DENIED" operation="open" profile="/snap/core/9665/usr/lib/snapd/snap-confine" name="/etc/pop-os/os-release" pid=7247 comm="snap-confine" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
Aug 3 22:32:42 cobalt kernel: [ 272.983405] audit: type=1400 audit(1596508362.567:211): apparmor="DENIED" operation="open" profile="snap.lxd.lxc" name="/var/lib/snapd/hostfs/etc/pop-os/os-release" pid=7247 comm="snap-exec" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
Aug 3 22:32:42 cobalt kernel: [ 273.040932] audit: type=1400 audit(1596508362.623:212): apparmor="DENIED" operation="open" profile="/snap/core/9665/usr/lib/snapd/snap-confine" name="/etc/pop-os/os-release" pid=7281 comm="snap-confine" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
Aug 3 22:32:42 cobalt kernel: [ 273.042574] audit: type=1400 audit(1596508362.627:213): apparmor="DENIED" operation="open" profile="snap.lxd.lxc" name="/var/lib/snapd/hostfs/etc/pop-os/os-release" pid=7281 comm="snap-exec" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
Aug 3 22:32:42 cobalt kernel: [ 273.198463] audit: type=1400 audit(1596508362.783:214): apparmor="STATUS" operation="profile_replace" info="same as current profile, skipping" profile="unconfined" name="lxd-test_</var/snap/lxd/common/lxd>" pid=7370 comm="apparmor_parser"
Aug 3 22:32:43 cobalt kernel: [ 273.616793] audit: type=1400 audit(1596508363.199:215): apparmor="STATUS" operation="profile_load" label="lxd-test_</var/snap/lxd/common/lxd>//&:lxd-test_<var-snap-lxd-common-lxd>:unconfined" name="lsb_release" pid=7491 comm="apparmor_parser"
Aug 3 22:32:43 cobalt kernel: [ 273.617201] audit: type=1400 audit(1596508363.199:216): apparmor="STATUS" operation="profile_load" label="lxd-test_</var/snap/lxd/common/lxd>//&:lxd-test_<var-snap-lxd-common-lxd>:unconfined" name="nvidia_modprobe" pid=7492 comm="apparmor_parser"
Aug 3 22:32:43 cobalt kernel: [ 273.617205] audit: type=1400 audit(1596508363.199:217): apparmor="STATUS" operation="profile_load" label="lxd-test_</var/snap/lxd/common/lxd>//&:lxd-test_<var-snap-lxd-common-lxd>:unconfined" name="nvidia_modprobe//kmod" pid=7492 comm="apparmor_parser"
Aug 3 22:32:52 cobalt kernel: [ 283.373693] audit: type=1400 audit(1596508372.958:228): apparmor="DENIED" operation="open" profile="/snap/core/9665/usr/lib/snapd/snap-confine" name="/etc/pop-os/os-release" pid=7558 comm="snap-confine" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
Aug 3 22:32:52 cobalt kernel: [ 283.376064] audit: type=1400 audit(1596508372.958:229): apparmor="DENIED" operation="open" profile="snap.lxd.lxc" name="/var/lib/snapd/hostfs/etc/pop-os/os-release" pid=7558 comm="snap-exec" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
Aug 3 22:32:53 cobalt kernel: [ 283.425445] audit: type=1400 audit(1596508373.006:230): apparmor="DENIED" operation="open" profile="/snap/core/9665/usr/lib/snapd/snap-confine" name="/etc/pop-os/os-release" pid=7597 comm="snap-confine" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
Aug 3 22:32:53 cobalt kernel: [ 283.427428] audit: type=1400 audit(1596508373.010:231): apparmor="DENIED" operation="open" profile="snap.lxd.lxc" name="/var/lib/snapd/hostfs/etc/pop-os/os-release" pid=7597 comm="snap-exec" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
Aug 3 22:32:53 cobalt kernel: [ 284.275680] audit: type=1400 audit(1596508373.858:232): apparmor="DENIED" operation="open" profile="/snap/core/9665/usr/lib/snapd/snap-confine" name="/etc/pop-os/os-release" pid=7757 comm="snap-confine" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
Aug 3 22:32:53 cobalt kernel: [ 284.277485] audit: type=1400 audit(1596508373.858:233): apparmor="DENIED" operation="open" profile="snap.lxd.lxc" name="/var/lib/snapd/hostfs/etc/pop-os/os-release" pid=7757 comm="snap-exec" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
Aug 3 22:33:03 cobalt kernel: [ 294.382714] audit: type=1400 audit(1596508383.966:234): apparmor="DENIED" operation="open" profile="/snap/core/9665/usr/lib/snapd/snap-confine" name="/etc/pop-os/os-release" pid=7835 comm="snap-confine" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
Aug 3 22:33:03 cobalt kernel: [ 294.384678] audit: type=1400 audit(1596508383.966:235): apparmor="DENIED" operation="open" profile="snap.lxd.lxc" name="/var/lib/snapd/hostfs/etc/pop-os/os-release" pid=7835 comm="snap-exec" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
Aug 3 22:33:05 cobalt kernel: [ 295.799955] audit: type=1400 audit(1596508385.382:236): apparmor="DENIED" operation="open" profile="/snap/core/9665/usr/lib/snapd/snap-confine" name="/etc/pop-os/os-release" pid=8382 comm="snap-confine" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
Aug 3 22:33:05 cobalt kernel: [ 295.801966] audit: type=1400 audit(1596508385.386:237): apparmor="DENIED" operation="open" profile="snap.lxd.lxc" name="/var/lib/snapd/hostfs/etc/pop-os/os-release" pid=8382 comm="snap-exec" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
Aug 3 22:33:05 cobalt kernel: [ 295.847021] audit: type=1400 audit(1596508385.430:238): apparmor="DENIED" operation="open" profile="/snap/core/9665/usr/lib/snapd/snap-confine" name="/etc/pop-os/os-release" pid=8416 comm="snap-confine" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
Aug 3 22:33:05 cobalt kernel: [ 295.848712] audit: type=1400 audit(1596508385.430:239): apparmor="DENIED" operation="open" profile="snap.lxd.lxc" name="/var/lib/snapd/hostfs/etc/pop-os/os-release" pid=8416 comm="snap-exec" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
Aug 3 22:33:05 cobalt kernel: [ 295.990260] audit: type=1400 audit(1596508385.574:240): apparmor="STATUS" operation="profile_replace" info="same as current profile, skipping" profile="unconfined" name="lxd-test_</var/snap/lxd/common/lxd>" pid=8507 comm="apparmor_parser"
Aug 3 22:33:06 cobalt kernel: [ 296.422811] audit: type=1400 audit(1596508386.006:241): apparmor="STATUS" operation="profile_load" label="lxd-test_</var/snap/lxd/common/lxd>//&:lxd-test_<var-snap-lxd-common-lxd>:unconfined" name="lsb_release" pid=8629 comm="apparmor_parser"
Aug 3 22:33:06 cobalt kernel: [ 296.423172] audit: type=1400 audit(1596508386.006:242): apparmor="STATUS" operation="profile_load" label="lxd-test_</var/snap/lxd/common/lxd>//&:lxd-test_<var-snap-lxd-common-lxd>:unconfined" name="nvidia_modprobe" pid=8630 comm="apparmor_parser"
Aug 3 22:33:06 cobalt kernel: [ 296.423175] audit: type=1400 audit(1596508386.006:243): apparmor="STATUS" operation="profile_load" label="lxd-test_</var/snap/lxd/common/lxd>//&:lxd-test_<var-snap-lxd-common-lxd>:unconfined" name="nvidia_modprobe//kmod" pid=8630 comm="apparmor_parser"
Aug 3 22:33:15 cobalt kernel: [ 306.185744] audit: type=1400 audit(1596508395.766:254): apparmor="DENIED" operation="open" profile="/snap/core/9665/usr/lib/snapd/snap-confine" name="/etc/pop-os/os-release" pid=8700 comm="snap-confine" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
Aug 3 22:33:15 cobalt kernel: [ 306.188182] audit: type=1400 audit(1596508395.770:255): apparmor="DENIED" operation="open" profile="snap.lxd.lxc" name="/var/lib/snapd/hostfs/etc/pop-os/os-release" pid=8700 comm="snap-exec" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
Aug 3 22:33:15 cobalt kernel: [ 306.244369] audit: type=1400 audit(1596508395.826:256): apparmor="DENIED" operation="open" profile="/snap/core/9665/usr/lib/snapd/snap-confine" name="/etc/pop-os/os-release" pid=8738 comm="snap-confine" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
Aug 3 22:33:15 cobalt kernel: [ 306.246512] audit: type=1400 audit(1596508395.830:257): apparmor="DENIED" operation="open" profile="snap.lxd.lxc" name="/var/lib/snapd/hostfs/etc/pop-os/os-release" pid=8738 comm="snap-exec" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
Aug 3 22:33:15 cobalt kernel: [ 306.338635] audit: type=1400 audit(1596508395.922:258): apparmor="DENIED" operation="open" profile="/snap/core/9665/usr/lib/snapd/snap-confine" name="/etc/pop-os/os-release" pid=8785 comm="snap-confine" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
Aug 3 22:33:15 cobalt kernel: [ 306.341697] audit: type=1400 audit(1596508395.922:259): apparmor="DENIED" operation="open" profile="snap.lxd.lxc" name="/var/lib/snapd/hostfs/etc/pop-os/os-release" pid=8785 comm="snap-exec" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
Aug 3 22:33:26 cobalt kernel: [ 316.495627] audit: type=1400 audit(1596508406.078:260): apparmor="DENIED" operation="open" profile="/snap/core/9665/usr/lib/snapd/snap-confine" name="/etc/pop-os/os-release" pid=8860 comm="snap-confine" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
Aug 3 22:33:26 cobalt kernel: [ 316.497969] audit: type=1400 audit(1596508406.078:261): apparmor="DENIED" operation="open" profile="snap.lxd.lxc" name="/var/lib/snapd/hostfs/etc/pop-os/os-release" pid=8860 comm="snap-exec" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
Aug 3 22:33:27 cobalt kernel: [ 317.846886] audit: type=1400 audit(1596508407.430:262): apparmor="DENIED" operation="open" profile="/snap/core/9665/usr/lib/snapd/snap-confine" name="/etc/pop-os/os-release" pid=9390 comm="snap-confine" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
Aug 3 22:33:27 cobalt kernel: [ 317.848537] audit: type=1400 audit(1596508407.430:263): apparmor="DENIED" operation="open" profile="snap.lxd.lxc" name="/var/lib/snapd/hostfs/etc/pop-os/os-release" pid=9390 comm="snap-exec" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
Aug 3 22:33:27 cobalt kernel: [ 317.900080] audit: type=1400 audit(1596508407.482:264): apparmor="DENIED" operation="open" profile="/snap/core/9665/usr/lib/snapd/snap-confine" name="/etc/pop-os/os-release" pid=9424 comm="snap-confine" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
Aug 3 22:33:27 cobalt kernel: [ 317.902553] audit: type=1400 audit(1596508407.486:265): apparmor="DENIED" operation="open" profile="snap.lxd.lxc" name="/var/lib/snapd/hostfs/etc/pop-os/os-release" pid=9424 comm="snap-exec" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
Aug 3 22:33:27 cobalt kernel: [ 317.971638] audit: type=1400 audit(1596508407.554:266): apparmor="DENIED" operation="open" profile="/snap/core/9665/usr/lib/snapd/snap-confine" name="/etc/pop-os/os-release" pid=9456 comm="snap-confine" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
Aug 3 22:33:27 cobalt kernel: [ 317.973339] audit: type=1400 audit(1596508407.554:267): apparmor="DENIED" operation="open" profile="snap.lxd.lxc" name="/var/lib/snapd/hostfs/etc/pop-os/os-release" pid=9456 comm="snap-exec" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
Aug 3 22:33:29 cobalt kernel: [ 320.395336] audit: type=1400 audit(1596508409.978:268): apparmor="STATUS" operation="profile_replace" info="same as current profile, skipping" profile="unconfined" name="lxd-test_</var/snap/lxd/common/lxd>" pid=9553 comm="apparmor_parser"
Aug 3 22:33:30 cobalt kernel: [ 320.957587] audit: type=1400 audit(1596508410.538:269): apparmor="STATUS" operation="profile_load" label="lxd-test_</var/snap/lxd/common/lxd>//&:lxd-test_<var-snap-lxd-common-lxd>:unconfined" name="lsb_release" pid=9673 comm="apparmor_parser"
Aug 3 22:33:40 cobalt kernel: [ 330.635515] audit: type=1400 audit(1596508420.218:282): apparmor="DENIED" operation="open" profile="/snap/core/9665/usr/lib/snapd/snap-confine" name="/etc/pop-os/os-release" pid=9726 comm="snap-confine" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
Aug 3 22:33:40 cobalt kernel: [ 330.637856] audit: type=1400 audit(1596508420.218:283): apparmor="DENIED" operation="open" profile="snap.lxd.lxc" name="/var/lib/snapd/hostfs/etc/pop-os/os-release" pid=9726 comm="snap-exec" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
Aug 3 22:33:40 cobalt kernel: [ 330.700559] audit: type=1400 audit(1596508420.282:284): apparmor="DENIED" operation="open" profile="/snap/core/9665/usr/lib/snapd/snap-confine" name="/etc/pop-os/os-release" pid=9765 comm="snap-confine" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
Aug 3 22:33:40 cobalt kernel: [ 330.702439] audit: type=1400 audit(1596508420.286:285): apparmor="DENIED" operation="open" profile="snap.lxd.lxc" name="/var/lib/snapd/hostfs/etc/pop-os/os-release" pid=9765 comm="snap-exec" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
Aug 3 22:33:40 cobalt kernel: [ 330.794208] audit: type=1400 audit(1596508420.378:286): apparmor="DENIED" operation="open" profile="/snap/core/9665/usr/lib/snapd/snap-confine" name="/etc/pop-os/os-release" pid=9810 comm="snap-confine" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
Aug 3 22:33:40 cobalt kernel: [ 330.797141] audit: type=1400 audit(1596508420.378:287): apparmor="DENIED" operation="open" profile="snap.lxd.lxc" name="/var/lib/snapd/hostfs/etc/pop-os/os-release" pid=9810 comm="snap-exec" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
Aug 3 22:33:50 cobalt kernel: [ 340.910519] audit: type=1400 audit(1596508430.494:288): apparmor="DENIED" operation="open" profile="/snap/core/9665/usr/lib/snapd/snap-confine" name="/etc/pop-os/os-release" pid=9890 comm="snap-confine" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
Aug 3 22:33:50 cobalt kernel: [ 340.912547] audit: type=1400 audit(1596508430.494:289): apparmor="DENIED" operation="open" profile="snap.lxd.lxc" name="/var/lib/snapd/hostfs/etc/pop-os/os-release" pid=9890 comm="snap-exec" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
Aug 3 22:33:51 cobalt kernel: [ 342.265548] audit: type=1400 audit(1596508431.846:290): apparmor="DENIED" operation="open" profile="/snap/core/9665/usr/lib/snapd/snap-confine" name="/etc/pop-os/os-release" pid=10419 comm="snap-confine" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
Aug 3 22:33:51 cobalt kernel: [ 342.267369] audit: type=1400 audit(1596508431.850:291): apparmor="DENIED" operation="open" profile="snap.lxd.lxc" name="/var/lib/snapd/hostfs/etc/pop-os/os-release" pid=10419 comm="snap-exec" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
Aug 3 22:33:51 cobalt kernel: [ 342.320207] audit: type=1400 audit(1596508431.902:292): apparmor="DENIED" operation="open" profile="/snap/core/9665/usr/lib/snapd/snap-confine" name="/etc/pop-os/os-release" pid=10455 comm="snap-confine" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
Aug 3 22:33:51 cobalt kernel: [ 342.321973] audit: type=1400 audit(1596508431.902:293): apparmor="DENIED" operation="open" profile="snap.lxd.lxc" name="/var/lib/snapd/hostfs/etc/pop-os/os-release" pid=10455 comm="snap-exec" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
