Hello.
Suddenly I can’t create new containers (or at least they won’t start of come online). This has worked before.
This is how it looks when I try to start them:
$ lxc launch ubuntu:focal tunis1:c1
Creating c1
Starting c1
Error: Failed to run: /snap/lxd/current/bin/lxd forkstart c1 /var/snap/lxd/common/lxd/containers /var/snap/lxd/common/lxd/logs/c1/lxc.conf: exit status 1
Try `lxc info --show-log tunis1:c1` for more info
$ lxc info --show-log tunis1:c1
Status: STOPPED
Type: container
Created: 2023/05/08 14:12 CEST
Last Used: 2023/05/08 14:12 CEST
Log:
lxc c1 20230508121234.787 WARN conf - ../src/src/lxc/conf.c:lxc_map_ids:3621 - newuidmap binary is missing
lxc c1 20230508121234.787 WARN conf - ../src/src/lxc/conf.c:lxc_map_ids:3627 - newgidmap binary is missing
lxc c1 20230508121234.788 WARN conf - ../src/src/lxc/conf.c:lxc_map_ids:3621 - newuidmap binary is missing
lxc c1 20230508121234.788 WARN conf - ../src/src/lxc/conf.c:lxc_map_ids:3627 - newgidmap binary is missing
lxc c1 20230508121234.788 WARN cgfsng - ../src/src/lxc/cgroups/cgfsng.c:fchowmodat:1619 - No such file or directory - Failed to fchownat(40, memory.oom.group, 1000000000, 0, AT_EMPTY_PATH | AT_SYMLINK_NOFOLLOW )
lxc c1 20230508121234.791 WARN start - ../src/src/lxc/start.c:lxc_spawn:1832 - Bad file descriptor - Failed to allocate new network namespace id
lxc c1 20230508121234.797 ERROR network - ../src/src/lxc/network.c:lxc_network_move_created_netdev_priv:3549 - No such process - Failed to move network device "veth685074f6" with ifindex 188 to network namespace 3348002 and rename to physYIbNno
lxc c1 20230508121234.798 ERROR start - ../src/src/lxc/start.c:lxc_spawn:1840 - Failed to create the network
lxc c1 20230508121234.801 ERROR lxccontainer - ../src/src/lxc/lxccontainer.c:wait_on_daemonized_start:878 - Received container state "ABORTING" instead of "RUNNING"
lxc c1 20230508121234.801 ERROR start - ../src/src/lxc/start.c:__lxc_start:2107 - Failed to spawn container "c1"
lxc c1 20230508121234.801 WARN start - ../src/src/lxc/start.c:lxc_abort:1036 - No such process - Failed to send SIGKILL via pidfd 41 for process 3348002
lxc 20230508121234.821 ERROR af_unix - ../src/src/lxc/af_unix.c:lxc_abstract_unix_recv_fds_iov:218 - Connection reset by peer - Failed to receive response
lxc 20230508121234.821 ERROR commands - ../src/src/lxc/commands.c:lxc_cmd_rsp_recv_fds:128 - Failed to receive file descriptors for command "get_init_pid"
The containers seems to have been partially started, but something prevents them (new containers) from starting:
$ lxc list tunis1:
| c1 | STOPPED | | | CONTAINER | 0 |
| juju-3eef05-0 | RUNNING | 192.168.151.46 (eth0) | | CONTAINER | 0 |
| juju-f2d3e9-0 | STOPPED | | | CONTAINER | 0 |
| juju-f2d3e9-1 | STOPPED | | | CONTAINER | 0 |
Whats going on? How can I fix this?
$ lxc version tunis1:
Client version: 5.13
Server version: 5.13
