incus launch images:ubuntu/20.04 first
Creates container, but does not start automatically.
New CONTAINER is listed. STATE is STOPPED
incus start first
Error: Failed to run: /opt/incus/bin/incusd forkstart first /var/lib/incus/containers /var/log/incus/first/lxc.conf: exit status 1
Looking to understand the correct incus setup…and possible resultion.
incus info --show-log first produces following
Status: STOPPED
Type: container
Created: 2023/12/19 22:37 PST
Last Used: 2023/12/19 22:38 PST
Log:
lxc first 20231220063803.732 ERROR conf - …/src/lxc/conf.c:lxc_map_ids:3701 - newuidmap failed to write mapping “newuidmap: uid range [0-1000000000) → [1000000-1001000000) not allowed”: newuidmap 23013 0 1000000 1000000000
lxc first 20231220063803.732 ERROR start - …/src/lxc/start.c:lxc_spawn:1788 - Failed to set up id mapping.
lxc first 20231220063803.732 ERROR lxccontainer - …/src/lxc/lxccontainer.c:wait_on_daemonized_start:878 - Received container state “ABORTING” instead of “RUNNING”
lxc first 20231220063803.733 ERROR start - …/src/lxc/start.c:__lxc_start:2107 - Failed to spawn container “first”
lxc first 20231220063803.733 WARN start - …/src/lxc/start.c:lxc_abort:1036 - No such process - Failed to send SIGKILL via pidfd 43 for process 23013
You didn’t do anything wrong, you’re just on a system which has the uidmap package installed and so requires some additional configuration. The 0.4 package will do that automatically.
This situation is mentioned in the installation doc though it doesn’t go in great details:
If newuidmap/newgidmap tools are present on your system and /etc/subuid, etc/subgid exist, they must be configured to allow the root user a contiguous range of at least 10M UID/GID.
Though in your case given your containers were using a larger chunk, following those instructions to the letter wouldn’t have worked, you’d have needed to tweak them to match your existing containers.
