I’m new on lxc. I follow documentation for create unprivileged container, but I have multple error when I create or destroy.
I don’t understand this concept of mapping and uid.
When I create, I have this :
$ lxc-create -n $USER-alpine -t download -- -d alpine -r 3.19 -a amd64
lxc 20240428123120.584 ERROR idmap_utils - ../src/lxc/idmap_utils.c:lxc_map_ids:245 - newuidmap failed to write mapping "newuidmap: write to uid_map failed: Invalid argument": newuidmap 11529 0 100000 65536 0 100000 65536 65536 1000 1
Failed to write id mapping for child process
lxc 20240428123120.584 ERROR utils - ../src/lxc/utils.c:lxc_drop_groups:1570 - Operation not permitted - Failed to drop supplimentary groups
lxc 20240428123120.584 ERROR utils - ../src/lxc/utils.c:lxc_switch_uid_gid:1545 - Invalid argument - Failed to switch to gid 0
lxc-create: arnaud-alpine: ../src/lxc/lxccontainer.c: create_run_template: 1589 Failed to create container from template
lxc-create: arnaud-alpine: ../src/lxc/idmap_utils.c: lxc_map_ids: 245 newuidmap failed to write mapping "newuidmap: write to uid_map failed: Invalid argument": newuidmap 11531 0 100000 65536 0 100000 65536 65536 1000 1
lxc-create: arnaud-alpine: ../src/lxc/conf.c: userns_exec_full: 4812 error setting up {g,u}id mappings for child process "11531"
lxc-create: arnaud-alpine: ../src/lxc/lxccontainer.c: container_destroy: 2956 Error destroying rootfs for arnaud-alpine
lxc-create: arnaud-alpine: ../src/lxc/tools/lxc_create.c: lxc_create_main: 318 Failed to create container arnaud-alpine
But after, I have container :
$ lxc-ls -f
NAME STATE AUTOSTART GROUPS IPV4 IPV6 UNPRIVILEGED
arnaud-alpine STOPPED 0 - - - true
mycontainer STOPPED 0 - - - true
Oops, the mention was mostly because of destroy failing where it could have explained a difference in behavior between create working and destroy failing, but since create also fails, that’s something else.
The error appears to be Failed to drop supplimentary groups rather than an issue with the maps themselves.
This is a unprivileged container that you are trying to create (a priori yes, prompt console in $, and not #)?
In this case yours idmaps are well defined in /home/$USER/.config/lxc/default.conf and not in /etc/lxc/default.conf ?
(I only speak French: sorry in advance for the bad translations…)
for some reason, you have the same UID mapping specified twice.
See: newuidmap 11529 0 100000 65536 0 100000 65536 65536 1000 1
means that you want to set the following UID maps for the process with PID=11529:
I would suggest to check all LXC configuration files and see if you (probably) have duplicate entries like lxc.idmap = u 0 100000 65536 a few times. If so, just remove the duplicates and it should work.
Also, I don’t understand why do you have 65536 1000 1 mapping. Where it comes from?
I just followed the doc. I modified /etc/sub{u,g}id files and /etc/lxc/default.conf for root.
Then copy the default.conf file and add the user uid and gid. (the range is the same as root).
Then it talks about Ubuntu, but since I’m with Arch I also consulted the Arch doc, which doesn’t modify the official LXC doc.
On the other hand, I hadn’t seen that the command to create a container was different between root and a user.
The first time I just did a lxc-create with my user account, whereas I see that you have to use system-run before lxc-create.
Sorry, I misread. On the other hand, since this has created containers that neither root nor my user can delete, I don’t see how to remove them.
I can’t see any problem with /etc/sub{u,g}id files in your case.
As I said before, the problem might be that you have an excessive (duplicate) lxc.idmap = u ... lines in your configuration. Please, show ~/.config/lxc/default.conf contents and also /var/lib/lxc/mycontainer/config, /var/lib/lxc/arnaud-alpine/config.
I’m sorry, I don’t understand this. Have you copied /etc/lxc/default.conf file manually? Where have you placed a copy (which path)?
@arnsk if i read you correctly, it appears that you’re following some guidelines in configuring lxc, could you point us to this… maybe it would be easyer to deal
Are there any errors related to LXC or LXD.DAEMON in your syslog ?
cat /var/log/syslog | grep “lxc” | grep “error”
cat /var/log/syslog | grep “lxd” | grep “error”
I followed the documentation correctly, but I made a mistake in the container creation command line.
I used lxc-create --name mycontainer --template download
instead of systemd-run --unit=my-unit --user --scope -p "Delegate=yes" -- lxc-create --name mycontainer --template download
What created the errors in my first post. And as I said, I now have two containers that I can’t delete with my user account, and the root account doesn’t see them.
This is my default.conf :
cat .config/lxc/default.conf
lxc.net.0.type = veth
lxc.net.0.link = lxcbr0
lxc.net.0.flags = up
lxc.net.0.hwaddr = 00:16:3e:xx:xx:xx
lxc.idmap = g 0 100000 65536
I don’t have /var/log/syslog file. They is a file /var/log/lxc/lxc.log but it’s empty.
I had the same issue. For some it may be the include line and duplicates in two different files. For me it was the duplicate entries in ~/.local/share/lxc/mycontainer/config. I probably inadvertently executed the echo statements twice. Hopefully this helps someone who sees this post.
