I used the command lxc config device add nginx-proxy hostport443 proxy listen=tcp:0.0.0.0:443 connect=tcp:127.0.0.1:443
to allow the nginx service within the “nginx-proxy” instance to respond to client requests on port 443 of the host device. However, I noticed in the nginx logs that the remote_addr
is now showing the IP address of the host device instead of the actual client IP address. What should I do to resolve this issue?
