Nice guide to cloudflare DNS01 challenges?
General Idea
I did try to setup the dns-01 challenge, but ran into several issues:
  1. There are several different kinds of cloudflare tokens (ones that require an id and ones that don’t)
  2. Appropriate configuration directive answers for a particular provider (in this case cloudflare)
  3. A guide on how todo this step-by-step
Proposal
Have documentation on how to setup dns-01 challenges for EACH provider. I would vounteer to be a beta builder / tester of this.
How does this sound? I don’ thave the knowledge to do EVERYTHING, but I could build a howto from cloudlfare to INCUS and post wherever if others could help fill in the appropriate details.
Incus uses Lego, so maybe just link here and offer Incus specific example? DNS Providers :: Let’s Encrypt client and ACME library written in Go.
I did test the LEGO config, and it successfully retrieves a cert. Next step would be appropriate values for incus? Here is a proposed beginning:
acme.agree_tos: true
acme.domain: foo.example.net
acme.email: admin@foo.example.net
acme.challenge: DNS-01
acme.provider: cloudflare
acme.provider.environment: |-
  CLOUDFLARE_EMAIL=admin@foo.example.net
  CLOUDFLARE_API_KEY=XYZ
The tricky part is the cloudflare environment the BAR thing followed by the minus. I tried this exact config and had very much sadness. One thing that is NOT clear is the
acme.provider.resolvers should it be filled in? And if so do I use my default dns server? IP or dns name?
here are the errors (I have NO idea how to enter the multi line thing in the webui or the cli. Is it a @#$@#$@$#^%$#^Y yaml stupidity thing?
CzrMw_N0VMXlrIGWUMtUWxmpfW-8NZ6lUJ4ncI7I: Timeout during connect (likely firewall problem)\n"
time="2025-03-10T22:06:46-04:00" level=warning msg="Failed reverting cluster config" err="Failed to begin transaction: context canceled"
time="2025-03-10T22:06:46-04:00" level=warning msg="Failed reverting node config" err="Failed to begin transaction: context canceled"
time="2025-03-10T22:08:19-04:00" level=warning msg="AppArmor support has been disabled because of lack of kernel support"
time="2025-03-10T22:08:19-04:00" level=warning msg=" - AppArmor support has been disabled, Disabled because of lack of kernel support"
time="2025-03-10T22:08:21-04:00" level=error msg="Failed to create DNS-01 challenge provider" err="cloudflare: some credentials information are missing: CLOUDFLARE_EMAIL,CLOUDFLARE_API_KEY or some credentials information are missing: CLOUDFLARE_DNS_API_TOKEN,CLOUDFLARE_ZONE_API_TOKEN"
It would be nice to have an easier way to enter multiple strings for those of us who can’t get this to work on either the cli OR the webui…Sadness.
The web UI input for the “acme.provider.environment” needs changing to support multi-line input. In the meantime, incus config edit will need to be used to edit the DNS-01 challenge environment configuration.
Without seeing your complete config it is difficult to work out exactly what the issue is, but the error message does state that CLOUDFLARE_DNS_API_TOKEN and CLOUDFLARE_ZONE_API_TOKEN are missing.
As @FoxtrotCZ mentioned, Incus uses LEGO. The configuration for the Cloudflare DNS provider describes what environment settings are required and / or optional.
The “acme.provider.resolvers” setting is only required where you have a local split horizon DNS configuration, e.g., you are using a local DNS service for an owned domain, but the DNS authority exists elsewhere. In this situation, you need to configure the DNS-01 challenge to use the authoritative DNS, i.e., when checking for the challenge token you want your providers DNS server to be used, not your local DNS server.
Incus config edit is nice. I did test lego directly, and was able to get a certificate from cloudflare using just the proper envirohments and the dns entry to modify.
And thank you for a nice concise reply!
Alas this fails too.
  acme.agree_tos: "true"
  acme.domain: my.zone.name
  acme.email: me@somewhere.com
  acme.provider.environment: '| -
    CLOUDFLARE_EMAIL=<someone@somewhere.com
    CLOUDFLARE_DNS_API_KEY=<redacted>'
The system then converts this to a single line and then the logs:
ime="2025-03-14T15:35:08-04:00" level=error msg="Failed to create DNS-01 challenge provider" err="cloudflare: some credentials information are missing: CLOUDFLARE_API_KEY or some credentials information are missing: CLOUDFLARE_DNS_API_TOKEN,CLOUDFLARE_ZONE_API_TOKEN"
time="2025-03-14T15:48:17-04:00" level=error msg="Failed to create DNS-01 challenge provider" err="cloudflare: some credentials information are missing: CLOUDFLARE_API_KEY or some credentials information are missing: CLOUDFLARE_DNS_API_TOKEN,CLOUDFLARE_ZONE_API_TOKEN"
This would be incus config edit, and then the system makes my 2 lines into one.
You need:
Dumb question: do I just paste in with incus config edit? It seemed to transform everything into one line, or is this some YAML file I need to put somewhere?
Put it in exactly as listed, still complaining about credentials missing. I used incus config edit
Of courseI changed requisite (and tested) creds for cloudflare! as well as proper zone and email.
I have a similar issue with getting a ceritifcate with incus from Route53.
I created a dedicated user for Route53 access and tested credentials with aws cli and lego.
They work.
  acme.domain: infra4.REDACTED
  acme.provider: route53
    AWS_ACCESS_KEY_ID="REDACTED"
    AWS_SECRET_ACCESS_KEY="REDACTED"
    AWS_REGION=us-east-1
    AWS_HOSTED_ZONE_ID=REDACTED
  core.https_address: 10.10.0.104:8443
and incus info
incus info
  acme.provider.environment: SENSITIVE
api_extensions_count: 562
api_status: stable
api_version: "1.0"
auth: trusted
public: false
auth_methods:
  - tls
auth_user_name: ubuntu
auth_user_method: unix
environment:
  addresses:
    - 10.10.0.104:8443
  architectures:
    - x86_64
    - i686
  certificate: ""
  certificate_fingerprint: 362364a5acf0f4d3b9ebea9cf8d767ccbdfbe713ffcdfa43cf20fce939a564da
  driver: qemu | lxc
  driver_version: 11.1.2 | 7.0.0
  firewall: nftables
  kernel: Linux
  kernel_architecture: x86_64
  kernel_features: {}
  kernel_version: 7.0.0-38-generic
  lxc_features:
    environment_runtime_hooks: "true"
  os_name: Ubuntu
  os_version: "26.04"
  project: default
  server: incus
  server_clustered: false
  server_event_mode: full-mesh
  server_name: infra4
  server_pid: 322310
  server_version: 7.5.1
  storage: dir
  storage_version: "1"
  storage_supported_drivers:
    - name: dir
      version: "1"
      remote: false
    - name: lvm
      version: 2.03.31(2) (2025-02-27) / 1.02.205 (2025-02-27) / 4.50.0
      remote: false
    - name: truenas
Seems like I made it work.
I cleaned up whitespace and added a dummy ENV var at the end, applied changes with ansible and it worked.
AWS_ACCESS_KEY_ID=redacted
AWS_SECRET_ACCESS_KEY=redacted
AWS_HOSTED_ZONE_ID=redacted
TEST_123=a
