I am not able to get any connection from the host to containers and vice versa. Ping for example is not working.
Here is my setup:
Host:
user@host:~$ lxc version
Client version: 5.11
Server version: 5.11
user@host:~$ lxc profile show default
config: {}
nictype: bridged
parent: br0
pool: lvmpool
- /1.0/instances/AD
- /1.0/instances/FS
user@host:~$ sudo brctl show
bridge name bridge id STP enabled interfaces
br0 8000.f6c4defedb0b no eno1
veth82bf8546
vethef8c1590
vethf7cbec78
vnet0
virbr0 8000.525400a5fc78 yes
user@host:~$ lxc network show br0
config: {}
type: bridge
- /1.0/instances/AD
- /1.0/instances/FS
- /1.0/profiles/default
managed: false
status: ""
locations: []
user@host:~$ ip a
inet6 ::1/128 scope host
2: eno1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq master br0 state UP group default qlen 1000
link/ether 6c:2b:59:8e:2e:7f brd ff:ff:ff:ff:ff:ff
altname enp5s0f0
inet 10.16.99.252/24 brd 10.16.99.255 scope global eno1
3: eno2: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
link/ether 6c:2b:59:8e:2e:80 brd ff:ff:ff:ff:ff:ff
altname enp5s0f1
4: br0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
link/ether f6:c4:de:fe:db:0b brd ff:ff:ff:ff:ff:ff
inet 10.16.99.10/24 brd 10.16.99.255 scope global br0
inet6 fe80::f4c4:deff:fefe:db0b/64 scope link
5: virbr0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN group default qlen 1000
link/ether 52:54:00:a5:fc:78 brd ff:ff:ff:ff:ff:ff
inet 192.168.122.1/24 brd 192.168.122.255 scope global virbr0
6: vnet0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master br0 state UNKNOWN group default qlen 1000
link/ether fe:54:00:a7:fc:9e brd ff:ff:ff:ff:ff:ff
inet6 fe80::fc54:ff:fea7:fc9e/64 scope link
8: veth82bf8546@if7: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master br0 state UP group default qlen 1000
link/ether 2e:9e:b6:76:6f:3b brd ff:ff:ff:ff:ff:ff link-netnsid 0
10: vethef8c1590@if9: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master br0 state UP group default qlen 1000
link/ether 0e:41:e1:4b:71:20 brd ff:ff:ff:ff:ff:ff link-netnsid 1
12: vethf7cbec78@if11: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master br0 state UP group default qlen 1000
link/ether 6a:3e:f0:75:c3:fd brd ff:ff:ff:ff:ff:ff link-netnsid 2
user@host:~$ ip r
default via 10.16.99.1 dev br0 proto static
default via 10.16.99.1 dev eno1 proto static
10.16.99.0/24 dev eno1 proto kernel scope link src 10.16.99.252
10.16.99.0/24 dev br0 proto kernel scope link src 10.16.99.10
192.168.122.0/24 dev virbr0 proto kernel scope link src 192.168.122.1 linkdown
Container:
user@host:~$ lxc config show --expanded AD
boot.autostart: "1"
boot.autostart.delay: "1"
boot.autostart.priority: "100"
image.architecture: amd64
image.description: Ubuntu jammy amd64 (20230304_07:43)
image.os: Ubuntu
image.release: jammy
image.serial: "20230304_07:43"
image.type: squashfs
image.variant: default
security.privileged: "true"
volatile.base_image: 5909a4fcd125acab1c7f90c8c36479b29f4783fe9954a7101867d4deea64330d
volatile.cloud-init.instance-id: 44c8e5c1-1242-420e-b7ac-990fb66af2fe
volatile.eth0.host_name: veth82bf8546
volatile.eth0.hwaddr: 00:16:3e:39:70:c6
volatile.idmap.base: "0"
volatile.idmap.current: '[]'
volatile.idmap.next: '[]'
volatile.uuid: 7626b18c-f98b-4328-b2fd-d828c724b0c5
nictype: bridged
parent: br0
pool: lvmpool
root@AD:~# ip a
7: eth0@if8: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
link/ether 00:16:3e:39:70:c6 brd ff:ff:ff:ff:ff:ff link-netnsid 0
inet 10.16.99.25/24 brd 10.16.99.255 scope global eth0
inet6 fe80::216:3eff:fe39:70c6/64 scope link
root@AD:~# ip r
default via 10.16.99.1 dev eth0 proto static
10.16.99.0/24 dev eth0 proto kernel scope link src 10.16.99.25
Thanks for any advice!
Best,
Chris
