No IPV4 address for freebsd vm
I use Incus 6.0.1 on Debian Bookworm and Linux containers and VMs (cli or desktop) run without any problems.
However, when installing FreeBSD, it cannot get an IP address from DHCP. FreeBSD uses vtnet0 network structure. The installed containers and VMs cannot get Ipv4 but they have Ipv6 addresses. FreeBSD machines cannot have internet access. Virt-manager is also installed and running on my system.
How can I solve this problem? Thanks for your help.
incus ls
iptables -L -n -v
Chain INPUT (policy ACCEPT 0 packets, 0 bytes)
 pkts bytes target     prot opt in     out     source               destination
 317K 1152M LIBVIRT_INP  0    --  *      *       0.0.0.0/0            0.0.0.0/0
Chain FORWARD (policy ACCEPT 0 packets, 0 bytes)
   26  1976 LIBVIRT_FWX  0    --  *      *       0.0.0.0/0            0.0.0.0/0
   26  1976 LIBVIRT_FWI  0    --  *      *       0.0.0.0/0            0.0.0.0/0
   26  1976 LIBVIRT_FWO  0    --  *      *       0.0.0.0/0            0.0.0.0/0
Chain OUTPUT (policy ACCEPT 0 packets, 0 bytes)
 183K   16M LIBVIRT_OUT  0    --  *      *       0.0.0.0/0            0.0.0.0/0
Chain LIBVIRT_FWI (1 references)
    0     0 ACCEPT     0    --  *      virbr0  0.0.0.0/0            192.168.122.0/24     ctstate RELATED,ESTABLISHED
    0     0 REJECT     0    --  *      virbr0  0.0.0.0/0            0.0.0.0/0            reject-with icmp-port-unreachable
Chain LIBVIRT_FWO (1 references)
    0     0 ACCEPT     0    --  virbr0 *       192.168.122.0/24     0.0.0.0/0
    0     0 REJECT     0    --  virbr0 *       0.0.0.0/0            0.0.0.0/0            reject-with icmp-port-unreachable
Chain LIBVIRT_FWX (1 references)
    0     0 ACCEPT     0    --  virbr0 virbr0  0.0.0.0/0            0.0.0.0/0
Chain LIBVIRT_INP (1 references)
    0     0 ACCEPT     17   --  virbr0 *       0.0.0.0/0            0.0.0.0/0            udp dpt:53
    0     0 ACCEPT     6    --  virbr0 *       0.0.0.0/0            0.0.0.0/0            tcp dpt:53
    0     0 ACCEPT     17   --  virbr0 *       0.0.0.0/0            0.0.0.0/0            udp dpt:67
    0     0 ACCEPT     6    --  virbr0 *       0.0.0.0/0            0.0.0.0/0            tcp dpt:67
Chain LIBVIRT_OUT (1 references)
    0     0 ACCEPT     17   --  *      virbr0  0.0.0.0/0            0.0.0.0/0            udp dpt:53
    0     0 ACCEPT     6    --  *      virbr0  0.0.0.0/0            0.0.0.0/0            tcp dpt:53
    0     0 ACCEPT     17   --  *      virbr0  0.0.0.0/0            0.0.0.0/0            udp dpt:68
    0     0 ACCEPT     6    --  *      virbr0  0.0.0.0/0            0.0.0.0/0            tcp dpt:68
ip a
    inet6 ::1/128 scope host noprefixroute
2: eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc fq_codel state DOWN group default qlen 1000
    link/ether 80:fa:5b:42:3e:a4 brd ff:ff:ff:ff:ff:ff
3: wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
    link/ether 30:e3:7a:ae:4d:ef brd ff:ff:ff:ff:ff:ff
    inet 192.168.1.165/24 brd 192.168.1.255 scope global dynamic noprefixroute wlan0
       valid_lft 84843sec preferred_lft 84843sec
    inet6 fe80::34f7:b8f7:8c1c:ad51/64 scope link noprefixroute
4: virbr0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN group default qlen 1000
    link/ether 52:54:00:1e:9c:26 brd ff:ff:ff:ff:ff:ff
    inet 192.168.122.1/24 brd 192.168.122.255 scope global virbr0
ip link show
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN mode DEFAULT group default qlen 1000
2: eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc fq_codel state DOWN mode DEFAULT group default qlen 1000
3: wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP mode DORMANT group default qlen 1000
4: virbr0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN mode DEFAULT group default qlen 1000
incus config device add <instance_name> eth0 nic nictype=bridged parent=virbr0
This command solved problem.
Hi again,
I use Incus 6.6 on Linux Mint Virginia, Linux containers and VMs (cli or desktop) run without any problems.
iptables -L -n -v | grep incus
    0     0 ACCEPT     all  --  incusbr0 *       0.0.0.0/0            0.0.0.0/0
    0     0 ACCEPT     all  --  *      incusbr0  0.0.0.0/0            0.0.0.0/0
  278 79417 ACCEPT     all  --  incusbr0 *       0.0.0.0/0            0.0.0.0/0
ip a
2: enp3s0f1: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc fq_codel state DOWN group default qlen 1000
3: wlp2s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
    inet 192.168.1.104/24 brd 192.168.1.255 scope global dynamic noprefixroute wlp2s0
       valid_lft 80288sec preferred_lft 80288sec
    inet6 fe80::925c:7894:5c13:9ac1/64 scope link noprefixroute
4: incusbr0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
    link/ether 00:16:3e:95:29:de brd ff:ff:ff:ff:ff:ff
    inet 10.126.157.1/24 scope global incusbr0
    inet6 fd42:df1b:7995:457c::1/64 scope global
    inet6 fe80::216:3eff:fe95:29de/64 scope link
11: tap7109052a: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq master incusbr0 state UP group default qlen 1000
    link/ether 02:6e:83:1e:62:59 brd ff:ff:ff:ff:ff:ff
ip link show
2: enp3s0f1: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc fq_codel state DOWN mode DEFAULT group default qlen 1000
3: wlp2s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP mode DORMANT group default qlen 1000
4: incusbr0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP mode DEFAULT group default qlen 1000
11: tap7109052a: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq master incusbr0 state UP mode DEFAULT group default qlen 1000
In this case
incus config device add freebsd eth0 nic nictype=bridged parent=incusbr0
doesn’t solve my problem.
Any suggestion?
Thanks in advance.
If it’s not firewalling then maybe it’s to do with UDP checksum. It could be that the FreeBSD VM is sending DHCP packets with no checksum set, on the assumption they will be added by the physical NIC on egress.
On linux guests you can do:
ethtool --offload eth0 tx off
but I don’t know what the equivalent is for FreeBSD.
According to this old post, lxd had a workaround to update the checksums using mangle rules.
However, on a pure incus 6.0.2 system here, iptables -L -n -v -t mangle doesn’t show anything. On a system with ufw and libvirt as well, I see libvirt adds one for itself:
Chain LIBVIRT_PRT (1 references)
  220 75251 CHECKSUM   udp  --  *      virbr0  0.0.0.0/0            0.0.0.0/0            udp dpt:68 CHECKSUM fill
but not one for incus. Therefore, maybe incus’ dnsmasq has its own workaround now. But still, it would be worth doing a tcpdump on the incusbr0 interface, and an strace on the dnsmasq process, to see if the DHCP discover packets are being received.
FreeBSD VM booting sequence;
Starting dhclient.
DHCPDISCOVER on vtneto to 255.255.255.255 port 67 interval 4
DHCPDISCOVER on vtneto to 255.255.255.255 port 67 interval 9
DHCPDISCOVER on vtnete to 255.255.255.255 port 67 interval 20 DHCPDISCOVER on vtneto to 255.255.255.255 port 67 interval 16
DHCPDISCOVER on vtnete to 255.255.255.255 port 67 interval 12
**5 bad udp checksums in 5 packets**
No DHCPOFFERS received.
No working leases in persistent database sleeping.
Waiting 30s for the default route interface:
add host 127.0.0.1: gateway 100 fib 0: route already in table
add host::1: gateway 100 fib 0: route already in table
add net fe80::: gateway:: 1
add net ff02::: gateway:: 1
add net::ffff: 0.0.0.0: gateway:: 1
add net: 0.0.0.0: gateway:: 1
Starting local_unbound.
It’s look like a checksum problem.
Tcpdump as follow;
tcpdump -i incusbr0 port 67 -vvv
tcpdump: listening on incusbr0, link-type EN10MB (Ethernet), snapshot length 262144 bytes
15:33:58.105980 IP (tos 0x10, ttl 128, id 0, offset 0, flags [none], proto UDP (17), length 328)
    0.0.0.0.bootpc > 255.255.255.255.bootps: [udp sum ok] BOOTP/DHCP, Request from 00:16:3e:9b:fc:f4 (oui Unknown), length 300, xid 0x4c1f21fd, secs 6, Flags [none] (0x0000)
	  Client-Ethernet-Address 00:16:3e:9b:fc:f4 (oui Unknown)
	  Vendor-rfc1048 Extensions
	    Magic Cookie 0x63825363
	    DHCP-Message (53), length 1: Discover
	    Client-ID (61), length 7: ether 00:16:3e:9b:fc:f4
	    Hostname (12), length 7: "freebsd"
	    Parameter-Request (55), length 10:
	      Subnet-Mask (1), BR (28), Time-Zone (2), Classless-Static-Route (121)
	      Default-Gateway (3), Domain-Name (15), Domain-Name-Server (6), Hostname (12)
	      Unknown (119), MTU (26)
	    END (255), length 0
	    PAD (0), length 0, occurs 26
15:33:58.106514 IP (tos 0xc0, ttl 64, id 31759, offset 0, flags [none], proto UDP (17), length 328)
    medimint.catav.cyou.bootps > 10.126.157.22.bootpc: [bad udp cksum 0x5059 -> 0x5213!] BOOTP/DHCP, Reply, length 300, xid 0x4c1f21fd, secs 6, Flags [none] (0x0000)
	  Your-IP 10.126.157.22
	  Server-IP medimint.catav.cyou
	    DHCP-Message (53), length 1: Offer
	    Server-ID (54), length 4: medimint.catav.cyou
	    Lease-Time (51), length 4: 3600
	    RN (58), length 4: 1800
	    RB (59), length 4: 3150
	    Subnet-Mask (1), length 4: 255.255.255.0
	    BR (28), length 4: 10.126.157.255
	    Default-Gateway (3), length 4: medimint.catav.cyou
	    Domain-Name-Server (6), length 4: medimint.catav.cyou
	    Domain-Name (15), length 5: "incus"
	    END (255), length 0
	    PAD (0), length 0
15:34:04.267288 IP (tos 0x10, ttl 128, id 0, offset 0, flags [none], proto UDP (17), length 328)
    0.0.0.0.bootpc > 255.255.255.255.bootps: [udp sum ok] BOOTP/DHCP, Request from 00:16:3e:9b:fc:f4 (oui Unknown), length 300, xid 0x4c1f21fd, secs 12, Flags [none] (0x0000)
	    END (255), length 0
15:34:04.267852 IP (tos 0xc0, ttl 64, id 34125, offset 0, flags [none], proto UDP (17), length 328)
    medimint.catav.cyou.bootps > 10.126.157.22.bootpc: [bad udp cksum 0x5059 -> 0x520d!] BOOTP/DHCP, Reply, length 300, xid 0x4c1f21fd, secs 12, Flags [none] (0x0000)
	    END (255), length 0
	    PAD (0), length 0
15:34:16.281625 IP (tos 0x10, ttl 128, id 0, offset 0, flags [none], proto UDP (17), length 328)
    0.0.0.0.bootpc > 255.255.255.255.bootps: [udp sum ok] BOOTP/DHCP, Request from 00:16:3e:9b:fc:f4 (oui Unknown), length 300, xid 0x4c1f21fd, secs 24, Flags [none] (0x0000)
	    END (255), length 0
15:34:16.282210 IP (tos 0xc0, ttl 64, id 36379, offset 0, flags [none], proto UDP (17), length 328)
    medimint.catav.cyou.bootps > 10.126.157.22.bootpc: [bad udp cksum 0x5059 -> 0x5201!] BOOTP/DHCP, Reply, length 300, xid 0x4c1f21fd, secs 24, Flags [none] (0x0000)
	    END (255), length 0
	    PAD (0), length 0
15:34:29.415223 IP (tos 0x10, ttl 128, id 0, offset 0, flags [none], proto UDP (17), length 328)
    0.0.0.0.bootpc > 255.255.255.255.bootps: [udp sum ok] BOOTP/DHCP, Request from 00:16:3e:9b:fc:f4 (oui Unknown), length 300, xid 0x4c1f21fd, secs 37, Flags [none] (0x0000)
	    END (255), length 0
15:34:29.415831 IP (tos 0xc0, ttl 64, id 44947, offset 0, flags [none], proto UDP (17), length 328)
    medimint.catav.cyou.bootps > 10.126.157.22.bootpc: [bad udp cksum 0x5059 -> 0x51f4!] BOOTP/DHCP, Reply, length 300, xid 0x4c1f21fd, secs 37, Flags [none] (0x0000)
	    END (255), length 0
	    PAD (0), length 0
15:34:42.477172 IP (tos 0x10, ttl 128, id 0, offset 0, flags [none], proto UDP (17), length 328)
    0.0.0.0.bootpc > 255.255.255.255.bootps: [udp sum ok] BOOTP/DHCP, Request from 00:16:3e:9b:fc:f4 (oui Unknown), length 300, xid 0x4c1f21fd, secs 50, Flags [none] (0x0000)
	    END (255), length 0
15:34:42.477590 IP (tos 0xc0, ttl 64, id 55688, offset 0, flags [none], proto UDP (17), length 328)
    medimint.catav.cyou.bootps > 10.126.157.22.bootpc: [bad udp cksum 0x5059 -> 0x51e7!] BOOTP/DHCP, Reply, length 300, xid 0x4c1f21fd, secs 50, Flags [none] (0x0000)
	    END (255), length 0
	    PAD (0), length 0
15:36:01.267924 IP (tos 0x10, ttl 128, id 0, offset 0, flags [none], proto UDP (17), length 328)
    0.0.0.0.bootpc > 255.255.255.255.bootps: [udp sum ok] BOOTP/DHCP, Request from 00:16:3e:9b:fc:f4 (oui Unknown), length 300, xid 0xa26ac46d, Flags [none] (0x0000)
	    END (255), length 0
15:36:01.268040 IP (tos 0xc0, ttl 64, id 37903, offset 0, flags [none], proto UDP (17), length 328)
    medimint.catav.cyou.bootps > 10.126.157.22.bootpc: [bad udp cksum 0x5059 -> 0x595d!] BOOTP/DHCP, Reply, length 300, xid 0xa26ac46d, Flags [none] (0x0000)
	    END (255), length 0
	    PAD (0), length 0
15:36:05.295033 IP (tos 0x10, ttl 128, id 0, offset 0, flags [none], proto UDP (17), length 328)
    0.0.0.0.bootpc > 255.255.255.255.bootps: [udp sum ok] BOOTP/DHCP, Request from 00:16:3e:9b:fc:f4 (oui Unknown), length 300, xid 0xa26ac46d, secs 4, Flags [none] (0x0000)
	    END (255), length 0
15:36:05.295546 IP (tos 0xc0, ttl 64, id 40453, offset 0, flags [none], proto UDP (17), length 328)
    medimint.catav.cyou.bootps > 10.126.157.22.bootpc: [bad udp cksum 0x5059 -> 0x5959!] BOOTP/DHCP, Reply, length 300, xid 0xa26ac46d, secs 4, Flags [none] (0x0000)
	    END (255), length 0
	    PAD (0), length 0
15:36:14.451926 IP (tos 0x10, ttl 128, id 0, offset 0, flags [none], proto UDP (17), length 328)
    0.0.0.0.bootpc > 255.255.255.255.bootps: [udp sum ok] BOOTP/DHCP, Request from 00:16:3e:9b:fc:f4 (oui Unknown), length 300, xid 0xa26ac46d, secs 13, Flags [none] (0x0000)
	    END (255), length 0
15:36:14.452485 IP (tos 0xc0, ttl 64, id 47241, offset 0, flags [none], proto UDP (17), length 328)
    medimint.catav.cyou.bootps > 10.126.157.22.bootpc: [bad udp cksum 0x5059 -> 0x5950!] BOOTP/DHCP, Reply, length 300, xid 0xa26ac46d, secs 13, Flags [none] (0x0000)
	    END (255), length 0
	    PAD (0), length 0
15:36:22.469840 IP (tos 0x10, ttl 128, id 0, offset 0, flags [none], proto UDP (17), length 328)
    0.0.0.0.bootpc > 255.255.255.255.bootps: [udp sum ok] BOOTP/DHCP, Request from 00:16:3e:9b:fc:f4 (oui Unknown), length 300, xid 0xa26ac46d, secs 21, Flags [none] (0x0000)
	    END (255), length 0
15:36:22.470408 IP (tos 0xc0, ttl 64, id 51277, offset 0, flags [none], proto UDP (17), length 328)
    medimint.catav.cyou.bootps > 10.126.157.22.bootpc: [bad udp cksum 0x5059 -> 0x5948!] BOOTP/DHCP, Reply, length 300, xid 0xa26ac46d, secs 21, Flags [none] (0x0000)
	    END (255), length 0
	    PAD (0), length 0
15:36:32.485485 IP (tos 0x10, ttl 128, id 0, offset 0, flags [none], proto UDP (17), length 328)
    0.0.0.0.bootpc > 255.255.255.255.bootps: [udp sum ok] BOOTP/DHCP, Request from 00:16:3e:9b:fc:f4 (oui Unknown), length 300, xid 0xa26ac46d, secs 31, Flags [none] (0x0000)
	    END (255), length 0
15:36:32.486082 IP (tos 0xc0, ttl 64, id 55872, offset 0, flags [none], proto UDP (17), length 328)
    medimint.catav.cyou.bootps > 10.126.157.22.bootpc: [bad udp cksum 0x5059 -> 0x593e!] BOOTP/DHCP, Reply, length 300, xid 0xa26ac46d, secs 31, Flags [none] (0x0000)
	    END (255), length 0
	    PAD (0), length 0
15:36:42.507927 IP (tos 0x10, ttl 128, id 0, offset 0, flags [none], proto UDP (17), length 328)
    0.0.0.0.bootpc > 255.255.255.255.bootps: [udp sum ok] BOOTP/DHCP, Request from 00:16:3e:9b:fc:f4 (oui Unknown), length 300, xid 0xa26ac46d, secs 41, Flags [none] (0x0000)
	    END (255), length 0
15:36:42.508540 IP (tos 0xc0, ttl 64, id 58096, offset 0, flags [none], proto UDP (17), length 328)
    medimint.catav.cyou.bootps > 10.126.157.22.bootpc: [bad udp cksum 0x5059 -> 0x5934!] BOOTP/DHCP, Reply, length 300, xid 0xa26ac46d, secs 41, Flags [none] (0x0000)
	    END (255), length 0
	    PAD (0), length 0
Interesting: so it’s the replies going back to FreeBSD being rejected because of bad checksums.
Then I guess it’s worth trying:
# does this show tx-checksumming: on ?
ethtool --show-offload incusbr0 | grep -i checksum
# if so, try this:
ethtool --offload incusbr0 tx off
rx-checksumming: off [fixed]
tx-checksumming: on
	tx-checksum-ipv4: off [fixed]
	tx-checksum-ip-generic: on
	tx-checksum-ipv6: off [fixed]
	tx-checksum-fcoe-crc: off [fixed]
	tx-checksum-sctp: off [fixed]
Actual changes:
tx-checksum-ip-generic: off
tx-tcp-segmentation: off [not requested]
tx-tcp-ecn-segmentation: off [not requested]
tx-tcp-mangleid-segmentation: off [not requested]
tx-tcp6-segmentation: off [not requested]
freebsd | RUNNING | 10.126.157.22 (eth0) | fd42:df1b:7995:457c:216:3eff:fe9b:fcf4 (eth0) | VIRTUAL-MACHINE | 0 |
PS: Does this pose a security vulnerability?
I can’t see how. It just makes the kernel do a bit more work to calculate checksums properly instead of deferring them until later.
How can I make this command permanent?
Incus itself creates the incusbr0 network, and I don’t see a config hook in the docs.
You could try creating /etc/networkd-dispatcher/routable.d/incus containing
#!/bin/bash -eu
if [ "$IFACE" = "incusbr0" ]; then
fi
(and make it executable: chmod +x). But I don’t know if systemd-networkd will invoke it for an interface it didn’t create or initialize itself. Try it anyway. You could also try carrier.d or configured.d directories (man networkctl for descriptions)
This solution did not work. I added the command to the KDE startup applications and that worked. Thanks again.
Hi, I found an alternative solution for this workaround:
<<EOF sudo tee /etc/systemd/system/disable-incusbr0-tx-checksum.service > /dev/null
[Unit]
Description=Disable incusbr0 tx checksum for FreeBSD VMs
After=incus-startup.service
Requires=incus.socket
[Service]
Type=oneshot
ExecStart=ethtool --offload incusbr0 tx off
[Install]
WantedBy=multi-user.target
EOF
sudo systemctl daemon-reload
sudo systemctl enable disable-incusbr0-tx-checksum
Thank you for your interest and help.
Zeki Çatav
zekicatav.com
14 Şub 2025 Cum 14:39 tarihinde Hiroaki Nakamura via Linux Containers Forum <noreply@discuss.linuxcontainers.org> şunu yazdı:
