hirvi
(hirvi)
1
Hello ,
I can’ access to the images server https://imageslinuxcontainer.org , certificate expired 10 days ago .
error: Get https://images.linuxcontainers.org/streams/v1/index.json: x509: certificate has expired or is not yet valid
See you +++ , and thank you very much !
stgraber
(Stéphane Graber)
2
That’s pretty embarrassing and I’m frankly not sure how this didn’t get flagged earlier…
I’ve reported the issue with the operators of our UK mirror (which is the one with the expired cert) and they’re working on resolving this now.
stgraber
(Stéphane Graber)
3
This should have been resolved now.
I’ve been told that the new certificate did get generated but that the deployment scripts failed to put it in place…
hirvi
(hirvi)
4
Problem solved !
Thank you for the fast reaction !
See you later +++
