In my setup I wish to use a common bridge used by kvm libvirt VMs and LXD containers. VMs and LXD containers should be able to communicate with each other.
I use centOS 8 and set up a libvirt virbr0 and configured this bridge in LXD. Everything works fine but DNS resolution. I can ping from any VM to any container and vice versa using the ip address. I can ping each VM from any other VM and the host by name. And I can ping any VM from any container by name (e.g. either FQDN vm01.intra or just host vm01 )
But I can’t ping any container from a VM nor any other container by name (neither FQDN nor just host, mind, by IP address works fine).
I found a lot of info on the net about setting up LXD to use virbr0. But none mentioned a DNS problem.
In virbr0 configuration I found in /var/lib/libvirt/dnsmasq/default.addnhosts no host name entry for the container but for every VM:
"ip-address": "192.168.122.61",
"mac-address": "52:54:00:be:63:b2",
"hostname": "vmtest01",
"client-id": "00:6f:75:72:61:6e:6f:73",
"expiry-time": 1582628832
"ip-address": "192.168.122.145",
"mac-address": "52:54:00:c2:30:d3",
"hostname": "vmtest02",
"client-id": "01:52:54:00:c2:30:d3",
"expiry-time": 1582629369
"ip-address": "192.168.122.43",
"mac-address": "00:16:3e:05:01:87",
"client-id": "01:00:16:3e:05:01:87",
"expiry-time": 1582629482
The last entry is an LXD container according to the MAC:
#lxc config show contest-01 --expanded
environment.LANG: de_DE.UTF-8
environment.LC_ALL: de_DE.UTF-8
image.architecture: amd64
image.description: Centos 8 amd64 (20200222_07:41)
image.os: Centos
image.release: "8"
image.serial: "20200222_07:41"
image.type: squashfs
volatile.base_image: c0d1c1964f0952b73ebf21c31bc726279570267e637a98d26d58d849f2dd506d
volatile.eth0.host_name: vethc641281d
volatile.eth0.hwaddr: 00:16:3e:05:01:87
volatile.idmap.base: "0"
volatile.idmap.current: '[{"Isuid":true,"Isgid":false,"Hostid":1000000,"Nsid":0,"Maprange":65536},{"Isuid":false,"Isgid":true,"Hostid":1000000,"Nsid":0,"Maprange":65536}]'
volatile.idmap.next: '[{"Isuid":true,"Isgid":false,"Hostid":1000000,"Nsid":0,"Maprange":65536},{"Isuid":false,"Isgid":true,"Hostid":1000000,"Nsid":0,"Maprange":65536}]'
volatile.last_state.idmap: '[{"Isuid":true,"Isgid":false,"Hostid":1000000,"Nsid":0,"Maprange":65536},{"Isuid":false,"Isgid":true,"Hostid":1000000,"Nsid":0,"Maprange":65536}]'
nictype: bridged
parent: virbr0
pool: lvmpool
My virbr0 configuration is:
# virsh net-dumpxml default
<network connections='2'>
<name>default</name>
<uuid>415529d9-f16a-4447-9354-3c4f8cc9d709</uuid>
<forward mode='nat'>
<nat>
<port start='1024' end='65535'/>
</nat>
</forward>
<bridge name='virbr0' zone='trusted' stp='on' delay='0'/>
<mac address='52:54:00:ea:1c:27'/>
<domain name='intra'/>
<dns forwardPlainNames='no'>
<forwarder addr='127.0.0.1'/>
<host ip='192.168.122.1'>
<hostname>host</hostname>
<hostname>host.intra</hostname>
</host>
</dns>
<ip address='192.168.122.1' netmask='255.255.255.0'>
<dhcp>
<range start='192.168.122.20' end='192.168.122.200'/>
</dhcp>
</ip>
I’m wondering about the "connection=‘2’ above. Obviously it doesn’t count the container, just the vm’s.
Any hint is greatly appreciated.
