$ sudo dmesg
[ 0.000000] Linux version 4.15.0-118-generic (buildd@lgw01-amd64-039) (gcc version 7.5.0 (Ubuntu 7.5.0-3ubuntu1~18.04)) #119-Ubuntu SMP Tue Sep 8 12:30:01 UTC 2020 (Ubuntu 4.15.0-118.119-generic 4.15.18)
[ 0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-4.15.0-118-generic root=UUID=3a220a69-923d-42d8-b67d-2035ab1c7c8c ro
[ 0.000000] KERNEL supported cpus:
[ 0.000000] Intel GenuineIntel
[ 0.000000] AMD AuthenticAMD
[ 0.000000] Centaur CentaurHauls
[ 0.000000] x86/fpu: x87 FPU will use FXSAVE
[ 0.000000] e820: BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009dfff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x00000000cf378fff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000cf379000-0x00000000cf38efff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000cf38f000-0x00000000cf3cdfff] ACPI data
[ 0.000000] BIOS-e820: [mem 0x00000000cf3ce000-0x00000000cfffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000e0000000-0x00000000efffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fe000000-0x00000000ffffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000102fffffff] usable
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] SMBIOS 2.6 present.
[ 0.000000] DMI: Dell Inc. PowerEdge R510/084YMW, BIOS 1.14.0 05/30/2018
[ 0.000000] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[ 0.000000] e820: remove [mem 0x000a0000-0x000fffff] usable
[ 0.000000] e820: last_pfn = 0x1030000 max_arch_pfn = 0x400000000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF uncachable
[ 0.000000] C0000-CBFFF write-protect
[ 0.000000] CC000-D3FFF write-back
[ 0.000000] D4000-EBFFF uncachable
[ 0.000000] EC000-FFFFF write-protect
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 0000000000 mask FF80000000 write-back
[ 0.000000] 1 base 0080000000 mask FFC0000000 write-back
[ 0.000000] 2 base 00C0000000 mask FFF0000000 write-back
[ 0.000000] 3 base 0100000000 mask FF00000000 write-back
[ 0.000000] 4 base 0200000000 mask FE00000000 write-back
[ 0.000000] 5 base 0400000000 mask FC00000000 write-back
[ 0.000000] 6 base 0800000000 mask F800000000 write-back
[ 0.000000] 7 base 1000000000 mask FFC0000000 write-back
[ 0.000000] 8 disabled
[ 0.000000] 9 disabled
[ 0.000000] x86/PAT: Configuration [0-7]: WB WC UC- UC WB WP UC- WT
[ 0.000000] e820: update [mem 0xd0000000-0xffffffff] usable ==> reserved
[ 0.000000] e820: last_pfn = 0xcf379 max_arch_pfn = 0x400000000
[ 0.000000] found SMP MP-table at [mem 0x000fe710-0x000fe71f]
[ 0.000000] Scanning 1 areas for low memory corruption
[ 0.000000] Using GB pages for direct mapping
[ 0.000000] RAMDISK: [mem 0x310af000-0x3484efff]
[ 0.000000] ACPI: Early table checksum verification disabled
[ 0.000000] ACPI: RSDP 0x00000000000F1530 000024 (v02 DELL )
[ 0.000000] ACPI: XSDT 0x00000000000F1634 00009C (v01 DELL PE_SC3 00000001 DELL 00000001)
[ 0.000000] ACPI: FACP 0x00000000CF3B3F9C 0000F4 (v03 DELL PE_SC3 00000001 DELL 00000001)
[ 0.000000] ACPI: DSDT 0x00000000CF38F000 003B44 (v01 DELL PE_SC3 00000001 INTL 20050624)
[ 0.000000] ACPI: FACS 0x00000000CF3B6000 000040
[ 0.000000] ACPI: APIC 0x00000000CF3B3478 00015E (v01 DELL PE_SC3 00000001 DELL 00000001)
[ 0.000000] ACPI: SPCR 0x00000000CF3B35D8 000050 (v01 DELL PE_SC3 00000001 DELL 00000001)
[ 0.000000] ACPI: HPET 0x00000000CF3B362C 000038 (v01 DELL PE_SC3 00000001 DELL 00000001)
[ 0.000000] ACPI: DMAR 0x00000000CF3B3668 0001D0 (v01 DELL PE_SC3 00000001 DELL 00000001)
[ 0.000000] ACPI: MCFG 0x00000000CF3B38C4 00003C (v01 DELL PE_SC3 00000001 DELL 00000001)
[ 0.000000] ACPI: WD__ 0x00000000CF3B3904 000134 (v01 DELL PE_SC3 00000001 DELL 00000001)
[ 0.000000] ACPI: SLIC 0x00000000CF3B3A3C 000024 (v01 DELL PE_SC3 00000001 DELL 00000001)
[ 0.000000] ACPI: ERST 0x00000000CF392CE4 000270 (v01 DELL PE_SC3 00000001 DELL 00000001)
[ 0.000000] ACPI: HEST 0x00000000CF392F54 0003A8 (v01 DELL PE_SC3 00000001 DELL 00000001)
[ 0.000000] ACPI: BERT 0x00000000CF392B44 000030 (v01 DELL PE_SC3 00000001 DELL 00000001)
[ 0.000000] ACPI: EINJ 0x00000000CF392B74 000170 (v01 DELL PE_SC3 00000001 DELL 00000001)
[ 0.000000] ACPI: SRAT 0x00000000CF3B3BC0 000370 (v01 DELL PE_SC3 00000001 DELL 00000001)
[ 0.000000] ACPI: TCPA 0x00000000CF3B3F34 000064 (v02 DELL PE_SC3 00000001 DELL 00000001)
[ 0.000000] ACPI: SSDT 0x00000000CF3B7000 003FD4 (v01 INTEL PPM RCM 80000001 INTL 20061109)
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] SRAT: PXM 1 -> APIC 0x20 -> Node 0
[ 0.000000] SRAT: PXM 2 -> APIC 0x00 -> Node 1
[ 0.000000] SRAT: PXM 1 -> APIC 0x22 -> Node 0
[ 0.000000] SRAT: PXM 2 -> APIC 0x02 -> Node 1
[ 0.000000] SRAT: PXM 1 -> APIC 0x32 -> Node 0
[ 0.000000] SRAT: PXM 2 -> APIC 0x12 -> Node 1
[ 0.000000] SRAT: PXM 1 -> APIC 0x34 -> Node 0
[ 0.000000] SRAT: PXM 2 -> APIC 0x14 -> Node 1
[ 0.000000] SRAT: PXM 1 -> APIC 0x21 -> Node 0
[ 0.000000] SRAT: PXM 2 -> APIC 0x01 -> Node 1
[ 0.000000] SRAT: PXM 1 -> APIC 0x23 -> Node 0
[ 0.000000] SRAT: PXM 2 -> APIC 0x03 -> Node 1
[ 0.000000] SRAT: PXM 1 -> APIC 0x33 -> Node 0
[ 0.000000] SRAT: PXM 2 -> APIC 0x13 -> Node 1
[ 0.000000] SRAT: PXM 1 -> APIC 0x35 -> Node 0
[ 0.000000] SRAT: PXM 2 -> APIC 0x15 -> Node 1
[ 0.000000] ACPI: SRAT: Node 1 PXM 2 [mem 0x00000000-0xcfffffff]
[ 0.000000] ACPI: SRAT: Node 1 PXM 2 [mem 0x100000000-0x82fffffff]
[ 0.000000] ACPI: SRAT: Node 0 PXM 1 [mem 0x830000000-0x102fffffff]
[ 0.000000] NUMA: Node 1 [mem 0x00000000-0xcfffffff] + [mem 0x100000000-0x82fffffff] -> [mem 0x00000000-0x82fffffff]
[ 0.000000] NODE_DATA(0) allocated [mem 0x102ffd5000-0x102fffffff]
[ 0.000000] NODE_DATA(1) allocated [mem 0x82ffd5000-0x82fffffff]
[ 0.000000] tsc: Fast TSC calibration using PIT
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000000001000-0x0000000000ffffff]
[ 0.000000] DMA32 [mem 0x0000000001000000-0x00000000ffffffff]
[ 0.000000] Normal [mem 0x0000000100000000-0x000000102fffffff]
[ 0.000000] Device empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 1: [mem 0x0000000000001000-0x000000000009dfff]
[ 0.000000] node 1: [mem 0x0000000000100000-0x00000000cf378fff]
[ 0.000000] node 1: [mem 0x0000000100000000-0x000000082fffffff]
[ 0.000000] node 0: [mem 0x0000000830000000-0x000000102fffffff]
[ 0.000000] Reserved but unavailable: 99 pages
[ 0.000000] Initmem setup node 0 [mem 0x0000000830000000-0x000000102fffffff]
[ 0.000000] On node 0 totalpages: 8388608
[ 0.000000] Normal zone: 131072 pages used for memmap
[ 0.000000] Normal zone: 8388608 pages, LIFO batch:31
[ 0.000000] Initmem setup node 1 [mem 0x0000000000001000-0x000000082fffffff]
[ 0.000000] On node 1 totalpages: 8385302
[ 0.000000] DMA zone: 64 pages used for memmap
[ 0.000000] DMA zone: 21 pages reserved
[ 0.000000] DMA zone: 3997 pages, LIFO batch:0
[ 0.000000] DMA32 zone: 13198 pages used for memmap
[ 0.000000] DMA32 zone: 844665 pages, LIFO batch:31
[ 0.000000] Normal zone: 117760 pages used for memmap
[ 0.000000] Normal zone: 7536640 pages, LIFO batch:31
[ 0.000000] ACPI: PM-Timer IO Port: 0x808
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
[ 0.000000] IOAPIC[0]: apic_id 0, version 32, address 0xfec00000, GSI 0-23
[ 0.000000] IOAPIC[1]: apic_id 1, version 32, address 0xfec80000, GSI 32-55
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] ACPI: HPET id: 0x8086a301 base: 0xfed00000
[ 0.000000] smpboot: Allowing 16 CPUs, 0 hotplug CPUs
[ 0.000000] PM: Registered nosave memory: [mem 0x00000000-0x00000fff]
[ 0.000000] PM: Registered nosave memory: [mem 0x0009e000-0x000fffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xcf379000-0xcf38efff]
[ 0.000000] PM: Registered nosave memory: [mem 0xcf38f000-0xcf3cdfff]
[ 0.000000] PM: Registered nosave memory: [mem 0xcf3ce000-0xcfffffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xd0000000-0xdfffffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xe0000000-0xefffffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xf0000000-0xfdffffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfe000000-0xffffffff]
[ 0.000000] e820: [mem 0xd0000000-0xdfffffff] available for PCI devices
[ 0.000000] Booting paravirtualized kernel on bare hardware
[ 0.000000] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645519600211568 ns
[ 0.000000] random: get_random_bytes called from start_kernel+0x99/0x500 with crng_init=0
[ 0.000000] setup_percpu: NR_CPUS:8192 nr_cpumask_bits:16 nr_cpu_ids:16 nr_node_ids:2
[ 0.000000] percpu: Embedded 45 pages/cpu s147456 r8192 d28672 u262144
[ 0.000000] pcpu-alloc: s147456 r8192 d28672 u262144 alloc=1*2097152
[ 0.000000] pcpu-alloc: [0] 00 02 04 06 08 10 12 14 [1] 01 03 05 07 09 11 13 15
[ 0.000000] Built 2 zonelists, mobility grouping on. Total pages: 16511795
[ 0.000000] Policy zone: Normal
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.15.0-118-generic root=UUID=3a220a69-923d-42d8-b67d-2035ab1c7c8c ro
[ 0.000000] Calgary: detecting Calgary via BIOS EBDA area
[ 0.000000] Calgary: Unable to locate Rio Grande table in EBDA - bailing!
[ 0.000000] Memory: 65892464K/67095640K available (12300K kernel code, 2482K rwdata, 4272K rodata, 2436K init, 2724K bss, 1203176K reserved, 0K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=16, Nodes=2
[ 0.000000] Kernel/User page tables isolation: enabled
[ 0.000000] ftrace: allocating 39396 entries in 154 pages
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] RCU restricting CPUs from NR_CPUS=8192 to nr_cpu_ids=16.
[ 0.000000] Tasks RCU enabled.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=16
[ 0.000000] NR_IRQS: 524544, nr_irqs: 1096, preallocated irqs: 16
[ 0.000000] Console: colour dummy device 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] mempolicy: Enabling automatic NUMA balancing. Configure with numa_balancing= or the kernel.numa_balancing sysctl
[ 0.000000] ACPI: Core revision 20170831
[ 0.000000] ACPI: 2 ACPI AML tables successfully acquired and loaded
[ 0.000000] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484882848 ns
[ 0.000000] hpet clockevent registered
[ 0.000000] APIC: Switch to symmetric I/O mode setup
[ 0.000000] DMAR-IR: This system BIOS has enabled interrupt remapping
on a chipset that contains an erratum making that
feature unstable. To maintain system stability
interrupt remapping is being disabled. Please
contact your BIOS vendor for an update
[ 0.000000] Switched APIC routing to physical flat.
[ 0.000000] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.020000] tsc: Fast TSC calibration using PIT
[ 0.024000] tsc: Detected 2133.561 MHz processor
[ 0.024000] Calibrating delay loop (skipped), value calculated using timer frequency.. 4267.12 BogoMIPS (lpj=8534244)
[ 0.024000] pid_max: default: 32768 minimum: 301
[ 0.024000] Security Framework initialized
[ 0.024000] Yama: becoming mindful.
[ 0.024000] AppArmor: AppArmor initialized
[ 0.042708] Dentry cache hash table entries: 8388608 (order: 14, 67108864 bytes)
[ 0.051092] Inode-cache hash table entries: 4194304 (order: 13, 33554432 bytes)
[ 0.051386] Mount-cache hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.051651] Mountpoint-cache hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.052032] CPU0: Thermal monitoring enabled (TM1)
[ 0.052045] process: using mwait in idle threads
[ 0.052050] Last level iTLB entries: 4KB 512, 2MB 7, 4MB 7
[ 0.052053] Last level dTLB entries: 4KB 512, 2MB 32, 4MB 32, 1GB 0
[ 0.052057] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[ 0.052061] Spectre V2 : Mitigation: Full generic retpoline
[ 0.052064] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[ 0.052067] Spectre V2 : Enabling Restricted Speculation for firmware calls
[ 0.052080] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[ 0.052084] Spectre V2 : User space: Mitigation: STIBP via seccomp and prctl
[ 0.052087] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl and seccomp
[ 0.052123] MDS: Vulnerable: Clear CPU buffers attempted, no microcode
[ 0.059841] Freeing SMP alternatives memory: 36K
[ 0.062274] smpboot: CPU 0 Converting physical 1 to logical package 0
[ 0.170306] smpboot: CPU0: Intel(R) Xeon(R) CPU L5630 @ 2.13GHz (family: 0x6, model: 0x2c, stepping: 0x2)
[ 0.170474] Performance Events: PEBS fmt1+, Westmere events, 16-deep LBR, Intel PMU driver.
[ 0.170498] core: CPUID marked event: 'bus cycles' unavailable
[ 0.170502] ... version: 3
[ 0.170504] ... bit width: 48
[ 0.170507] ... generic registers: 4
[ 0.170509] ... value mask: 0000ffffffffffff
[ 0.170512] ... max period: 000000007fffffff
[ 0.170514] ... fixed-purpose events: 3
[ 0.170516] ... event mask: 000000070000000f
[ 0.170578] Hierarchical SRCU implementation.
[ 0.172000] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[ 0.172000] smp: Bringing up secondary CPUs ...
[ 0.172000] x86: Booting SMP configuration:
[ 0.172000] .... node #1, CPUs: #1
[ 0.004000] smpboot: CPU 1 Converting physical 0 to logical package 1
[ 0.256146] .... node #0, CPUs: #2
[ 0.260220] .... node #1, CPUs: #3
[ 0.264183] .... node #0, CPUs: #4
[ 0.268225] .... node #1, CPUs: #5
[ 0.272201] .... node #0, CPUs: #6
[ 0.275674] .... node #1, CPUs: #7
[ 0.280013] .... node #0, CPUs: #8
[ 0.284259] MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
[ 0.284467] .... node #1, CPUs: #9
[ 0.288187] .... node #0, CPUs: #10
[ 0.292209] .... node #1, CPUs: #11
[ 0.296186] .... node #0, CPUs: #12
[ 0.300217] .... node #1, CPUs: #13
[ 0.304183] .... node #0, CPUs: #14
[ 0.307654] .... node #1, CPUs: #15
[ 0.311622] smp: Brought up 2 nodes, 16 CPUs
[ 0.311622] smpboot: Max logical packages: 2
[ 0.311622] smpboot: Total of 16 processors activated (68274.02 BogoMIPS)
[ 0.318685] devtmpfs: initialized
[ 0.318685] x86/mm: Memory block size: 2048MB
[ 0.318685] evm: security.selinux
[ 0.318685] evm: security.SMACK64
[ 0.318685] evm: security.SMACK64EXEC
[ 0.318685] evm: security.SMACK64TRANSMUTE
[ 0.318685] evm: security.SMACK64MMAP
[ 0.318685] evm: security.apparmor
[ 0.318685] evm: security.ima
[ 0.318685] evm: security.capability
[ 0.318685] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.318685] futex hash table entries: 4096 (order: 6, 262144 bytes)
[ 0.318685] pinctrl core: initialized pinctrl subsystem
[ 0.320003] RTC time: 18:55:59, date: 10/06/20
[ 0.321005] NET: Registered protocol family 16
[ 0.321116] audit: initializing netlink subsys (disabled)
[ 0.321133] audit: type=2000 audit(1602010559.320:1): state=initialized audit_enabled=0 res=1
[ 0.321133] cpuidle: using governor ladder
[ 0.321133] cpuidle: using governor menu
[ 0.321133] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[ 0.321133] ACPI: bus type PCI registered
[ 0.321133] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.321133] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[ 0.321133] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in E820
[ 0.321133] PCI: Using configuration type 1 for base access
[ 0.321209] mtrr: your CPUs had inconsistent variable MTRR settings
[ 0.321216] mtrr: probably your BIOS does not setup all CPUs.
[ 0.321219] mtrr: corrected configuration.
[ 0.324082] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.324082] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.324206] ACPI: Added _OSI(Module Device)
[ 0.324210] ACPI: Added _OSI(Processor Device)
[ 0.324213] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.324216] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.324219] ACPI: Added _OSI(Linux-Dell-Video)
[ 0.324221] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[ 0.324224] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[ 0.324945] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
[ 0.332456] ACPI: Interpreter enabled
[ 0.332477] ACPI: (supports S0 S4 S5)
[ 0.332480] ACPI: Using IOAPIC for interrupt routing
[ 0.332624] HEST: Table parsing has been initialized.
[ 0.332631] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.332852] ACPI: Enabled 2 GPEs in block 00 to 3F
[ 0.343088] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.343098] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
[ 0.343303] acpi PNP0A08:00: PCIe AER handled by firmware
[ 0.343711] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME PCIeCapability]
[ 0.343716] acpi PNP0A08:00: FADT indicates ASPM is unsupported, using BIOS configuration
[ 0.344134] PCI host bridge to bus 0000:00
[ 0.344140] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7 window]
[ 0.344144] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
[ 0.344147] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[ 0.344152] pci_bus 0000:00: root bus resource [mem 0xd0000000-0xfdffffff window]
[ 0.344156] pci_bus 0000:00: root bus resource [mem 0xfed40000-0xfed44fff window]
[ 0.344160] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 0.344175] pci 0000:00:00.0: [8086:3403] type 00 class 0x060000
[ 0.344210] pci 0000:00:00.0: enabling Extended Tags
[ 0.344251] pci 0000:00:00.0: PME# supported from D0 D3hot D3cold
[ 0.344337] pci 0000:00:01.0: [8086:3408] type 01 class 0x060400
[ 0.344367] pci 0000:00:01.0: enabling Extended Tags
[ 0.344408] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[ 0.344499] pci 0000:00:03.0: [8086:340a] type 01 class 0x060400
[ 0.344530] pci 0000:00:03.0: enabling Extended Tags
[ 0.344570] pci 0000:00:03.0: PME# supported from D0 D3hot D3cold
[ 0.344660] pci 0000:00:07.0: [8086:340e] type 01 class 0x060400
[ 0.344691] pci 0000:00:07.0: enabling Extended Tags
[ 0.344731] pci 0000:00:07.0: PME# supported from D0 D3hot D3cold
[ 0.344820] pci 0000:00:09.0: [8086:3410] type 01 class 0x060400
[ 0.344849] pci 0000:00:09.0: enabling Extended Tags
[ 0.344888] pci 0000:00:09.0: PME# supported from D0 D3hot D3cold
[ 0.344970] pci 0000:00:0a.0: [8086:3411] type 01 class 0x060400
[ 0.344999] pci 0000:00:0a.0: enabling Extended Tags
[ 0.345038] pci 0000:00:0a.0: PME# supported from D0 D3hot D3cold
[ 0.345131] pci 0000:00:14.0: [8086:342e] type 00 class 0x080000
[ 0.345251] pci 0000:00:14.1: [8086:3422] type 00 class 0x080000
[ 0.345370] pci 0000:00:14.2: [8086:3423] type 00 class 0x080000
[ 0.345491] pci 0000:00:1a.0: [8086:3a37] type 00 class 0x0c0300
[ 0.345535] pci 0000:00:1a.0: reg 0x20: [io 0xec40-0xec5f]
[ 0.345630] pci 0000:00:1a.1: [8086:3a38] type 00 class 0x0c0300
[ 0.345673] pci 0000:00:1a.1: reg 0x20: [io 0xec60-0xec7f]
[ 0.345778] pci 0000:00:1a.7: [8086:3a3c] type 00 class 0x0c0320
[ 0.345799] pci 0000:00:1a.7: reg 0x10: [mem 0xdf0fe000-0xdf0fe3ff]
[ 0.345882] pci 0000:00:1a.7: PME# supported from D0 D3hot D3cold
[ 0.345951] pci 0000:00:1d.0: [8086:3a34] type 00 class 0x0c0300
[ 0.345995] pci 0000:00:1d.0: reg 0x20: [io 0xec80-0xec9f]
[ 0.346090] pci 0000:00:1d.1: [8086:3a35] type 00 class 0x0c0300
[ 0.346134] pci 0000:00:1d.1: reg 0x20: [io 0xeca0-0xecbf]
[ 0.346229] pci 0000:00:1d.2: [8086:3a36] type 00 class 0x0c0300
[ 0.346274] pci 0000:00:1d.2: reg 0x20: [io 0xecc0-0xecdf]
[ 0.346369] pci 0000:00:1d.3: [8086:3a39] type 00 class 0x0c0300
[ 0.346413] pci 0000:00:1d.3: reg 0x20: [io 0xece0-0xecff]
[ 0.346515] pci 0000:00:1d.7: [8086:3a3a] type 00 class 0x0c0320
[ 0.346537] pci 0000:00:1d.7: reg 0x10: [mem 0xdf0ff000-0xdf0ff3ff]
[ 0.346619] pci 0000:00:1d.7: PME# supported from D0 D3hot D3cold
[ 0.346685] pci 0000:00:1e.0: [8086:244e] type 01 class 0x060401
[ 0.346801] pci 0000:00:1f.0: [8086:3a16] type 00 class 0x060100
[ 0.346883] pci 0000:00:1f.0: quirk: [io 0x0800-0x087f] claimed by ICH6 ACPI/GPIO/TCO
[ 0.346891] pci 0000:00:1f.0: quirk: [io 0x0880-0x08bf] claimed by ICH6 GPIO
[ 0.346897] pci 0000:00:1f.0: ICH7 LPC Generic IO decode 1 PIO at 0c00 (mask 007f)
[ 0.346902] pci 0000:00:1f.0: ICH7 LPC Generic IO decode 2 PIO at 0ca0 (mask 000f)
[ 0.346907] pci 0000:00:1f.0: ICH7 LPC Generic IO decode 3 PIO at 00e0 (mask 000f)
[ 0.347051] pci 0000:01:00.0: [14e4:163b] type 00 class 0x020000
[ 0.347075] pci 0000:01:00.0: reg 0x10: [mem 0xda000000-0xdbffffff 64bit]
[ 0.347174] pci 0000:01:00.0: PME# supported from D0 D3hot D3cold
[ 0.347249] pci 0000:01:00.1: [14e4:163b] type 00 class 0x020000
[ 0.347273] pci 0000:01:00.1: reg 0x10: [mem 0xdc000000-0xddffffff 64bit]
[ 0.347371] pci 0000:01:00.1: PME# supported from D0 D3hot D3cold
[ 0.356023] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 0.356033] pci 0000:00:01.0: bridge window [mem 0xda000000-0xddffffff]
[ 0.356097] pci 0000:02:00.0: [1000:0079] type 00 class 0x010400
[ 0.356112] pci 0000:02:00.0: reg 0x10: [io 0xfc00-0xfcff]
[ 0.356122] pci 0000:02:00.0: reg 0x14: [mem 0xdf1bc000-0xdf1bffff 64bit]
[ 0.356131] pci 0000:02:00.0: reg 0x1c: [mem 0xdf1c0000-0xdf1fffff 64bit]
[ 0.356143] pci 0000:02:00.0: reg 0x30: [mem 0xdf100000-0xdf13ffff pref]
[ 0.356149] pci 0000:02:00.0: enabling Extended Tags
[ 0.356195] pci 0000:02:00.0: supports D1 D2
[ 0.368017] pci 0000:00:03.0: PCI bridge to [bus 02]
[ 0.368025] pci 0000:00:03.0: bridge window [io 0xf000-0xffff]
[ 0.368029] pci 0000:00:03.0: bridge window [mem 0xdf100000-0xdf1fffff]
[ 0.368085] pci 0000:00:07.0: PCI bridge to [bus 03]
[ 0.368133] pci 0000:00:09.0: PCI bridge to [bus 04]
[ 0.368176] pci 0000:00:0a.0: PCI bridge to [bus 05]
[ 0.368227] pci 0000:06:03.0: [102b:0532] type 00 class 0x030000
[ 0.368247] pci 0000:06:03.0: reg 0x10: [mem 0xd9800000-0xd9ffffff pref]
[ 0.368256] pci 0000:06:03.0: reg 0x14: [mem 0xde7fc000-0xde7fffff]
[ 0.368264] pci 0000:06:03.0: reg 0x18: [mem 0xde800000-0xdeffffff]
[ 0.368296] pci 0000:06:03.0: reg 0x30: [mem 0x00000000-0x0000ffff pref]
[ 0.368391] pci 0000:00:1e.0: PCI bridge to [bus 06] (subtractive decode)
[ 0.368400] pci 0000:00:1e.0: bridge window [mem 0xde000000-0xdeffffff]
[ 0.368404] pci 0000:00:1e.0: bridge window [mem 0xd9800000-0xd9ffffff 64bit pref]
[ 0.368406] pci 0000:00:1e.0: bridge window [io 0x0000-0x0cf7 window] (subtractive decode)
[ 0.368408] pci 0000:00:1e.0: bridge window [io 0x0d00-0xffff window] (subtractive decode)
[ 0.368409] pci 0000:00:1e.0: bridge window [mem 0x000a0000-0x000bffff window] (subtractive decode)
[ 0.368411] pci 0000:00:1e.0: bridge window [mem 0xd0000000-0xfdffffff window] (subtractive decode)
[ 0.368412] pci 0000:00:1e.0: bridge window [mem 0xfed40000-0xfed44fff window] (subtractive decode)
[ 0.370416] ACPI: PCI Interrupt Link [LK00] (IRQs 3 4 5 6 7 10 11 14 *15)
[ 0.370550] ACPI: PCI Interrupt Link [LK01] (IRQs 3 4 5 6 7 10 11 *14 15)
[ 0.370681] ACPI: PCI Interrupt Link [LK02] (IRQs 3 4 5 6 7 10 *11 14 15)
[ 0.370812] ACPI: PCI Interrupt Link [LK03] (IRQs 3 4 5 6 7 *10 11 14 15)
[ 0.370942] ACPI: PCI Interrupt Link [LK04] (IRQs 3 4 *5 6 7 10 11 14 15)
[ 0.371072] ACPI: PCI Interrupt Link [LK05] (IRQs 3 4 5 *6 7 10 11 14 15)
[ 0.371203] ACPI: PCI Interrupt Link [LK06] (IRQs 3 4 5 6 7 10 *11 14 15)
[ 0.371333] ACPI: PCI Interrupt Link [LK07] (IRQs 3 4 5 6 7 10 11 *14 15)
[ 0.371776] SCSI subsystem initialized
[ 0.371810] libata version 3.00 loaded.
[ 0.371810] pci 0000:06:03.0: vgaarb: setting as boot VGA device
[ 0.371810] pci 0000:06:03.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[ 0.371810] pci 0000:06:03.0: vgaarb: bridge control possible
[ 0.371810] vgaarb: loaded
[ 0.371810] ACPI: bus type USB registered
[ 0.371810] usbcore: registered new interface driver usbfs
[ 0.371810] usbcore: registered new interface driver hub
[ 0.372053] usbcore: registered new device driver usb
[ 0.372117] EDAC MC: Ver: 3.0.0
[ 0.372137] PCI: Using ACPI for IRQ routing
[ 0.378352] PCI: Discovered peer bus fe
[ 0.378355] PCI: root bus fe: using default resources
[ 0.378356] PCI: Probing PCI hardware (bus fe)
[ 0.378391] PCI host bridge to bus 0000:fe
[ 0.378396] pci_bus 0000:fe: root bus resource [io 0x0000-0xffff]
[ 0.378400] pci_bus 0000:fe: root bus resource [mem 0x00000000-0xffffffffff]
[ 0.378404] pci_bus 0000:fe: No busn resource found for root bus, will use [bus fe-ff]
[ 0.378409] pci_bus 0000:fe: busn_res: can not insert [bus fe-ff] under domain [bus 00-ff] (conflicts with (null) [bus 00-ff])
[ 0.378415] pci 0000:fe:00.0: [8086:2c70] type 00 class 0x060000
[ 0.378467] pci 0000:fe:00.1: [8086:2d81] type 00 class 0x060000
[ 0.378517] pci 0000:fe:02.0: [8086:2d90] type 00 class 0x060000
[ 0.378563] pci 0000:fe:02.1: [8086:2d91] type 00 class 0x060000
[ 0.378608] pci 0000:fe:02.2: [8086:2d92] type 00 class 0x060000
[ 0.378653] pci 0000:fe:02.3: [8086:2d93] type 00 class 0x060000
[ 0.378702] pci 0000:fe:02.4: [8086:2d94] type 00 class 0x060000
[ 0.378748] pci 0000:fe:02.5: [8086:2d95] type 00 class 0x060000
[ 0.378796] pci 0000:fe:03.0: [8086:2d98] type 00 class 0x060000
[ 0.378841] pci 0000:fe:03.1: [8086:2d99] type 00 class 0x060000
[ 0.378886] pci 0000:fe:03.2: [8086:2d9a] type 00 class 0x060000
[ 0.378933] pci 0000:fe:03.4: [8086:2d9c] type 00 class 0x060000
[ 0.378983] pci 0000:fe:04.0: [8086:2da0] type 00 class 0x060000
[ 0.379028] pci 0000:fe:04.1: [8086:2da1] type 00 class 0x060000
[ 0.379074] pci 0000:fe:04.2: [8086:2da2] type 00 class 0x060000
[ 0.379119] pci 0000:fe:04.3: [8086:2da3] type 00 class 0x060000
[ 0.379167] pci 0000:fe:05.0: [8086:2da8] type 00 class 0x060000
[ 0.379212] pci 0000:fe:05.1: [8086:2da9] type 00 class 0x060000
[ 0.379262] pci 0000:fe:05.2: [8086:2daa] type 00 class 0x060000
[ 0.379308] pci 0000:fe:05.3: [8086:2dab] type 00 class 0x060000
[ 0.379356] pci 0000:fe:06.0: [8086:2db0] type 00 class 0x060000
[ 0.379401] pci 0000:fe:06.1: [8086:2db1] type 00 class 0x060000
[ 0.379446] pci 0000:fe:06.2: [8086:2db2] type 00 class 0x060000
[ 0.379490] pci 0000:fe:06.3: [8086:2db3] type 00 class 0x060000
[ 0.379553] pci_bus 0000:fe: busn_res: [bus fe-ff] end is updated to fe
[ 0.379555] pci_bus 0000:fe: busn_res: can not insert [bus fe] under domain [bus 00-ff] (conflicts with (null) [bus 00-ff])
[ 0.379564] PCI: Discovered peer bus ff
[ 0.379567] PCI: root bus ff: using default resources
[ 0.379568] PCI: Probing PCI hardware (bus ff)
[ 0.379593] PCI host bridge to bus 0000:ff
[ 0.379597] pci_bus 0000:ff: root bus resource [io 0x0000-0xffff]
[ 0.379600] pci_bus 0000:ff: root bus resource [mem 0x00000000-0xffffffffff]
[ 0.379604] pci_bus 0000:ff: No busn resource found for root bus, will use [bus ff-ff]
[ 0.379609] pci_bus 0000:ff: busn_res: can not insert [bus ff] under domain [bus 00-ff] (conflicts with (null) [bus 00-ff])
[ 0.379614] pci 0000:ff:00.0: [8086:2c70] type 00 class 0x060000
[ 0.379663] pci 0000:ff:00.1: [8086:2d81] type 00 class 0x060000
[ 0.379713] pci 0000:ff:02.0: [8086:2d90] type 00 class 0x060000
[ 0.379760] pci 0000:ff:02.1: [8086:2d91] type 00 class 0x060000
[ 0.379807] pci 0000:ff:02.2: [8086:2d92] type 00 class 0x060000
[ 0.379860] pci 0000:ff:02.3: [8086:2d93] type 00 class 0x060000
[ 0.379911] pci 0000:ff:02.4: [8086:2d94] type 00 class 0x060000
[ 0.379958] pci 0000:ff:02.5: [8086:2d95] type 00 class 0x060000
[ 0.380013] pci 0000:ff:03.0: [8086:2d98] type 00 class 0x060000
[ 0.380065] pci 0000:ff:03.1: [8086:2d99] type 00 class 0x060000
[ 0.380113] pci 0000:ff:03.2: [8086:2d9a] type 00 class 0x060000
[ 0.380160] pci 0000:ff:03.4: [8086:2d9c] type 00 class 0x060000
[ 0.380212] pci 0000:ff:04.0: [8086:2da0] type 00 class 0x060000
[ 0.380259] pci 0000:ff:04.1: [8086:2da1] type 00 class 0x060000
[ 0.380310] pci 0000:ff:04.2: [8086:2da2] type 00 class 0x060000
[ 0.380357] pci 0000:ff:04.3: [8086:2da3] type 00 class 0x060000
[ 0.380410] pci 0000:ff:05.0: [8086:2da8] type 00 class 0x060000
[ 0.380458] pci 0000:ff:05.1: [8086:2da9] type 00 class 0x060000
[ 0.380513] pci 0000:ff:05.2: [8086:2daa] type 00 class 0x060000
[ 0.380562] pci 0000:ff:05.3: [8086:2dab] type 00 class 0x060000
[ 0.380614] pci 0000:ff:06.0: [8086:2db0] type 00 class 0x060000
[ 0.380663] pci 0000:ff:06.1: [8086:2db1] type 00 class 0x060000
[ 0.380712] pci 0000:ff:06.2: [8086:2db2] type 00 class 0x060000
[ 0.380760] pci 0000:ff:06.3: [8086:2db3] type 00 class 0x060000
[ 0.380829] pci_bus 0000:ff: busn_res: [bus ff] end is updated to ff
[ 0.380831] pci_bus 0000:ff: busn_res: can not insert [bus ff] under domain [bus 00-ff] (conflicts with (null) [bus 00-ff])
[ 0.380840] PCI: pci_cache_line_size set to 64 bytes
[ 0.380931] e820: reserve RAM buffer [mem 0x0009e000-0x0009ffff]
[ 0.380932] e820: reserve RAM buffer [mem 0xcf379000-0xcfffffff]
[ 0.381069] NetLabel: Initializing
[ 0.381073] NetLabel: domain hash size = 128
[ 0.381075] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.381096] NetLabel: unlabeled traffic allowed by default
[ 0.381123] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0
[ 0.381123] hpet0: 4 comparators, 64-bit 14.318180 MHz counter
[ 0.384051] clocksource: Switched to clocksource hpet
[ 0.400773] VFS: Disk quotas dquot_6.6.0
[ 0.400812] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.400963] AppArmor: AppArmor Filesystem Enabled
[ 0.401007] pnp: PnP ACPI init
[ 0.401244] system 00:00: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.401309] pnp 00:01: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.401702] pnp 00:02: Plug and Play ACPI device, IDs PNP0501 (active)
[ 0.402080] pnp 00:03: Plug and Play ACPI device, IDs PNP0501 (active)
[ 0.403252] system 00:04: [io 0x0800-0x087f] has been reserved
[ 0.403258] system 00:04: [io 0x0880-0x08ff] could not be reserved
[ 0.403262] system 00:04: [io 0x0900-0x091f] has been reserved
[ 0.403265] system 00:04: [io 0x0920-0x0923] has been reserved
[ 0.403269] system 00:04: [io 0x0924] has been reserved
[ 0.403272] system 00:04: [io 0x0c00-0x0c7f] has been reserved
[ 0.403276] system 00:04: [io 0x0ca0-0x0ca7] has been reserved
[ 0.403280] system 00:04: [io 0x0ca9-0x0cab] has been reserved
[ 0.403283] system 00:04: [io 0x0cad-0x0caf] has been reserved
[ 0.403291] system 00:04: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.403372] pnp 00:05: [irq 0 disabled]
[ 0.403419] system 00:05: [io 0x0ca8] has been reserved
[ 0.403424] system 00:05: [io 0x0cac] has been reserved
[ 0.403431] system 00:05: Plug and Play ACPI device, IDs IPI0001 PNP0c01 (active)
[ 0.404402] system 00:06: [mem 0xe0000000-0xefffffff] has been reserved
[ 0.404412] system 00:06: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.404528] system 00:07: [mem 0xfed90000-0xfed91fff] has been reserved
[ 0.404537] system 00:07: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.404851] pnp: PnP ACPI: found 8 devices
[ 0.411567] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ 0.411618] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 0.411625] pci 0000:00:01.0: bridge window [mem 0xda000000-0xddffffff]
[ 0.411633] pci 0000:00:03.0: PCI bridge to [bus 02]
[ 0.411637] pci 0000:00:03.0: bridge window [io 0xf000-0xffff]
[ 0.411643] pci 0000:00:03.0: bridge window [mem 0xdf100000-0xdf1fffff]
[ 0.411651] pci 0000:00:07.0: PCI bridge to [bus 03]
[ 0.411661] pci 0000:00:09.0: PCI bridge to [bus 04]
[ 0.411670] pci 0000:00:0a.0: PCI bridge to [bus 05]
[ 0.411684] pci 0000:06:03.0: BAR 6: assigned [mem 0xde000000-0xde00ffff pref]
[ 0.411689] pci 0000:00:1e.0: PCI bridge to [bus 06]
[ 0.411694] pci 0000:00:1e.0: bridge window [mem 0xde000000-0xdeffffff]
[ 0.411700] pci 0000:00:1e.0: bridge window [mem 0xd9800000-0xd9ffffff 64bit pref]
[ 0.411708] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7 window]
[ 0.411710] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff window]
[ 0.411711] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[ 0.411713] pci_bus 0000:00: resource 7 [mem 0xd0000000-0xfdffffff window]
[ 0.411714] pci_bus 0000:00: resource 8 [mem 0xfed40000-0xfed44fff window]
[ 0.411716] pci_bus 0000:01: resource 1 [mem 0xda000000-0xddffffff]
[ 0.411718] pci_bus 0000:02: resource 0 [io 0xf000-0xffff]
[ 0.411719] pci_bus 0000:02: resource 1 [mem 0xdf100000-0xdf1fffff]
[ 0.411721] pci_bus 0000:06: resource 1 [mem 0xde000000-0xdeffffff]
[ 0.411722] pci_bus 0000:06: resource 2 [mem 0xd9800000-0xd9ffffff 64bit pref]
[ 0.411724] pci_bus 0000:06: resource 4 [io 0x0000-0x0cf7 window]
[ 0.411725] pci_bus 0000:06: resource 5 [io 0x0d00-0xffff window]
[ 0.411727] pci_bus 0000:06: resource 6 [mem 0x000a0000-0x000bffff window]
[ 0.411728] pci_bus 0000:06: resource 7 [mem 0xd0000000-0xfdffffff window]
[ 0.411729] pci_bus 0000:06: resource 8 [mem 0xfed40000-0xfed44fff window]
[ 0.411760] pci_bus 0000:fe: resource 4 [io 0x0000-0xffff]
[ 0.411762] pci_bus 0000:fe: resource 5 [mem 0x00000000-0xffffffffff]
[ 0.411766] pci_bus 0000:ff: resource 4 [io 0x0000-0xffff]
[ 0.411767] pci_bus 0000:ff: resource 5 [mem 0x00000000-0xffffffffff]
[ 0.411823] NET: Registered protocol family 2
[ 0.412222] TCP established hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.413264] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 0.413480] TCP: Hash tables configured (established 524288 bind 65536)
[ 0.413615] UDP hash table entries: 32768 (order: 8, 1048576 bytes)
[ 0.413892] UDP-Lite hash table entries: 32768 (order: 8, 1048576 bytes)
[ 0.414206] NET: Registered protocol family 1
[ 0.440054] pci 0000:02:00.0: [Firmware Bug]: disabling VPD access (can't determine size of non-standard VPD format)
[ 0.440068] pci 0000:06:03.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[ 0.440154] PCI: CLS 64 bytes, default 64
[ 0.440200] Unpacking initramfs...
[ 1.586449] Freeing initrd memory: 56960K
[ 1.586530] DMAR: Host address width 40
[ 1.586535] DMAR: DRHD base: 0x000000fed90000 flags: 0x1
[ 1.586554] DMAR: dmar0: reg_base_addr fed90000 ver 1:0 cap c90780106f0462 ecap f020fe
[ 1.586559] DMAR: RMRR base: 0x000000cf4c8000 end: 0x000000cf4dffff
[ 1.586562] DMAR: RMRR base: 0x000000cf4b1000 end: 0x000000cf4bffff
[ 1.586565] DMAR: RMRR base: 0x000000cf4a1000 end: 0x000000cf4a1fff
[ 1.586568] DMAR: RMRR base: 0x000000cf4a3000 end: 0x000000cf4a3fff
[ 1.586571] DMAR: RMRR base: 0x000000cf4a5000 end: 0x000000cf4a5fff
[ 1.586574] DMAR: RMRR base: 0x000000cf4a7000 end: 0x000000cf4a7fff
[ 1.586577] DMAR: RMRR base: 0x000000cf4a9000 end: 0x000000cf4a9fff
[ 1.586580] DMAR: RMRR base: 0x000000cf4c0000 end: 0x000000cf4c0fff
[ 1.586583] DMAR: RMRR base: 0x000000cf4c2000 end: 0x000000cf4c2fff
[ 1.586586] DMAR: ATSR flags: 0x0
[ 1.586656] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 1.586660] software IO TLB: mapped [mem 0xcb379000-0xcf379000] (64MB)
[ 1.587467] Scanning for low memory corruption every 60 seconds
[ 1.588518] Initialise system trusted keyrings
[ 1.588531] Key type blacklist registered
[ 1.588615] workingset: timestamp_bits=36 max_order=24 bucket_order=0
[ 1.590211] zbud: loaded
[ 1.591084] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.591280] fuse init (API version 7.26)
[ 1.593237] Key type asymmetric registered
[ 1.593242] Asymmetric key parser 'x509' registered
[ 1.593297] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 1.593365] io scheduler noop registered
[ 1.593368] io scheduler deadline registered
[ 1.593408] io scheduler cfq registered (default)
[ 1.596188] pcieport 0000:00:01.0: Signaling PME with IRQ 25
[ 1.596216] pcieport 0000:00:03.0: Signaling PME with IRQ 26
[ 1.596247] pcieport 0000:00:07.0: Signaling PME with IRQ 27
[ 1.596289] pcieport 0000:00:09.0: Signaling PME with IRQ 28
[ 1.596319] pcieport 0000:00:0a.0: Signaling PME with IRQ 29
[ 1.596437] vesafb: mode is 1280x1024x32, linelength=5120, pages=0
[ 1.596441] vesafb: scrolling: redraw
[ 1.596444] vesafb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[ 1.596460] vesafb: framebuffer at 0xd9800000, mapped to 0x (ptrval), using 5120k, total 5120k
[ 1.887211] Console: switching to colour frame buffer device 160x64
[ 2.121537] fb0: VESA VGA frame buffer device
[ 2.122663] intel_idle: MWAIT substates: 0x1120
[ 2.122665] intel_idle: v0.4.1 model 0x2C
[ 2.123570] intel_idle: lapic_timer_reliable_states 0xffffffff
[ 2.123704] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input0
[ 2.125610] ACPI: Power Button [PWRF]
[ 2.127458] ERST: Error Record Serialization Table (ERST) support is initialized.
[ 2.129659] pstore: using zlib compression
[ 2.130755] pstore: Registered erst as persistent store backend
[ 2.132717] GHES: APEI firmware first mode is enabled by APEI bit and WHEA _OSC.
[ 2.134624] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[ 2.156668] 00:02: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 115200) is a 16550A
[ 2.192234] 00:03: ttyS1 at I/O 0x2f8 (irq = 3, base_baud = 115200) is a 16550A
[ 2.196678] Linux agpgart interface v0.103
[ 2.203096] loop: module loaded
[ 2.204129] libphy: Fixed MDIO Bus: probed
[ 2.205117] tun: Universal TUN/TAP device driver, 1.6
[ 2.206365] PPP generic driver version 2.4.2
[ 2.207434] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 2.209269] ehci-pci: EHCI PCI platform driver
[ 2.211084] ehci-pci 0000:00:1a.7: EHCI Host Controller
[ 2.212420] ehci-pci 0000:00:1a.7: new USB bus registered, assigned bus number 1
[ 2.214281] ehci-pci 0000:00:1a.7: debug port 1
[ 2.219363] ehci-pci 0000:00:1a.7: cache line size of 64 is not supported
[ 2.219385] ehci-pci 0000:00:1a.7: irq 19, io mem 0xdf0fe000
[ 2.236024] ehci-pci 0000:00:1a.7: USB 2.0 started, EHCI 1.00
[ 2.237524] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.239488] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.241505] usb usb1: Product: EHCI Host Controller
[ 2.242802] usb usb1: Manufacturer: Linux 4.15.0-118-generic ehci_hcd
[ 2.244430] usb usb1: SerialNumber: 0000:00:1a.7
[ 2.245723] hub 1-0:1.0: USB hub found
[ 2.246662] hub 1-0:1.0: 4 ports detected
[ 2.248339] ehci-pci 0000:00:1d.7: EHCI Host Controller
[ 2.249943] ehci-pci 0000:00:1d.7: new USB bus registered, assigned bus number 2
[ 2.251853] ehci-pci 0000:00:1d.7: debug port 1
[ 2.256898] ehci-pci 0000:00:1d.7: cache line size of 64 is not supported
[ 2.256916] ehci-pci 0000:00:1d.7: irq 21, io mem 0xdf0ff000
[ 2.272025] ehci-pci 0000:00:1d.7: USB 2.0 started, EHCI 1.00
[ 2.273484] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.275103] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.276860] usb usb2: Product: EHCI Host Controller
[ 2.278013] usb usb2: Manufacturer: Linux 4.15.0-118-generic ehci_hcd
[ 2.279986] usb usb2: SerialNumber: 0000:00:1d.7
[ 2.347844] hub 2-0:1.0: USB hub found
[ 2.415332] hub 2-0:1.0: 4 ports detected
[ 2.485721] ehci-platform: EHCI generic platform driver
[ 2.553534] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 2.588399] tsc: Refined TSC clocksource calibration: 2133.405 MHz
[ 2.621190] ohci-pci: OHCI PCI platform driver
[ 2.621223] ohci-platform: OHCI generic platform driver
[ 2.621239] uhci_hcd: USB Universal Host Controller Interface driver
[ 2.621796] uhci_hcd 0000:00:1a.0: UHCI Host Controller
[ 2.689036] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x1ec074e45e5, max_idle_ns: 440795220282 ns
[ 2.755876] uhci_hcd 0000:00:1a.0: new USB bus registered, assigned bus number 3
[ 2.755884] uhci_hcd 0000:00:1a.0: detected 2 ports
[ 2.755927] uhci_hcd 0000:00:1a.0: irq 17, io base 0x0000ec40
[ 2.823772] usb 1-3: new high-speed USB device number 2 using ehci-pci
[ 2.891914] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[ 3.148786] usb 1-3: New USB device found, idVendor=0424, idProduct=2514
[ 3.204493] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.204494] usb usb3: Product: UHCI Host Controller
[ 3.204496] usb usb3: Manufacturer: Linux 4.15.0-118-generic uhci_hcd
[ 3.204497] usb usb3: SerialNumber: 0000:00:1a.0
[ 3.204643] hub 3-0:1.0: USB hub found
[ 3.274508] usb 1-3: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.345821] hub 1-3:1.0: USB hub found
[ 3.417303] hub 3-0:1.0: 2 ports detected
[ 3.417845] uhci_hcd 0000:00:1a.1: UHCI Host Controller
[ 3.493034] hub 1-3:1.0: 4 ports detected
[ 3.568076] uhci_hcd 0000:00:1a.1: new USB bus registered, assigned bus number 4
[ 3.568088] uhci_hcd 0000:00:1a.1: detected 2 ports
[ 4.385582] clocksource: Switched to clocksource tsc
[ 4.385622] uhci_hcd 0000:00:1a.1: irq 18, io base 0x0000ec60
[ 4.532604] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[ 4.604944] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4.676852] usb usb4: Product: UHCI Host Controller
[ 4.748255] usb usb4: Manufacturer: Linux 4.15.0-118-generic uhci_hcd
[ 4.820789] usb usb4: SerialNumber: 0000:00:1a.1
[ 4.892982] hub 4-0:1.0: USB hub found
[ 4.965493] hub 4-0:1.0: 2 ports detected
[ 5.037133] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[ 5.109218] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 5
[ 5.181927] uhci_hcd 0000:00:1d.0: detected 2 ports
[ 5.253496] uhci_hcd 0000:00:1d.0: irq 21, io base 0x0000ec80
[ 5.324808] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
[ 5.430159] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 5.505219] usb usb5: Product: UHCI Host Controller
[ 5.577442] usb usb5: Manufacturer: Linux 4.15.0-118-generic uhci_hcd
[ 5.651054] usb usb5: SerialNumber: 0000:00:1d.0
[ 5.723835] hub 5-0:1.0: USB hub found
[ 5.795859] hub 5-0:1.0: 2 ports detected
[ 5.868402] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[ 5.940209] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 6
[ 6.013332] uhci_hcd 0000:00:1d.1: detected 2 ports
[ 6.085242] uhci_hcd 0000:00:1d.1: irq 20, io base 0x0000eca0
[ 6.156351] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
[ 6.229643] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 6.244072] usb 5-1: new low-speed USB device number 2 using uhci_hcd
[ 6.303733] usb usb6: Product: UHCI Host Controller
[ 6.303734] usb usb6: Manufacturer: Linux 4.15.0-118-generic uhci_hcd
[ 6.303735] usb usb6: SerialNumber: 0000:00:1d.1
[ 6.303942] hub 6-0:1.0: USB hub found
[ 6.573859] usb 5-1: New USB device found, idVendor=1c4f, idProduct=0002
[ 6.601026] hub 6-0:1.0: 2 ports detected
[ 6.601505] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[ 6.673855] usb 5-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 6.747709] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 7
[ 6.821250] usb 5-1: Product: USB Keyboard
[ 6.821251] usb 5-1: Manufacturer: SIGMACHIP
[ 6.948069] usb 5-2: new full-speed USB device number 3 using uhci_hcd
[ 6.978636] uhci_hcd 0000:00:1d.2: detected 2 ports
[ 7.243861] usb 5-2: New USB device found, idVendor=0624, idProduct=0248
[ 7.294319] uhci_hcd 0000:00:1d.2: irq 21, io base 0x0000ecc0
[ 7.294367] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001
[ 7.369750] usb 5-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 7.445153] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 7.445154] usb usb7: Product: UHCI Host Controller
[ 7.445156] usb usb7: Manufacturer: Linux 4.15.0-118-generic uhci_hcd
[ 7.445157] usb usb7: SerialNumber: 0000:00:1d.2
[ 7.445414] hub 7-0:1.0: USB hub found
[ 7.526818] usb 5-2: Product: USB Composite Device-0
[ 7.526820] usb 5-2: Manufacturer: Avocent
[ 7.526821] usb 5-2: SerialNumber: 20120430
[ 8.330840] hub 7-0:1.0: 2 ports detected
[ 8.402955] uhci_hcd 0000:00:1d.3: UHCI Host Controller
[ 8.476573] uhci_hcd 0000:00:1d.3: new USB bus registered, assigned bus number 8
[ 8.550658] uhci_hcd 0000:00:1d.3: detected 2 ports
[ 8.622475] uhci_hcd 0000:00:1d.3: irq 20, io base 0x0000ece0
[ 8.694604] usb usb8: New USB device found, idVendor=1d6b, idProduct=0001
[ 8.767082] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 8.840236] usb usb8: Product: UHCI Host Controller
[ 8.913123] usb usb8: Manufacturer: Linux 4.15.0-118-generic uhci_hcd
[ 8.987710] usb usb8: SerialNumber: 0000:00:1d.3
[ 9.061849] hub 8-0:1.0: USB hub found
[ 9.133825] hub 8-0:1.0: 2 ports detected
[ 9.204791] i8042: PNP: No PS/2 controller found.
[ 9.276549] i8042: Probing ports directly.
[ 9.350202] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 9.421005] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 9.491934] mousedev: PS/2 mouse device common for all mice
[ 9.568670] rtc_cmos 00:01: RTC can wake from S4
[ 9.642446] rtc_cmos 00:01: rtc core: registered rtc_cmos as rtc0
[ 9.718847] rtc_cmos 00:01: alarms up to one day, y3k, 242 bytes nvram, hpet irqs
[ 9.795291] i2c /dev entries driver
[ 9.871530] device-mapper: uevent: version 1.0.3
[ 9.942699] device-mapper: ioctl: 4.37.0-ioctl (2017-09-20) initialised: dm-devel@redhat.com
[ 10.018238] ledtrig-cpu: registered to indicate activity on CPUs
[ 10.092596] NET: Registered protocol family 10
[ 10.171619] Segment Routing with IPv6
[ 10.243142] NET: Registered protocol family 17
[ 10.315160] Key type dns_resolver registered
[ 10.389542] mce: Using 9 MCE banks
[ 10.460542] RAS: Correctable Errors collector initialized.
[ 10.535590] microcode: sig=0x206c2, pf=0x1, revision=0x1f
[ 10.609057] microcode: Microcode Update Driver: v2.2.
[ 10.609073] sched_clock: Marking stable (10609040075, 0)->(10621421128, -12381053)
[ 10.763782] registered taskstats version 1
[ 10.866457] Loading compiled-in X.509 certificates
[ 10.944538] Loaded X.509 cert 'Build time autogenerated kernel key: 12f2d460e247d21dc5d156478bb7d4abc0f5a070'
[ 11.020311] zswap: loaded using pool lzo/zbud
[ 11.109202] Key type big_key registered
[ 11.183584] Key type trusted registered
[ 11.259969] Key type encrypted registered
[ 11.332123] AppArmor: AppArmor sha1 policy hashing enabled
[ 11.404930] ima: No TPM chip found, activating TPM-bypass! (rc=-19)
[ 11.478801] ima: Allocated hash algorithm: sha1
[ 11.553107] evm: HMAC attrs: 0x1
[ 11.626097] Magic number: 8:276:948
[ 11.698609] tty tty5: hash matches
[ 11.770244] processor cpu3: hash matches
[ 11.840295] memory memory1: hash matches
[ 11.911336] rtc_cmos 00:01: setting system clock to 2020-10-06 18:56:11 UTC (1602010571)
[ 11.985949] BIOS EDD facility v0.16 2004-Jun-25, 0 devices found
[ 12.058967] EDD information not available.
[ 12.666620] Freeing unused kernel image memory: 2436K
[ 12.748015] Write protecting the kernel read-only data: 20480k
[ 12.825225] Freeing unused kernel image memory: 2008K
[ 12.898023] Freeing unused kernel image memory: 1872K
[ 13.007932] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 13.078141] x86/mm: Checking user space page tables
[ 13.158219] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 13.455332] bnx2: QLogic bnx2 Gigabit Ethernet Driver v2.2.6 (January 29, 2014)
[ 13.529973] bnx2 0000:01:00.0 eth0: Broadcom NetXtreme II BCM5716 1000Base-T (C0) PCI Express found at mem da000000, IRQ 30, node addr 84:2b:2b:63:dc:8b
[ 13.605576] bnx2 0000:01:00.1 eth1: Broadcom NetXtreme II BCM5716 1000Base-T (C0) PCI Express found at mem dc000000, IRQ 31, node addr 84:2b:2b:63:dc:8c
[ 13.680206] megasas: 07.703.05.00-rc1
[ 13.755153] megaraid_sas 0000:02:00.0: FW now in Ready state
[ 13.829258] megaraid_sas 0000:02:00.0: 32 bit DMA mask and 32 bit consistent mask
[ 13.830771] bnx2 0000:01:00.1 eno2: renamed from eth1
[ 13.904031] megaraid_sas 0000:02:00.0: firmware supports msix : (0)
[ 14.054476] megaraid_sas 0000:02:00.0: current msix/online cpus : (1/16)
[ 14.129451] megaraid_sas 0000:02:00.0: RDPQ mode : (disabled)
[ 14.249662] bnx2 0000:01:00.0 eno1: renamed from eth0
[ 14.316041] megaraid_sas 0000:02:00.0: controller type : MR(512MB)
[ 14.397605] megaraid_sas 0000:02:00.0: Online Controller Reset(OCR) : Enabled
[ 14.472698] megaraid_sas 0000:02:00.0: Secure JBOD support : No
[ 14.549523] megaraid_sas 0000:02:00.0: megasas_init_mfi: fw_support_ieee=67108864
[ 14.624643] megaraid_sas 0000:02:00.0: INIT adapter done
[ 14.699633] megaraid_sas 0000:02:00.0: Jbod map is not supported megasas_setup_jbod_map 5113
[ 14.785491] hidraw: raw HID events driver (C) Jiri Kosina
[ 14.828103] megaraid_sas 0000:02:00.0: pci id : (0x1000)/(0x0079)/(0x1028)/(0x1f17)
[ 14.940977] megaraid_sas 0000:02:00.0: unevenspan support : no
[ 15.019208] megaraid_sas 0000:02:00.0: firmware crash dump : no
[ 15.097598] megaraid_sas 0000:02:00.0: jbod sync map : no
[ 15.174620] scsi host0: Avago SAS based MegaRAID driver
[ 15.322245] SSE version of gcm_enc/dec engaged.
[ 15.323468] scsi 0:2:0:0: Direct-Access DELL PERC H700 2.10 PQ: 0 ANSI: 5
[ 15.357013] usbcore: registered new interface driver usbhid
[ 15.357015] usbhid: USB HID core driver
[ 15.632539] scsi 0:2:1:0: Direct-Access DELL PERC H700 2.10 PQ: 0 ANSI: 5
[ 15.714657] input: SIGMACHIP USB Keyboard as /devices/pci0000:00/0000:00:1d.0/usb5/5-1/5-1:1.0/0003:1C4F:0002.0001/input/input4
[ 15.755728] sd 0:2:0:0: Attached scsi generic sg0 type 0
[ 15.755741] sd 0:2:0:0: [sda] 248774656 512-byte logical blocks: (127 GB/119 GiB)
[ 15.755775] sd 0:2:0:0: [sda] Write Protect is off
[ 15.755778] sd 0:2:0:0: [sda] Mode Sense: 1f 00 00 08
[ 15.755837] sd 0:2:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 15.757184] sda: sda1 sda2 < sda5 >
[ 15.757738] sd 0:2:0:0: [sda] Attached SCSI disk
[ 15.852262] hid-generic 0003:1C4F:0002.0001: input,hidraw0: USB HID v1.10 Keyboard [SIGMACHIP USB Keyboard] on usb-0000:00:1d.0-1/input0
[ 15.874228] sd 0:2:1:0: Attached scsi generic sg1 type 0
[ 15.874655] sd 0:2:1:0: [sdb] 35156656128 512-byte logical blocks: (18.0 TB/16.4 TiB)
[ 15.874774] sd 0:2:1:0: [sdb] Write Protect is off
[ 15.874776] sd 0:2:1:0: [sdb] Mode Sense: 1f 00 00 08
[ 15.874918] sd 0:2:1:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 15.899434] sd 0:2:1:0: [sdb] Attached SCSI disk
[ 15.954984] input: SIGMACHIP USB Keyboard as /devices/pci0000:00/0000:00:1d.0/usb5/5-1/5-1:1.1/0003:1C4F:0002.0002/input/input5
[ 16.881618] random: fast init done
[ 16.932328] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[ 16.932459] hid-generic 0003:1C4F:0002.0002: input,hidraw1: USB HID v1.10 Device [SIGMACHIP USB Keyboard] on usb-0000:00:1d.0-1/input1
[ 16.932697] input: Avocent USB Composite Device-0 as /devices/pci0000:00/0000:00:1d.0/usb5/5-2/5-2:1.0/0003:0624:0248.0003/input/input6
[ 16.968655] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[ 16.968958] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[ 16.996193] hid-generic 0003:0624:0248.0003: input,hidraw2: USB HID v1.00 Keyboard [Avocent USB Composite Device-0] on usb-0000:00:1d.0-2/input0
[ 16.996353] input: Avocent USB Composite Device-0 as /devices/pci0000:00/0000:00:1d.0/usb5/5-2/5-2:1.1/0003:0624:0248.0004/input/input7
[ 16.996483] hid-generic 0003:0624:0248.0004: input,hidraw3: USB HID v1.00 Mouse [Avocent USB Composite Device-0] on usb-0000:00:1d.0-2/input1
[ 17.744159] checking generic (d9800000 500000) vs hw (d9800000 800000)
[ 17.744160] fb: switching to mgag200drmfb from VESA VGA
[ 17.843909] Console: switching to colour dummy device 80x25
[ 17.847349] [TTM] Zone kernel: Available graphics memory: 32977888 kiB
[ 17.847357] [TTM] Zone dma32: Available graphics memory: 2097152 kiB
[ 17.847361] [TTM] Initializing pool allocator
[ 17.847369] [TTM] Initializing DMA pool allocator
[ 17.908072] fbcon: mgadrmfb (fb0) is primary device
[ 17.908170] Console: switching to colour frame buffer device 160x64
[ 18.138209] mgag200 0000:06:03.0: fb0: mgadrmfb frame buffer device
[ 18.152137] [drm] Initialized mgag200 1.0.0 20110418 for 0000:06:03.0 on minor 0
[ 18.524100] raid6: sse2x1 gen() 3922 MB/s
[ 18.572107] raid6: sse2x1 xor() 2970 MB/s
[ 18.620096] raid6: sse2x2 gen() 4621 MB/s
[ 18.668094] raid6: sse2x2 xor() 3470 MB/s
[ 18.716093] raid6: sse2x4 gen() 5224 MB/s
[ 18.764084] raid6: sse2x4 xor() 3844 MB/s
[ 18.764114] raid6: using algorithm sse2x4 gen() 5224 MB/s
[ 18.764144] raid6: .... xor() 3844 MB/s, rmw enabled
[ 18.764172] raid6: using ssse3x2 recovery algorithm
[ 18.771486] xor: measuring software checksum speed
[ 18.808087] prefetch64-sse: 6455.000 MB/sec
[ 18.848079] generic_sse: 5764.000 MB/sec
[ 18.848105] xor: using function: prefetch64-sse (6455.000 MB/sec)
[ 18.855362] async_tx: api initialized (async)
[ 18.979341] Btrfs loaded, crc32c=crc32c-intel
[ 19.067560] BTRFS: device fsid 9f2b3be5-1877-40e4-aa3a-98d70c7c7b61 devid 1 transid 1005786 /dev/sdb
[ 19.129528] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 19.754895] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 19.765600] ERST: NVRAM ERST Log Address Range not implemented yet.
[ 19.769342] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 19.789524] systemd[1]: Detected architecture x86-64.
[ 20.008726] systemd[1]: Set hostname to <R510-LXD8-Offsite>.
[ 20.253044] systemd[1]: Reached target User and Group Name Lookups.
[ 20.522543] systemd[1]: Created slice System Slice.
[ 20.694932] systemd[1]: Listening on udev Control Socket.
[ 20.864834] systemd[1]: Listening on Journal Socket.
[ 21.034709] systemd[1]: Starting Load Kernel Modules...
[ 21.168357] Loading iSCSI transport class v2.0-870.
[ 21.187655] iscsi: registered transport (tcp)
[ 21.236634] iscsi: registered transport (iser)
[ 21.418556] systemd[1]: Starting Uncomplicated firewall...
[ 21.574903] systemd[1]: Mounting Kernel Debug File System...
[ 22.269669] random: crng init done
[ 22.269671] random: 7 urandom warning(s) missed due to ratelimiting
[ 22.793920] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
[ 24.025706] ip_local_port_range: prefer different parity for start/end values.
[ 24.438904] systemd-journald[582]: Received request to flush runtime journal from PID 1
[ 25.005859] EDAC MC1: Giving out device to module i7core_edac.c controller i7 core #1: DEV 0000:fe:03.0 (INTERRUPT)
[ 25.005896] EDAC PCI0: Giving out device to module i7core_edac controller EDAC PCI controller: DEV 0000:fe:03.0 (POLLED)
[ 25.006051] EDAC MC0: Giving out device to module i7core_edac.c controller i7 core #0: DEV 0000:ff:03.0 (INTERRUPT)
[ 25.006079] EDAC PCI1: Giving out device to module i7core_edac controller EDAC PCI controller: DEV 0000:ff:03.0 (POLLED)
[ 25.006097] EDAC i7core: Driver loaded, 2 memory controller(s) found.
[ 25.006541] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 25.060250] ipmi message handler version 39.2
[ 25.061088] ACPI Error: No handler for Region [IPMI] (000000006976a5df) [IPMI] (20170831/evregion-166)
[ 25.063520] ACPI Error: Region IPMI (ID=7) has no handler (20170831/exfldio-299)
[ 25.066189] No Local Variables are initialized for Method [_GHL]
[ 25.066192] No Arguments are initialized for method [_GHL]
[ 25.066200] ACPI Error: Method parse/execution failed \_SB.PMI0._GHL, AE_NOT_EXIST (20170831/psparse-550)
[ 25.066225] ACPI Error: Method parse/execution failed \_SB.PMI0._PMC, AE_NOT_EXIST (20170831/psparse-550)
[ 25.066245] ACPI Exception: AE_NOT_EXIST, Evaluating _PMC (20170831/power_meter-755)
[ 25.100125] dcdbas dcdbas: Dell Systems Management Base Driver (version 5.6.0-3.2)
[ 25.123330] ipmi device interface
[ 25.146678] IPMI System Interface driver.
[ 25.146713] ipmi_si dmi-ipmi-si.0: ipmi_platform: probing via SMBIOS
[ 25.146717] ipmi_si: SMBIOS: io 0xca8 regsize 1 spacing 4 irq 0
[ 25.146719] ipmi_si: Adding SMBIOS-specified kcs state machine
[ 25.146856] ipmi_si: Trying SMBIOS-specified kcs state machine at i/o address 0xca8, slave address 0x20, irq 0
[ 25.303354] gpio_ich: GPIO from 451 to 511 on gpio_ich
[ 25.518173] ipmi_si dmi-ipmi-si.0: Found new BMC (man_id: 0x0002a2, prod_id: 0x0100, dev_id: 0x20)
[ 25.692211] kvm: VM_EXIT_LOAD_IA32_PERF_GLOBAL_CTRL does not work properly. Using workaround
[ 25.702290] ipmi_si dmi-ipmi-si.0: IPMI kcs interface initialized
[ 25.712331] IPMI SSIF Interface driver
[ 26.332001] BTRFS info (device sdb): disk space caching is enabled
[ 26.332014] BTRFS info (device sdb): has skinny extents
[ 26.491624] Adding 997884k swap on /dev/mapper/cryptswap1. Priority:-2 extents:1 across:997884k FS
[ 77.069232] audit: type=1400 audit(1602010636.656:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/lxc-start" pid=1193 comm="apparmor_parser"
[ 77.071088] audit: type=1400 audit(1602010636.656:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/man" pid=1194 comm="apparmor_parser"
[ 77.071093] audit: type=1400 audit(1602010636.656:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_filter" pid=1194 comm="apparmor_parser"
[ 77.071096] audit: type=1400 audit(1602010636.656:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_groff" pid=1194 comm="apparmor_parser"
[ 77.071100] audit: type=1400 audit(1602010636.656:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/tcpdump" pid=1197 comm="apparmor_parser"
[ 77.072631] audit: type=1400 audit(1602010636.660:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/snapd/snap-confine" pid=1195 comm="apparmor_parser"
[ 77.072637] audit: type=1400 audit(1602010636.660:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/snapd/snap-confine//mount-namespace-capture-helper" pid=1195 comm="apparmor_parser"
[ 77.073716] audit: type=1400 audit(1602010636.660:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/sbin/dhclient" pid=1192 comm="apparmor_parser"
[ 77.073721] audit: type=1400 audit(1602010636.660:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=1192 comm="apparmor_parser"
[ 77.073725] audit: type=1400 audit(1602010636.660:11): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/NetworkManager/nm-dhcp-helper" pid=1192 comm="apparmor_parser"
[ 77.210123] Ethernet Channel Bonding Driver: v3.7.1 (April 27, 2011)
[ 77.213244] bonding: bond0 is being created...
[ 77.268573] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 77.270774] br0: port 1(bond0) entered blocking state
[ 77.270781] br0: port 1(bond0) entered disabled state
[ 77.270932] device bond0 entered promiscuous mode
[ 77.295270] IPv6: ADDRCONF(NETDEV_UP): bond0: link is not ready
[ 78.577507] new mount options do not match the existing superblock, will be ignored
[ 78.905850] bond0: Unable to set down delay as MII monitoring is disabled
[ 78.906062] bond0: Unable to set up delay as MII monitoring is disabled
[ 78.914499] IPv6: ADDRCONF(NETDEV_UP): bond0: link is not ready
[ 79.065619] bnx2 0000:01:00.1 eno2: using MSIX
[ 79.066051] device eno2 entered promiscuous mode
[ 79.066149] bond0: Enslaving eno2 as a backup interface with a down link
[ 79.066706] IPv6: ADDRCONF(NETDEV_UP): br0: link is not ready
[ 79.185662] bnx2 0000:01:00.0 eno1: using MSIX
[ 79.186179] device eno1 entered promiscuous mode
[ 79.186243] bond0: Enslaving eno1 as a backup interface with a down link
[ 81.514813] bnx2 0000:01:00.0 eno1: NIC Copper Link is Up, 100 Mbps full duplex
[ 81.528152] bond0: link status definitely up for interface eno1, 100 Mbps full duplex
[ 81.528157] bond0: Warning: No 802.3ad response from the link partner for any adapters in the bond
[ 81.528166] bond0: first active interface up!
[ 81.528180] IPv6: ADDRCONF(NETDEV_CHANGE): bond0: link becomes ready
[ 81.528248] br0: port 1(bond0) entered blocking state
[ 81.528250] br0: port 1(bond0) entered forwarding state
[ 81.528311] IPv6: ADDRCONF(NETDEV_CHANGE): br0: link becomes ready
[ 86.234539] new mount options do not match the existing superblock, will be ignored
[ 104.167149] nf_conntrack version 0.5.0 (65536 buckets, 262144 max)
[ 104.767159] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 105.174441] Ebtables v2.0 registered
[ 106.713010] BTRFS info (device sdb): disk space caching is enabled
[ 107.822872] spl: loading out-of-tree module taints kernel.
[ 107.834352] SPL: Loaded module v0.7.5-1ubuntu2.2
[ 107.839239] znvpair: module license 'CDDL' taints kernel.
[ 107.839241] Disabling lock debugging due to kernel taint
[ 109.609924] ZFS: Loaded module v0.7.5-1ubuntu16.10, ZFS pool version 5000, ZFS filesystem version 5
[ 110.339211] IPv6: ADDRCONF(NETDEV_UP): veth39be0ee0: link is not ready
[ 110.388938] br0: port 2(veth39be0ee0) entered blocking state
[ 110.388942] br0: port 2(veth39be0ee0) entered disabled state
[ 110.389071] device veth39be0ee0 entered promiscuous mode
[ 110.618615] kauditd_printk_skb: 39 callbacks suppressed
[ 110.618617] audit: type=1400 audit(1602010669.796:51): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lxd-adlive-tor_</var/snap/lxd/common/lxd>" pid=3388 comm="apparmor_parser"
[ 110.785642] eth0: renamed from vethbe484017
[ 110.812354] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 110.812734] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 110.812786] br0: port 2(veth39be0ee0) entered blocking state
[ 110.812789] br0: port 2(veth39be0ee0) entered forwarding state
[ 111.155868] IPv6: ADDRCONF(NETDEV_UP): veth8599a45e: link is not ready
[ 111.165762] br0: port 3(veth8599a45e) entered blocking state
[ 111.165765] br0: port 3(veth8599a45e) entered disabled state
[ 111.165873] device veth8599a45e entered promiscuous mode
[ 111.165908] br0: port 3(veth8599a45e) entered blocking state
[ 111.165910] br0: port 3(veth8599a45e) entered forwarding state
[ 111.340134] br0: port 3(veth8599a45e) entered disabled state
[ 111.840397] audit: type=1400 audit(1602010671.020:52): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lxd-backup-server-TO_</var/snap/lxd/common/lxd>" pid=3591 comm="apparmor_parser"
[ 112.009580] eth0: renamed from veth384066e0
[ 112.048469] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 112.048895] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 112.048949] br0: port 3(veth8599a45e) entered blocking state
[ 112.048952] br0: port 3(veth8599a45e) entered forwarding state
[ 112.619912] IPv6: ADDRCONF(NETDEV_UP): veth6a42eb44: link is not ready
[ 112.629889] br0: port 4(veth6a42eb44) entered blocking state
[ 112.629892] br0: port 4(veth6a42eb44) entered disabled state
[ 112.629986] device veth6a42eb44 entered promiscuous mode
[ 113.687943] audit: type=1400 audit(1602010672.864:53): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lxd-lxd-mosaic_</var/snap/lxd/common/lxd>" pid=3811 comm="apparmor_parser"
[ 114.049659] eth0: renamed from veth34c9efd8
[ 114.072416] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 114.072785] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 114.072840] br0: port 4(veth6a42eb44) entered blocking state
[ 114.072842] br0: port 4(veth6a42eb44) entered forwarding state
[ 115.336848] IPv6: ADDRCONF(NETDEV_UP): veth16cfa8f4: link is not ready
[ 115.347492] br0: port 5(veth16cfa8f4) entered blocking state
[ 115.347496] br0: port 5(veth16cfa8f4) entered disabled state
[ 115.347630] device veth16cfa8f4 entered promiscuous mode
[ 116.748110] audit: type=1400 audit(1602010675.924:54): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lxd-pg-11-standby_</var/snap/lxd/common/lxd>" pid=4043 comm="apparmor_parser"
[ 117.065666] eth0: renamed from veth3507989b
[ 117.088350] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 117.088717] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 117.088770] br0: port 5(veth16cfa8f4) entered blocking state
[ 117.088773] br0: port 5(veth16cfa8f4) entered forwarding state
[ 132.237454] audit: type=1400 audit(1602010691.416:55): apparmor="STATUS" operation="profile_load" label="lxd-adlive-tor_</var/snap/lxd/common/lxd>//&:lxd-adlive-tor_<var-snap-lxd-common-lxd>:unconfined" name="lxc-container-default" pid=5123 comm="apparmor_parser"
[ 132.237462] audit: type=1400 audit(1602010691.416:56): apparmor="STATUS" operation="profile_load" label="lxd-adlive-tor_</var/snap/lxd/common/lxd>//&:lxd-adlive-tor_<var-snap-lxd-common-lxd>:unconfined" name="lxc-container-default-cgns" pid=5123 comm="apparmor_parser"
[ 132.237466] audit: type=1400 audit(1602010691.416:57): apparmor="STATUS" operation="profile_load" label="lxd-adlive-tor_</var/snap/lxd/common/lxd>//&:lxd-adlive-tor_<var-snap-lxd-common-lxd>:unconfined" name="lxc-container-default-with-mounting" pid=5123 comm="apparmor_parser"
[ 132.237470] audit: type=1400 audit(1602010691.416:58): apparmor="STATUS" operation="profile_load" label="lxd-adlive-tor_</var/snap/lxd/common/lxd>//&:lxd-adlive-tor_<var-snap-lxd-common-lxd>:unconfined" name="lxc-container-default-with-nesting" pid=5123 comm="apparmor_parser"
[ 132.695314] audit: type=1400 audit(1602010691.872:59): apparmor="STATUS" operation="profile_load" label="lxd-adlive-tor_</var/snap/lxd/common/lxd>//&:lxd-adlive-tor_<var-snap-lxd-common-lxd>:unconfined" name="/usr/bin/lxc-start" pid=5125 comm="apparmor_parser"
[ 133.323291] audit: type=1400 audit(1602010692.500:60): apparmor="STATUS" operation="profile_load" label="lxd-adlive-tor_</var/snap/lxd/common/lxd>//&:lxd-adlive-tor_<var-snap-lxd-common-lxd>:unconfined" name="/sbin/dhclient" pid=5124 comm="apparmor_parser"
[ 133.323298] audit: type=1400 audit(1602010692.500:61): apparmor="STATUS" operation="profile_load" label="lxd-adlive-tor_</var/snap/lxd/common/lxd>//&:lxd-adlive-tor_<var-snap-lxd-common-lxd>:unconfined" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=5124 comm="apparmor_parser"
[ 133.323303] audit: type=1400 audit(1602010692.500:62): apparmor="STATUS" operation="profile_load" label="lxd-adlive-tor_</var/snap/lxd/common/lxd>//&:lxd-adlive-tor_<var-snap-lxd-common-lxd>:unconfined" name="/usr/lib/NetworkManager/nm-dhcp-helper" pid=5124 comm="apparmor_parser"
[ 133.323307] audit: type=1400 audit(1602010692.500:63): apparmor="STATUS" operation="profile_load" label="lxd-adlive-tor_</var/snap/lxd/common/lxd>//&:lxd-adlive-tor_<var-snap-lxd-common-lxd>:unconfined" name="/usr/lib/connman/scripts/dhclient-script" pid=5124 comm="apparmor_parser"
[ 133.592502] audit: type=1400 audit(1602010692.772:64): apparmor="STATUS" operation="profile_load" label="lxd-adlive-tor_</var/snap/lxd/common/lxd>//&:lxd-adlive-tor_<var-snap-lxd-common-lxd>:unconfined" name="/usr/lib/snapd/snap-confine" pid=5128 comm="apparmor_parser"
[ 137.692036] kauditd_printk_skb: 44 callbacks suppressed
[ 137.692038] audit: type=1400 audit(1602010696.868:109): apparmor="STATUS" operation="profile_load" label="lxd-backup-server-TO_</var/snap/lxd/common/lxd>//&:lxd-backup-server-TO_<var-snap-lxd-common-lxd>:unconfined" name="/usr/lib/snapd/snap-confine" pid=5510 comm="apparmor_parser"
[ 137.692047] audit: type=1400 audit(1602010696.868:110): apparmor="STATUS" operation="profile_load" label="lxd-backup-server-TO_</var/snap/lxd/common/lxd>//&:lxd-backup-server-TO_<var-snap-lxd-common-lxd>:unconfined" name="/usr/lib/snapd/snap-confine//mount-namespace-capture-helper" pid=5510 comm="apparmor_parser"
[ 137.700738] audit: type=1400 audit(1602010696.880:111): apparmor="STATUS" operation="profile_load" label="lxd-backup-server-TO_</var/snap/lxd/common/lxd>//&:lxd-backup-server-TO_<var-snap-lxd-common-lxd>:unconfined" name="/usr/sbin/tcpdump" pid=5512 comm="apparmor_parser"
[ 137.710078] audit: type=1400 audit(1602010696.888:112): apparmor="STATUS" operation="profile_load" label="lxd-backup-server-TO_</var/snap/lxd/common/lxd>//&:lxd-backup-server-TO_<var-snap-lxd-common-lxd>:unconfined" name="/sbin/dhclient" pid=5509 comm="apparmor_parser"
[ 137.710085] audit: type=1400 audit(1602010696.888:113): apparmor="STATUS" operation="profile_load" label="lxd-backup-server-TO_</var/snap/lxd/common/lxd>//&:lxd-backup-server-TO_<var-snap-lxd-common-lxd>:unconfined" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=5509 comm="apparmor_parser"
[ 137.710090] audit: type=1400 audit(1602010696.888:114): apparmor="STATUS" operation="profile_load" label="lxd-backup-server-TO_</var/snap/lxd/common/lxd>//&:lxd-backup-server-TO_<var-snap-lxd-common-lxd>:unconfined" name="/usr/lib/NetworkManager/nm-dhcp-helper" pid=5509 comm="apparmor_parser"
[ 137.710094] audit: type=1400 audit(1602010696.888:115): apparmor="STATUS" operation="profile_load" label="lxd-backup-server-TO_</var/snap/lxd/common/lxd>//&:lxd-backup-server-TO_<var-snap-lxd-common-lxd>:unconfined" name="/usr/lib/connman/scripts/dhclient-script" pid=5509 comm="apparmor_parser"
[ 137.943223] audit: type=1400 audit(1602010697.120:116): apparmor="STATUS" operation="profile_load" label="lxd-backup-server-TO_</var/snap/lxd/common/lxd>//&:lxd-backup-server-TO_<var-snap-lxd-common-lxd>:unconfined" name="/snap/snapd/9279/usr/lib/snapd/snap-confine" pid=5644 comm="apparmor_parser"
[ 137.943231] audit: type=1400 audit(1602010697.120:117): apparmor="STATUS" operation="profile_load" label="lxd-backup-server-TO_</var/snap/lxd/common/lxd>//&:lxd-backup-server-TO_<var-snap-lxd-common-lxd>:unconfined" name="/snap/snapd/9279/usr/lib/snapd/snap-confine//mount-namespace-capture-helper" pid=5644 comm="apparmor_parser"
[ 137.997727] audit: type=1400 audit(1602010697.176:118): apparmor="STATUS" operation="profile_load" label="lxd-backup-server-TO_</var/snap/lxd/common/lxd>//&:lxd-backup-server-TO_<var-snap-lxd-common-lxd>:unconfined" name="snap.lxd.lxc" pid=5653 comm="apparmor_parser"
[ 144.954987] kauditd_printk_skb: 27 callbacks suppressed
[ 144.954989] audit: type=1400 audit(1602010704.132:146): apparmor="STATUS" operation="profile_load" label="lxd-pg-11-standby_</var/snap/lxd/common/lxd>//&:lxd-pg-11-standby_<var-snap-lxd-common-lxd>:unconfined" name="/usr/bin/lxc-start" pid=5857 comm="apparmor_parser"
[ 145.257628] audit: type=1400 audit(1602010704.436:147): apparmor="STATUS" operation="profile_load" label="lxd-pg-11-standby_</var/snap/lxd/common/lxd>//&:lxd-pg-11-standby_<var-snap-lxd-common-lxd>:unconfined" name="/usr/sbin/tcpdump" pid=5861 comm="apparmor_parser"
[ 145.416960] audit: type=1400 audit(1602010704.596:148): apparmor="STATUS" operation="profile_load" label="lxd-pg-11-standby_</var/snap/lxd/common/lxd>//&:lxd-pg-11-standby_<var-snap-lxd-common-lxd>:unconfined" name="/usr/lib/lxd/lxd-bridge-proxy" pid=5858 comm="apparmor_parser"
[ 145.429767] audit: type=1400 audit(1602010704.608:149): apparmor="STATUS" operation="profile_load" label="lxd-pg-11-standby_</var/snap/lxd/common/lxd>//&:lxd-pg-11-standby_<var-snap-lxd-common-lxd>:unconfined" name="lxc-container-default" pid=5855 comm="apparmor_parser"
[ 145.429778] audit: type=1400 audit(1602010704.608:150): apparmor="STATUS" operation="profile_load" label="lxd-pg-11-standby_</var/snap/lxd/common/lxd>//&:lxd-pg-11-standby_<var-snap-lxd-common-lxd>:unconfined" name="lxc-container-default-cgns" pid=5855 comm="apparmor_parser"
[ 145.429784] audit: type=1400 audit(1602010704.608:151): apparmor="STATUS" operation="profile_load" label="lxd-pg-11-standby_</var/snap/lxd/common/lxd>//&:lxd-pg-11-standby_<var-snap-lxd-common-lxd>:unconfined" name="lxc-container-default-with-mounting" pid=5855 comm="apparmor_parser"
[ 145.429791] audit: type=1400 audit(1602010704.608:152): apparmor="STATUS" operation="profile_load" label="lxd-pg-11-standby_</var/snap/lxd/common/lxd>//&:lxd-pg-11-standby_<var-snap-lxd-common-lxd>:unconfined" name="lxc-container-default-with-nesting" pid=5855 comm="apparmor_parser"
[ 145.437731] audit: type=1400 audit(1602010704.616:153): apparmor="STATUS" operation="profile_load" label="lxd-pg-11-standby_</var/snap/lxd/common/lxd>//&:lxd-pg-11-standby_<var-snap-lxd-common-lxd>:unconfined" name="/sbin/dhclient" pid=5856 comm="apparmor_parser"
[ 145.437738] audit: type=1400 audit(1602010704.616:154): apparmor="STATUS" operation="profile_load" label="lxd-pg-11-standby_</var/snap/lxd/common/lxd>//&:lxd-pg-11-standby_<var-snap-lxd-common-lxd>:unconfined" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=5856 comm="apparmor_parser"
[ 145.437742] audit: type=1400 audit(1602010704.616:155): apparmor="STATUS" operation="profile_load" label="lxd-pg-11-standby_</var/snap/lxd/common/lxd>//&:lxd-pg-11-standby_<var-snap-lxd-common-lxd>:unconfined" name="/usr/lib/NetworkManager/nm-dhcp-helper" pid=5856 comm="apparmor_parser"
[ 196.429794] kauditd_printk_skb: 3 callbacks suppressed
[ 196.429795] audit: type=1400 audit(1602010755.608:159): apparmor="DENIED" operation="ptrace" namespace="root//lxd-backup-server-TO_<var-snap-lxd-common-lxd>" profile="/snap/snapd/9279/usr/lib/snapd/snap-confine" pid=8419 comm="start-stop-daem" requested_mask="tracedby" denied_mask="tracedby" peer="unconfined"
[ 196.429992] audit: type=1400 audit(1602010755.608:160): apparmor="DENIED" operation="ptrace" namespace="root//lxd-backup-server-TO_<var-snap-lxd-common-lxd>" profile="/snap/snapd/9279/usr/lib/snapd/snap-confine//mount-namespace-capture-helper" pid=8419 comm="start-stop-daem" requested_mask="tracedby" denied_mask="tracedby" peer="unconfined"
[ 196.430014] audit: type=1400 audit(1602010755.608:161): apparmor="DENIED" operation="ptrace" namespace="root//lxd-backup-server-TO_<var-snap-lxd-common-lxd>" profile="snap-update-ns.lxd" pid=8419 comm="start-stop-daem" requested_mask="tracedby" denied_mask="tracedby" peer="unconfined"
[ 238.896799] audit: type=1400 audit(1602010798.073:162): apparmor="DENIED" operation="mount" info="failed flags match" error=-13 profile="lxd-backup-server-TO_</var/snap/lxd/common/lxd>" name="/run/lxcfs/controllers/sys/fs/cgroup/systemd/" pid=9599 comm="lxcfs" fstype="cgroup" srcname="cgroup" flags="rw, nosuid, nodev, noexec, relatime"
[ 924.889909] veth34c9efd8: renamed from eth0
[ 924.909609] br0: port 4(veth6a42eb44) entered disabled state
[ 924.977338] device veth6a42eb44 left promiscuous mode
[ 924.977384] br0: port 4(veth6a42eb44) entered disabled state
[ 926.146880] audit: type=1400 audit(1602011485.334:163): apparmor="STATUS" operation="profile_remove" profile="unconfined" name="lxd-lxd-mosaic_</var/snap/lxd/common/lxd>" pid=25554 comm="apparmor_parser"
[ 930.619596] IPv6: ADDRCONF(NETDEV_UP): vethdd110f6d: link is not ready
[ 930.630085] br0: port 4(vethdd110f6d) entered blocking state
[ 930.630089] br0: port 4(vethdd110f6d) entered disabled state
[ 930.630221] device vethdd110f6d entered promiscuous mode
[ 930.813211] audit: type=1400 audit(1602011489.998:164): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lxd-lxd-mosaic_</var/snap/lxd/common/lxd>" pid=25716 comm="apparmor_parser"
[ 930.982918] eth0: renamed from vethef3d4daf
[ 931.025638] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 931.028263] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 931.028320] br0: port 4(vethdd110f6d) entered blocking state
[ 931.028323] br0: port 4(vethdd110f6d) entered forwarding state
[ 931.491858] audit: type=1400 audit(1602011490.678:165): apparmor="STATUS" operation="profile_load" label="lxd-lxd-mosaic_</var/snap/lxd/common/lxd>//&:lxd-lxd-mosaic_<var-snap-lxd-common-lxd>:unconfined" name="/usr/bin/man" pid=25919 comm="apparmor_parser"
[ 931.491867] audit: type=1400 audit(1602011490.678:166): apparmor="STATUS" operation="profile_load" label="lxd-lxd-mosaic_</var/snap/lxd/common/lxd>//&:lxd-lxd-mosaic_<var-snap-lxd-common-lxd>:unconfined" name="man_filter" pid=25919 comm="apparmor_parser"
[ 931.491874] audit: type=1400 audit(1602011490.678:167): apparmor="STATUS" operation="profile_load" label="lxd-lxd-mosaic_</var/snap/lxd/common/lxd>//&:lxd-lxd-mosaic_<var-snap-lxd-common-lxd>:unconfined" name="man_groff" pid=25919 comm="apparmor_parser"
[ 931.492425] audit: type=1400 audit(1602011490.678:168): apparmor="STATUS" operation="profile_load" label="lxd-lxd-mosaic_</var/snap/lxd/common/lxd>//&:lxd-lxd-mosaic_<var-snap-lxd-common-lxd>:unconfined" name="/usr/sbin/mysqld" pid=25921 comm="apparmor_parser"
[ 931.492774] audit: type=1400 audit(1602011490.678:169): apparmor="STATUS" operation="profile_load" label="lxd-lxd-mosaic_</var/snap/lxd/common/lxd>//&:lxd-lxd-mosaic_<var-snap-lxd-common-lxd>:unconfined" name="/usr/sbin/tcpdump" pid=25924 comm="apparmor_parser"
[ 931.492864] audit: type=1400 audit(1602011490.678:170): apparmor="STATUS" operation="profile_load" label="lxd-lxd-mosaic_</var/snap/lxd/common/lxd>//&:lxd-lxd-mosaic_<var-snap-lxd-common-lxd>:unconfined" name="/usr/lib/snapd/snap-confine" pid=25920 comm="apparmor_parser"
[ 931.492869] audit: type=1400 audit(1602011490.678:171): apparmor="STATUS" operation="profile_load" label="lxd-lxd-mosaic_</var/snap/lxd/common/lxd>//&:lxd-lxd-mosaic_<var-snap-lxd-common-lxd>:unconfined" name="/usr/lib/snapd/snap-confine//mount-namespace-capture-helper" pid=25920 comm="apparmor_parser"
[ 931.494059] audit: type=1400 audit(1602011490.682:172): apparmor="STATUS" operation="profile_load" label="lxd-lxd-mosaic_</var/snap/lxd/common/lxd>//&:lxd-lxd-mosaic_<var-snap-lxd-common-lxd>:unconfined" name="/sbin/dhclient" pid=25918 comm="apparmor_parser"
[ 931.494066] audit: type=1400 audit(1602011490.682:173): apparmor="STATUS" operation="profile_load" label="lxd-lxd-mosaic_</var/snap/lxd/common/lxd>//&:lxd-lxd-mosaic_<var-snap-lxd-common-lxd>:unconfined" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=25918 comm="apparmor_parser"
[ 931.494070] audit: type=1400 audit(1602011490.682:174): apparmor="STATUS" operation="profile_load" label="lxd-lxd-mosaic_</var/snap/lxd/common/lxd>//&:lxd-lxd-mosaic_<var-snap-lxd-common-lxd>:unconfined" name="/usr/lib/NetworkManager/nm-dhcp-helper" pid=25918 comm="apparmor_parser"
[ 1224.473927] perf: interrupt took too long (2501 > 2500), lowering kernel.perf_event_max_sample_rate to 79750
[ 1707.909004] perf: interrupt took too long (3140 > 3126), lowering kernel.perf_event_max_sample_rate to 63500
[ 1837.621828] vethef3d4daf: renamed from eth0
[ 1837.641040] br0: port 4(vethdd110f6d) entered disabled state
[ 1837.713909] device vethdd110f6d left promiscuous mode
[ 1837.713957] br0: port 4(vethdd110f6d) entered disabled state
[ 1838.954973] kauditd_printk_skb: 31 callbacks suppressed
[ 1838.954975] audit: type=1400 audit(1602012398.151:206): apparmor="STATUS" operation="profile_remove" profile="unconfined" name="lxd-lxd-mosaic_</var/snap/lxd/common/lxd>" pid=13991 comm="apparmor_parser"
[ 1838.965571] IPv6: ADDRCONF(NETDEV_UP): veth5d33e062: link is not ready
[ 1838.975281] br0: port 4(veth5d33e062) entered blocking state
[ 1838.975284] br0: port 4(veth5d33e062) entered disabled state
[ 1838.975380] device veth5d33e062 entered promiscuous mode
[ 1839.155909] audit: type=1400 audit(1602012398.351:207): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lxd-lxd-mosaic_</var/snap/lxd/common/lxd>" pid=14125 comm="apparmor_parser"
[ 1839.358354] eth0: renamed from veth32354a6c
[ 1839.397058] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 1839.399873] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 1839.399930] br0: port 4(veth5d33e062) entered blocking state
[ 1839.399933] br0: port 4(veth5d33e062) entered forwarding state
[ 1839.744566] audit: type=1400 audit(1602012398.939:208): apparmor="STATUS" operation="profile_load" label="lxd-lxd-mosaic_</var/snap/lxd/common/lxd>//&:lxd-lxd-mosaic_<var-snap-lxd-common-lxd>:unconfined" name="/usr/bin/man" pid=14344 comm="apparmor_parser"
[ 1839.744574] audit: type=1400 audit(1602012398.939:209): apparmor="STATUS" operation="profile_load" label="lxd-lxd-mosaic_</var/snap/lxd/common/lxd>//&:lxd-lxd-mosaic_<var-snap-lxd-common-lxd>:unconfined" name="man_filter" pid=14344 comm="apparmor_parser"
[ 1839.744578] audit: type=1400 audit(1602012398.939:210): apparmor="STATUS" operation="profile_load" label="lxd-lxd-mosaic_</var/snap/lxd/common/lxd>//&:lxd-lxd-mosaic_<var-snap-lxd-common-lxd>:unconfined" name="man_groff" pid=14344 comm="apparmor_parser"
[ 1839.744875] audit: type=1400 audit(1602012398.943:211): apparmor="STATUS" operation="profile_load" label="lxd-lxd-mosaic_</var/snap/lxd/common/lxd>//&:lxd-lxd-mosaic_<var-snap-lxd-common-lxd>:unconfined" name="/usr/sbin/mysqld" pid=14346 comm="apparmor_parser"
[ 1839.745373] audit: type=1400 audit(1602012398.943:212): apparmor="STATUS" operation="profile_load" label="lxd-lxd-mosaic_</var/snap/lxd/common/lxd>//&:lxd-lxd-mosaic_<var-snap-lxd-common-lxd>:unconfined" name="/usr/sbin/tcpdump" pid=14348 comm="apparmor_parser"
[ 1839.745544] audit: type=1400 audit(1602012398.943:213): apparmor="STATUS" operation="profile_load" label="lxd-lxd-mosaic_</var/snap/lxd/common/lxd>//&:lxd-lxd-mosaic_<var-snap-lxd-common-lxd>:unconfined" name="/usr/lib/snapd/snap-confine" pid=14345 comm="apparmor_parser"
[ 1839.745549] audit: type=1400 audit(1602012398.943:214): apparmor="STATUS" operation="profile_load" label="lxd-lxd-mosaic_</var/snap/lxd/common/lxd>//&:lxd-lxd-mosaic_<var-snap-lxd-common-lxd>:unconfined" name="/usr/lib/snapd/snap-confine//mount-namespace-capture-helper" pid=14345 comm="apparmor_parser"
[ 1839.746698] audit: type=1400 audit(1602012398.943:215): apparmor="STATUS" operation="profile_load" label="lxd-lxd-mosaic_</var/snap/lxd/common/lxd>//&:lxd-lxd-mosaic_<var-snap-lxd-common-lxd>:unconfined" name="/sbin/dhclient" pid=14343 comm="apparmor_parser"
[ 2343.470707] perf: interrupt took too long (3927 > 3925), lowering kernel.perf_event_max_sample_rate to 50750
[ 3788.642076] perf: interrupt took too long (4924 > 4908), lowering kernel.perf_event_max_sample_rate to 40500
