Hi all,
I’m running into a mix of issues after changing kernels in my Manjaro box.
First, every time I run anything lxc related, I get this warning (which AFAIK shouldn’t happen, as it requires 5.12):
WARNING: cgroup v2 is not fully supported yet, proceeding with partial confinement
The most important bit is that I no longer have network connectivity inside my containers:
❯ lxc network list
| NAME | TYPE | MANAGED | IPV4 | IPV6 | DESCRIPTION | USED BY |
| br-f570df43cbe0 | bridge | NO | | | | 0 |
| docker0 | bridge | NO | | | | 0 |
| enp3s0 | physical | NO | | | | 0 |
| lxdbr0 | bridge | YES | 10.182.69.1/24 | fd42:773c:f259:281f::1/64 | | 3 |
| virbr0 | bridge | NO | | | | 0 |
| wlp4s0 | physical | NO | | | | 0 |
No IPv4 leases are active on any container:
❯ lxc list
| bash | RUNNING | | fd42:773c:f259:281f:216:3eff:fe8d:ed00 (eth0) | CONTAINER | 0 |
| krita | RUNNING | | fd42:773c:f259:281f:216:3eff:fe78:166a (eth0) | CONTAINER | 0 |
I’m running the Snap edge version of lxd, and I’ve restarted the daemon via systemd just in case.
I’ve also checked and fixed the dnsmasq daemon misconfiguration detailed [here]>(No networking in containers, missing dnsmasq? snap on debian - #3 by rantoie).
I’ve also noticed that my containers can’t be stopped or otherwise restarted, I get this error:
root@bash:~# sudo halt
sudo: unable to resolve host bash: Connection refused
Failed to connect to bus: No such file or directory
Failed to talk to init daemon.
Is there any way I can fix it?
