It’s not version mismatch. The logs would have looked different.
lxd --version
on all?
Is there a way to delete database in JOE, and copy a new one from Moe for example.
Or perhaps manually remove joe from cluster
I don’t know how else to say it: joe is not the problem. All nodes are affected.
lxd --version
3.0.3
on all servers it says that?
yep
what is latest?
3.10 on snap. 3.0.3 shows on my apt.
I would circle back to the cluster IP. What is that WAN IP pointed to?
Yeah so version numbers may not be 100% accurate or it is stuck in in between. Cluster ip? This all working fine for months until upgrade. All on same IP range
This is interesting
lxd
WARN[02-08|11:55:51] CGroup memory swap accounting is disabled, swap limits will be ignored.
WARN[02-08|11:55:56] Raft: Heartbeat timeout from “” reached, starting election
WARN[02-08|11:56:00] Raft: Election timeout reached, restarting election
WARN[02-08|11:56:03] Raft: Election timeout reached, restarting election
WARN[02-08|11:56:08] Raft: Election timeout reached, restarting election
WARN[02-08|11:56:12] Raft: Election timeout reached, restarting election
WARN[02-08|11:56:17] Raft: Election timeout reached, restarting election
WARN[02-08|11:56:17] Raft: AppendEntries to {Voter 4 64.71.77.80:8443} rejected, sending older logs (next: 5066720)
WARN[02-08|11:56:18] Raft: Failed to contact 2 in 1.505950989s
WARN[02-08|11:56:20] Raft: Failed to contact 2 in 2.825055425s
WARN[02-08|11:56:21] Raft: Failed to contact 2 in 4.094632009s
Which server is that?
Joe, 4th server that had upgrade
NFO[02-08|12:00:07] Kernel features:
INFO[02-08|12:00:07] - netnsid-based network retrieval: no
INFO[02-08|12:00:07] - unprivileged file capabilities: yes
INFO[02-08|12:00:07] Initializing local database
DBUG[02-08|12:00:07] Initializing database gateway
DBUG[02-08|12:00:07] Connecting to a local LXD over a Unix socket
DBUG[02-08|12:00:07] Sending request to LXD method=GET url=http://unix.socket/1.0 etag=
DBUG[02-08|12:00:07] Detected stale unix socket, deleting
INFO[02-08|12:00:07] Starting /dev/lxd handler:
INFO[02-08|12:00:07] - binding devlxd socket socket=/var/lib/lxd/devlxd/sock
INFO[02-08|12:00:07] REST API daemon:
INFO[02-08|12:00:07] - binding Unix socket socket=/var/lib/lxd/unix.socket
INFO[02-08|12:00:07] - binding TCP socket socket=[::]:8443
INFO[02-08|12:00:07] Initializing global database
DBUG[02-08|12:00:07] Dqlite: server connection failed err=failed to establish network connection: Head https://64.71.77.29:8443/internal/database: dial tcp 64.71.77.29:8443: connect: connection refused address=64.71.77.29:8443 attempt=0
DBUG[02-08|12:00:07] Dqlite: server connection failed err=failed to establish network connection: Head https://64.71.77.32:8443/internal/database: dial tcp 64.71.77.32:8443: connect: connection refused address=64.71.77.32:8443 attempt=0
DBUG[02-08|12:00:07] Dqlite: server connection failed err=failed to establish network connection: 503 Service Unavailable address=64.71.77.80:8443 attempt=0
DBUG[02-08|12:00:07] Dqlite: connection failed err=no available dqlite leader server found attempt=0
BTW Firewall does allow port 8443
Looks to me like joe is operating correctly for the most part.
Not familiar with this log
Just no one is talking to each other
Joe is saying service unavailable 503. Might investigate more down that path, never seen that one before.
Going out a bit, it is prime internet time here, So far I am going to backup and reboot tomorrow morning early and pray, pray alot. I will attack this later with a fresh perspective, thank you all for help. Let me know if you think of anything.
