Hi
I’m encountering with below error when hit distrobuilder pack-lxd --vm ./ubuntu.yaml ./rootfs: rsync: [receiver] write failed on No space left on device (28) rsync error: error in file IO (code 11) at receiver.c(378) [receiver=3.2.3] rsync: [sender] write error: Broken pipe (32) Error: Failed to copy rootfs: Failed to copy "/var/cache/distrobuilder.1376720849/overlay/" to "/var/cache/distrobuilder.1376720849/vm": exit status 11
I have enough disk space 7TeraBytes.
I searched and somebody said that i must use --inplace in rsync to solve this problem.
The error changed: rsync: [generator] chown "/home/ubuntu/tmp/vm/boot/efi" failed: Operation not permitted (1) rsync error: some files/attrs were not transferred (see previous errors) (code 23) at main.c(1333) [sender=3.2.3]
