NordVPN in LXC UnPriv/Priv Container Doesn't Work
Goal: Designate a network, using NordVPN, which is the only network a certain container can use, so as to prevent leaking onto the host network.
I am using snap lxd.
I consistently receive the error message: “transport is closing”, right after “Connecting to {Country} #NUMB (domain name)”
Errors in Syslog:
nordvpnd.service: Failed with result ‘exit-code’.
nordvpnd.socket: TCP_NODELAY failed: Operation not supported
I was going to follow this guide: https://blog.san-ss.com.ar/2015/11/setting-up-vpn-gateway-in-ubuntu-using
Note: On the host system, it works flawlessly.
Looks like that particular VPN is trying to do something that requires more privileges than containers normally have.
What protocol does NordVPN use in this case?
What’s in nordvpnd.socket and nordvpnd.service?
This text will be hidden
In /var/lib/nordvpn/data/.config.ovpn:(redacted the certification and keys)
client
dev tun
remote 23.226.133.173 1194 udp
resolv-retry infinite
remote-random
nobind
tun-mtu 1500
tun-mtu-extra 32
mssfix 1450
persist-key
persist-tun
reneg-sec 0
server-poll-timeout 5
remote-cert-tls server
auth-user-pass
verb 3
pull
fast-io
cipher AES-256-CBC
auth SHA512
redacted…
pull-filter ignore "ifconfig-ipv6 "
pull-filter ignore "route-ipv6 "
ping 15
ping-restart 0
ping-timer-rem
NordVPN Daemon
/usr/sbin/nordvpnd
Running ‘nordvpnd’, retreieves this :
Error on listening to UNIX domain socket: listen unix /run/nordvpnd.sock: bind: address already in use
I’m assuming it’s that because it’s running currently.
In /etc/systemd/system/nordvpnd.socket:
[Unit]
Description=NordVPN Daemon Socket
PartOf=nordvpnd.service
[Socket]
ListenStream=/run/nordvpnd.sock
NoDelay=true
[Install]
WantedBy=sockets.target
In /etc/systemd/system/nordvpnd.service
[Unit]
Requires=nordvpnd.socket
After=network-online.target
[Service]
ExecStart=/usr/sbin/nordvpnd
NonBlocking=true
KillMode=process
Restart=on-failure
RestartSec=5
[Install]
WantedBy=default.target
Try removing that NoDelay line, that should make systemd happier.
I tried removing the line and ‘NoDelay = false’, both followed by systemd daemon-reload and a reboot, to no avail; same error message: ‘transport is closing’ preceded by the ‘connecting to…’
I forgot to mention this:
Occasionally, upon using 'nordvpn connect, I receive this message :
'Whoops! Cannot reach System Daemon. ’
In the syslog, I have seen this error message, but I don’t know why:
‘Get “https://zwyr157wwiu6eior.com/v1/helpers/ips/insights”: dial tcp 0.0.0.0:443: connect: connection refused’
nordvpnd[255]: panic: runtime error: index out of range [1] with length 1
systemd[1]: nordvpnd.service: Main process exited, code=exited, status=2/INVALIDARGUMENT
systemd[1]: nordvpnd.service: Failed with result ‘exit-code’.
networkd-dispatcher[253]: WARNING:Unknown index 3 seen, reloading interface list
networkd-dispatcher[253]: ERROR:Unknown interface index 3 seen even after reload
Anyone?
NordVPN does not appear to offer a free, no credit card required, account. It is difficult for someone to check and replicate.
If I set up a VPN and provided you the proper authentication, assuming the same issue will arise, would you be willing to test it? @simos
NordVPN has a manager written in Go and manages OpenVPN. It gives the following error when running in a LXD container,
Jun 16 17:31:37 nordvpn nordvpnd[1250]: 2020/06/16 17:31:37 [INFO] Tue Jun 16 17:31:37 2020 MANAGEMENT: Connected to management server at /var/run/nordvpn-openvpn.sock
Jun 16 17:31:37 nordvpn nordvpnd[1250]: panic: runtime error: index out of range [1] with length 1
Jun 16 17:31:37 nordvpn nordvpnd[1250]: goroutine 258 [running]:
Jun 16 17:31:37 nordvpn nordvpnd[1250]: nordvpn/daemon.ruleParsing(...)
Jun 16 17:31:37 nordvpn nordvpnd[1250]: #011/builds/nordvpn/apps-source/linux-app/src/daemon/vpn_ipv6.go:117
Jun 16 17:31:37 nordvpn nordvpnd[1250]: nordvpn/daemon.(*Ipv6).Disable(0xc0047c2e60, 0x0, 0x0)
Jun 16 17:31:37 nordvpn nordvpnd[1250]: #011/builds/nordvpn/apps-source/linux-app/src/daemon/vpn_ipv6.go:43 +0x6c7
Jun 16 17:31:37 nordvpn nordvpnd[1250]: nordvpn/daemon.(*OpenVPN).Start(0xc0007df860, 0x2b89520, 0xc000028960, 0x18, 0xc000028980, 0x18, 0x0, 0x0, 0x0, 0x0, ...)
Jun 16 17:31:37 nordvpn nordvpnd[1250]: #011/builds/nordvpn/apps-source/linux-app/src/daemon/vpn_openvpn.go:159 +0xd11
Jun 16 17:31:37 nordvpn nordvpnd[1250]: created by nordvpn/daemon.Connect
Jun 16 17:31:37 nordvpn nordvpnd[1250]: #011/builds/nordvpn/apps-source/linux-app/src/daemon/rpc.go:288 +0x882
Jun 16 17:31:37 nordvpn systemd[1]: nordvpnd.service: Main process exited, code=exited, status=2/INVALIDARGUMENT
Jun 16 17:31:37 nordvpn systemd[1]: nordvpnd.service: Failed with result 'exit-code'.
Jun 16 17:31:42 nordvpn systemd[1]: nordvpnd.service: Service hold-off time over, scheduling restart.
This looks like a bug in the NordVPN client (incidentally, it is written in Go).
What you can do, is report this issue to them, and perhaps point them to this discussion.
They appear they are willing to fix things.
As a workaround you can use the OpenVPN client in Ubuntu to make a connection to one of the NordVPN servers. I have tested this and it works fine. Just make sure you avoid the DNS leaks.
Did you ever figure this out? I just hit the exact same issue (same “runtime error: index out of range [1] with length 1” error), and NordVPN’s support have not been very useful. I might just use the OpenVPN client directly. I was hoping to take advantage of their “NordLynx” WireGuard-based protocol, however they don’t have vanilla WireGuard configs available.
It is up to the NordVPN people to fix the client to work in a container.
I have not reported it.
Frankly, it is good that you can use the stock OpenVPN client in Ubuntu, provided that you take care of security issues such DNS leaks.
I reported it, and they said something along the lines of LXC is not supported, use openvpn to connect to the server.
Yeah I just got a similar response: “Unfortunately, we do not officially have any tutorials or support for such a setup. Because of this reason, we are not able to help you with it”, which is really frustrating as it’s obviously some sort of bug in their code
@Ashar003, I have written a blog post on getting NordVPN to work in a LXD container. Feel free to forward to NordVPN so that they fix their client.
