I am running lxd 3.5 in debian bullseye after upgrading kernel to 5.9.0-2-amd64- not able to create any containers . creating command seems stuck for long time .
also ipv6 address is not showing in lxc list
DBUG[11-24|09:39:56] Connecting to a local LXD over a Unix socket
DBUG[11-24|09:39:56] Sending request to LXD method=GET url=http://unix.socket/1.0 etag=
DBUG[11-24|09:39:56] Got response struct from LXD
"config": {
"core.https_address": "[::]:8448",
"core.trust_password": true
"api_extensions": [
"storage_zfs_remove_snapshots",
"container_host_shutdown_timeout",
"container_stop_priority",
"container_syscall_filtering",
"auth_pki",
"container_last_used_at",
"etag",
"patch",
"usb_devices",
"https_allowed_credentials",
"image_compression_algorithm",
"directory_manipulation",
"container_cpu_time",
"storage_zfs_use_refquota",
"storage_lvm_mount_options",
"network",
"profile_usedby",
"container_push",
"container_exec_recording",
"certificate_update",
"container_exec_signal_handling",
"gpu_devices",
"container_image_properties",
"migration_progress",
"id_map",
"network_firewall_filtering",
"network_routes",
"storage",
"file_delete",
"file_append",
"network_dhcp_expiry",
"storage_lvm_vg_rename",
"storage_lvm_thinpool_rename",
"network_vlan",
"image_create_aliases",
"container_stateless_copy",
"container_only_migration",
"storage_zfs_clone_copy",
"unix_device_rename",
"storage_lvm_use_thinpool",
"storage_rsync_bwlimit",
"network_vxlan_interface",
"storage_btrfs_mount_options",
"entity_description",
"image_force_refresh",
"storage_lvm_lv_resizing",
"id_map_base",
"file_symlinks",
"container_push_target",
"network_vlan_physical",
"storage_images_delete",
"container_edit_metadata",
"container_snapshot_stateful_migration",
"storage_driver_ceph",
"storage_ceph_user_name",
"resource_limits",
"storage_volatile_initial_source",
"storage_ceph_force_osd_reuse",
"storage_block_filesystem_btrfs",
"resources",
"kernel_limits",
"storage_api_volume_rename",
"macaroon_authentication",
"network_sriov",
"console",
"restrict_devlxd",
"migration_pre_copy",
"infiniband",
"maas_network",
"devlxd_events",
"proxy",
"network_dhcp_gateway",
"file_get_symlink",
"network_leases",
"unix_device_hotplug",
"storage_api_local_volume_handling",
"operation_description",
"clustering",
"event_lifecycle",
"storage_api_remote_volume_handling",
"nvidia_runtime",
"container_mount_propagation",
"container_backup",
"devlxd_images",
"container_local_cross_pool_handling",
"proxy_unix",
"proxy_udp",
"clustering_join",
"proxy_tcp_udp_multi_port_handling",
"network_state",
"proxy_unix_dac_properties",
"container_protection_delete",
"unix_priv_drop",
"pprof_http",
"proxy_haproxy_protocol",
"network_hwaddr",
"proxy_nat",
"network_nat_order",
"container_full",
"candid_authentication",
"backup_compression",
"candid_config",
"nvidia_runtime_config",
"storage_api_volume_snapshots",
"storage_unmapped",
"projects",
"candid_config_key",
"network_vxlan_ttl",
"container_incremental_copy",
"usb_optional_vendorid",
"snapshot_scheduling",
"container_copy_project",
"clustering_server_address",
"clustering_image_replication",
"container_protection_shift",
"snapshot_expiry",
"container_backup_override_pool",
"snapshot_expiry_creation",
"network_leases_location",
"resources_cpu_socket",
"resources_gpu",
"resources_numa",
"kernel_features",
"id_map_current",
"event_location",
"storage_api_remote_volume_snapshots",
"network_nat_address",
"container_nic_routes",
"rbac",
"cluster_internal_copy",
"seccomp_notify",
"lxc_features",
"container_nic_ipvlan",
"network_vlan_sriov",
"storage_cephfs",
"container_nic_ipfilter",
"resources_v2",
"container_exec_user_group_cwd",
"container_syscall_intercept",
"container_disk_shift",
"storage_shifted",
"resources_infiniband",
"daemon_storage",
"instances",
"image_types",
"resources_disk_sata",
"clustering_roles",
"images_expiry",
"resources_network_firmware",
"backup_compression_algorithm",
"ceph_data_pool_name",
"container_syscall_intercept_mount",
"compression_squashfs",
"container_raw_mount",
"container_nic_routed",
"container_syscall_intercept_mount_fuse",
"container_disk_ceph",
"virtual-machines",
"image_profiles",
"clustering_architecture",
"resources_disk_id",
"storage_lvm_stripes",
"vm_boot_priority",
"unix_hotplug_devices",
"api_filtering",
"instance_nic_network",
"clustering_sizing",
"firewall_driver",
"projects_limits",
"container_syscall_intercept_hugetlbfs",
"limits_hugepages",
"container_nic_routed_gateway",
"projects_restrictions",
"custom_volume_snapshot_expiry",
"volume_snapshot_scheduling",
"trust_ca_certificates",
"snapshot_disk_usage",
"clustering_edit_roles",
"container_nic_routed_host_address",
"container_nic_ipvlan_gateway",
"resources_usb_pci",
"resources_cpu_threads_numa",
"resources_cpu_core_die",
"api_os",
"container_nic_routed_host_table",
"container_nic_ipvlan_host_table",
"container_nic_ipvlan_mode",
"resources_system",
"images_push_relay",
"network_dns_search",
"container_nic_routed_limits",
"instance_nic_bridged_vlan",
"network_state_bond_bridge",
"usedby_consistency",
"custom_block_volumes",
"clustering_failure_domains",
"resources_gpu_mdev",
"console_vga_type",
"projects_limits_disk",
"network_type_macvlan",
"network_type_sriov",
"container_syscall_intercept_bpf_devices",
"network_type_ovn",
"projects_networks",
"projects_networks_restricted_uplinks",
"custom_volume_backup",
"backup_override_name",
"storage_rsync_compression",
"network_type_physical",
"network_ovn_external_subnets",
"network_ovn_nat",
"network_ovn_external_routes_remove",
"tpm_device_type",
"storage_zfs_clone_copy_rebase"
"api_status": "stable",
"api_version": "1.0",
"auth": "trusted",
"public": false,
"auth_methods": [
"tls"
"environment": {
"addresses": [
"149.56.107.165:8448",
"[2607:5300:60:a5a5::]:8448",
"10.0.3.1:8448",
"10.78.204.1:8448",
"[fd42:ca1b:d8d3:acb0::1]:8448"
"architectures": [
"x86_64",
"i686"
"certificate": "-----BEGIN CERTIFICATE-----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\n-----END CERTIFICATE-----\n",
"certificate_fingerprint": "21a4f8c30273c49dbae2907de56b8b21f4f2f53d17d08658d90da7b99eafa115",
"driver": "lxc",
"driver_version": "4.0.4",
"firewall": "xtables",
"kernel": "Linux",
"kernel_architecture": "x86_64",
"kernel_features": {
"netnsid_getifaddrs": "true",
"seccomp_listener": "true",
"seccomp_listener_continue": "true",
"shiftfs": "false",
"uevent_injection": "true",
"unpriv_fscaps": "true"
"kernel_version": "5.9.0-1-amd64",
"lxc_features": {
"cgroup2": "true",
"devpts_fd": "false",
"mount_injection_file": "true",
"network_gateway_device_route": "true",
"network_ipvlan": "true",
"network_l2proxy": "true",
"network_phys_macvlan_mtu": "true",
"network_veth_router": "true",
"pidfd": "true",
"seccomp_allow_deny_syntax": "true",
"seccomp_notify": "true",
"seccomp_proxy_send_notify_fd": "false"
"os_name": "Debian GNU/Linux",
"os_version": "",
"project": "default",
"server": "lxd",
"server_clustered": false,
"server_name": "cpu-6228",
"server_pid": 1352,
"server_version": "4.8",
"storage": "zfs",
"storage_version": "0.8.5-2"
Creating test
DBUG[11-24|09:39:56] Connecting to a remote simplestreams server
DBUG[11-24|09:39:56] Connected to the websocket: ws://unix.socket/1.0/events
DBUG[11-24|09:39:56] Sending request to LXD method=POST url=http://unix.socket/1.0/instances etag=
"architecture": "",
"config": {},
"devices": {},
"ephemeral": false,
"profiles": null,
"stateful": false,
"description": "",
"name": "test",
"source": {
"type": "image",
"certificate": "",
"alias": "debian/buster",
"server": "https://images.linuxcontainers.org",
"protocol": "simplestreams",
"mode": "pull"
"instance_type": "",
"type": "container"
DBUG[11-24|09:50:03] Got operation from LXD
"id": "8766af50-1d59-4fa4-a606-41dabeb61fa0",
"class": "task",
"description": "Creating container",
"created_at": "2020-11-24T09:50:03.148393655Z",
"updated_at": "2020-11-24T09:50:03.148393655Z",
"status": "Running",
"status_code": 103,
"resources": {
"containers": [
"/1.0/containers/test"
"instances": [
"/1.0/instances/test"
"metadata": null,
"may_cancel": false,
"err": "",
"location": "none"
DBUG[11-24|09:50:03] Sending request to LXD method=GET url=http://unix.socket/1.0/operations/8766af50-1d59-4fa4-a606-41dabeb61fa0 etag=
DBUG[11-24|09:50:03] Got response struct from LXD
"class": "task",
"status_code": 103,
"resources": {
"containers": [
"instances": [
"metadata": null,
"err": "",
"location": "none"
| vm618027 | RUNNING | 1.1.1.1(eth0) | | CONTAINER | 0 |
please have a look on this .
