I have problem with connection to Internet from instance. I have just installed latest lxd 5.12-c63881f, executed lxd init, created default bridge and launched instance ubuntu 22. Nothing special. But instance doesn’t have connection with external network. 100% packets lost while ping 8.8.8.8 from instance. I don’t understand what problem is. Could anyone help me?
Configuration netplan on the host:
cat /etc/netplan/net-config.yaml
network:
ethernets:
enp2s0:
dhcp4: no
addresses:
- 192.168.50.2/24
routes:
- to: 192.168.254.0/24
via: 192.168.50.11
enp4s0:
dhcp4: no
addresses: [10.24.64.68/24]
routes:
- to: default
via: 10.24.64.1
nameservers:
addresses: [172.16.0.250]
vlans:
vlan96:
link: enp4s0
dhcp4: no
addresses: [192.168.96.2/24]
routes:
- to: 192.168.32.0/24
via: 192.168.96.1
vlan192:
link: enp4s0
dhcp4: yes
dhcp4-overrides:
use-routes: false
version: 2
ip route on the host:
ip route
default via 10.24.64.1 dev enp4s0 proto static
10.24.64.0/24 dev enp4s0 proto kernel scope link src 10.24.64.68
10.146.92.0/24 dev lxdbr0 proto kernel scope link src 10.146.92.1
172.17.0.0/16 dev docker0 proto kernel scope link src 172.17.0.1 linkdown
172.18.0.0/16 dev br-63710f7d7f13 proto kernel scope link src 172.18.0.1
192.168.0.0/24 dev vlan192 proto kernel scope link src 192.168.0.156 metric 100
192.168.0.71 dev vlan192 proto dhcp scope link src 192.168.0.156 metric 100
192.168.32.0/24 via 192.168.96.1 dev vlan96 proto static
192.168.50.0/24 dev enp2s0 proto kernel scope link src 192.168.50.2
192.168.96.0/24 dev vlan96 proto kernel scope link src 192.168.96.2
192.168.254.0/24 via 192.168.50.11 dev enp2s0 proto static
sudo iptables -L on the host:
# Warning: iptables-legacy tables present, use iptables-legacy to see them
Chain INPUT (policy ACCEPT)
target prot opt source destination
Chain FORWARD (policy DROP)
DOCKER-USER all -- anywhere anywhere
DOCKER-ISOLATION-STAGE-1 all -- anywhere anywhere
ACCEPT all -- anywhere anywhere ctstate RELATED,ESTABLISHED
DOCKER all -- anywhere anywhere
Chain OUTPUT (policy ACCEPT)
Chain DOCKER (1 references)
Chain DOCKER-ISOLATION-STAGE-1 (1 references)
DOCKER-ISOLATION-STAGE-2 all -- anywhere anywhere
RETURN all -- anywhere anywhere
Chain DOCKER-ISOLATION-STAGE-2 (1 references)
DROP all -- anywhere anywhere
Chain DOCKER-USER (1 references)
ip a on the instance:
ip a
1: lo: mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
inet6 ::1/128 scope host
3: enp5s0: mtu 1500 qdisc mq state UP group default qlen 1000
link/ether 00:16:3e:93:06:df brd ff:ff:ff:ff:ff:ff
inet 10.146.92.161/24 metric 100 brd 10.146.92.255 scope global dynamic enp5s0
valid_lft 3500sec preferred_lft 3500sec
inet6 fd42:336b:85e2:de83:216:3eff:fe93:6df/64 scope global mngtmpaddr noprefixroute
inet6 fe80::216:3eff:fe93:6df/64 scope link
ip route on the instance:
ip route
default via 10.146.92.1 dev enp5s0 proto dhcp src 10.146.92.161 metric 100
10.146.92.0/24 dev enp5s0 proto kernel scope link src 10.146.92.161 metric 100
10.146.92.1 dev enp5s0 proto dhcp scope link src 10.146.92.161 metric 100
Also I have additional question. Can I create macvlan with static ip? How can i do it right?
DOCKER-ISOLATION-STAGE-2 all – anywhere anywhere
RETURN all – anywhere anywhere
Chain DOCKER-ISOLATION-STAGE-2 (2 references)
DROP all – anywhere anywhere
